root/radiance/ray/src/common/tonemap.c
Revision: 3.36
Committed: Fri Apr 22 14:35:54 2011 UTC (14 years, 1 month ago) by greg
Changes since 3.35: +5 -7 lines
Fixed bug in mapping to extreme monitor spaces
2 static const char RCSid[] = "$Id: tonemap.c,v 3.35 2011/03/07 20:49:19 greg Exp $";
5 * Tone mapping functions.
6 * See tonemap.h for detailed function descriptions.
7 * Added von Kries white-balance calculations 10/01 (GW).
8 *
9 * Externals declared in tonemap.h
10 */
11
12 #include "copyright.h"
13
14 #include <stdio.h>
15 #include <stdlib.h>
16 #include <math.h>
17 #include "tmprivat.h"
18 #include "tmerrmsg.h"
19
20 #define exp10(x) exp(M_LN10*(x))
21
22 /* our list of conversion packages */
23 struct tmPackage *tmPkg[TM_MAXPKG];
24 int tmNumPkgs = 0; /* number of registered packages */
25
26 /* luminance->brightness lookup */
27 static TMbright *tmFloat2BrtLUT = NULL;
28
29 #define tmCvLumLUfp(pf) tmFloat2BrtLUT[*(int32 *)(pf) >> 15]
30
31
32 TMstruct *
33 tmInit( /* initialize new tone mapping */
34 int flags,
35 RGBPRIMP monpri,
36 double gamval
37 )
38 {
39 COLORMAT cmat;
40 TMstruct *tmnew;
41 int i;
42 /* allocate structure */
43 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
44 if (tmnew == NULL)
45 return(NULL);
46
47 tmnew->flags = flags & ~TM_F_UNIMPL;
48 if (tmnew->flags & TM_F_BW)
49 tmnew->flags &= ~TM_F_MESOPIC;
50 /* set monitor transform */
51 if (monpri == NULL || monpri == stdprims || tmnew->flags & TM_F_BW) {
52 tmnew->monpri = stdprims;
53 tmnew->clf[RED] = rgb2xyzmat[1][0];
54 tmnew->clf[GRN] = rgb2xyzmat[1][1];
55 tmnew->clf[BLU] = rgb2xyzmat[1][2];
56 } else {
57 comprgb2xyzmat(cmat, tmnew->monpri=monpri);
58 tmnew->clf[RED] = cmat[1][0];
59 tmnew->clf[GRN] = cmat[1][1];
60 tmnew->clf[BLU] = cmat[1][2];
61 }
62 /* set gamma value */
63 if (gamval < MINGAM)
64 tmnew->mongam = DEFGAM;
65 else
66 tmnew->mongam = gamval;
67 /* set color divisors */
68 for (i = 0; i < 3; i++)
69 tmnew->cdiv[i] = 256.*pow(tmnew->clf[i], 1./tmnew->mongam);
70
71 /* set input transform */
72 tmnew->inppri = tmnew->monpri;
73 tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] =
74 tmnew->inpsf = WHTEFFICACY;
75 tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] =
76 tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.;
77 tmnew->inpdat = NULL;
78 tmnew->hbrmin = 10; tmnew->hbrmax = -10;
79 tmnew->histo = NULL;
80 tmnew->mbrmin = 10; tmnew->mbrmax = -10;
81 tmnew->lumap = NULL;
82 /* zero private data */
83 for (i = TM_MAXPKG; i--; )
84 tmnew->pd[i] = NULL;
85 tmnew->lastError = TM_E_OK;
86 tmnew->lastFunc = "NoErr";
87 /* return new TMstruct */
88 return(tmnew);
89 }
90
91
92 int
93 tmSetSpace( /* set input color space for conversions */
94 TMstruct *tms,
95 RGBPRIMP pri,
96 double sf,
97 MEM_PTR dat
98 )
99 {
100 static const char funcName[] = "tmSetSpace";
101 int i, j;
102 /* error check */
103 if (tms == NULL)
104 returnErr(TM_E_TMINVAL);
105 if (sf <= 1e-12)
106 returnErr(TM_E_ILLEGAL);
107 /* check if no change */
108 if (pri == tms->inppri && FEQ(sf, tms->inpsf) && dat == tms->inpdat)
109 returnOK;
110 tms->inppri = pri; /* let's set it */
111 tms->inpsf = sf;
