| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: tonemap.c,v 3.14 2003/09/18 20:18:19 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Tone mapping functions.
| 6 |
* See tonemap.h for detailed function descriptions.
| 7 |
* Added von Kries white-balance calculations 10/01 (GW).
| 8 |
| 9 |
* Externals declared in tonemap.h
| 10 |
| 11 |
| 12 |
#include "copyright.h"
| 13 |
| 14 |
#include <stdio.h>
| 15 |
#include <math.h>
| 16 |
#include "tmprivat.h"
| 17 |
#include "tmerrmsg.h"
| 18 |
| 19 |
#define exp10(x) exp(M_LN10*(x))
| 20 |
| 21 |
struct tmStruct *tmTop = NULL; /* current tone mapping stack */
| 22 |
| 23 |
/* our list of conversion packages */
| 24 |
struct tmPackage *tmPkg[TM_MAXPKG];
| 25 |
int tmNumPkgs = 0; /* number of registered packages */
| 26 |
| 27 |
int tmLastError; /* last error incurred by library */
| 28 |
char *tmLastFunction; /* error-generating function name */
| 29 |
| 30 |
| 31 |
struct tmStruct *
| 32 |
tmInit(flags, monpri, gamval) /* initialize new tone mapping */
| 33 |
int flags;
| 34 |
RGBPRIMP monpri;
| 35 |
double gamval;
| 36 |
| 37 |
COLORMAT cmat;
| 38 |
register struct tmStruct *tmnew;
| 39 |
register int i;
| 40 |
/* allocate structure */
| 41 |
tmnew = (struct tmStruct *)malloc(sizeof(struct tmStruct));
| 42 |
if (tmnew == NULL)
| 43 |
return(NULL);
| 44 |
| 45 |
tmnew->flags = flags & ~TM_F_UNIMPL;
| 46 |
if (tmnew->flags & TM_F_BW)
| 47 |
tmnew->flags &= ~TM_F_MESOPIC;
| 48 |
/* set monitor transform */
| 49 |
if (monpri == NULL || monpri == stdprims || tmnew->flags & TM_F_BW) {
| 50 |
tmnew->monpri = stdprims;
| 51 |
tmnew->clf[RED] = rgb2xyzmat[1][0];
| 52 |
tmnew->clf[GRN] = rgb2xyzmat[1][1];
| 53 |
tmnew->clf[BLU] = rgb2xyzmat[1][2];
| 54 |
} else {
| 55 |
comprgb2xyzWBmat(cmat, tmnew->monpri=monpri);
| 56 |
tmnew->clf[RED] = cmat[1][0];
| 57 |
tmnew->clf[GRN] = cmat[1][1];
| 58 |
tmnew->clf[BLU] = cmat[1][2];
| 59 |
| 60 |
/* set gamma value */
| 61 |
if (gamval < MINGAM)
| 62 |
tmnew->mongam = DEFGAM;
| 63 |
else
| 64 |
tmnew->mongam = gamval;
| 65 |
/* set color divisors */
| 66 |
for (i = 0; i < 3; i++)
| 67 |
tmnew->cdiv[i] = 256.*pow(tmnew->clf[i], 1./tmnew->mongam);
| 68 |
| 69 |
/* set input transform */
| 70 |
tmnew->inppri = tmnew->monpri;
| 71 |
tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] =
| 72 |
tmnew->inpsf = WHTEFFICACY;
| 73 |
tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] =
| 74 |
tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.;
| 75 |
tmnew->hbrmin = 10; tmnew->hbrmax = -10;
| 76 |
tmnew->histo = NULL;
| 77 |
tmnew->mbrmin = 10; tmnew->mbrmax = -10;
