1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: tonemap.c,v 3.48 2021/04/07 23:12:19 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Tone mapping functions. |
6 |
* See tonemap.h for detailed function descriptions. |
7 |
* Added von Kries white-balance calculations 10/01 (GW). |
8 |
9 |
* Externals declared in tonemap.h |
10 |
11 |
12 |
#include "copyright.h" |
13 |
14 |
#include <stdio.h> |
15 |
#include <stdlib.h> |
16 |
#include <math.h> |
17 |
#include <string.h> |
18 |
#include "tmprivat.h" |
19 |
#include "tmerrmsg.h" |
20 |
21 |
#define exp10(x) exp(M_LN10*(x)) |
22 |
23 |
/* our list of conversion packages */ |
24 |
struct tmPackage *tmPkg[TM_MAXPKG]; |
25 |
int tmNumPkgs = 0; /* number of registered packages */ |
26 |
27 |
/* luminance->brightness lookup */ |
28 |
static TMbright *tmFloat2BrtLUT = NULL; |
29 |
30 |
#define tmCvLumLUfp(pf) tmFloat2BrtLUT[*(int32 *)(pf) >> 15] |
31 |
32 |
33 |
TMstruct * |
34 |
tmInit( /* initialize new tone mapping */ |
35 |
int flags, |
36 |
RGBPRIMP monpri, |
37 |
double gamval |
38 |
39 |
40 |
COLORMAT cmat; |
41 |
TMstruct *tmnew; |
42 |
int i; |
43 |
/* allocate structure */ |
44 |
tmnew = (TMstruct *)malloc(sizeof(TMstruct)); |
45 |
if (tmnew == NULL) |
46 |
return(NULL); |
47 |
48 |
tmnew->flags = flags & ~TM_F_UNIMPL; |
49 |
if (tmnew->flags & TM_F_BW) |
50 |
tmnew->flags &= ~TM_F_MESOPIC; |
51 |
/* set monitor transform */ |
52 |
if (monpri == NULL || monpri == stdprims || tmnew->flags & TM_F_BW) { |
53 |
tmnew->monpri = stdprims; |
54 |
tmnew->clf[RED] = rgb2xyzmat[1][0]; |
55 |
tmnew->clf[GRN] = rgb2xyzmat[1][1]; |
56 |
tmnew->clf[BLU] = rgb2xyzmat[1][2]; |
57 |
} else { |
58 |
comprgb2xyzmat(cmat, tmnew->monpri=monpri); |
59 |
tmnew->clf[RED] = cmat[1][0]; |
60 |
tmnew->clf[GRN] = cmat[1][1]; |
61 |
tmnew->clf[BLU] = cmat[1][2]; |
62 |
63 |
/* set gamma value */ |
64 |
if (gamval < MINGAM) |
65 |
tmnew->mongam = DEFGAM; |
66 |
else |
67 |
tmnew->mongam = gamval; |
68 |
/* set color divisors */ |
69 |
for (i = 0; i < 3; i++) |
70 |
tmnew->cdiv[i] = TM_BRES*pow(tmnew->clf[i], 1./tmnew->mongam); |
71 |
72 |
/* set input transform */ |
73 |
tmnew->inppri = tmnew->monpri; |
74 |
tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] = |
75 |
tmnew->inpsf = WHTEFFICACY; |
76 |
tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] = |
77 |
tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.; |
78 |
tmnew->inpdat = NULL; |
79 |
tmnew->hbrmin = 10; tmnew->hbrmax = -10; |
80 |
tmnew->histo = NULL; |
81 |
tmnew->mbrmin = 10; tmnew->mbrmax = -10; |
82 |
tmnew->lumap = NULL; |
83 |
/* zero private data */ |
84 |
for (i = TM_MAXPKG; i--; ) |
85 |
tmnew->pd[i] = NULL; |
86 |
tmnew->lastError = TM_E_OK; |
87 |
tmnew->lastFunc = "NoErr"; |
88 |
/* return new TMstruct */ |
89 |
return(tmnew); |
90 |
91 |
92 |
93 |
int |
94 |
tmSetSpace( /* set input color space for conversions */ |
95 |
TMstruct *tms, |
96 |
