root/radiance/ray/src/common/tonemap.c
Revision: 3.37
Committed: Fri May 20 02:06:38 2011 UTC (12 years, 11 months ago) by greg
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R2P1, rad5R3
Changes since 3.36: +6 -6 lines
# User Rev Content
1 greg 3.1 #ifndef lint
2 greg 3.37 static const char RCSid[] = "$Id: tonemap.c,v 3.36 2011/04/22 14:35:54 greg Exp $";
3 greg 3.1 #endif
4     /*
5     * Tone mapping functions.
6     * See tonemap.h for detailed function descriptions.
7 greg 3.9 * Added von Kries white-balance calculations 10/01 (GW).
8     *
9     * Externals declared in tonemap.h
10     */
11
12 greg 3.10 #include "copyright.h"
13 greg 3.1
14     #include <stdio.h>
15 greg 3.34 #include <stdlib.h>
16 greg 3.1 #include <math.h>
17     #include "tmprivat.h"
18     #include "tmerrmsg.h"
19
20     #define exp10(x) exp(M_LN10*(x))
21
22 greg 3.4 /* our list of conversion packages */
23     struct tmPackage *tmPkg[TM_MAXPKG];
24     int tmNumPkgs = 0; /* number of registered packages */
25 greg 3.1
26 greg 3.23 /* luminance->brightness lookup */
27 greg 3.24 static TMbright *tmFloat2BrtLUT = NULL;
28 greg 3.23
29     #define tmCvLumLUfp(pf) tmFloat2BrtLUT[*(int32 *)(pf) >> 15]
30
31 gregl 3.5
32 greg 3.16 TMstruct *
33     tmInit( /* initialize new tone mapping */
34     int flags,
35     RGBPRIMP monpri,
36     double gamval
37     )
38 greg 3.1 {
39     COLORMAT cmat;
40 greg 3.16 TMstruct *tmnew;
41     int i;
42 greg 3.1 /* allocate structure */
43 greg 3.16 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
44 greg 3.1 if (tmnew == NULL)
45     return(NULL);
46
47     tmnew->flags = flags & ~TM_F_UNIMPL;
48 greg 3.15 if (tmnew->flags & TM_F_BW)
49     tmnew->flags &= ~TM_F_MESOPIC;
50 greg 3.1 /* set monitor transform */
51     if (monpri == NULL || monpri == stdprims || tmnew->flags & TM_F_BW) {
52     tmnew->monpri = stdprims;
53     tmnew->clf[RED] = rgb2xyzmat[1][0];
54     tmnew->clf[GRN] = rgb2xyzmat[1][1];
55     tmnew->clf[BLU] = rgb2xyzmat[1][2];
56     } else {
57 greg 3.26 comprgb2xyzmat(cmat, tmnew->monpri=monpri);
58 greg 3.1 tmnew->clf[RED] = cmat[1][0];
59     tmnew->clf[GRN] = cmat[1][1];
60     tmnew->clf[BLU] = cmat[1][2];
61     }
62     /* set gamma value */
63     if (gamval < MINGAM)
64     tmnew->mongam = DEFGAM;
65     else
66     tmnew->mongam = gamval;
67 greg 3.4 /* set color divisors */
68     for (i = 0; i < 3; i++)
69     tmnew->cdiv[i] = 256.*pow(tmnew->clf[i], 1./tmnew->mongam);
70
71 greg 3.1 /* set input transform */
72     tmnew->inppri = tmnew->monpri;
73     tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] =
74     tmnew->inpsf = WHTEFFICACY;
75     tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] =
76     tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.;
77 greg 3.18 tmnew->inpdat = NULL;
78 greg 3.9 tmnew->hbrmin = 10; tmnew->hbrmax = -10;
79 greg 3.1 tmnew->histo = NULL;