| 78 |
tmnew->lumap = NULL;
| 79 |
/* zero private data */
| 80 |
for (i = TM_MAXPKG; i--; )
| 81 |
tmnew->pd[i] = NULL;
| 82 |
/* make tmnew current */
| 83 |
tmnew->tmprev = tmTop;
| 84 |
return(tmTop = tmnew);
| 85 |
| 86 |
| 87 |
| 88 |
int
| 89 |
tmSetSpace(pri, sf) /* set input color space for conversions */
| 90 |
RGBPRIMP pri;
| 91 |
double sf;
| 92 |
| 93 |
static char funcName[] = "tmSetSpace";
| 94 |
register int i, j;
| 95 |
/* error check */
| 96 |
if (tmTop == NULL)
| 97 |
returnErr(TM_E_TMINVAL);
| 98 |
if (sf <= 1e-12)
| 99 |
returnErr(TM_E_ILLEGAL);
| 100 |
/* check if no change */
| 101 |
if (pri == tmTop->inppri && FEQ(sf, tmTop->inpsf))
| 102 |
returnOK;
| 103 |
tmTop->inppri = pri; /* let's set it */
| 104 |
tmTop->inpsf = sf;
| 105 |
| 106 |
if (tmTop->flags & TM_F_BW) { /* color doesn't matter */
| 107 |
tmTop->monpri = tmTop->inppri; /* eliminate xform */
| 108 |
if (tmTop->inppri == TM_XYZPRIM) {
| 109 |
tmTop->clf[CIEX] = tmTop->clf[CIEZ] = 0.;
| 110 |
tmTop->clf[CIEY] = 1.;
| 111 |
} else {
| 112 |
comprgb2xyzWBmat(tmTop->cmat, tmTop->monpri);
| 113 |
tmTop->clf[RED] = tmTop->cmat[1][0];
| 114 |
tmTop->clf[GRN] = tmTop->cmat[1][1];
| 115 |
tmTop->clf[BLU] = tmTop->cmat[1][2];
| 116 |
| 117 |
tmTop->cmat[0][0] = tmTop->cmat[1][1] = tmTop->cmat[2][2] =
| 118 |
tmTop->inpsf;
| 119 |
tmTop->cmat[0][1] = tmTop->cmat[0][2] = tmTop->cmat[1][0] =
| 120 |
tmTop->cmat[1][2] = tmTop->cmat[2][0] = tmTop->cmat[2][1] = 0.;
| 121 |
| 122 |
} else if (tmTop->inppri == TM_XYZPRIM) /* input is XYZ */
| 123 |
compxyz2rgbWBmat(tmTop->cmat, tmTop->monpri);
| 124 |
| 125 |
else { /* input is RGB */
| 126 |
if (tmTop->inppri != tmTop->monpri &&
| 127 |
PRIMEQ(tmTop->inppri, tmTop->monpri))
| 128 |
tmTop->inppri = tmTop->monpri; /* no xform */
| 129 |
comprgb2rgbWBmat(tmTop->cmat, tmTop->inppri, tmTop->monpri);
| 130 |
| 131 |
| 132 |
for (j = 0; j < 3; j++)
| 133 |
tmTop->cmat[i][j] *= tmTop->inpsf;
| 134 |
| 135 |
| 136 |
if (tmTop->clf[i] > .001)
| 137 |
tmTop->cdiv[i] =
| 138 |
256.*pow(tmTop->clf[i], 1./tmTop->mongam);
| 139 |
else
| 140 |
tmTop->cdiv[i] = 1;
| 141 |
/* notify packages */
| 142 |
for (i = tmNumPkgs; i--; )
| 143 |
if (tmTop->pd[i] != NULL && tmPkg[i]->NewSpace != NULL)
| 144 |
(*tmPkg[i]->NewSpace)(tmTop);
| 145 |
returnOK;
| 146 |
| 147 |
| 148 |
| 149 |
void
| 150 |
tmClearHisto() /* clear current histogram */
| 151 |
| 152 |
if (tmTop == NULL || tmTop->histo == NULL)
| 153 |
return;
| 154 |
free((MEM_PTR)tmTop->histo);
| 155 |
tmTop->histo = NULL;
| 156 |
| 157 |
| 158 |
| 159 |
int
| 160 |