112 tms->inpdat = dat;
113
114 if (tms->flags & TM_F_BW) { /* color doesn't matter */
115 tms->monpri = tms->inppri; /* eliminate xform */
116 if (tms->inppri == TM_XYZPRIM) {
117 tms->clf[CIEX] = tms->clf[CIEZ] = 0.;
118 tms->clf[CIEY] = 1.;
119 } else {
120 comprgb2xyzmat(tms->cmat, tms->monpri);
121 tms->clf[RED] = tms->cmat[1][0];
122 tms->clf[GRN] = tms->cmat[1][1];
123 tms->clf[BLU] = tms->cmat[1][2];
124 }
125 tms->cmat[0][0] = tms->cmat[1][1] = tms->cmat[2][2] =
126 tms->inpsf;
127 tms->cmat[0][1] = tms->cmat[0][2] = tms->cmat[1][0] =
128 tms->cmat[1][2] = tms->cmat[2][0] = tms->cmat[2][1] = 0.;
129
130 } else if (tms->inppri == TM_XYZPRIM) /* input is XYZ */
131 compxyz2rgbWBmat(tms->cmat, tms->monpri);
132
133 else { /* input is RGB */
134 if (tms->inppri != tms->monpri &&
135 PRIMEQ(tms->inppri, tms->monpri))
136 tms->inppri = tms->monpri; /* no xform */
137 if (!comprgb2rgbWBmat(tms->cmat, tms->inppri, tms->monpri))
138 returnErr(TM_E_ILLEGAL);
139 }
140 for (i = 0; i < 3; i++)
141 for (j = 0; j < 3; j++)
142 tms->cmat[i][j] *= tms->inpsf;
143 /* set color divisors */
144 for (i = 0; i < 3; i++)
145 tms->cdiv[i] = 256.*pow(tms->clf[i] < .001 ? .001 :
146 tms->clf[i], 1./tms->mongam);
147 /* notify packages */
148 for (i = tmNumPkgs; i--; )
149 if (tms->pd[i] != NULL && tmPkg[i]->NewSpace != NULL)
150 (*tmPkg[i]->NewSpace)(tms);
151 returnOK;
152 }
153
154
155 void
156 tmClearHisto( /* clear current histogram */
157 TMstruct *tms
158 )
159 {
160 if (tms == NULL || tms->histo == NULL)
161 return;
162 free((MEM_PTR)tms->histo);
163 tms->histo = NULL;
164 }
165
166
167 TMbright
168 tmCvLuminance( /* convert a single luminance */
169 double lum
170 )
171 {
172 double d;
173
174 #ifdef isfinite
175 if (!isfinite(lum) || lum <= TM_NOLUM)
176 #else
177 if (lum <= TM_NOLUM)
178 #endif
179 return(TM_NOBRT);
180 d = TM_BRTSCALE*log(lum);
181 return((TMbright)(d + .5 - (d < 0.)));
182 }
183
184
185 int
186 tmCvLums( /* convert luminances using lookup */
187 TMbright *ls,
188 float *scan,
189 int len
190 )
191 {
192 if (tmFloat2BrtLUT == NULL) { /* initialize lookup table */
193 int32 i;
194 tmFloat2BrtLUT = (TMbright *)malloc(sizeof(TMbright)*0x10000);
195 if (tmFloat2BrtLUT == NULL)
196 return(TM_E_NOMEM);
197 for (i = 0; i < 0x10000; i++) {
198 int32 l = (i<<1 | 1) << 14;
199 #ifndef isfinite
200 if ((l & 0x7f800000) == 0x7f800000)
201 tmFloat2BrtLUT[i] = TM_NOBRT;
202 else
203 #endif
204 tmFloat2BrtLUT[i] = tmCvLuminance(*(float *)&l);
205 }
206 }
207 if (len <= 0)
208 return(TM_E_OK);
209 if ((ls == NULL) | (scan == NULL))
210 return(TM_E_ILLEGAL);
211 while (len--) {
212 if (*scan <= TM_NOLUM) {
213 *ls++ = TM_NOBRT;
214 ++scan;
215 continue;
216 }
217 *ls++ = tmCvLumLUfp(scan++);
218 }
219 return(TM_E_OK);
220 }
221
222
223 int
224 tmCvGrays( /* convert float gray values */
225 TMstruct *tms,
226 TMbright *ls,
227 float *scan,
228 int len
229 )
230 {
231 static const char funcName[] = "tmCvGrays";
232 int i;
233
234 if (tms == NULL)
235 returnErr(TM_E_TMINVAL);
236 if ((ls == NULL) | (scan == NULL) | (len < 0))
237 returnErr(TM_E_ILLEGAL);
238 if (tmFloat2BrtLUT == NULL) /* initialize */