RGBPRIMP pri, |
97 |
double sf, |
98 |
MEM_PTR dat |
99 |
100 |
101 |
static const char funcName[] = "tmSetSpace"; |
102 |
int i, j; |
103 |
/* error check */ |
104 |
if (tms == NULL) |
105 |
returnErr(TM_E_TMINVAL); |
106 |
if (sf <= 1e-12) |
107 |
returnErr(TM_E_ILLEGAL); |
108 |
/* check if no change */ |
109 |
if (pri == tms->inppri && FEQ(sf, tms->inpsf) && dat == tms->inpdat) |
110 |
returnOK; |
111 |
tms->inppri = pri; /* let's set it */ |
112 |
tms->inpsf = sf; |
113 |
tms->inpdat = dat; |
114 |
115 |
if (tms->flags & TM_F_BW) { /* color doesn't matter */ |
116 |
tms->monpri = tms->inppri; /* eliminate xform */ |
117 |
if (tms->inppri == TM_XYZPRIM) { |
118 |
tms->clf[CIEX] = tms->clf[CIEZ] = 0.; |
119 |
tms->clf[CIEY] = 1.; |
120 |
} else { |
121 |
comprgb2xyzmat(tms->cmat, tms->monpri); |
122 |
tms->clf[RED] = tms->cmat[1][0]; |
123 |
tms->clf[GRN] = tms->cmat[1][1]; |
124 |
tms->clf[BLU] = tms->cmat[1][2]; |
125 |
126 |
tms->cmat[0][0] = tms->cmat[1][1] = tms->cmat[2][2] = 1.; |
127 |
tms->cmat[0][1] = tms->cmat[0][2] = tms->cmat[1][0] = |
128 |
tms->cmat[1][2] = tms->cmat[2][0] = tms->cmat[2][1] = 0.; |
129 |
130 |
} else if (tms->inppri == TM_XYZPRIM) { /* input is XYZ */ |
131 |
compxyz2rgbWBmat(tms->cmat, tms->monpri); |
132 |
133 |
} else { /* input is RGB */ |
134 |
if (tms->inppri != tms->monpri && |
135 |
PRIMEQ(tms->inppri, tms->monpri)) |
136 |
tms->inppri = tms->monpri; /* no xform */ |
137 |
if (!comprgb2rgbWBmat(tms->cmat, tms->inppri, tms->monpri)) |
138 |
139 |
140 |
141 |
for (j = 0; j < 3; j++) |
142 |
tms->cmat[i][j] *= tms->inpsf; |
143 |
144 |
145 |
tms->cdiv[i] = TM_BRES*pow(tms->clf[i] < .001 ? .001 : |
146 |
tms->clf[i], 1./tms->mongam); |
147 |
/* notify packages */ |
148 |
for (i = tmNumPkgs; i--; ) |
149 |
if (tms->pd[i] != NULL && tmPkg[i]->NewSpace != NULL) |
150 |
(*tmPkg[i]->NewSpace)(tms); |
151 |
returnOK; |
152 |
153 |
154 |
155 |
void |
156 |
tmClearHisto( /* clear current histogram */ |
157 |
TMstruct *tms |
158 |
159 |
160 |
if (tms == NULL || tms->histo == NULL) |
161 |
return; |
162 |
free(tms->histo); |
163 |
tms->histo = NULL; |
164 |
165 |
166 |
167 |
TMbright |
168 |
tmCvLuminance( /* convert a single luminance */ |
169 |
double lum |
170 |
171 |
172 |
double d; |
173 |
174 |
#ifdef isfinite |
175 |
if (!isfinite(lum) || lum <= TM_NOLUM) |
176 |
#else |
177 |
if (lum <= TM_NOLUM) |
178 |
#endif |
179 |
return(TM_NOBRT); |
180 |
d = TM_BRTSCALE*log(lum); |
181 |
return((TMbright)(d + .5 - (d < 0.))); |
182 |
183 |
184 |
185 |
int |
186 |
tmCvLums( /* convert luminances using lookup */ |
187 |
TMbright *ls, |
188 |
float *scan, |
189 |
int len |
190 |
191 |
192 |
if (tmFloat2BrtLUT == NULL) { /* initialize lookup table */ |
193 |
int32 i; |
194 |
tmFloat2BrtLUT = (TMbright *)malloc(sizeof(TMbright)*0x10000); |
195 |
if (tmFloat2BrtLUT == NULL) |
196 |
return(TM_E_NOMEM); |
197 |
for (i = 0; i < 0x10000; i++) { |
198 |