tmCvColors(ls, cs, scan, len) /* convert float colors */
| 161 |
TMbright *ls;
| 162 |
BYTE *cs;
| 163 |
COLOR *scan;
| 164 |
int len;
| 165 |
| 166 |
static char funcName[] = "tmCvColors";
| 167 |
static COLOR csmall = {.5*MINLUM, .5*MINLUM, .5*MINLUM};
| 168 |
COLOR cmon;
| 169 |
double lum, slum;
| 170 |
register double d;
| 171 |
register int i;
| 172 |
| 173 |
if (tmTop == NULL)
| 174 |
| 175 |
if ((ls == NULL) | (scan == NULL) | (len < 0))
| 176 |
| 177 |
for (i = len; i--; ) {
| 178 |
if (tmNeedMatrix(tmTop)) { /* get monitor RGB */
| 179 |
colortrans(cmon, tmTop->cmat, scan[i]);
| 180 |
} else {
| 181 |
cmon[RED] = tmTop->inpsf*scan[i][RED];
| 182 |
cmon[GRN] = tmTop->inpsf*scan[i][GRN];
| 183 |
cmon[BLU] = tmTop->inpsf*scan[i][BLU];
| 184 |
| 185 |
/* world luminance */
| 186 |
lum = tmTop->clf[RED]*cmon[RED] +
| 187 |
tmTop->clf[GRN]*cmon[GRN] +
| 188 |
tmTop->clf[BLU]*cmon[BLU] ;
| 189 |
/* check range */
| 190 |
if (clipgamut(cmon, lum, CGAMUT_LOWER, csmall, cwhite))
| 191 |
| 192 |
| 193 |
| 194 |
if (lum < MINLUM) {
| 195 |
ls[i] = MINBRT-1; /* bogus value */
| 196 |
lum = MINLUM;
| 197 |
} else {
| 198 |
d = TM_BRTSCALE*log(lum); /* encode it */
| 199 |
ls[i] = d>0. ? (int)(d+.5) : (int)(d-.5);
| 200 |
| 201 |
if (cs == TM_NOCHROM) /* no color? */
| 202 |
continue;
| 203 |
if (tmTop->flags & TM_F_MESOPIC && lum < LMESUPPER) {
| 204 |
slum = scotlum(cmon); /* mesopic adj. */
| 205 |
if (lum < LMESLOWER)
| 206 |
cmon[RED] = cmon[GRN] = cmon[BLU] = slum;
| 207 |
else {
| 208 |
d = (lum - LMESLOWER)/(LMESUPPER - LMESLOWER);
| 209 |
| 210 |
| 211 |
cmon[BLU] = d*lum;
| 212 |
else
| 213 |
scalecolor(cmon, d);
| 214 |
d = (1.-d)*slum;
| 215 |
cmon[RED] += d;
| 216 |
cmon[GRN] += d;
| 217 |
cmon[BLU] += d;
| 218 |
| 219 |
} else if (tmTop->flags & TM_F_BW) {
| 220 |
cmon[RED] = cmon[GRN] = cmon[BLU] = lum;
| 221 |
| 222 |
d = tmTop->clf[RED]*cmon[RED]/lum;
| 223 |
cs[3*i ] = d>=.999 ? 255 :
| 224 |
(int)(256.*pow(d, 1./tmTop->mongam));
| 225 |
d = tmTop->clf[GRN]*cmon[GRN]/lum;
| 226 |
cs[3*i+1] = d>=.999 ? 255 :
| 227 |
| 228 |
d = tmTop->clf[BLU]*cmon[BLU]/lum;
| 229 |
cs[3*i+2] = d>=.999 ? 255 :
| 230 |
| 231 |
| 232 |
returnOK;
| 233 |
| 234 |
| 235 |
| 236 |
int
| 237 |
tmCvGrays(ls, scan, len) /* convert float gray values */
| 238 |
TMbright *ls;
| 239 |
float *scan;
| 240 |
int len;
| 241 |
| 242 |
static char funcName[] = "tmCvGrays";
| 243 |
register double d;
| 244 |
register int i;
| 245 |
| 246 |
if (tmTop == NULL)
| 247 |
| 248 |
| 249 |
| 250 |
| 251 |
if (scan[i] <= TM_NOLUM) {
| 252 |
ls[i] = TM_NOBRT; /* bogus value */