80 greg 3.9 tmnew->mbrmin = 10; tmnew->mbrmax = -10;
81 greg 3.1 tmnew->lumap = NULL;
82 greg 3.4 /* zero private data */
83     for (i = TM_MAXPKG; i--; )
84     tmnew->pd[i] = NULL;
85 greg 3.17 tmnew->lastError = TM_E_OK;
86     tmnew->lastFunc = "NoErr";
87 greg 3.16 /* return new TMstruct */
88     return(tmnew);
89 greg 3.1 }
90
91
92     int
93 greg 3.16 tmSetSpace( /* set input color space for conversions */
94     TMstruct *tms,
95     RGBPRIMP pri,
96 greg 3.18 double sf,
97     MEM_PTR dat
98 greg 3.16 )
99 greg 3.1 {
100 greg 3.17 static const char funcName[] = "tmSetSpace";
101 greg 3.16 int i, j;
102 greg 3.1 /* error check */
103 greg 3.16 if (tms == NULL)
104 greg 3.1 returnErr(TM_E_TMINVAL);
105     if (sf <= 1e-12)
106     returnErr(TM_E_ILLEGAL);
107     /* check if no change */
108 greg 3.18 if (pri == tms->inppri && FEQ(sf, tms->inpsf) && dat == tms->inpdat)
109 greg 3.1 returnOK;
110 greg 3.16 tms->inppri = pri; /* let's set it */
111     tms->inpsf = sf;
112 greg 3.18 tms->inpdat = dat;
113 greg 3.1
114 greg 3.16 if (tms->flags & TM_F_BW) { /* color doesn't matter */
115     tms->monpri = tms->inppri; /* eliminate xform */
116     if (tms->inppri == TM_XYZPRIM) {
117     tms->clf[CIEX] = tms->clf[CIEZ] = 0.;
118     tms->clf[CIEY] = 1.;
119 greg 3.1 } else {
120 greg 3.26 comprgb2xyzmat(tms->cmat, tms->monpri);
121 greg 3.16 tms->clf[RED] = tms->cmat[1][0];
122     tms->clf[GRN] = tms->cmat[1][1];
123     tms->clf[BLU] = tms->cmat[1][2];
124     }
125     tms->cmat[0][0] = tms->cmat[1][1] = tms->cmat[2][2] =
126     tms->inpsf;
127     tms->cmat[0][1] = tms->cmat[0][2] = tms->cmat[1][0] =
128     tms->cmat[1][2] = tms->cmat[2][0] = tms->cmat[2][1] = 0.;
129 greg 3.1
130 greg 3.16 } else if (tms->inppri == TM_XYZPRIM) /* input is XYZ */
131     compxyz2rgbWBmat(tms->cmat, tms->monpri);
132 greg 3.1
133     else { /* input is RGB */
134 greg 3.16 if (tms->inppri != tms->monpri &&
135     PRIMEQ(tms->inppri, tms->monpri))
136     tms->inppri = tms->monpri; /* no xform */
137 greg 3.36 if (!comprgb2rgbWBmat(tms->cmat, tms->inppri, tms->monpri))
138     returnErr(TM_E_ILLEGAL);
139 greg 3.1 }
140     for (i = 0; i < 3; i++)
141     for (j = 0; j < 3; j++)
142 greg 3.16 tms->cmat[i][j] *= tms->inpsf;
143 greg 3.4 /* set color divisors */
144     for (i = 0; i < 3; i++)
145 greg 3.36 tms->cdiv[i] = 256.*pow(tms->clf[i] < .001 ? .001 :
146     tms->clf[i], 1./tms->mongam);
147 greg 3.4 /* notify packages */
148     for (i = tmNumPkgs; i--; )
149 greg 3.16 if (tms->pd[i] != NULL && tmPkg[i]->NewSpace != NULL)
150     (*tmPkg[i]->NewSpace)(tms);
151 greg 3.1 returnOK;
152     }
153
154
155     void
156 greg 3.23 tmClearHisto( /* clear current histogram */
157 greg 3.16 TMstruct *tms
158     )
159 greg 3.1 {
160 greg 3.16 if (tms == NULL || tms->histo == NULL)
161 greg 3.1 return;
162 greg 3.16 free((MEM_PTR)tms->histo);
163     tms->histo = NULL;
164 greg 3.1 }