int32 l = (i<<1 | 1) << 14; |
199 |
#ifndef isfinite |
200 |
if ((l & 0x7f800000) == 0x7f800000) |
201 |
tmFloat2BrtLUT[i] = TM_NOBRT; |
202 |
else |
203 |
#endif |
204 |
tmFloat2BrtLUT[i] = tmCvLuminance(*(float *)&l); |
205 |
206 |
207 |
if (len <= 0) |
208 |
return(TM_E_OK); |
209 |
if ((ls == NULL) | (scan == NULL)) |
210 |
return(TM_E_ILLEGAL); |
211 |
while (len--) { |
212 |
if (*scan <= TM_NOLUM) { |
213 |
*ls++ = TM_NOBRT; |
214 |
++scan; |
215 |
continue; |
216 |
217 |
*ls++ = tmCvLumLUfp(scan++); |
218 |
219 |
return(TM_E_OK); |
220 |
221 |
222 |
223 |
int |
224 |
tmCvGrays( /* convert float gray values */ |
225 |
TMstruct *tms, |
226 |
TMbright *ls, |
227 |
float *scan, |
228 |
int len |
229 |
230 |
231 |
static const char funcName[] = "tmCvGrays"; |
232 |
int i; |
233 |
234 |
if (tms == NULL) |
235 |
236 |
if ((ls == NULL) | (scan == NULL) | (len < 0)) |
237 |
238 |
if (tmFloat2BrtLUT == NULL) /* initialize */ |
239 |
tmCvLums(NULL, NULL, 0); |
240 |
for (i = len; i--; ) { |
241 |
float lum = tms->inpsf * scan[i]; |
242 |
243 |
ls[i] = TM_NOBRT; |
244 |
else |
245 |
ls[i] = tmCvLumLUfp(&lum); |
246 |
247 |
returnOK; |
248 |
249 |
250 |
251 |
int |
252 |
tmCvColors( /* convert float colors */ |
253 |
TMstruct *tms, |
254 |
TMbright *ls, |
255 |
uby8 *cs, |
256 |
COLOR *scan, |
257 |
int len |
258 |
259 |
260 |
static const char funcName[] = "tmCvColors"; |
261 |
static uby8 gamtab[1024]; |
262 |
static double curgam = .0; |
263 |
COLOR cmon; |
264 |
float lum, slum, d; |
265 |
int i; |
266 |
267 |
if (tms == NULL) |
268 |
269 |
270 |
271 |
272 |
273 |
if (cs != TM_NOCHROM && fabs(tms->mongam - curgam) > .02) { |
274 |
curgam = tms->mongam; /* (re)build table */ |
275 |
for (i = 1024; i--; ) |
276 |
gamtab[i] = (int)(256.*pow((i+.5)/1024., 1./curgam)); |
277 |
278 |
279 |
if (tmNeedMatrix(tms)) { /* get monitor RGB */ |
280 |
colortrans(cmon, tms->cmat, scan[i]); |
281 |
} else { |
282 |
cmon[RED] = tms->inpsf*scan[i][RED]; |
283 |
cmon[GRN] = tms->inpsf*scan[i][GRN]; |
284 |
cmon[BLU] = tms->inpsf*scan[i][BLU]; |
285 |
286 |
#ifdef isfinite |
287 |
if (!isfinite(cmon[RED]) || cmon[RED] < .0f) cmon[RED] = .0f; |
288 |
if (!isfinite(cmon[GRN]) || cmon[GRN] < .0f) cmon[GRN] = .0f; |
289 |
if (!isfinite(cmon[BLU]) || cmon[BLU] < .0f) cmon[BLU] = .0f; |
290 |
#else |
291 |
if (cmon[RED] < .0f) cmon[RED] = .0f; |
292 |
if (cmon[GRN] < .0f) cmon[GRN] = .0f; |
293 |
if (cmon[BLU] < .0f) cmon[BLU] = .0f; |
294 |
#endif |
295 |
/* world luminance */ |
296 |
lum = tms->clf[RED]*cmon[RED] + |
297 |
tms->clf[GRN]*cmon[GRN] + |
298 |
tms->clf[BLU]*cmon[BLU] ; |
299 |
if (lum <= TM_NOLUM) { /* convert brightness */ |
300 |
lum = cmon[RED] = cmon[GRN] = cmon[BLU] = TM_NOLUM; |
301 |
ls[i] = TM_NOBRT; |
302 |
} else |
303 |
304 |
if (cs == TM_NOCHROM) /* no color? */ |
305 |
continue; |
306 |
if (tms->flags & TM_F_MESOPIC && lum < LMESUPPER) { |
307 |
slum = scotlum(cmon); /* mesopic adj. */ |