239 tmCvLums(NULL, NULL, 0);
240 for (i = len; i--; ) {
241 float lum = tms->inpsf * scan[i];
242 if (lum <= TM_NOLUM)
243 ls[i] = TM_NOBRT;
244 else
245 ls[i] = tmCvLumLUfp(&lum);
246 }
247 returnOK;
248 }
249
250
251 int
252 tmCvColors( /* convert float colors */
253 TMstruct *tms,
254 TMbright *ls,
255 BYTE *cs,
256 COLOR *scan,
257 int len
258 )
259 {
260 static const char funcName[] = "tmCvColors";
261 static BYTE gamtab[1024];
262 static double curgam = .0;
263 COLOR cmon;
264 float lum, slum, d;
265 int i;
266
267 if (tms == NULL)
268 returnErr(TM_E_TMINVAL);
269 if ((ls == NULL) | (scan == NULL) | (len < 0))
270 returnErr(TM_E_ILLEGAL);
271 if (tmFloat2BrtLUT == NULL) /* initialize */
272 tmCvLums(NULL, NULL, 0);
273 if (cs != TM_NOCHROM && fabs(tms->mongam - curgam) > .02) {
274 curgam = tms->mongam; /* (re)build table */
275 for (i = 1024; i--; )
276 gamtab[i] = (int)(256.*pow((i+.5)/1024., 1./curgam));
277 }
278 for (i = len; i--; ) {
279 if (tmNeedMatrix(tms)) { /* get monitor RGB */
280 colortrans(cmon, tms->cmat, scan[i]);
281 } else {
282 cmon[RED] = tms->inpsf*scan[i][RED];
283 cmon[GRN] = tms->inpsf*scan[i][GRN];
284 cmon[BLU] = tms->inpsf*scan[i][BLU];
285 }
286 #ifdef isfinite
287 if (!isfinite(cmon[RED]) || cmon[RED] < .0f) cmon[RED] = .0f;
288 if (!isfinite(cmon[GRN]) || cmon[GRN] < .0f) cmon[GRN] = .0f;
289 if (!isfinite(cmon[BLU]) || cmon[BLU] < .0f) cmon[BLU] = .0f;
290 #else
291 if (cmon[RED] < .0f) cmon[RED] = .0f;
292 if (cmon[GRN] < .0f) cmon[GRN] = .0f;
293 if (cmon[BLU] < .0f) cmon[BLU] = .0f;
294 #endif
295 /* world luminance */
296 lum = tms->clf[RED]*cmon[RED] +
297 tms->clf[GRN]*cmon[GRN] +
298 tms->clf[BLU]*cmon[BLU] ;
299 if (lum <= TM_NOLUM) { /* convert brightness */
300 lum = cmon[RED] = cmon[GRN] = cmon[BLU] = TM_NOLUM;
301 ls[i] = TM_NOBRT;
302 } else
303 ls[i] = tmCvLumLUfp(&lum);
304 if (cs == TM_NOCHROM) /* no color? */
305 continue;
306 if (tms->flags & TM_F_MESOPIC && lum < LMESUPPER) {
307 slum = scotlum(cmon); /* mesopic adj. */
308 if (lum < LMESLOWER) {
309 cmon[RED] = cmon[GRN] = cmon[BLU] = slum;
310 } else {
311 d = (lum - LMESLOWER)/(LMESUPPER - LMESLOWER);
312 if (tms->flags & TM_F_BW)
313 cmon[RED] = cmon[GRN] =
314 cmon[BLU] = d*lum;
315 else
316 scalecolor(cmon, d);
317 d = (1.f-d)*slum;
318 cmon[RED] += d;
319 cmon[GRN] += d;
320 cmon[BLU] += d;
321 }
322 } else if (tms->flags & TM_F_BW) {
323 cmon[RED] = cmon[GRN] = cmon[BLU] = lum;
324 }
325 d = tms->clf[RED]*cmon[RED]/lum;
326 cs[3*i ] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
327 d = tms->clf[GRN]*cmon[GRN]/lum;
328 cs[3*i+1] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
329 d = tms->clf[BLU]*cmon[BLU]/lum;
330 cs[3*i+2] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
331 }
332 returnOK;
333 }
334
335
336 int
337 tmAddHisto( /* add values to histogram */
338 TMstruct *tms,
339 TMbright *ls,
340 int len,
341 int wt
342 )
343 {
344 static const char funcName[] = "tmAddHisto";
345 int oldorig=0, oldlen, horig, hlen;
346 int i, j;
347
348 if (tms == NULL)
349 returnErr(TM_E_TMINVAL);
350 if (len < 0)
351 returnErr(TM_E_ILLEGAL);
352 if (len == 0)
353 returnOK;
