root/radiance/ray/src/common/tonemap.h
Revision: 3.29
Committed: Thu Jan 7 19:13:57 2021 UTC (4 years, 5 months ago) by greg
Changes since 3.28: +4 -2 lines
fix: fixed issue with last change and made it so TMAP_TYP can be float
1 /* RCSid $Id: tonemap.h,v 3.28 2021/01/07 02:13:49 greg Exp $ */
2 /*
3 * Header file for tone mapping functions.
4 *
5 * Include after "color.h"
6 */
7 #ifndef _RAD_TONEMAP_H_
8 #define _RAD_TONEMAP_H_
9
10 #include "tiff.h" /* needed for int32, etc. */
11
12 #ifdef __cplusplus
13 extern "C" {
14 #endif
15
16 /**** Argument Macros ****/
17 /* flags of what to do */
18 #define TM_F_HCONTR 01 /* human contrast sensitivity */
19 #define TM_F_MESOPIC 02 /* mesopic color sensitivity */
20 #define TM_F_LINEAR 04 /* linear brightness mapping */
21 #define TM_F_ACUITY 010 /* acuity adjustment */
22 #define TM_F_VEIL 020 /* veiling glare */
23 #define TM_F_CWEIGHT 040 /* center weighting */
24 #define TM_F_FOVEAL 0100 /* use foveal sample size */
25 #define TM_F_BW 0200 /* luminance only */
26 #define TM_F_NOSTDERR 0400 /* don't report errors to stderr */
27 /* combined modes */
28 #define TM_F_CAMERA 0
29 #define TM_F_HUMAN (TM_F_HCONTR|TM_F_MESOPIC|TM_F_VEIL|\
30 TM_F_ACUITY|TM_F_FOVEAL)
31 #define TM_F_UNIMPL (TM_F_CWEIGHT|TM_F_VEIL|TM_F_ACUITY|TM_F_FOVEAL)
32
33 /* special pointer values */
34 #define TM_XYZPRIM (RGBPRIMP)NULL /* indicate XYZ primaries (Note 1) */
35 #define TM_NOCHROM (uby8 *)NULL /* indicate no chrominance */
36 #define TM_NOCHROMP (uby8 **)NULL /* indicate no chrominances */
37 #define TM_GETFILE (FILE *)NULL /* indicate file must be opened */
38
39
40 /**** Error Return Values ****/
41
42 #define TM_E_OK 0 /* normal return status */
43 #define TM_E_NOMEM 1 /* out of memory */
44 #define TM_E_ILLEGAL 2 /* illegal argument value */
45 #define TM_E_TMINVAL 3 /* no valid tone mapping */
46 #define TM_E_TMFAIL 4 /* cannot compute tone mapping */
47 #define TM_E_BADFILE 5 /* cannot open or understand file */
48 #define TM_E_CODERR1 6 /* code consistency error 1 */
49 #define TM_E_CODERR2 7 /* code consistency error 2 */
50
51
52 /**** Conversion Constants and Table Sizes ****/
53
54 #define TM_BRTSCALE 256 /* brightness scale factor (integer) */
55
56 #define TM_NOBRT (~0x7fff) /* bogus brightness value */
57 #define TM_NOLUM (1e-17) /* ridiculously small luminance */
58
59 #define TM_BRES 4096 /* luminance tone-map resolution */
60
61 #define TM_MAXPKG 8 /* maximum number of color formats */
62
63
64 /**** Global Data Types and Structures ****/
65
66 #ifndef MEM_PTR
67 #define MEM_PTR void *
68 #endif
69 #ifndef HIST_TYP
70 #define HIST_TYP unsigned long
71 #endif
72 #ifndef TMAP_TYP
73 #define TMAP_TYP uint16
74 #endif
75
76 extern char *tmErrorMessage[]; /* error messages */
77
78 typedef short TMbright; /* encoded luminance type */
79
80 /* basic tone mapping data structure */
81 typedef struct {
82 int flags; /* flags of what to do */
83 RGBPRIMP monpri; /* monitor RGB primaries */
84 double mongam; /* monitor gamma value (approx.) */
85 COLOR clf; /* computed luminance coefficients */
86 int cdiv[3]; /* computed color divisors */
87 RGBPRIMP inppri; /* current input primaries */
88 double inpsf; /* current input scalefactor */
89 MEM_PTR inpdat; /* current input client data */
90 COLORMAT cmat; /* color conversion matrix */
91 TMbright hbrmin, hbrmax; /* histogram brightness limits */
92 HIST_TYP *histo; /* input histogram */
93 TMbright mbrmin, mbrmax; /* mapped brightness limits */
94 TMAP_TYP *lumap; /* computed luminance map */
95 MEM_PTR pd[TM_MAXPKG]; /* pointers to private data */
96 int lastError; /* last error incurred */