165
166
167 greg 3.23 TMbright
168     tmCvLuminance( /* convert a single luminance */
169     double lum
170     )
171     {
172     double d;
173
174     #ifdef isfinite
175     if (!isfinite(lum) || lum <= TM_NOLUM)
176     #else
177     if (lum <= TM_NOLUM)
178     #endif
179     return(TM_NOBRT);
180     d = TM_BRTSCALE*log(lum);
181 greg 3.35 return((TMbright)(d + .5 - (d < 0.)));
182 greg 3.23 }
183
184
185     int
186     tmCvLums( /* convert luminances using lookup */
187     TMbright *ls,
188     float *scan,
189     int len
190     )
191     {
192     if (tmFloat2BrtLUT == NULL) { /* initialize lookup table */
193     int32 i;
194     tmFloat2BrtLUT = (TMbright *)malloc(sizeof(TMbright)*0x10000);
195     if (tmFloat2BrtLUT == NULL)
196     return(TM_E_NOMEM);
197     for (i = 0; i < 0x10000; i++) {
198     int32 l = (i<<1 | 1) << 14;
199     #ifndef isfinite
200     if ((l & 0x7f800000) == 0x7f800000)
201     tmFloat2BrtLUT[i] = TM_NOBRT;
202     else
203     #endif
204     tmFloat2BrtLUT[i] = tmCvLuminance(*(float *)&l);
205     }
206     }
207     if (len <= 0)
208     return(TM_E_OK);
209     if ((ls == NULL) | (scan == NULL))
210     return(TM_E_ILLEGAL);
211     while (len--) {
212     if (*scan <= TM_NOLUM) {
213     *ls++ = TM_NOBRT;
214     ++scan;
215     continue;
216     }
217     *ls++ = tmCvLumLUfp(scan++);
218     }
219     return(TM_E_OK);
220     }
221
222
223     int
224     tmCvGrays( /* convert float gray values */
225     TMstruct *tms,
226     TMbright *ls,
227     float *scan,
228     int len
229     )
230     {
231     static const char funcName[] = "tmCvGrays";
232     int i;
233
234     if (tms == NULL)
235     returnErr(TM_E_TMINVAL);
236     if ((ls == NULL) | (scan == NULL) | (len < 0))
237     returnErr(TM_E_ILLEGAL);
238 greg 3.24 if (tmFloat2BrtLUT == NULL) /* initialize */
239     tmCvLums(NULL, NULL, 0);
240 greg 3.23 for (i = len; i--; ) {
241     float lum = tms->inpsf * scan[i];
242     if (lum <= TM_NOLUM)
243     ls[i] = TM_NOBRT;
244     else
245     ls[i] = tmCvLumLUfp(&lum);
246     }
247     returnOK;
248     }
249
250
251 greg 3.1 int
252 greg 3.16 tmCvColors( /* convert float colors */
253     TMstruct *tms,
254     TMbright *ls,
255 greg 3.37 uby8 *cs,
256 greg 3.16 COLOR *scan,
257     int len
258     )
259 greg 3.1 {
260 greg 3.17 static const char funcName[] = "tmCvColors";
261 greg 3.37 static uby8 gamtab[1024];
262 greg 3.20 static double curgam = .0;
263 greg 3.1 COLOR cmon;
264 greg 3.23 float lum, slum, d;
265 greg 3.16 int i;
266 greg 3.1
267 greg 3.16 if (tms == NULL)
268 greg 3.1 returnErr(TM_E_TMINVAL);
269 schorsch 3.13 if ((ls == NULL) | (scan == NULL) | (len < 0))
270 greg 3.1 returnErr(TM_E_ILLEGAL);
271 greg 3.24 if (tmFloat2BrtLUT == NULL) /* initialize */
272     tmCvLums(NULL, NULL, 0);
273 greg 3.21 if (cs != TM_NOCHROM && fabs(tms->mongam - curgam) > .02) {