354 /* first, grow limits */
355 if (tms->histo == NULL) {
356 for (i = len; i-- && ls[i] < MINBRT; )
357 ;
358 if (i < 0)
359 returnOK;
360 tms->hbrmin = tms->hbrmax = ls[i];
361 oldlen = 0;
362 } else {
363 oldorig = HISTI(tms->hbrmin);
364 oldlen = HISTI(tms->hbrmax) + 1 - oldorig;
365 }
366 for (i = len; i--; ) {
367 if ((j = ls[i]) < MINBRT)
368 continue;
369 if (j < tms->hbrmin)
370 tms->hbrmin = j;
371 else if (j > tms->hbrmax)
372 tms->hbrmax = j;
373 }
374 horig = HISTI(tms->hbrmin);
375 hlen = HISTI(tms->hbrmax) + 1 - horig;
376 if (hlen > oldlen) { /* (re)allocate histogram */
377 int *newhist = (int *)calloc(hlen, sizeof(int));
378 if (newhist == NULL)
379 returnErr(TM_E_NOMEM);
380 if (oldlen) { /* copy and free old */
381 for (i = oldlen, j = i+oldorig-horig; i; )
382 newhist[--j] = tms->histo[--i];
383 free((MEM_PTR)tms->histo);
384 }
385 tms->histo = newhist;
386 }
387 if (wt == 0)
388 returnOK;
389 for (i = len; i--; ) /* add in new counts */
390 if (ls[i] >= MINBRT)
391 tms->histo[ HISTI(ls[i]) - horig ] += wt;
392 returnOK;
393 }
394
395
396 static double
397 htcontrs( /* human threshold contrast sensitivity, dL(La) */
398 double La
399 )
400 {
401 double l10La, l10dL;
402 /* formula taken from Ferwerda et al. [SG96] */
403 if (La < 1.148e-4)
404 return(1.38e-3);
405 l10La = log10(La);
406 if (l10La < -1.44) /* rod response regime */
407 l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86;
408 else if (l10La < -.0184)
409 l10dL = l10La - .395;
410 else if (l10La < 1.9) /* cone response regime */
411 l10dL = pow(.249*l10La + .65, 2.7) - .72;
412 else
413 l10dL = l10La - 1.255;
414
415 return(exp10(l10dL));
416 }
417
418
419 int
420 tmFixedMapping( /* compute fixed, linear tone-mapping */
421 TMstruct *tms,
422 double expmult,
423 double gamval
424 )
425 {
426 static const char funcName[] = "tmFixedMapping";
427 double d;
428 int i;
429
430 if (!tmNewMap(tms))
431 returnErr(TM_E_NOMEM);
432 if (expmult <= .0)
433 expmult = 1.;
434 if (gamval < MINGAM)
435 gamval = tms->mongam;
436 d = log(expmult/tms->inpsf);
437 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
438 double val = 256. * exp(
439 ( d + (tms->mbrmin+i)*(1./TM_BRTSCALE) )
440 / gamval);
441 tms->lumap[i] = val >= (double)0xffff ? 0xffff : (int)val;
442 }
443 returnOK;
444 }
445
446
447 int
448 tmComputeMapping( /* compute histogram tone-mapping */
449 TMstruct *tms,
450 double gamval,
451 double Lddyn,
452 double Ldmax
453 )
454 {
455 static const char funcName[] = "tmComputeMapping";
456 int *histo;
457 float *cumf;
458 int brt0, histlen, threshold, ceiling, trimmings;
459 double logLddyn, Ldmin, Ldavg, Lwavg, Tr, Lw, Ld;
460 int32 histot;
461 double sum;
462 double d;
463 int i, j;
464
465 if (tms == NULL || tms->histo == NULL)
466 returnErr(TM_E_TMINVAL);
467 /* check arguments */
468 if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN;
469 if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX;
470 if (gamval < MINGAM) gamval = tms->mongam;
471 /* compute handy values */
472 Ldmin = Ldmax/Lddyn;
473 logLddyn = log(Lddyn);
474 Ldavg = sqrt(Ldmax*Ldmin);
475 i = HISTI(tms->hbrmin);