97 const char *lastFunc; /* error-generating function name */
98 } TMstruct;
99
100 /* conversion package functions */
101 struct tmPackage {
102 MEM_PTR (*Init)(TMstruct *tms);
103 void (*NewSpace)(TMstruct *tms);
104 void (*Free)(MEM_PTR pp);
105 };
106 /* our list of conversion packages */
107 extern struct tmPackage *tmPkg[TM_MAXPKG];
108 extern int tmNumPkgs; /* number of registered packages */
109
110
111 /**** Useful Macros ****/
112
113 /* compute luminance from encoded value */
114 #define tmLuminance(li) exp((li)*(1./TM_BRTSCALE))
115
116 /* does tone mapping need color matrix? */
117 #define tmNeedMatrix(t) ((t)->monpri != (t)->inppri)
118
119 /* register a conversion package */
120 #define tmRegPkg(pf) ( tmNumPkgs >= TM_MAXPKG ? -1 : \
121 (tmPkg[tmNumPkgs] = (pf), tmNumPkgs++) )
122
123 /* get the specific package's data */
124 #define tmPkgData(t,i) ((t)->pd[i]!=NULL ? (t)->pd[i] : (*tmPkg[i]->Init)(t))
125
126
127 /**** Library Function Calls ****/
128
129 extern TMbright
130 tmCvLuminance(double lum);
131 /*
132 Convert a single luminance value to an encoded brightness value.
133 */
134
135 extern int
136 tmCvLums(TMbright *ls, float *scan, int len);
137 /*
138 Convert luminance values to encoded brightness values using lookup.
139
140 ls - returned encoded luminance values.
141 scan - input scanline.
142 len - scanline length.
143
144 returns - 0 on success, TM_E_* on error.
145 */
146
147 extern TMstruct *
148 tmInit(int flags, RGBPRIMP monpri, double gamval);
149 /*
150 Allocate and initialize new tone mapping.
151
152 flags - TM_F_* flags indicating what is to be done.
153 monpri - display monitor primaries (Note 1).
154 gamval - display gamma response (can be approximate).
155
156 returns - new tone-mapping pointer, or NULL if no memory.
157 */
158
159 extern int
160 tmSetSpace(TMstruct *tms, RGBPRIMP pri, double sf, MEM_PTR dat);
161 /*
162 Set color primaries and scale factor for incoming scanlines.
163
164 tms - tone mapping structure pointer.
165 pri - RGB color input primaries (Note 1).
166 sf - scale factor to get to luminance in cd/m^2.
167 dat - application-specific data (NULL if not needed)
168
169 returns - 0 on success, TM_E_* code on failure.
170 */
171
172 extern void
173 tmClearHisto(TMstruct *tms);
174 /*
175 Clear histogram for current tone mapping.
176
177 tms - tone mapping structure pointer.
178 */
179
180 extern int
181 tmAddHisto(TMstruct *tms, TMbright *ls, int len, int wt);
182 /*
183 Add brightness values to current histogram.
184
185 tms - tone mapping structure pointer.
186 ls - encoded luminance values.
187 len - number of luminance values.
188 wt - integer weight to use for each value (usually 1 or -1).
189
190 returns - 0 on success, TM_E_* on error.
191 */
192
193 extern int
194 tmFixedMapping(TMstruct *tms, double expmult, double gamval);
195 /*
196 Assign a fixed, linear tone-mapping using the given multiplier,
197 which is the ratio of maximum output to uncalibrated input.
198 This mapping will be used in subsequent calls to tmMapPixels()
199 until a new tone mapping is computed.
200 Only the min. and max. values are used from the histogram.
201
202 tms - tone mapping structure pointer.
203 expmult - the fixed exposure multiplier to use.
204 gamval - display gamma response (0. for default).
205
206 returns - 0 on success, TM_E_* on error.
207 */
208
209 extern int
210 tmComputeMapping(TMstruct *tms, double gamval, double Lddyn, double Ldmax);
211 /*
212 Compute tone mapping function from the current histogram.
213 This mapping will be used in subsequent calls to tmMapPixels()
214 until a new tone mapping is computed.