274 greg 3.20 curgam = tms->mongam; /* (re)build table */
275     for (i = 1024; i--; )
276     gamtab[i] = (int)(256.*pow((i+.5)/1024., 1./curgam));
277     }
278 greg 3.1 for (i = len; i--; ) {
279 greg 3.16 if (tmNeedMatrix(tms)) { /* get monitor RGB */
280     colortrans(cmon, tms->cmat, scan[i]);
281 greg 3.15 } else {
282 greg 3.16 cmon[RED] = tms->inpsf*scan[i][RED];
283     cmon[GRN] = tms->inpsf*scan[i][GRN];
284     cmon[BLU] = tms->inpsf*scan[i][BLU];
285 greg 3.1 }
286 greg 3.23 #ifdef isfinite
287     if (!isfinite(cmon[RED]) || cmon[RED] < .0f) cmon[RED] = .0f;
288     if (!isfinite(cmon[GRN]) || cmon[GRN] < .0f) cmon[GRN] = .0f;
289     if (!isfinite(cmon[BLU]) || cmon[BLU] < .0f) cmon[BLU] = .0f;
290     #else
291     if (cmon[RED] < .0f) cmon[RED] = .0f;
292     if (cmon[GRN] < .0f) cmon[GRN] = .0f;
293     if (cmon[BLU] < .0f) cmon[BLU] = .0f;
294 greg 3.22 #endif
295 greg 3.1 /* world luminance */
296 greg 3.16 lum = tms->clf[RED]*cmon[RED] +
297     tms->clf[GRN]*cmon[GRN] +
298     tms->clf[BLU]*cmon[BLU] ;
299 greg 3.25 if (lum <= TM_NOLUM) { /* convert brightness */
300     lum = cmon[RED] = cmon[GRN] = cmon[BLU] = TM_NOLUM;
301 greg 3.23 ls[i] = TM_NOBRT;
302 greg 3.25 } else
303 greg 3.23 ls[i] = tmCvLumLUfp(&lum);
304 greg 3.1 if (cs == TM_NOCHROM) /* no color? */
305     continue;
306 greg 3.16 if (tms->flags & TM_F_MESOPIC && lum < LMESUPPER) {
307 greg 3.1 slum = scotlum(cmon); /* mesopic adj. */
308 greg 3.25 if (lum < LMESLOWER) {
309 greg 3.1 cmon[RED] = cmon[GRN] = cmon[BLU] = slum;
310 greg 3.25 } else {
311 greg 3.1 d = (lum - LMESLOWER)/(LMESUPPER - LMESLOWER);
312 greg 3.16 if (tms->flags & TM_F_BW)
313 greg 3.1 cmon[RED] = cmon[GRN] =
314     cmon[BLU] = d*lum;
315     else
316     scalecolor(cmon, d);
317 greg 3.23 d = (1.f-d)*slum;
318 greg 3.1 cmon[RED] += d;
319     cmon[GRN] += d;
320     cmon[BLU] += d;
321     }
322 greg 3.16 } else if (tms->flags & TM_F_BW) {
323 greg 3.1 cmon[RED] = cmon[GRN] = cmon[BLU] = lum;
324     }
325 greg 3.16 d = tms->clf[RED]*cmon[RED]/lum;
326 greg 3.23 cs[3*i ] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
327 greg 3.16 d = tms->clf[GRN]*cmon[GRN]/lum;
328 greg 3.23 cs[3*i+1] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
329 greg 3.16 d = tms->clf[BLU]*cmon[BLU]/lum;
330 greg 3.23 cs[3*i+2] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
331 greg 3.1 }
332     returnOK;
333     }
334
335
336 greg 3.9 int
337 greg 3.16 tmAddHisto( /* add values to histogram */
338     TMstruct *tms,
339     TMbright *ls,
340     int len,
341     int wt
342     )
343 greg 3.1 {
344 greg 3.17 static const char funcName[] = "tmAddHisto";
345 greg 3.9 int oldorig=0, oldlen, horig, hlen;
346 greg 3.16 int i, j;
347 greg 3.1
348 greg 3.16 if (tms == NULL)
349 greg 3.1 returnErr(TM_E_TMINVAL);
350 gwlarson 3.8 if (len < 0)
351     returnErr(TM_E_ILLEGAL);
352     if (len == 0)
353     returnOK;