308 |
if (lum < LMESLOWER) { |
309 |
cmon[RED] = cmon[GRN] = cmon[BLU] = slum; |
310 |
} else { |
311 |
d = (lum - LMESLOWER)/(LMESUPPER - LMESLOWER); |
312 |
if (tms->flags & TM_F_BW) |
313 |
cmon[RED] = cmon[GRN] = |
314 |
cmon[BLU] = d*lum; |
315 |
else |
316 |
scalecolor(cmon, d); |
317 |
d = (1.f-d)*slum; |
318 |
cmon[RED] += d; |
319 |
cmon[GRN] += d; |
320 |
cmon[BLU] += d; |
321 |
322 |
} else if (tms->flags & TM_F_BW) { |
323 |
cmon[RED] = cmon[GRN] = cmon[BLU] = lum; |
324 |
325 |
d = tms->clf[RED]*cmon[RED]/lum; |
326 |
cs[3*i ] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)]; |
327 |
d = tms->clf[GRN]*cmon[GRN]/lum; |
328 |
cs[3*i+1] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)]; |
329 |
d = tms->clf[BLU]*cmon[BLU]/lum; |
330 |
cs[3*i+2] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)]; |
331 |
332 |
returnOK; |
333 |
334 |
335 |
336 |
int |
337 |
tmAddHisto( /* add values to histogram */ |
338 |
TMstruct *tms, |
339 |
TMbright *ls, |
340 |
int len, |
341 |
int wt |
342 |
343 |
344 |
static const char funcName[] = "tmAddHisto"; |
345 |
int oldorig=0, oldlen, horig, hlen; |
346 |
int i, j; |
347 |
348 |
if (tms == NULL) |
349 |
350 |
if (len < 0) |
351 |
352 |
if (len == 0) |
353 |
returnOK; |
354 |
/* first, grow limits */ |
355 |
if (tms->histo == NULL) { |
356 |
for (i = len; i-- && ls[i] < MINBRT; ) |
357 |
358 |
if (i < 0) |
359 |
returnOK; |
360 |
tms->hbrmin = tms->hbrmax = ls[i]; |
361 |
oldlen = 0; |
362 |
} else { |
363 |
oldorig = HISTI(tms->hbrmin); |
364 |
oldlen = HISTI(tms->hbrmax) + 1 - oldorig; |
365 |
366 |
367 |
if ((j = ls[i]) < MINBRT) |
368 |
continue; |
369 |
if (j < tms->hbrmin) |
370 |
tms->hbrmin = j; |
371 |
else if (j > tms->hbrmax) |
372 |
tms->hbrmax = j; |
373 |
374 |
horig = HISTI(tms->hbrmin); |
375 |
hlen = HISTI(tms->hbrmax) + 1 - horig; |
376 |
if (hlen > oldlen) { /* (re)allocate histogram */ |
377 |
HIST_TYP *newhist = (HIST_TYP *)calloc(hlen, sizeof(HIST_TYP)); |
378 |
if (newhist == NULL) |
379 |
returnErr(TM_E_NOMEM); |
380 |
if (oldlen) { /* copy and free old */ |
381 |
memcpy(newhist+(oldorig-horig), |
382 |
tms->histo, oldlen*sizeof(HIST_TYP)); |
383 |
free(tms->histo); |
384 |
385 |
tms->histo = newhist; |
386 |
387 |
if (wt == 0) |
388 |
returnOK; |
389 |
for (i = len; i--; ) /* add in new counts */ |
390 |
if (ls[i] >= MINBRT) |
391 |
tms->histo[ HISTI(ls[i]) - horig ] += wt; |
392 |
returnOK; |
393 |
394 |
395 |
396 |
static double |
397 |
htcontrs( /* human threshold contrast sensitivity, dL(La) */ |
398 |
double La |
399 |
400 |
401 |
double l10La, l10dL; |
402 |
/* formula taken from Ferwerda et al. [SG96] */ |
403 |
if (La < 1.148e-4) |
404 |
return(1.38e-3); |
405 |
l10La = log10(La); |
406 |
if (l10La < -1.44) /* rod response regime */ |
407 |
l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86; |
408 |
else if (l10La < -.0184) |
409 |
l10dL = l10La - .395; |
410 |
