--- ray/src/common/tonemap.h 1997/11/17 13:54:35 3.7 +++ ray/src/common/tonemap.h 2003/07/14 22:23:59 3.16 @@ -1,14 +1,18 @@ -/* Copyright (c) 1997 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: tonemap.h,v 3.16 2003/07/14 22:23:59 schorsch Exp $ */ /* * Header file for tone mapping functions. + * + * Include after "color.h" */ - /* required non-system header files */ -#include "color.h" +#ifndef _RAD_TONEMAP_H_ +#define _RAD_TONEMAP_H_ +#include "tifftypes.h" +#ifdef __cplusplus +extern "C" { +#endif + /**** Argument Macros ****/ /* Flags of what to do */ #define TM_F_HCONTR 01 /* human contrast sensitivity */ @@ -32,6 +36,7 @@ #define TM_NOCHROMP (BYTE **)NULL /* indicate no chrominances */ #define TM_GETFILE (FILE *)NULL /* indicate file must be opened */ + /**** Error Return Values ****/ #define TM_E_OK 0 /* normal return status */ @@ -48,6 +53,9 @@ #define TM_BRTSCALE 128 /* brightness scale factor (integer) */ +#define TM_NOBRT (-1<<15) /* bogus brightness value */ +#define TM_NOLUM (1e-17) /* ridiculously small luminance */ + #define TM_MAXPKG 8 /* maximum number of color formats */ @@ -82,19 +90,11 @@ extern struct tmStruct { } *tmTop; /* current tone mapping stack */ /* conversion package functions */ -#ifdef NOPROTO struct tmPackage { - MEM_PTR (*Init)(); /* initialize private data */ - void (*NewSpace)(); /* new input color space (optional) */ - void (*Free)(); /* free private data */ -}; -#else -struct tmPackage { MEM_PTR (*Init)(struct tmStruct *tms); - int (*NewSpace)(struct tmStruct *tms); + void (*NewSpace)(struct tmStruct *tms); void (*Free)(MEM_PTR pp); }; -#endif /* our list of conversion packages */ extern struct tmPackage *tmPkg[TM_MAXPKG]; extern int tmNumPkgs; /* number of registered packages */ @@ -103,7 +103,7 @@ extern int tmNumPkgs; /* number of registered packages /**** Useful Macros ****/ /* compute luminance from encoded value */ -#define tmLuminance(li) exp((li)/(double)TM_BRTSCALE) +#define tmLuminance(li) exp((li)*(1./TM_BRTSCALE)) /* does tone mapping need color matrix? */ #define tmNeedMatrix(t) ((t)->monpri != (t)->inppri) @@ -118,16 +118,7 @@ extern int tmNumPkgs; /* number of registered packages /**** Library Function Calls ****/ -#ifdef NOPROTO -extern struct tmStruct *tmInit(), *tmPop(), *tmDup(); -extern void tmClearHisto(), tmDone(); -extern int tmSetSpace(), tmCvColors(), tmCvColrs(); -extern int tmAddHisto(), tmComputeMapping(), tmMapPixels(); -extern int tmLoadPicture(), tmMapPicture(), tmPull(), tmPush(); - -#else - extern struct tmStruct * tmInit(int flags, RGBPRIMP monpri, double gamval); /* @@ -158,32 +149,6 @@ tmClearHisto(void); */ extern int -tmCvColors(TMbright *ls, BYTE *cs, COLOR *scan, int len); -/* - Convert RGB/XYZ float scanline to encoded luminance and chrominance. - - ls - returned encoded luminance values. - cs - returned encoded chrominance values (Note 2). - scan - input scanline. - len - scanline length. - - returns - 0 on success, TM_E_* on error. -*/ - -extern int -tmCvColrs(TMbright *ls, BYTE *cs, COLR *scan, int len); -/* - Convert RGBE/XYZE scanline to encoded luminance and chrominance. - - ls - returned encoded luminance values. - cs - returned encoded chrominance values (Note 2). - scan - input scanline. - len - scanline length. - - returns - 0 on success, TM_E_* on error. -*/ - -extern int tmAddHisto(TMbright *ls, int len, int wt); /* Add brightness values to current histogram. @@ -196,11 +161,26 @@ tmAddHisto(TMbright *ls, int len, int wt); */ extern int +tmFixedMapping(double expmult, double gamval); +/* + Assign a fixed, linear tone-mapping using the given multiplier, + which is the ratio of maximum output to uncalibrated input. + This mapping will be used in subsequent calls to tmMapPixels() + until a new tone mapping is computed. + Only the min. and max. values are used from the histogram. + + expmult - the fixed exposure multiplier to use. + gamval - display gamma response (0. for default). + returns - 0 on success, TM_E_* on error. +*/ + +extern int tmComputeMapping(double gamval, double Lddyn, double Ldmax); /* - Compute tone mapping function. This mapping will be used - in subsequent calls to tmMapPixels() until a new tone mapping - is computed. I.e., calls to tmAddHisto() have no immediate effect. + Compute tone mapping function from the current histogram. + This mapping will be used in subsequent calls to tmMapPixels() + until a new tone mapping is computed. + I.e., calls to tmAddHisto() have no immediate effect. gamval - display gamma response (0. for default). Lddyn - the display's dynamic range (0. for default). @@ -222,7 +202,93 @@ tmMapPixels(BYTE *ps, TMbright *ls, BYTE *cs, int len) returns - 0 on success, TM_E_* on failure. */ +extern struct tmStruct * +tmPop(void); +/* + Pops current tone mapping from stack. + + returns - pointer to tone mapping structure, or NULL if none. +*/ + extern int +tmPull(struct tmStruct *tms); +/* + Pull tone mapping from