476 brt0 = HISTV(i);
477 histlen = HISTI(tms->hbrmax) + 1 - i;
478 /* histogram total and mean */
479 histot = 0; sum = 0;
480 j = brt0 + histlen*HISTEP;
481 for (i = histlen; i--; ) {
482 histot += tms->histo[i];
483 sum += (double)(j -= HISTEP) * tms->histo[i];
484 }
485 threshold = histot*0.005 + .5;
486 if (!histot)
487 returnErr(TM_E_TMFAIL);
488 Lwavg = tmLuminance( (double)sum / histot );
489 /* use linear tone mapping? */
490 if (tms->flags & TM_F_LINEAR || threshold < 4 ||
491 tms->hbrmax - tms->hbrmin < TM_BRTSCALE*logLddyn)
492 goto linearmap;
493 /* clamp histogram */
494 histo = (int *)malloc(histlen*sizeof(int));
495 cumf = (float *)malloc((histlen+2)*sizeof(float));
496 if ((histo == NULL) | (cumf == NULL))
497 returnErr(TM_E_NOMEM);
498 cumf[histlen+1] = 1.; /* guard for assignment code */
499 for (i = histlen; i--; ) /* make malleable copy */
500 histo[i] = tms->histo[i];
501 do { /* iterate to solution */
502 sum = 0; /* cumulative probability */
503 for (i = 0; i < histlen; i++) {
504 cumf[i] = (double)sum/histot;
505 sum += histo[i];
506 }
507 cumf[histlen] = 1.;
508 Tr = histot * (double)(tms->hbrmax - tms->hbrmin) /
509 ((double)histlen*TM_BRTSCALE) / logLddyn;
510 ceiling = Tr + 1.;
511 trimmings = 0; /* clip to envelope */
512 for (i = histlen; i--; ) {
513 if (tms->flags & TM_F_HCONTR) {
514 Lw = tmLuminance(brt0 + i*HISTEP);
515 Ld = Ldmin * exp( logLddyn *
516 .5*(cumf[i]+cumf[i+1]) );
517 ceiling = Tr * (htcontrs(Ld) * Lw) /
518 (htcontrs(Lw) * Ld) + 1.;
519 }
520 if (histo[i] > ceiling) {
521 trimmings += histo[i] - ceiling;
522 histo[i] = ceiling;
523 }
524 }
525 /* check if we're out of data */
526 if ((histot -= trimmings) <= threshold) {
527 free((MEM_PTR)histo);
528 free((MEM_PTR)cumf);
529 goto linearmap;
530 }
531 } while (trimmings > threshold);
532 /* allocate space for mapping */
533 if (!tmNewMap(tms))
534 returnErr(TM_E_NOMEM);
535 /* assign tone-mapping */
536 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
537 j = d = (double)i/(tms->mbrmax-tms->mbrmin)*histlen;
538 d -= (double)j;
539 Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1]));
540 d = (Ld - Ldmin)/(Ldmax - Ldmin);
541 tms->lumap[i] = 256.*pow(d, 1./gamval);
542 }
543 free((MEM_PTR)histo); /* clean up and return */
544 free((MEM_PTR)cumf);
545 returnOK;
546 linearmap: /* linear tone-mapping */
547 if (tms->flags & TM_F_HCONTR)
548 d = htcontrs(Ldavg) / htcontrs(Lwavg);
549 else
550 d = Ldavg / Lwavg;
551 return(tmFixedMapping(tms, tms->inpsf*d/Ldmax, gamval));
552 }
553
554
555 int
556 tmMapPixels( /* apply tone-mapping to pixel(s) */
557 TMstruct *tms,
558 BYTE *ps,
559 TMbright *ls,
560 BYTE *cs,
561 int len
562 )
563 {
564 static const char funcName[] = "tmMapPixels";
565 int32 li, pv;
566
567 if (tms == NULL || tms->lumap == NULL)
568 returnErr(TM_E_TMINVAL);
569 if ((ps == NULL) | (ls == NULL) | (len < 0))
570 returnErr(TM_E_ILLEGAL);
571 while (len--) {
572 if ((li = *ls++) < tms->mbrmin) {
573 li = 0;
574 } else {
575 if (li > tms->mbrmax)
576 li = tms->mbrmax;
577 li = tms->lumap[li - tms->mbrmin];
578 }
579 if (cs == TM_NOCHROM)
580 *ps++ = li>255 ? 255 : li;
581 else {
