root/radiance/ray/src/common/tonemap.h
Revision: 3.16
Committed: Mon Jul 14 22:23:59 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 3.15: +4 -3 lines
# User Rev Content
1 schorsch 3.16 /* RCSid $Id: tonemap.h,v 3.15 2003/07/14 04:56:54 greg Exp $ */
2 greg 3.1 /*
3     * Header file for tone mapping functions.
4 gwlarson 3.8 *
5     * Include after "color.h"
6 greg 3.1 */
7 schorsch 3.13 #ifndef _RAD_TONEMAP_H_
8     #define _RAD_TONEMAP_H_
9 schorsch 3.16
10     #include "tifftypes.h"
11
12 greg 3.11 #ifdef __cplusplus
13     extern "C" {
14     #endif
15 greg 3.15
16 greg 3.1 /**** Argument Macros ****/
17     /* Flags of what to do */
18     #define TM_F_HCONTR 01 /* human contrast sensitivity */
19     #define TM_F_MESOPIC 02 /* mesopic color sensitivity */
20     #define TM_F_LINEAR 04 /* linear brightness mapping */
21     #define TM_F_ACUITY 010 /* acuity adjustment */
22     #define TM_F_VEIL 020 /* veiling glare */
23     #define TM_F_CWEIGHT 040 /* center weighting */
24     #define TM_F_FOVEAL 0100 /* use foveal sample size */
25     #define TM_F_BW 0200 /* luminance only */
26 greg 3.2 #define TM_F_NOSTDERR 0400 /* don't report errors to stderr */
27 greg 3.1 /* combined modes */
28     #define TM_F_CAMERA 0
29     #define TM_F_HUMAN (TM_F_HCONTR|TM_F_MESOPIC|TM_F_VEIL|\
30     TM_F_ACUITY|TM_F_FOVEAL)
31     #define TM_F_UNIMPL (TM_F_CWEIGHT|TM_F_VEIL|TM_F_ACUITY|TM_F_FOVEAL)
32
33     /* special pointer values */
34     #define TM_XYZPRIM (RGBPRIMP)NULL /* indicate XYZ primaries (Note 1) */
35     #define TM_NOCHROM (BYTE *)NULL /* indicate no chrominance */
36     #define TM_NOCHROMP (BYTE **)NULL /* indicate no chrominances */
37     #define TM_GETFILE (FILE *)NULL /* indicate file must be opened */
38 gwlarson 3.8
39 greg 3.1
40     /**** Error Return Values ****/
41
42     #define TM_E_OK 0 /* normal return status */
43     #define TM_E_NOMEM 1 /* out of memory */
44     #define TM_E_ILLEGAL 2 /* illegal argument value */
45     #define TM_E_TMINVAL 3 /* no valid tone mapping */
46     #define TM_E_TMFAIL 4 /* cannot compute tone mapping */
47     #define TM_E_BADFILE 5 /* cannot open or understand file */
48 greg 3.4 #define TM_E_CODERR1 6 /* code consistency error 1 */
49     #define TM_E_CODERR2 7 /* code consistency error 2 */
50 greg 3.1
51 greg 3.4
52 greg 3.1 /**** Conversion Constants and Table Sizes ****/
53
54     #define TM_BRTSCALE 128 /* brightness scale factor (integer) */
55
56 gwlarson 3.10 #define TM_NOBRT (-1<<15) /* bogus brightness value */
57 greg 3.11 #define TM_NOLUM (1e-17) /* ridiculously small luminance */
58 gwlarson 3.10
59 greg 3.4 #define TM_MAXPKG 8 /* maximum number of color formats */
60 greg 3.1
61
62 greg 3.4 /**** Global Data Types and Structures ****/
63
64     #ifndef MEM_PTR
65     #define MEM_PTR void *
66     #endif
67
68 greg 3.1 extern char *tmErrorMessage[]; /* error messages */
69 gregl 3.6 extern int tmLastError; /* last error incurred by library */
70     extern char *tmLastFunction; /* error-generating function name */
71 greg 3.1
72     typedef short TMbright; /* encoded luminance type */
73
74     /* basic tone mapping data structure */
75     extern struct tmStruct {
76     int flags; /* flags of what to do */
77     RGBPRIMP monpri; /* monitor RGB primaries */
78     double mongam; /* monitor gamma value (approx.) */
79     COLOR clf; /* computed luminance coefficients */
80 greg 3.4 int cdiv[3]; /* computed color divisors */
81 greg 3.1 RGBPRIMP inppri; /* current input primaries */
82     double inpsf; /* current input scalefactor */
83     COLORMAT cmat; /* color conversion matrix */
84 gregl 3.7 TMbright hbrmin, hbrmax; /* histogram brightness limits */
85 greg 3.1 int *histo; /* input histogram */