354 greg 3.1 /* first, grow limits */
355 greg 3.16 if (tms->histo == NULL) {
356 greg 3.1 for (i = len; i-- && ls[i] < MINBRT; )
357     ;
358     if (i < 0)
359     returnOK;
360 greg 3.16 tms->hbrmin = tms->hbrmax = ls[i];
361 greg 3.1 oldlen = 0;
362     } else {
363 greg 3.31 oldorig = HISTI(tms->hbrmin);
364     oldlen = HISTI(tms->hbrmax) + 1 - oldorig;
365 greg 3.1 }
366     for (i = len; i--; ) {
367     if ((j = ls[i]) < MINBRT)
368     continue;
369 greg 3.16 if (j < tms->hbrmin)
370     tms->hbrmin = j;
371     else if (j > tms->hbrmax)
372     tms->hbrmax = j;
373 greg 3.1 }
374 greg 3.31 horig = HISTI(tms->hbrmin);
375     hlen = HISTI(tms->hbrmax) + 1 - horig;
376 greg 3.1 if (hlen > oldlen) { /* (re)allocate histogram */
377 greg 3.16 int *newhist = (int *)calloc(hlen, sizeof(int));
378 greg 3.1 if (newhist == NULL)
379     returnErr(TM_E_NOMEM);
380     if (oldlen) { /* copy and free old */
381 greg 3.2 for (i = oldlen, j = i+oldorig-horig; i; )
382 greg 3.16 newhist[--j] = tms->histo[--i];
383     free((MEM_PTR)tms->histo);
384 greg 3.1 }
385 greg 3.16 tms->histo = newhist;
386 greg 3.1 }
387     if (wt == 0)
388     returnOK;
389     for (i = len; i--; ) /* add in new counts */
390     if (ls[i] >= MINBRT)
391 greg 3.31 tms->histo[ HISTI(ls[i]) - horig ] += wt;
392 greg 3.1 returnOK;
393     }
394
395
396     static double
397 greg 3.16 htcontrs( /* human threshold contrast sensitivity, dL(La) */
398     double La
399     )
400 greg 3.1 {
401     double l10La, l10dL;
402     /* formula taken from Ferwerda et al. [SG96] */
403     if (La < 1.148e-4)
404     return(1.38e-3);
405     l10La = log10(La);
406     if (l10La < -1.44) /* rod response regime */
407     l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86;
408     else if (l10La < -.0184)
409     l10dL = l10La - .395;
410     else if (l10La < 1.9) /* cone response regime */
411     l10dL = pow(.249*l10La + .65, 2.7) - .72;
412     else
413     l10dL = l10La - 1.255;
414
415     return(exp10(l10dL));
416     }
417
418
419 greg 3.9 int
420 greg 3.16 tmFixedMapping( /* compute fixed, linear tone-mapping */
421     TMstruct *tms,
422     double expmult,
423     double gamval
424     )
425 greg 3.9 {
426 greg 3.17 static const char funcName[] = "tmFixedMapping";
427 greg 3.9 double d;
428 greg 3.16 int i;
429 greg 3.9
430 greg 3.16 if (!tmNewMap(tms))
431 greg 3.9 returnErr(TM_E_NOMEM);
432     if (expmult <= .0)
433     expmult = 1.;
434     if (gamval < MINGAM)
435 greg 3.16 gamval = tms->mongam;
436     d = log(expmult/tms->inpsf);
437 greg 3.28 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
438     double val = 256. * exp(
439 greg 3.16 ( d + (tms->mbrmin+i)*(1./TM_BRTSCALE) )
440 greg 3.28 / gamval);
441     tms->lumap[i] = val >= (double)0xffff ? 0xffff : (int)val;
442     }
443 greg 3.9 returnOK;
444     }
445
446
447 greg 3.1 int
448 greg 3.16 tmComputeMapping( /* compute histogram tone-mapping */