215 I.e., calls to tmAddHisto() have no immediate effect.
216
217 tms - tone mapping structure pointer.
218 gamval - display gamma response (0. for default).
219 Lddyn - the display's dynamic range (0. for default).
220 Ldmax - maximum display luminance in cd/m^2 (0. for default).
221
222 returns - 0 on success, TM_E_* on failure.
223 */
224
225 extern int
226 tmMapPixels(TMstruct *tms, uby8 *ps, TMbright *ls, uby8 *cs, int len);
227 /*
228 Apply tone mapping function to pixel values.
229
230 tms - tone mapping structure pointer.
231 ps - returned pixel values (Note 2).
232 ls - encoded luminance values.
233 cs - encoded chrominance values (Note 2).
234 len - number of pixels.
235
236 returns - 0 on success, TM_E_* on failure.
237 */
238
239 extern TMstruct *
240 tmDup(TMstruct *orig);
241 /*
242 Duplicate the given tone mapping into a new struct.
243
244 orig - tone mapping structure to duplicate.
245
246 returns - pointer to new struct, or NULL on error.
247 */
248
249 extern void
250 tmDone(TMstruct *tms);
251 /*
252 Free data associated with the given tone mapping structure.
253
254 tms - tone mapping structure to free.
255 */
256
257 extern int
258 tmCvGrays(TMstruct *tms, TMbright *ls, float *scan, int len);
259 /*
260 Convert gray float scanline to encoded luminance.
261
262 tms - tone mapping structure pointer.
263 ls - returned encoded luminance values.
264 scan - input scanline.
265 len - scanline length.
266
267 returns - 0 on success, TM_E_* on error.
268 */
269
270 extern int
271 tmCvColors(TMstruct *tms, TMbright *ls, uby8 *cs, COLOR *scan, int len);
272 /*
273 Convert RGB/XYZ float scanline to encoded luminance and chrominance.
274
275 tms - tone mapping structure pointer.
276 ls - returned encoded luminance values.
277 cs - returned encoded chrominance values (Note 2).
278 scan - input scanline.
279 len - scanline length.
280
281 returns - 0 on success, TM_E_* on error.
282 */
283
284 extern int
285 tmCvColrs(TMstruct *tms, TMbright *ls, uby8 *cs, COLR *scan, int len);
286 /*
287 Convert RGBE/XYZE scanline to encoded luminance and chrominance.
288
289 tms - tone mapping structure pointer.
290 ls - returned encoded luminance values.
291 cs - returned encoded chrominance values (Note 2).
292 scan - input scanline.
293 len - scanline length.
294
295 returns - 0 on success, TM_E_* on error.
296 */
297
298 extern int
299 tmLoadPicture(TMstruct *tms, TMbright **lpp, uby8 **cpp, int *xp, int *yp,
300 char *fname, FILE *fp);
301 /*
302 Load Radiance picture and convert to tone mapping representation.
303 Memory for the luminance and chroma arrays is allocated using
304 malloc(3), and should be freed with free(3) when no longer needed.
305 Calls tmSetSpace() to calibrate input color space.
306
307 tms - tone mapping structure pointer.
308 lpp - returned array of encoded luminances, picture ordering.
309 cpp - returned array of encoded chrominances (Note 2).
310 xp, yp - returned picture dimensions.
311 fname - picture file name.
312 fp - pointer to open file (Note 3).
313
314 returns - 0 on success, TM_E_* on failure.
315 */
316
317 extern int
318 tmMapPicture(uby8 **psp, int *xp, int *yp, int flags,
319 RGBPRIMP monpri, double gamval, double Lddyn, double Ldmax,
320 char *fname, FILE *fp);
321 /*
322 Load and apply tone mapping to Radiance picture.
323 If fp is TM_GETFILE and (flags&TM_F_UNIMPL)!=0, tmMapPicture()
324 calls pcond to perform the actual conversion, which takes
325 longer but gives access to all the TM_F_* features.
326 Memory for the final pixel array is allocated using malloc(3),
327 and should be freed with free(3) when it is no longer needed.
328
329 psp - returned array of tone mapped pixels, picture ordering.
330 xp, yp - returned picture dimensions.
331 flags - TM_F_* flags indicating what is to be done.
332 monpri - display monitor primaries (Note 1).