86 gregl 3.7 TMbright mbrmin, mbrmax; /* mapped brightness limits */
87 greg 3.1 unsigned short *lumap; /* computed luminance map */
88     struct tmStruct *tmprev; /* previous tone mapping */
89 greg 3.4 MEM_PTR pd[TM_MAXPKG]; /* pointers to private data */
90 greg 3.1 } *tmTop; /* current tone mapping stack */
91 greg 3.4
92     /* conversion package functions */
93     struct tmPackage {
94     MEM_PTR (*Init)(struct tmStruct *tms);
95 greg 3.11 void (*NewSpace)(struct tmStruct *tms);
96 greg 3.4 void (*Free)(MEM_PTR pp);
97     };
98     /* our list of conversion packages */
99     extern struct tmPackage *tmPkg[TM_MAXPKG];
100     extern int tmNumPkgs; /* number of registered packages */
101
102
103 greg 3.1 /**** Useful Macros ****/
104
105 greg 3.4 /* compute luminance from encoded value */
106 greg 3.11 #define tmLuminance(li) exp((li)*(1./TM_BRTSCALE))
107 greg 3.1
108 greg 3.4 /* does tone mapping need color matrix? */
109     #define tmNeedMatrix(t) ((t)->monpri != (t)->inppri)
110
111     /* register a conversion package */
112     #define tmRegPkg(pf) ( tmNumPkgs >= TM_MAXPKG ? -1 : \
113     (tmPkg[tmNumPkgs] = (pf), tmNumPkgs++) )
114
115     /* get the specific package's data */
116     #define tmPkgData(t,i) ((t)->pd[i]!=NULL ? (t)->pd[i] : (*tmPkg[i]->Init)(t))
117
118
119 greg 3.1 /**** Library Function Calls ****/
120
121
122     extern struct tmStruct *
123     tmInit(int flags, RGBPRIMP monpri, double gamval);
124     /*
125     Initialize new tone mapping and push it onto stack.
126
127     flags - TM_F_* flags indicating what is to be done.
128     monpri - display monitor primaries (Note 1).
129     gamval - display gamma response (can be approximate).
130
131     returns - new tmTop, or NULL if insufficient memory.
132     */
133
134     extern int
135     tmSetSpace(RGBPRIMP pri, double sf);
136     /*
137     Set color primaries and scale factor for incoming scanlines.
138
139     pri - RGB color input primaries (Note 1).
140     sf - scale factor to get to luminance in cd/m^2.
141
142     returns - 0 on success, TM_E_* code on failure.
143     */
144
145     extern void
146     tmClearHisto(void);
147     /*
148     Clear histogram for current tone mapping.
149     */
150
151     extern int
152     tmAddHisto(TMbright *ls, int len, int wt);
153     /*
154     Add brightness values to current histogram.
155
156     ls - encoded luminance values.
157     len - number of luminance values.
158     wt - integer weight to use for each value (usually 1 or -1).
159
160     returns - 0 on success, TM_E_* on error.
161     */
162
163     extern int
164 greg 3.11 tmFixedMapping(double expmult, double gamval);
165     /*
166     Assign a fixed, linear tone-mapping using the given multiplier,
167     which is the ratio of maximum output to uncalibrated input.
168     This mapping will be used in subsequent calls to tmMapPixels()
169     until a new tone mapping is computed.
170     Only the min. and max. values are used from the histogram.
171
172     expmult - the fixed exposure multiplier to use.
173     gamval - display gamma response (0. for default).
174     returns - 0 on success, TM_E_* on error.
175     */
176
177     extern int
178 greg 3.1 tmComputeMapping(double gamval, double Lddyn, double Ldmax);
179     /*
180 greg 3.11 Compute tone mapping function from the current histogram.
181     This mapping will be used in subsequent calls to tmMapPixels()
182     until a new tone mapping is computed.
183     I.e., calls to tmAddHisto() have no immediate effect.
184 greg 3.1
185     gamval - display gamma response (0. for default).
186     Lddyn - the display's dynamic range (0. for default).
187     Ldmax - maximum display luminance in cd/m^2 (0. for default).
188
189     returns - 0 on success, TM_E_* on failure.