449     TMstruct *tms,
450     double gamval,
451     double Lddyn,
452     double Ldmax
453     )
454 greg 3.1 {
455 greg 3.17 static const char funcName[] = "tmComputeMapping";
456 greg 3.1 int *histo;
457     float *cumf;
458 greg 3.9 int brt0, histlen, threshold, ceiling, trimmings;
459 greg 3.1 double logLddyn, Ldmin, Ldavg, Lwavg, Tr, Lw, Ld;
460 greg 3.11 int32 histot;
461 greg 3.9 double sum;
462 greg 3.16 double d;
463     int i, j;
464 greg 3.1
465 greg 3.16 if (tms == NULL || tms->histo == NULL)
466 greg 3.1 returnErr(TM_E_TMINVAL);
467     /* check arguments */
468     if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN;
469     if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX;
470 greg 3.16 if (gamval < MINGAM) gamval = tms->mongam;
471 greg 3.1 /* compute handy values */
472     Ldmin = Ldmax/Lddyn;
473     logLddyn = log(Lddyn);
474     Ldavg = sqrt(Ldmax*Ldmin);
475 greg 3.31 i = HISTI(tms->hbrmin);
476 greg 3.32 brt0 = HISTV(i);
477 greg 3.31 histlen = HISTI(tms->hbrmax) + 1 - i;
478 greg 3.1 /* histogram total and mean */
479     histot = 0; sum = 0;
480     j = brt0 + histlen*HISTEP;
481     for (i = histlen; i--; ) {
482 greg 3.16 histot += tms->histo[i];
483 greg 3.30 sum += (double)(j -= HISTEP) * tms->histo[i];
484 greg 3.1 }
485 greg 3.14 threshold = histot*0.005 + .5;
486 greg 3.29 if (!histot)
487 greg 3.1 returnErr(TM_E_TMFAIL);
488     Lwavg = tmLuminance( (double)sum / histot );
489 greg 3.29 /* use linear tone mapping? */
490 greg 3.30 if (tms->flags & TM_F_LINEAR || threshold < 4 ||
491     tms->hbrmax - tms->hbrmin < TM_BRTSCALE*logLddyn)
492 greg 3.29 goto linearmap;
493 greg 3.9 /* clamp histogram */
494     histo = (int *)malloc(histlen*sizeof(int));
495     cumf = (float *)malloc((histlen+2)*sizeof(float));
496 schorsch 3.13 if ((histo == NULL) | (cumf == NULL))
497 greg 3.9 returnErr(TM_E_NOMEM);
498     cumf[histlen+1] = 1.; /* guard for assignment code */
499     for (i = histlen; i--; ) /* make malleable copy */
500 greg 3.16 histo[i] = tms->histo[i];
501 greg 3.9 do { /* iterate to solution */
502     sum = 0; /* cumulative probability */
503     for (i = 0; i < histlen; i++) {
504     cumf[i] = (double)sum/histot;
505     sum += histo[i];
506     }
507     cumf[histlen] = 1.;
508 greg 3.16 Tr = histot * (double)(tms->hbrmax - tms->hbrmin) /
509 greg 3.9 ((double)histlen*TM_BRTSCALE) / logLddyn;
510     ceiling = Tr + 1.;
511     trimmings = 0; /* clip to envelope */
512     for (i = histlen; i--; ) {
513 greg 3.16 if (tms->flags & TM_F_HCONTR) {
514 greg 3.9 Lw = tmLuminance(brt0 + i*HISTEP);
515     Ld = Ldmin * exp( logLddyn *
516     .5*(cumf[i]+cumf[i+1]) );
517     ceiling = Tr * (htcontrs(Ld) * Lw) /
518     (htcontrs(Lw) * Ld) + 1.;
519 greg 3.2 }
520 greg 3.9 if (histo[i] > ceiling) {
521     trimmings += histo[i] - ceiling;
522     histo[i] = ceiling;
523 greg 3.1 }
524     }
