root/radiance/ray/src/common/tonemap.h
Revision: 3.8
Committed: Mon Aug 17 17:58:47 1998 UTC (26 years, 10 months ago) by gwlarson
Changes since 3.7: +5 -4 lines
took "color.h" include out of tonemap.h and put in tmprivat.h
changed routines so zero-length arrays don't return error
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 /* SCCSid "$SunId$ SGI" */
4
5 /*
6 * Header file for tone mapping functions.
7 *
8 * Include after "color.h"
9 */
10
11
12 /**** Argument Macros ****/
13 /* Flags of what to do */
14 #define TM_F_HCONTR 01 /* human contrast sensitivity */
15 #define TM_F_MESOPIC 02 /* mesopic color sensitivity */
16 #define TM_F_LINEAR 04 /* linear brightness mapping */
17 #define TM_F_ACUITY 010 /* acuity adjustment */
18 #define TM_F_VEIL 020 /* veiling glare */
19 #define TM_F_CWEIGHT 040 /* center weighting */
20 #define TM_F_FOVEAL 0100 /* use foveal sample size */
21 #define TM_F_BW 0200 /* luminance only */
22 #define TM_F_NOSTDERR 0400 /* don't report errors to stderr */
23 /* combined modes */
24 #define TM_F_CAMERA 0
25 #define TM_F_HUMAN (TM_F_HCONTR|TM_F_MESOPIC|TM_F_VEIL|\
26 TM_F_ACUITY|TM_F_FOVEAL)
27 #define TM_F_UNIMPL (TM_F_CWEIGHT|TM_F_VEIL|TM_F_ACUITY|TM_F_FOVEAL)
28
29 /* special pointer values */
30 #define TM_XYZPRIM (RGBPRIMP)NULL /* indicate XYZ primaries (Note 1) */
31 #define TM_NOCHROM (BYTE *)NULL /* indicate no chrominance */
32 #define TM_NOCHROMP (BYTE **)NULL /* indicate no chrominances */
33 #define TM_GETFILE (FILE *)NULL /* indicate file must be opened */
34
35
36 /**** Error Return Values ****/
37
38 #define TM_E_OK 0 /* normal return status */
39 #define TM_E_NOMEM 1 /* out of memory */
40 #define TM_E_ILLEGAL 2 /* illegal argument value */
41 #define TM_E_TMINVAL 3 /* no valid tone mapping */
42 #define TM_E_TMFAIL 4 /* cannot compute tone mapping */
43 #define TM_E_BADFILE 5 /* cannot open or understand file */
44 #define TM_E_CODERR1 6 /* code consistency error 1 */
45 #define TM_E_CODERR2 7 /* code consistency error 2 */
46
47
48 /**** Conversion Constants and Table Sizes ****/
49
50 #define TM_BRTSCALE 128 /* brightness scale factor (integer) */
51
52 #define TM_MAXPKG 8 /* maximum number of color formats */
53
54
55 /**** Global Data Types and Structures ****/
56
57 #ifndef MEM_PTR
58 #define MEM_PTR void *
59 #endif
60
61 extern char *tmErrorMessage[]; /* error messages */
62 extern int tmLastError; /* last error incurred by library */
63 extern char *tmLastFunction; /* error-generating function name */
64
65 typedef short TMbright; /* encoded luminance type */
66
67 /* basic tone mapping data structure */
68 extern struct tmStruct {
69 int flags; /* flags of what to do */
70 RGBPRIMP monpri; /* monitor RGB primaries */
71 double mongam; /* monitor gamma value (approx.) */
72 COLOR clf; /* computed luminance coefficients */
73 int cdiv[3]; /* computed color divisors */
74 RGBPRIMP inppri; /* current input primaries */
75 double inpsf; /* current input scalefactor */
76 COLORMAT cmat; /* color conversion matrix */
77 TMbright hbrmin, hbrmax; /* histogram brightness limits */
78 int *histo; /* input histogram */
79 TMbright mbrmin, mbrmax; /* mapped brightness limits */
80 unsigned short *lumap; /* computed luminance map */
81 struct tmStruct *tmprev; /* previous tone mapping */
82 MEM_PTR pd[TM_MAXPKG]; /* pointers to private data */
83 } *tmTop; /* current tone mapping stack */
84
85 /* conversion package functions */
86 #ifdef NOPROTO
87 struct tmPackage {
88 MEM_PTR (*Init)(); /* initialize private data */
89 void (*NewSpace)(); /* new input color space (optional) */
90 void (*Free)(); /* free private data */
91 };
92 #else
93 struct tmPackage {
94 MEM_PTR (*Init)(struct tmStruct *tms);
95 int (*NewSpace)(struct tmStruct *tms);
96 void (*Free)(MEM_PTR pp);
97 };
98 #endif
99 /* our list of conversion packages */
100 extern struct tmPackage *tmPkg[TM_MAXPKG];
101 extern int tmNumPkgs; /* number of registered packages */
102
103
104 /**** Useful Macros ****/
105
106 /* compute luminance from encoded value */
107 #define tmLuminance(li) exp((li)/(double)TM_BRTSCALE)
108
109 /* does tone mapping need color matrix? */
110 #define tmNeedMatrix(t) ((t)->monpri != (t)->inppri)
111
112 /* register a conversion package */
113 #define tmRegPkg(pf) ( tmNumPkgs >= TM_MAXPKG ? -1 : \
114 (tmPkg[tmNumPkgs] = (pf), tmNumPkgs++) )
115
116 /* get the specific package's data */
117 #define tmPkgData(t,i) ((t)->pd[i]!=NULL ? (t)->pd[i] : (*tmPkg[i]->Init)(t))
118
119
120 /**** Library Function Calls ****/
121
122 #ifdef NOPROTO
123
124 extern struct tmStruct *tmInit(), *tmPop(), *tmDup();
125 extern void tmClearHisto(), tmDone();
126 extern int tmSetSpace(), tmCvColors(), tmCvColrs();
127 extern int tmAddHisto(), tmComputeMapping(), tmMapPixels();
128 extern int tmLoadPicture(), tmMapPicture(), tmPull(), tmPush();
129
130 #else
131
132 extern struct tmStruct *
133 tmInit(int flags, RGBPRIMP monpri, double gamval);