190     */
191
192     extern int
193     tmMapPixels(BYTE *ps, TMbright *ls, BYTE *cs, int len);
194     /*
195     Apply tone mapping function to pixel values.
196
197     ps - returned pixel values (Note 2).
198     ls - encoded luminance values.
199     cs - encoded chrominance values (Note 2).
200     len - number of pixels.
201
202     returns - 0 on success, TM_E_* on failure.
203     */
204
205     extern struct tmStruct *
206     tmPop(void);
207     /*
208     Pops current tone mapping from stack.
209
210     returns - pointer to tone mapping structure, or NULL if none.
211     */
212
213     extern int
214     tmPull(struct tmStruct *tms);
215     /*
216     Pull tone mapping from anywhere in stack.
217
218     tms - tone mapping structure to find.
219
220     returns - 1 if found in stack, 0 otherwise.
221     */
222
223     extern int
224     tmPush(struct tmStruct *tms);
225     /*
226     Make tone mapping active by (pulling it and) pushing it to the top.
227
228     tms - initialized tone mapping structure.
229
230     returns - 0 on success, TM_E_* if tms is invalid.
231     */
232
233 greg 3.3 extern struct tmStruct *
234     tmDup(void);
235     /*
236     Duplicate the current tone mapping into a new structure on the stack.
237
238     returns - pointer to new top, or NULL on error.
239     */
240
241 greg 3.1 extern void
242     tmDone(struct tmStruct *tms);
243     /*
244     Free data associated with the given tone mapping structure.
245     Calls tmPull() first to remove it from the stack if present.
246     The calls tmDone(tmPop()), tmDone(tmTop) and tmDone(NULL)
247     all have the same effect, which is to remove and free
248     the current tone mapping.
249
250     tms - tone mapping structure to free.
251     */
252
253 greg 3.11 extern int
254     tmCvColors(TMbright *ls, BYTE *cs, COLOR *scan, int len);
255     /*
256     Convert RGB/XYZ float scanline to encoded luminance and chrominance.
257
258     ls - returned encoded luminance values.
259     cs - returned encoded chrominance values (Note 2).
260     scan - input scanline.
261     len - scanline length.
262
263     returns - 0 on success, TM_E_* on error.
264     */
265
266     extern int
267     tmCvGrays(TMbright *ls, float *scan, int len);
268     /*
269     Convert gray float scanline to encoded luminance.
270
271     ls - returned encoded luminance values.
272     scan - input scanline.
273     len - scanline length.
274
275     returns - 0 on success, TM_E_* on error.
276     */
277
278     extern int
279     tmCvColrs(TMbright *ls, BYTE *cs, COLR *scan, int len);
280     /*
281     Convert RGBE/XYZE scanline to encoded luminance and chrominance.
282
283     ls - returned encoded luminance values.
284     cs - returned encoded chrominance values (Note 2).
285     scan - input scanline.
286     len - scanline length.
287
288     returns - 0 on success, TM_E_* on error.
289     */
290
291     extern int
292     tmLoadPicture(TMbright **lpp, BYTE **cpp, int *xp, int *yp,
293     char *fname, FILE *fp);
294     /*
295     Load Radiance picture and convert to tone mapping representation.
296     Memory for the luminance and chroma arrays is allocated using
297     malloc(3), and should be freed with free(3) when no longer needed.
298     Calls tmSetSpace() to calibrate input color space.
299
300     lpp - returned array of encoded luminances, picture ordering.
301     cpp - returned array of encoded chrominances (Note 2).
302     xp, yp - returned picture dimensions.
303     fname - picture file name.
304     fp - pointer to open file (Note 3).
305
306     returns - 0 on success, TM_E_* on failure.
307     */
308
309     extern int
310     tmMapPicture(BYTE **psp, int *xp, int *yp, int flags,
311     RGBPRIMP monpri, double gamval, double Lddyn, double Ldmax,
312     char *fname, FILE *fp);
313     /*
314     Load and apply tone mapping to Radiance picture.
315     Stack is restored to its original state upon return.
316     If fp is TM_GETFILE and (flags&TM_F_UNIMPL)!=0, tmMapPicture()
317     calls pcond to perform the actual conversion, which takes
318     longer but gives access to all the TM_F_* features.
319     Memory for the final pixel array is allocated using malloc(3),
320     and should be freed with free(3) when it is no longer needed.
321
322     psp - returned array of tone mapped pixels, picture ordering.
323     xp, yp - returned picture dimensions.
324     flags - TM_F_* flags indicating what is to be done.