else if (l10La < 1.9) /* cone response regime */ |
411 |
l10dL = pow(.249*l10La + .65, 2.7) - .72; |
412 |
else |
413 |
l10dL = l10La - 1.255; |
414 |
415 |
return(exp10(l10dL)); |
416 |
417 |
418 |
419 |
int |
420 |
tmFixedMapping( /* compute fixed, linear tone-mapping */ |
421 |
TMstruct *tms, |
422 |
double expmult, |
423 |
double gamval, |
424 |
double Lddyn |
425 |
426 |
427 |
static const char funcName[] = "tmFixedMapping"; |
428 |
const int maxV = (1L<<(8*sizeof(TMAP_TYP))) - 1; |
429 |
double minD; |
430 |
int i; |
431 |
432 |
if (!tmNewMap(tms)) |
433 |
434 |
/* check arguments */ |
435 |
if (expmult <= .0) expmult = 1.; |
436 |
if (gamval < MINGAM) gamval = tms->mongam; |
437 |
if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN; |
438 |
minD = 1./Lddyn; |
439 |
for (i = tms->mbrmax-tms->mbrmin+1; i--; ) { |
440 |
double d; |
441 |
d = expmult/tms->inpsf * tmLuminance(tms->mbrmin + i); |
442 |
if (d >= 2.*minD) |
443 |
d -= minD; |
444 |
else /* soft black crushing */ |
445 |
d *= d/(4.*minD); |
446 |
d /= 1. - minD; |
447 |
d = TM_BRES*pow(d, 1./gamval); |
448 |
tms->lumap[i] = (d > maxV) ? maxV : (int)d; |
449 |
450 |
returnOK; |
451 |
452 |
453 |
454 |
int |
455 |
tmComputeMapping( /* compute histogram tone-mapping */ |
456 |
TMstruct *tms, |
457 |
double gamval, |
458 |
double Lddyn, |
459 |
double Ldmax |
460 |
461 |
462 |
static const char funcName[] = "tmComputeMapping"; |
463 |
HIST_TYP *histo; |
464 |
float *cumf; |
465 |
int brt0, histlen; |
466 |
HIST_TYP threshold, ceiling, trimmings, histot; |
467 |
double logLddyn, Ldmin, Lwavg, Tr, Lw, Ld; |
468 |
double sum; |
469 |
double d; |
470 |
int i, j; |
471 |
472 |
473 |
474 |
475 |
476 |
if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX; |
477 |
478 |
/* compute handy values */ |
479 |
Ldmin = Ldmax/Lddyn; |
480 |
logLddyn = log(Lddyn); |
481 |
i = HISTI(tms->hbrmin); |
482 |
brt0 = HISTV(i); |
483 |
histlen = HISTI(tms->hbrmax) + 1 - i; |
484 |
/* histogram total and mean */ |
485 |
histot = 0; sum = 0; |
486 |
j = brt0 + histlen*HISTEP; |
487 |
for (i = histlen; i--; ) { |
488 |
histot += tms->histo[i]; |
489 |
sum += (double)(j -= HISTEP) * tms->histo[i]; |
490 |
491 |
if (!histot) |
492 |
returnErr(TM_E_TMFAIL); |
493 |
threshold = histot*0.025 + 1.; |
494 |
Lwavg = tmLuminance( (double)sum / histot ); |
495 |
/* use linear tone mapping? */ |
496 |
if (tms->flags & TM_F_LINEAR || threshold < 4 || |
497 |
tms->hbrmax - tms->hbrmin < TM_BRTSCALE*logLddyn) |
498 |
goto linearmap; |
499 |
/* clamp histogram */ |
500 |
histo = (HIST_TYP *)malloc(histlen*sizeof(HIST_TYP)); |
501 |
cumf = (float *)malloc((histlen+2)*sizeof(float)); |
502 |
if ((histo == NULL) | (cumf == NULL)) |
503 |
504 |
cumf[histlen+1] = 1.; /* guard for assignment code */ |
505 |
/* make malleable copy */ |
506 |
memcpy(histo, tms->histo, histlen*sizeof(HIST_TYP)); |
507 |
do { /* iterate to solution */ |
508 |
