root/radiance/ray/src/common/tonemap.h
Sat Jan 15 16:57:46 2022 UTC (2 years, 4 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 3.31: +6 -9 lines
Diff to previous 3.31 , to selected 3.7
refactor: eliminated use of MEM_PTR and (char *) for untyped memory
Thu Mar 18 16:56:03 2021 UTC (3 years, 2 months ago) by greg
Changes since 3.30: +2 -2 lines
Diff to previous 3.30 , to selected 3.7
docs: fixed comment in function parameter list
Tue Mar 2 20:09:14 2021 UTC (3 years, 2 months ago) by greg
Changes since 3.29: +3 -2 lines
Diff to previous 3.29 , to selected 3.7
perf: added handling of blacks in linear tone-mapping
Thu Jan 7 19:13:57 2021 UTC (3 years, 4 months ago) by greg
Changes since 3.28: +4 -2 lines
Diff to previous 3.28 , to selected 3.7
fix: fixed issue with last change and made it so TMAP_TYP can be float
Thu Jan 7 02:13:49 2021 UTC (3 years, 4 months ago) by greg
Changes since 3.27: +3 -1 lines
Diff to previous 3.27 , to selected 3.7
perf: increased accuracy of luminance map
Wed Jan 6 19:25:00 2021 UTC (3 years, 4 months ago) by greg
Changes since 3.26: +8 -4 lines
Diff to previous 3.26 , to selected 3.7
refactor: added defined types for histogram and map tables
Fri May 20 02:06:38 2011 UTC (13 years ago) by greg
CVS Tags: rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Changes since 3.25: +9 -9 lines
Diff to previous 3.25 , to selected 3.7
Wed Aug 18 15:25:03 2010 UTC (13 years, 9 months ago) by greg
Diff to previous 3.24 , to selected 3.7
Adjusted TM_BRTSCALE again (512 overflowed some operations)
Tue Jul 27 16:13:40 2010 UTC (13 years, 10 months ago) by greg
Diff to previous 3.23 , to selected 3.7
Increased TM_BRTSCALE for better luminance resolution
Sat May 31 19:38:36 2008 UTC (16 years ago) by greg
Diff to previous 3.22 , to selected 3.7
Eliminated tifftypes.h in favor of tiff.h throughout
Wed May 10 15:21:58 2006 UTC (18 years ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 3.21: +18 -6 lines
Diff to previous 3.21 , to selected 3.7
Made COLOR conversion faster with lookup and fixed scale bug in tmCvGrays()
Tue Nov 15 06:53:00 2005 UTC (18 years, 6 months ago) by greg
Changes since 3.20: +6 -1 lines
Diff to previous 3.20 , to selected 3.7
Added tmCvLuminance() call
Mon Nov 14 22:18:18 2005 UTC (18 years, 6 months ago) by greg
Changes since 3.19: +3 -3 lines
Diff to previous 3.19 , to selected 3.7
Fri Jan 7 22:05:30 2005 UTC (19 years, 4 months ago) by greg
Changes since 3.18: +4 -2 lines
Diff to previous 3.18 , to selected 3.7
Added client data pointer to tmSetSpace() call
Fri Jan 7 21:41:06 2005 UTC (19 years, 4 months ago) by greg
Changes since 3.17: +5 -3 lines
Diff to previous 3.17 , to selected 3.7
Moved error codes inside passed TMstruct
Fri Jan 7 20:33:02 2005 UTC (19 years, 4 months ago) by greg
Changes since 3.16: +40 -59 lines
Diff to previous 3.16 , to selected 3.7
Mon Jul 14 22:23:59 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 3.15: +4 -3 lines
Diff to previous 3.15 , to selected 3.7
Mon Jul 14 04:56:54 2003 UTC (20 years, 10 months ago) by greg
Changes since 3.14: +28 -1 lines
Diff to previous 3.14 , to selected 3.7
Fri Jun 27 06:53:22 2003 UTC (20 years, 11 months ago) by greg
Changes since 3.13: +1 -4 lines
Diff to previous 3.13 , to selected 3.7
Fri Jun 6 16:38:47 2003 UTC (21 years ago) by schorsch
Changes since 3.12: +8 -24 lines
Diff to previous 3.12 , to selected 3.7
*** empty log message ***
Changes since 3.11: +2 -57 lines
Diff to previous 3.11 , to selected 3.7
Changes since 3.10: +173 -82 lines
Diff to previous 3.10 , to selected 3.7
Sun Dec 20 16:38:29 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 3.9: +2 -0 lines
Diff to previous 3.9 , to selected 3.7
added TM_NOBRT macro for undefined brightnesses
Mon Oct 5 16:49:52 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 3.8: +2 -2 lines
Diff to previous 3.8 , to selected 3.7
corrected comment about pixel ordering for tmLoadPicture and tmMapPicture
Mon Aug 17 17:58:47 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.7: +5 -4 lines
Diff to previous 3.7
took "color.h" include out of tonemap.h and put in tmprivat.h
changed routines so zero-length arrays don't return error
Revision 3.7 - (view) (download) (annotate) - [selected]
Mon Nov 17 13:54:35 1997 UTC (26 years, 6 months ago) by gregl
Changes since 3.6: +5 -2 lines
Diff to previous 3.6
changed behavior so that tmClearHisto() and tmAddHisto() do not
void computed tone mapping, even if brightness limits are exceeded
Tue Jul 29 11:54:45 1997 UTC (26 years, 10 months ago) by gregl
Changes since 3.5: +2 -0 lines
Diff to previous 3.5 , to selected 3.7
added tmLastError and tmLastFunction globals (set by tmErrorReturn)
Mon Apr 21 15:23:42 1997 UTC (27 years, 1 month ago) by greg
Changes since 3.4: +5 -1 lines
Diff to previous 3.4 , to selected 3.7
small comment changes
Fri Apr 18 13:59:48 1997 UTC (27 years, 1 month ago) by greg
Changes since 3.3: +48 -8 lines
Diff to previous 3.3 , to selected 3.7
added notion of conversion packages with private data
Wed Apr 16 20:28:07 1997 UTC (27 years, 1 month ago) by greg
Changes since 3.2: +11 -2 lines
Diff to previous 3.2 , to selected 3.7
minor bug fixes and added tmDup()
Tue Apr 15 20:04:41 1997 UTC (27 years, 1 month ago) by greg
Diff to previous 3.1 , to selected 3.7
changed TM_F_NOERRS to TM_F_NOSTDERR
skipped histogram clipping for TM_F_LINEAR in tmComputeMapping()
Tue Apr 15 16:53:03 1997 UTC (27 years, 1 month ago) by greg
Diff to selected 3.7