325     monpri - display monitor primaries (Note 1).
326     gamval - display gamma response.
327     Lddyn - the display's dynamic range (0. for default).
328     Ldmax - maximum display luminance in cd/m^2 (0. for default).
329     fname - picture file name.
330     fp - pointer to open file (Note 3).
331
332     returns - 0 on success, TM_E_* on failure.
333     */
334
335 greg 3.15 extern int
336     tmCvRGB48(TMbright *ls, BYTE *cs, uint16 (*scan)[3], int len, double gv);
337     /*
338     Convert 48-bit RGB scanline to encoded luminance and chrominance.
339
340     ls - returned encoded luminance values.
341     cs - returned encoded chrominance values (Note 2).
342     scan - input scanline.
343     len - scanline length.
344     gv - input gamma value.
345
346     returns - 0 on success, TM_E_* on error.
347     */
348
349     extern int
350     tmCvGray16(TMbright *ls, uint16 *scan, int len, double gv);
351     /*
352     Convert 16-bit gray scanline to encoded luminance.
353
354     ls - returned encoded luminance values.
355     scan - input scanline.
356     len - scanline length.
357     gv - input gamma value.
358 greg 3.4
359 greg 3.15 returns - 0 on success, TM_E_* on error.
360     */
361 greg 3.4
362 greg 3.1 /**** Notes ****/
363     /*
364     General:
365
366     The usual sequence after calling tmInit() is to convert some
367     pixel values to chroma and luminance encodings, which can
368     be passed to tmAddHisto() to put into the tone mapping histogram.
369     This histogram is then used along with the display parameters
370 greg 3.5 by tmComputeMapping() to compute the luminance mapping function.
371 greg 3.1 (Colors are tone-mapped as they are converted if TM_F_MESOPIC
372     is set.) The encoded chroma and luminance values may then be
373     passed to tmMapPixels() to apply the computed tone mapping in
374     a second pass.
375
376     Especially for RGBE colors in the same color space as the
377     target display, the conversion to chroma and luminance values
378     is fast enough that it may be recomputed on the second pass
379     if memory is at a premium. (Since the chroma values are only
380     used during final mapping, setting the cs parameter to TM_NOCHROM
381     on the first pass will save time.) Another memory saving option
382     if third and subsequent passes are not needed is to use the
383 greg 3.3 same array to store the mapped pixels as used to store
384 greg 3.1 the encoded chroma values. This way, only two extra bytes
385     for storing encoded luminances are required per pixel. This
386     is the method employed by tmMapPicture(), for example.
387     */
388     /*
389     Note 1:
390
391     All RGBPRIMP values should be pointers to static structures.
392     I.e., the same pointer should be used for the same primaries,
393     and those primaries should not change from one call to the next.
394     This is because the routines use the pointer value to identify
395     computed conversion matrices, so the matrices do not have to be
396     rebuilt each time. If you are using the standard primaries,
397     use the standard primary pointer, stdprims.
398
399     To indicate a set of input primaries are actually CIE XYZ,
400     the TM_XYZPRIM macro may be passed. If the input primaries
401     are unknown, it is wisest to pass tmTop->monpri to tmSetSpace().
402     By default, the input primaries equal the monitor primaries
403     and the scalefactor is set to WHTEFFICACY in tmInit().
404     */
405     /*
406     Note 2:
407
408     Chrominance is optional in most of these routines, whether
409     TM_F_BW is set or not. Passing a value of TM_NOCHROM (or
410     TM_NOCHROMP for picture reading) indicates that returned
411     color values are not desired.
412
413     If TM_NOCHROM is passed to a mapping routine expecting chroma
414     input, it will do without it and return luminance channel
415     rather than RGB pixel values. Otherwise, the array for
416     returned pixel values may be the same array used to pass
417     encoded chrominances if no other mappings are desired.
418     */
419     /*
420     Note 3:
421
422     Picture files may either be opened by the calling routine or by
423     the library function. If opened by the calling routine, the
424     pointer to the stream is passed, which may be a pipe or other
425     non-seekable input as it is only read once. It must be
426     positioned at the beginning when the function is called, and it
427     will be positioned at the end on return. It will not be closed.
428     If the passed stream pointer is TM_GETFILE, then the library
429     function will open the file, read its contents and close it
430     before returning, whether or not an error was encountered.
431     */
432 greg 3.11
433     #ifdef __cplusplus
434     }
435     #endif
436 schorsch 3.13 #endif /* _RAD_TONEMAP_H_ */
437