sum = 0; /* cumulative probability */ |
509 |
for (i = 0; i < histlen; i++) { |
510 |
cumf[i] = sum/histot; |
511 |
sum += (double)histo[i]; |
512 |
513 |
cumf[histlen] = 1.; |
514 |
Tr = histot * (double)(tms->hbrmax - tms->hbrmin) / |
515 |
((double)TM_BRTSCALE*histlen*logLddyn); |
516 |
ceiling = Tr + 1.; |
517 |
trimmings = 0; /* clip to envelope */ |
518 |
519 |
if (tms->flags & TM_F_HCONTR) { |
520 |
Lw = tmLuminance(brt0 + i*HISTEP); |
521 |
Ld = Ldmin * exp( logLddyn * |
522 |
.5*(cumf[i]+cumf[i+1]) ); |
523 |
ceiling = Tr * (htcontrs(Ld) * Lw) / |
524 |
(htcontrs(Lw) * Ld) + 1.; |
525 |
526 |
if (histo[i] > ceiling) { |
527 |
trimmings += histo[i] - ceiling; |
528 |
histo[i] = ceiling; |
529 |
530 |
531 |
/* check if we're out of data */ |
532 |
if ((histot -= trimmings) <= threshold) { |
533 |
free(histo); |
534 |
free(cumf); |
535 |
goto linearmap; |
536 |
537 |
threshold = 0.025*histot + 1.; |
538 |
539 |
} while ((threshold > 4) & (trimmings > threshold)); |
540 |
/* allocate space for mapping */ |
541 |
542 |
543 |
/* assign tone-mapping */ |
544 |
545 |
j = d = (double)i/(tms->mbrmax-tms->mbrmin)*histlen; |
546 |
d -= (double)j; |
547 |
Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1])); |
548 |
d = (Ld - Ldmin)/(Ldmax - Ldmin); |
549 |
tms->lumap[i] = TM_BRES*pow(d, 1./gamval); |
550 |
551 |
free(histo); /* clean up and return */ |
552 |
free(cumf); |
553 |
returnOK; |
554 |
linearmap: /* linear tone-mapping */ |
555 |
if (tms->flags & TM_F_HCONTR) |
556 |
d = htcontrs(sqrt(Ldmax*Ldmin)) / htcontrs(Lwavg); |
557 |
else |
558 |
d = Ldmax / tmLuminance(tms->hbrmax); |
559 |
return(tmFixedMapping(tms, tms->inpsf*d/Ldmax, gamval, Lddyn)); |
560 |
561 |
562 |
563 |
int |
564 |
tmMapPixels( /* apply tone-mapping to pixel(s) */ |
565 |
TMstruct *tms, |
566 |
uby8 *ps, |
567 |
TMbright *ls, |
568 |
uby8 *cs, |
569 |
int len |
570 |
571 |
572 |
static const char funcName[] = "tmMapPixels"; |
573 |
TMbright lv; |
574 |
TMAP_TYP li; |
575 |
int pv; |
576 |
577 |
if (tms == NULL || tms->lumap == NULL) |
578 |
579 |
if ((ps == NULL) | (ls == NULL) | (len < 0)) |
580 |
581 |
while (len--) { |
582 |
if ((lv = *ls++) < tms->mbrmin) { |
583 |
li = 0; |
584 |
} else { |
585 |
if (lv > tms->mbrmax) |
586 |
lv = tms->mbrmax; |
587 |
li = tms->lumap[lv - tms->mbrmin]; |
588 |
589 |
if (cs == TM_NOCHROM) { |
590 |
#if !(TM_BRES & 0xff) |
591 |
*ps++ = li>=TM_BRES ? 255 : li/(TM_BRES>>8); |
592 |
#else |
593 |
*ps++ = li>=TM_BRES ? 255 : (li<<8)/TM_BRES; |
594 |
#endif |
595 |
} else { |
596 |
pv = *cs++ * li / tms->cdiv[RED]; |
597 |
*ps++ = pv>255 ? 255 : pv; |
598 |
pv = *cs++ * li / tms->cdiv[GRN]; |
599 |
600 |
pv = *cs++ * li / tms->cdiv[BLU]; |
601 |
602 |
603 |
604 |
returnOK; |
605 |
606 |
607 |
608 |
TMstruct * |
609 |
tmDup( /* duplicate tone mapping */ |
610 |
TMstruct *tms |
611 |
612 |
613 |
int len; |
614 |
int i; |
615 |
TMstruct *tmnew; |
616 |
617 |