134 /*
135 Initialize new tone mapping and push it onto stack.
136
137 flags - TM_F_* flags indicating what is to be done.
138 monpri - display monitor primaries (Note 1).
139 gamval - display gamma response (can be approximate).
140
141 returns - new tmTop, or NULL if insufficient memory.
142 */
143
144 extern int
145 tmSetSpace(RGBPRIMP pri, double sf);
146 /*
147 Set color primaries and scale factor for incoming scanlines.
148
149 pri - RGB color input primaries (Note 1).
150 sf - scale factor to get to luminance in cd/m^2.
151
152 returns - 0 on success, TM_E_* code on failure.
153 */
154
155 extern void
156 tmClearHisto(void);
157 /*
158 Clear histogram for current tone mapping.
159 */
160
161 extern int
162 tmCvColors(TMbright *ls, BYTE *cs, COLOR *scan, int len);
163 /*
164 Convert RGB/XYZ float scanline to encoded luminance and chrominance.
165
166 ls - returned encoded luminance values.
167 cs - returned encoded chrominance values (Note 2).
168 scan - input scanline.
169 len - scanline length.
170
171 returns - 0 on success, TM_E_* on error.
172 */
173
174 extern int
175 tmCvColrs(TMbright *ls, BYTE *cs, COLR *scan, int len);
176 /*
177 Convert RGBE/XYZE scanline to encoded luminance and chrominance.
178
179 ls - returned encoded luminance values.
180 cs - returned encoded chrominance values (Note 2).
181 scan - input scanline.
182 len - scanline length.
183
184 returns - 0 on success, TM_E_* on error.
185 */
186
187 extern int
188 tmAddHisto(TMbright *ls, int len, int wt);
189 /*
190 Add brightness values to current histogram.
191
192 ls - encoded luminance values.
193 len - number of luminance values.
194 wt - integer weight to use for each value (usually 1 or -1).
195
196 returns - 0 on success, TM_E_* on error.
197 */
198
199 extern int
200 tmComputeMapping(double gamval, double Lddyn, double Ldmax);
201 /*
202 Compute tone mapping function. This mapping will be used
203 in subsequent calls to tmMapPixels() until a new tone mapping
204 is computed. I.e., calls to tmAddHisto() have no immediate effect.
205
206 gamval - display gamma response (0. for default).
207 Lddyn - the display's dynamic range (0. for default).
208 Ldmax - maximum display luminance in cd/m^2 (0. for default).
209
210 returns - 0 on success, TM_E_* on failure.
211 */
212
213 extern int
214 tmMapPixels(BYTE *ps, TMbright *ls, BYTE *cs, int len);
215 /*
216 Apply tone mapping function to pixel values.
217
218 ps - returned pixel values (Note 2).
219 ls - encoded luminance values.
220 cs - encoded chrominance values (Note 2).
221 len - number of pixels.
222
223 returns - 0 on success, TM_E_* on failure.
224 */
225
226 extern int
227 tmLoadPicture(TMbright **lpp, BYTE **cpp, int *xp, int *yp,
228 char *fname, FILE *fp);
229 /*
230 Load Radiance picture and convert to tone mapping representation.
231 Memory for the luminance and chroma arrays is allocated using
232 malloc(3), and should be freed with free(3) when no longer needed.
233 Calls tmSetSpace() to calibrate input color space.
234
235 lpp - returned array of encoded luminances, English ordering.
236 cpp - returned array of encoded chrominances (Note 2).
237 xp, yp - returned picture dimensions.
238 fname - picture file name.
239 fp - pointer to open file (Note 3).
240
241 returns - 0 on success, TM_E_* on failure.
242 */
243
244 extern int
245 tmMapPicture(BYTE **psp, int *xp, int *yp, int flags,
246 RGBPRIMP monpri, double gamval, double Lddyn, double Ldmax,
247 char *fname, FILE *fp);
248 /*
249 Load and apply tone mapping to Radiance picture.
250 Stack is restored to its original state upon return.
251 If fp is TM_GETFILE and (flags&TM_F_UNIMPL)!=0, tmMapPicture()
252 calls pcond to perform the actual conversion, which takes
253 longer but gives access to all the TM_F_* features.