333 gamval - display gamma response.
334 Lddyn - the display's dynamic range (0. for default).
335 Ldmax - maximum display luminance in cd/m^2 (0. for default).
336 fname - picture file name.
337 fp - pointer to open file (Note 3).
338
339 returns - 0 on success, TM_E_* on failure.
340 */
341
342 extern int
343 tmCvRGB48(TMstruct *tms, TMbright *ls, uby8 *cs, uint16 (*scan)[3],
344 int len, double gv);
345 /*
346 Convert 48-bit RGB scanline to encoded luminance and chrominance.
347
348 tms - tone mapping structure pointer.
349 ls - returned encoded luminance values.
350 cs - returned encoded chrominance values (Note 2).
351 scan - input scanline.
352 len - scanline length.
353 gv - input gamma value.
354
355 returns - 0 on success, TM_E_* on error.
356 */
357
358 extern int
359 tmCvGray16(TMstruct *tms, TMbright *ls, uint16 *scan, int len, double gv);
360 /*
361 Convert 16-bit gray scanline to encoded luminance.
362
363 tms - tone mapping structure pointer.
364 ls - returned encoded luminance values.
365 scan - input scanline.
366 len - scanline length.
367 gv - input gamma value.
368
369 returns - 0 on success, TM_E_* on error.
370 */
371
372 /**** Notes ****/
373 /*
374 General:
375
376 The usual sequence after calling tmInit() is to convert some
377 pixel values to chroma and luminance encodings, which can
378 be passed to tmAddHisto() to put into the tone mapping histogram.
379 This histogram is then used along with the display parameters
380 by tmComputeMapping() to compute the luminance mapping function.
381 (Colors are tone-mapped as they are converted if TM_F_MESOPIC
382 is set.) The encoded chroma and luminance values may then be
383 passed to tmMapPixels() to apply the computed tone mapping in
384 a second pass.
385
386 Especially for RGBE colors in the same color space as the
387 target display, the conversion to chroma and luminance values
388 is fast enough that it may be recomputed on the second pass
389 if memory is at a premium. (Since the chroma values are only
390 used during final mapping, setting the cs parameter to TM_NOCHROM
391 on the first pass will save time.) Another memory saving option
392 if third and subsequent passes are not needed is to use the
393 same array to store the mapped pixels as used to store
394 the encoded chroma values. This way, only two extra bytes
395 for storing encoded luminances are required per pixel. This
396 is the method employed by tmMapPicture(), for example.
397 */
398 /*
399 Note 1:
400
401 All RGBPRIMP values should be pointers to static structures.
402 I.e., the same pointer should be used for the same primaries,
403 and those primaries should not change from one call to the next.
404 This is because the routines use the pointer value to identify
405 computed conversion matrices, so the matrices do not have to be
406 rebuilt each time. If you are using the standard primaries,
407 use the standard primary pointer, stdprims.
408
409 To indicate a set of input primaries are actually CIE XYZ,
410 the TM_XYZPRIM macro may be passed. If the input primaries
411 are unknown, it is wisest to pass tmTop->monpri to tmSetSpace().
412 By default, the input primaries equal the monitor primaries
413 and the scalefactor is set to WHTEFFICACY in tmInit().
414 */
415 /*
416 Note 2:
417
418 Chrominance is optional in most of these routines, whether
419 TM_F_BW is set or not. Passing a value of TM_NOCHROM (or
420 TM_NOCHROMP for picture reading) indicates that returned
421 color values are not desired.
422
423 If TM_NOCHROM is passed to a mapping routine expecting chroma
424 input, it will do without it and return luminance channel
425 rather than RGB pixel values. Otherwise, the array for
426 returned pixel values may be the same array used to pass
427 encoded chrominances if no other mappings are desired.
428 */
429 /*
430 Note 3:
431
432 Picture files may either be opened by the calling routine or by
433 the library function. If opened by the calling routine, the
434 pointer to the stream is passed, which may be a pipe or other
435 non-seekable input as it is only read once. It must be
436 positioned at the beginning when the function is called, and it
437 will be positioned at the end on return. It will not be closed.
438 If the passed stream pointer is TM_GETFILE, then the library
439 function will open the file, read its contents and close it
440 before returning, whether or not an error was encountered.
441 */
442
443 #ifdef __cplusplus
444 }
445 #endif
446 #endif /* _RAD_TONEMAP_H_ */
447