anywhere in stack. + + tms - tone mapping structure to find. + + returns - 1 if found in stack, 0 otherwise. +*/ + +extern int +tmPush(struct tmStruct *tms); +/* + Make tone mapping active by (pulling it and) pushing it to the top. + + tms - initialized tone mapping structure. + + returns - 0 on success, TM_E_* if tms is invalid. +*/ + +extern struct tmStruct * +tmDup(void); +/* + Duplicate the current tone mapping into a new structure on the stack. + + returns - pointer to new top, or NULL on error. +*/ + +extern void +tmDone(struct tmStruct *tms); +/* + Free data associated with the given tone mapping structure. + Calls tmPull() first to remove it from the stack if present. + The calls tmDone(tmPop()), tmDone(tmTop) and tmDone(NULL) + all have the same effect, which is to remove and free + the current tone mapping. + + tms - tone mapping structure to free. +*/ + +extern int +tmCvColors(TMbright *ls, BYTE *cs, COLOR *scan, int len); +/* + Convert RGB/XYZ float scanline to encoded luminance and chrominance. + + ls - returned encoded luminance values. + cs - returned encoded chrominance values (Note 2). + scan - input scanline. + len - scanline length. + + returns - 0 on success, TM_E_* on error. +*/ + +extern int +tmCvGrays(TMbright *ls, float *scan, int len); +/* + Convert gray float scanline to encoded luminance. + + ls - returned encoded luminance values. + scan - input scanline. + len - scanline length. + + returns - 0 on success, TM_E_* on error. +*/ + +extern int +tmCvColrs(TMbright *ls, BYTE *cs, COLR *scan, int len); +/* + Convert RGBE/XYZE scanline to encoded luminance and chrominance. + + ls - returned encoded luminance values. + cs - returned encoded chrominance values (Note 2). + scan - input scanline. + len - scanline length. + + returns - 0 on success, TM_E_* on error. +*/ + +extern int tmLoadPicture(TMbright **lpp, BYTE **cpp, int *xp, int *yp, char *fname, FILE *fp); /* @@ -231,7 +297,7 @@ tmLoadPicture(TMbright **lpp, BYTE **cpp, int *xp, int malloc(3), and should be freed with free(3) when no longer needed. Calls tmSetSpace() to calibrate input color space. - lpp - returned array of encoded luminances, English ordering. + lpp - returned array of encoded luminances, picture ordering. cpp - returned array of encoded chrominances (Note 2). xp, yp - returned picture dimensions. fname - picture file name. @@ -253,7 +319,7 @@ tmMapPicture(BYTE **psp, int *xp, int *yp, int flags, Memory for the final pixel array is allocated using malloc(3), and should be freed with free(3) when it is no longer needed. - psp - returned array of tone mapped pixels, English ordering. + psp - returned array of tone mapped pixels, picture ordering. xp, yp - returned picture dimensions. flags - TM_F_* flags indicating what is to be done. monpri - display monitor primaries (Note 1). @@ -266,57 +332,33 @@ tmMapPicture(BYTE **psp, int *xp, int *yp, int flags, returns - 0 on success, TM_E_* on failure. */ -extern struct tmStruct * -tmPop(void); -/* - Pops current tone mapping from stack. - - returns - pointer to tone mapping structure, or NULL if none. -*/ - extern int -tmPull(struct tmStruct *tms); +tmCvRGB48(TMbright *ls, BYTE *cs, uint16 (*scan)[3], int len, double gv); /* - Pull tone mapping from anywhere in stack. + Convert 48-bit RGB scanline to encoded luminance and chrominance. - tms - tone mapping structure to find. + ls - returned encoded luminance values. + cs - returned encoded chrominance values (Note 2). + scan - input scanline. + len - scanline length. + gv - input gamma value. - returns - 1 if found in stack, 0 otherwise. + returns - 0 on success, TM_E_* on error. */ extern int -tmPush(struct tmStruct *tms); +tmCvGray16(TMbright *ls, uint16 *scan, int len, double gv); /* - Make tone mapping active by (pulling it and) pushing it to the top. + Convert 16-bit gray scanline to encoded luminance. - tms - initialized tone mapping structure. + ls - returned encoded luminance values. + scan - input scanline. + len - scanline length. + gv - input gamma value. - returns - 0 on success, TM_E_* if tms is invalid. + returns - 0 on success, TM_E_* on error. */ -extern struct tmStruct * -tmDup(void); -/* - Duplicate the current tone mapping into a new structure on the stack. - - returns - pointer to new top, or NULL on error. -*/ - -extern void -tmDone(struct tmStruct *tms); -/* - Free data associated with the given tone mapping structure. - Calls tmPull() first to remove it from the stack if present. - The calls tmDone(tmPop()), tmDone(tmTop) and tmDone(NULL) - all have the same effect, which is to remove and free - the current tone mapping. - - tms - tone mapping structure to free. -*/ - -#endif - - /**** Notes ****/ /* General: @@ -387,3 +429,9 @@ tmDone(struct tmStruct *tms); function will open the file, read its contents and close it before returning, whether or not an error was encountered. */ + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_TONEMAP_H_ */ +