254 Memory for the final pixel array is allocated using malloc(3),
255 and should be freed with free(3) when it is no longer needed.
256
257 psp - returned array of tone mapped pixels, English ordering.
258 xp, yp - returned picture dimensions.
259 flags - TM_F_* flags indicating what is to be done.
260 monpri - display monitor primaries (Note 1).
261 gamval - display gamma response.
262 Lddyn - the display's dynamic range (0. for default).
263 Ldmax - maximum display luminance in cd/m^2 (0. for default).
264 fname - picture file name.
265 fp - pointer to open file (Note 3).
266
267 returns - 0 on success, TM_E_* on failure.
268 */
269
270 extern struct tmStruct *
271 tmPop(void);
272 /*
273 Pops current tone mapping from stack.
274
275 returns - pointer to tone mapping structure, or NULL if none.
276 */
277
278 extern int
279 tmPull(struct tmStruct *tms);
280 /*
281 Pull tone mapping from anywhere in stack.
282
283 tms - tone mapping structure to find.
284
285 returns - 1 if found in stack, 0 otherwise.
286 */
287
288 extern int
289 tmPush(struct tmStruct *tms);
290 /*
291 Make tone mapping active by (pulling it and) pushing it to the top.
292
293 tms - initialized tone mapping structure.
294
295 returns - 0 on success, TM_E_* if tms is invalid.
296 */
297
298 extern struct tmStruct *
299 tmDup(void);
300 /*
301 Duplicate the current tone mapping into a new structure on the stack.
302
303 returns - pointer to new top, or NULL on error.
304 */
305
306 extern void
307 tmDone(struct tmStruct *tms);
308 /*
309 Free data associated with the given tone mapping structure.
310 Calls tmPull() first to remove it from the stack if present.
311 The calls tmDone(tmPop()), tmDone(tmTop) and tmDone(NULL)
312 all have the same effect, which is to remove and free
313 the current tone mapping.
314
315 tms - tone mapping structure to free.
316 */
317
318 #endif
319
320
321 /**** Notes ****/
322 /*
323 General:
324
325 The usual sequence after calling tmInit() is to convert some
326 pixel values to chroma and luminance encodings, which can
327 be passed to tmAddHisto() to put into the tone mapping histogram.
328 This histogram is then used along with the display parameters
329 by tmComputeMapping() to compute the luminance mapping function.
330 (Colors are tone-mapped as they are converted if TM_F_MESOPIC
331 is set.) The encoded chroma and luminance values may then be
332 passed to tmMapPixels() to apply the computed tone mapping in
333 a second pass.
334
335 Especially for RGBE colors in the same color space as the
336 target display, the conversion to chroma and luminance values
337 is fast enough that it may be recomputed on the second pass
338 if memory is at a premium. (Since the chroma values are only
339 used during final mapping, setting the cs parameter to TM_NOCHROM
340 on the first pass will save time.) Another memory saving option
341 if third and subsequent passes are not needed is to use the
342 same array to store the mapped pixels as used to store
343 the encoded chroma values. This way, only two extra bytes
344 for storing encoded luminances are required per pixel. This
345 is the method employed by tmMapPicture(), for example.
346 */
347 /*
348 Note 1:
349
350 All RGBPRIMP values should be pointers to static structures.
351 I.e., the same pointer should be used for the same primaries,
352 and those primaries should not change from one call to the next.
353 This is because the routines use the pointer value to identify
354 computed conversion matrices, so the matrices do not have to be
355 rebuilt each time. If you are using the standard primaries,
356 use the standard primary pointer, stdprims.
357
358 To indicate a set of input primaries are actually CIE XYZ,
359 the TM_XYZPRIM macro may be passed. If the input primaries
360 are unknown, it is wisest to pass tmTop->monpri to tmSetSpace().
361 By default, the input primaries equal the monitor primaries
362 and the scalefactor is set to WHTEFFICACY in tmInit().
363 */
364 /*
365 Note 2:
366
367 Chrominance is optional in most of these routines, whether
368 TM_F_BW is set or not. Passing a value of TM_NOCHROM (or
369 TM_NOCHROMP for picture reading) indicates that returned
370 color values are not desired.
371
372 If TM_NOCHROM is passed to a mapping routine expecting chroma
373 input, it will do without it and return luminance channel
374 rather than RGB pixel values. Otherwise, the array for
375 returned pixel values may be the same array used to pass
376 encoded chrominances if no other mappings are desired.
377 */
378 /*
379 Note 3:
380
381 Picture files may either be opened by the calling routine or by
382 the library function. If opened by the calling routine, the
383 pointer to the stream is passed, which may be a pipe or other
384 non-seekable input as it is only read once. It must be
385 positioned at the beginning when the function is called, and it
386 will be positioned at the end on return. It will not be closed.
387 If the passed stream pointer is TM_GETFILE, then the library
388 function will open the file, read its contents and close it
389 before returning, whether or not an error was encountered.
390 */