582 pv = *cs++ * li / tms->cdiv[RED];
583 *ps++ = pv>255 ? 255 : pv;
584 pv = *cs++ * li / tms->cdiv[GRN];
585 *ps++ = pv>255 ? 255 : pv;
586 pv = *cs++ * li / tms->cdiv[BLU];
587 *ps++ = pv>255 ? 255 : pv;
588 }
589 }
590 returnOK;
591 }
592
593
594 TMstruct *
595 tmDup( /* duplicate top tone mapping */
596 TMstruct *tms
597 )
598 {
599 int len;
600 int i;
601 TMstruct *tmnew;
602
603 if (tms == NULL) /* anything to duplicate? */
604 return(NULL);
605 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
606 if (tmnew == NULL)
607 return(NULL);
608 *tmnew = *tms; /* copy everything */
609 if (tmnew->histo != NULL) { /* duplicate histogram */
610 len = HISTI(tmnew->hbrmax) + 1 - HISTI(tmnew->hbrmin);
611 tmnew->histo = (int *)malloc(len*sizeof(int));
612 if (tmnew->histo != NULL)
613 for (i = len; i--; )
614 tmnew->histo[i] = tms->histo[i];
615 }
616 if (tmnew->lumap != NULL) { /* duplicate luminance mapping */
617 len = tmnew->mbrmax-tmnew->mbrmin+1;
618 tmnew->lumap = (unsigned short *)malloc(
619 len*sizeof(unsigned short) );
620 if (tmnew->lumap != NULL)
621 for (i = len; i--; )
622 tmnew->lumap[i] = tms->lumap[i];
623 }
624 /* clear package data */
625 for (i = tmNumPkgs; i--; )
626 tmnew->pd[i] = NULL;
627 /* return copy */
628 return(tmnew);
629 }
630
631
632 void
633 tmDone(tms) /* done with tone mapping -- destroy it */
634 TMstruct *tms;
635 {
636 int i;
637 /* NULL arg. is equiv. to tms */
638 if (tms == NULL)
639 return;
640 /* free tables */
641 if (tms->histo != NULL)
642 free((MEM_PTR)tms->histo);
643 if (tms->lumap != NULL)
644 free((MEM_PTR)tms->lumap);
645 /* free private data */
646 for (i = tmNumPkgs; i--; )
647 if (tms->pd[i] != NULL)
648 (*tmPkg[i]->Free)(tms->pd[i]);
649 free((MEM_PTR)tms); /* free basic structure */
650 }
651
652 /******************** Shared but Private library routines *********************/
653
654 BYTE tmMesofact[BMESUPPER-BMESLOWER];
655
656 void
657 tmMkMesofact() /* build mesopic lookup factor table */
658 {
659 int i;
660
661 if (tmMesofact[BMESUPPER-BMESLOWER-1])
662 return;
663
664 for (i = BMESLOWER; i < BMESUPPER; i++)
665 tmMesofact[i-BMESLOWER] = 256. *
666 (tmLuminance(i) - LMESLOWER) /
667 (LMESUPPER - LMESLOWER);
668 }
669
670
671 int
672 tmNewMap( /* allocate new tone-mapping array */
673 TMstruct *tms
674 )
675 {
676 if (tms->lumap != NULL && (tms->mbrmax - tms->mbrmin) !=
677 (tms->hbrmax - tms->hbrmin)) {
678 free((MEM_PTR)tms->lumap);
679 tms->lumap = NULL;
680 }
681 tms->mbrmin = tms->hbrmin;
682 tms->mbrmax = tms->hbrmax;
683 if (tms->mbrmin > tms->mbrmax)
684 return 0;
685 if (tms->lumap == NULL)
686 tms->lumap = (unsigned short *)malloc(sizeof(unsigned short)*
687 (tms->mbrmax-tms->mbrmin+1));
688 return(tms->lumap != NULL);
689 }
690
691
692 int
693 tmErrorReturn( /* error return (with message) */
694 const char *func,
695 TMstruct *tms,
696 int err
697 )
698 {
699 if (tms != NULL) {
700 tms->lastFunc = func;
701 tms->lastError = err;
702 if (tms->flags & TM_F_NOSTDERR)
703 return(err);
704 }
705 fputs(func, stderr);
706 fputs(": ", stderr);
707 fputs(tmErrorMessage[err], stderr);
708 fputs("!\n", stderr);
709 return(err);
710 }