525 greg 3.9 /* check if we're out of data */
526     if ((histot -= trimmings) <= threshold) {
527     free((MEM_PTR)histo);
528     free((MEM_PTR)cumf);
529     goto linearmap;
530     }
531     } while (trimmings > threshold);
532 greg 3.30 /* allocate space for mapping */
533     if (!tmNewMap(tms))
534     returnErr(TM_E_NOMEM);
535 greg 3.9 /* assign tone-mapping */
536 greg 3.16 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
537     j = d = (double)i/(tms->mbrmax-tms->mbrmin)*histlen;
538 greg 3.9 d -= (double)j;
539     Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1]));
540     d = (Ld - Ldmin)/(Ldmax - Ldmin);
541 greg 3.16 tms->lumap[i] = 256.*pow(d, 1./gamval);
542 greg 3.1 }
543 greg 3.9 free((MEM_PTR)histo); /* clean up and return */
544     free((MEM_PTR)cumf);
545 greg 3.1 returnOK;
546 greg 3.9 linearmap: /* linear tone-mapping */
547 greg 3.16 if (tms->flags & TM_F_HCONTR)
548 greg 3.9 d = htcontrs(Ldavg) / htcontrs(Lwavg);
549     else
550     d = Ldavg / Lwavg;
551 greg 3.16 return(tmFixedMapping(tms, tms->inpsf*d/Ldmax, gamval));
552 greg 3.1 }
553
554
555     int
556 greg 3.16 tmMapPixels( /* apply tone-mapping to pixel(s) */
557     TMstruct *tms,
558 greg 3.37 uby8 *ps,
559 greg 3.16 TMbright *ls,
560 greg 3.37 uby8 *cs,
561 greg 3.16 int len
562     )
563 greg 3.1 {
564 greg 3.17 static const char funcName[] = "tmMapPixels";
565 greg 3.16 int32 li, pv;
566 greg 3.1
567 greg 3.16 if (tms == NULL || tms->lumap == NULL)
568 greg 3.1 returnErr(TM_E_TMINVAL);
569 schorsch 3.13 if ((ps == NULL) | (ls == NULL) | (len < 0))
570 greg 3.1 returnErr(TM_E_ILLEGAL);
571     while (len--) {
572 greg 3.16 if ((li = *ls++) < tms->mbrmin) {
573 greg 3.9 li = 0;
574     } else {
575 greg 3.16 if (li > tms->mbrmax)
576     li = tms->mbrmax;
577     li = tms->lumap[li - tms->mbrmin];
578 greg 3.9 }
579 greg 3.1 if (cs == TM_NOCHROM)
580     *ps++ = li>255 ? 255 : li;
581     else {
582 greg 3.16 pv = *cs++ * li / tms->cdiv[RED];
583 greg 3.1 *ps++ = pv>255 ? 255 : pv;
584 greg 3.16 pv = *cs++ * li / tms->cdiv[GRN];
585 greg 3.1 *ps++ = pv>255 ? 255 : pv;
586 greg 3.16 pv = *cs++ * li / tms->cdiv[BLU];
587 greg 3.1 *ps++ = pv>255 ? 255 : pv;
588     }
589     }
590     returnOK;
591     }
592
593
594 greg 3.16 TMstruct *
595     tmDup( /* duplicate top tone mapping */
596     TMstruct *tms
597     )
598 greg 3.3 {
599     int len;
600 greg 3.16 int i;
601     TMstruct *tmnew;
602 greg 3.3
603 greg 3.16 if (tms == NULL) /* anything to duplicate? */
604 greg 3.3 return(NULL);
605 greg 3.16 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
606 greg 3.3 if (tmnew == NULL)
607     return(NULL);
608 greg 3.16 *tmnew = *tms; /* copy everything */
609 greg 3.3 if (tmnew->histo != NULL) { /* duplicate histogram */
610 greg 3.31 len = HISTI(tmnew->hbrmax) + 1 - HISTI(tmnew->hbrmin);
611 greg 3.3 tmnew->histo = (int *)malloc(len*sizeof(int));