if (tms == NULL) /* anything to duplicate? */ |
618 |
return(NULL); |
619 |
620 |
621 |
return(NULL); |
622 |
*tmnew = *tms; /* copy everything */ |
623 |
if (tmnew->histo != NULL) { /* duplicate histogram */ |
624 |
len = HISTI(tmnew->hbrmax) + 1 - HISTI(tmnew->hbrmin); |
625 |
tmnew->histo = (HIST_TYP *)malloc(len*sizeof(HIST_TYP)); |
626 |
if (tmnew->histo != NULL) |
627 |
memcpy(tmnew->histo, tms->histo, len*sizeof(HIST_TYP)); |
628 |
629 |
if (tmnew->lumap != NULL) { /* duplicate luminance mapping */ |
630 |
len = tmnew->mbrmax-tmnew->mbrmin+1; |
631 |
tmnew->lumap = (TMAP_TYP *)malloc(len*sizeof(TMAP_TYP)); |
632 |
if (tmnew->lumap != NULL) |
633 |
memcpy(tmnew->lumap, tms->lumap, len*sizeof(TMAP_TYP)); |
634 |
635 |
/* clear package data */ |
636 |
637 |
638 |
/* return copy */ |
639 |
return(tmnew); |
640 |
641 |
642 |
643 |
void |
644 |
tmDone(tms) /* done with tone mapping -- destroy it */ |
645 |
TMstruct *tms; |
646 |
647 |
int i; |
648 |
/* NULL arg. is equiv. to tms */ |
649 |
if (tms == NULL) |
650 |
return; |
651 |
/* free tables */ |
652 |
if (tms->histo != NULL) |
653 |
free(tms->histo); |
654 |
if (tms->lumap != NULL) |
655 |
free(tms->lumap); |
656 |
/* free private data */ |
657 |
658 |
if (tms->pd[i] != NULL) |
659 |
(*tmPkg[i]->Free)(tms->pd[i]); |
660 |
free(tms); /* free basic structure */ |
661 |
662 |
663 |
/******************** Shared but Private library routines *********************/ |
664 |
665 |
uby8 tmMesofact[BMESUPPER-BMESLOWER]; |
666 |
667 |
void |
668 |
tmMkMesofact() /* build mesopic lookup factor table */ |
669 |
670 |
int i; |
671 |
672 |
if (tmMesofact[BMESUPPER-BMESLOWER-1]) |
673 |
return; |
674 |
675 |
for (i = BMESLOWER; i < BMESUPPER; i++) |
676 |
tmMesofact[i-BMESLOWER] = 256. * |
677 |
(tmLuminance(i) - LMESLOWER) / |
678 |
679 |
680 |
681 |
682 |
int |
683 |
tmNewMap( /* allocate new tone-mapping array */ |
684 |
TMstruct *tms |
685 |
686 |
687 |
if (tms->lumap != NULL && (tms->mbrmax - tms->mbrmin) != |
688 |
(tms->hbrmax - tms->hbrmin)) { |
689 |
free(tms->lumap); |
690 |
tms->lumap = NULL; |
691 |
692 |
tms->mbrmin = tms->hbrmin; |
693 |
tms->mbrmax = tms->hbrmax; |
694 |
if (tms->mbrmin > tms->mbrmax) |
695 |
return(0); |
696 |
if (tms->lumap == NULL) |
697 |
tms->lumap = (TMAP_TYP *)calloc(tms->mbrmax-tms->mbrmin+1, |
698 |
699 |
else |
700 |
memset(tms->lumap, 0, (tms->mbrmax-tms->mbrmin+1)*sizeof(TMAP_TYP)); |
701 |
702 |
return(tms->lumap != NULL); |
703 |
704 |
705 |
706 |
int |
707 |
tmErrorReturn( /* error return (with message) */ |
708 |
const char *func, |
709 |
TMstruct *tms, |
710 |
int err |
711 |
712 |
713 |
if (tms != NULL) { |
714 |
tms->lastFunc = func; |
715 |
tms->lastError = err; |
716 |
if (tms->flags & TM_F_NOSTDERR) |
717 |
return(err); |
718 |
719 |
fputs(func, stderr); |
720 |
fputs(": ", stderr); |
721 |
fputs(tmErrorMessage[err], stderr); |
722 |
fputs("!\n", stderr); |
723 |
return(err); |
724 |