612     if (tmnew->histo != NULL)
613     for (i = len; i--; )
614 greg 3.16 tmnew->histo[i] = tms->histo[i];
615 greg 3.3 }
616     if (tmnew->lumap != NULL) { /* duplicate luminance mapping */
617 gregl 3.6 len = tmnew->mbrmax-tmnew->mbrmin+1;
618 greg 3.3 tmnew->lumap = (unsigned short *)malloc(
619     len*sizeof(unsigned short) );
620     if (tmnew->lumap != NULL)
621     for (i = len; i--; )
622 greg 3.16 tmnew->lumap[i] = tms->lumap[i];
623 greg 3.3 }
624 greg 3.4 /* clear package data */
625     for (i = tmNumPkgs; i--; )
626     tmnew->pd[i] = NULL;
627 greg 3.16 /* return copy */
628     return(tmnew);
629 greg 3.1 }
630
631
632     void
633     tmDone(tms) /* done with tone mapping -- destroy it */
634 greg 3.16 TMstruct *tms;
635 greg 3.1 {
636 greg 3.16 int i;
637     /* NULL arg. is equiv. to tms */
638     if (tms == NULL)
639 greg 3.1 return;
640     /* free tables */
641     if (tms->histo != NULL)
642 greg 3.4 free((MEM_PTR)tms->histo);
643 greg 3.1 if (tms->lumap != NULL)
644 greg 3.4 free((MEM_PTR)tms->lumap);
645     /* free private data */
646     for (i = tmNumPkgs; i--; )
647     if (tms->pd[i] != NULL)
648     (*tmPkg[i]->Free)(tms->pd[i]);
649     free((MEM_PTR)tms); /* free basic structure */
650 greg 3.9 }
651
652     /******************** Shared but Private library routines *********************/
653
654 greg 3.37 uby8 tmMesofact[BMESUPPER-BMESLOWER];
655 greg 3.9
656     void
657     tmMkMesofact() /* build mesopic lookup factor table */
658     {
659 greg 3.16 int i;
660 greg 3.9
661     if (tmMesofact[BMESUPPER-BMESLOWER-1])
662     return;
663
664     for (i = BMESLOWER; i < BMESUPPER; i++)
665     tmMesofact[i-BMESLOWER] = 256. *
666     (tmLuminance(i) - LMESLOWER) /
667     (LMESUPPER - LMESLOWER);
668     }
669
670
671     int
672 greg 3.33 tmNewMap( /* allocate new tone-mapping array */
673     TMstruct *tms
674     )
675     {
676     if (tms->lumap != NULL && (tms->mbrmax - tms->mbrmin) !=
677     (tms->hbrmax - tms->hbrmin)) {
678     free((MEM_PTR)tms->lumap);
679     tms->lumap = NULL;
680     }
681     tms->mbrmin = tms->hbrmin;
682     tms->mbrmax = tms->hbrmax;
683     if (tms->mbrmin > tms->mbrmax)
684     return 0;
685     if (tms->lumap == NULL)
686     tms->lumap = (unsigned short *)malloc(sizeof(unsigned short)*
687     (tms->mbrmax-tms->mbrmin+1));
688     return(tms->lumap != NULL);
689     }
690
691
692     int
693 greg 3.16 tmErrorReturn( /* error return (with message) */
694 greg 3.17 const char *func,
695 greg 3.16 TMstruct *tms,
696     int err
697     )
698 greg 3.9 {
699 greg 3.17 if (tms != NULL) {
700     tms->lastFunc = func;
701     tms->lastError = err;
702     if (tms->flags & TM_F_NOSTDERR)
703     return(err);
704     }
705 greg 3.9 fputs(func, stderr);
706     fputs(": ", stderr);
707     fputs(tmErrorMessage[err], stderr);
708     fputs("!\n", stderr);
709     return(err);
710 greg 3.1 }