| 253 |
} else {
| 254 |
d = TM_BRTSCALE*log(scan[i]); /* encode it */
| 255 |
| 256 |
| 257 |
returnOK;
| 258 |
| 259 |
| 260 |
| 261 |
int
| 262 |
tmAddHisto(ls, len, wt) /* add values to histogram */
| 263 |
register TMbright *ls;
| 264 |
int len;
| 265 |
int wt;
| 266 |
| 267 |
static char funcName[] = "tmAddHisto";
| 268 |
int oldorig=0, oldlen, horig, hlen;
| 269 |
register int i, j;
| 270 |
| 271 |
if (tmTop == NULL)
| 272 |
| 273 |
if (len < 0)
| 274 |
| 275 |
if (len == 0)
| 276 |
returnOK;
| 277 |
/* first, grow limits */
| 278 |
if (tmTop->histo == NULL) {
| 279 |
for (i = len; i-- && ls[i] < MINBRT; )
| 280 |
| 281 |
if (i < 0)
| 282 |
returnOK;
| 283 |
tmTop->hbrmin = tmTop->hbrmax = ls[i];
| 284 |
oldlen = 0;
| 285 |
} else {
| 286 |
oldorig = (tmTop->hbrmin-MINBRT)/HISTEP;
| 287 |
oldlen = (tmTop->hbrmax-MINBRT)/HISTEP + 1 - oldorig;
| 288 |
| 289 |
| 290 |
if ((j = ls[i]) < MINBRT)
| 291 |
continue;
| 292 |
if (j < tmTop->hbrmin)
| 293 |
tmTop->hbrmin = j;
| 294 |
else if (j > tmTop->hbrmax)
| 295 |
tmTop->hbrmax = j;
| 296 |
| 297 |
horig = (tmTop->hbrmin-MINBRT)/HISTEP;
| 298 |
hlen = (tmTop->hbrmax-MINBRT)/HISTEP + 1 - horig;
| 299 |
if (hlen > oldlen) { /* (re)allocate histogram */
| 300 |
register int *newhist = (int *)calloc(hlen, sizeof(int));
| 301 |
if (newhist == NULL)
| 302 |
returnErr(TM_E_NOMEM);
| 303 |
if (oldlen) { /* copy and free old */
| 304 |
for (i = oldlen, j = i+oldorig-horig; i; )
| 305 |
newhist[--j] = tmTop->histo[--i];
| 306 |
| 307 |
| 308 |
tmTop->histo = newhist;
| 309 |
| 310 |
if (wt == 0)
| 311 |
returnOK;
| 312 |
for (i = len; i--; ) /* add in new counts */
| 313 |
if (ls[i] >= MINBRT)
| 314 |
tmTop->histo[ (ls[i]-MINBRT)/HISTEP - horig ] += wt;
| 315 |
returnOK;
| 316 |
| 317 |
| 318 |
| 319 |
static double
| 320 |
htcontrs(La) /* human threshold contrast sensitivity, dL(La) */
| 321 |
double La;
| 322 |
| 323 |
double l10La, l10dL;
| 324 |
/* formula taken from Ferwerda et al. [SG96] */
| 325 |
if (La < 1.148e-4)
| 326 |
return(1.38e-3);
| 327 |
l10La = log10(La);
| 328 |
if (l10La < -1.44) /* rod response regime */
| 329 |
l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86;
| 330 |
else if (l10La < -.0184)
| 331 |
l10dL = l10La - .395;
| 332 |
else if (l10La < 1.9) /* cone response regime */
| 333 |
l10dL = pow(.249*l10La + .65, 2.7) - .72;
| 334 |
else
| 335 |
l10dL = l10La - 1.255;
| 336 |
| 337 |
return(exp10(l10dL));
| 338 |
| 339 |
| 340 |
| 341 |
static int
| 342 |
tmNewMap()
| 343 |
| 344 |
if (tmTop->lumap != NULL && (tmTop->mbrmax - tmTop->mbrmin) !=
| 345 |
(tmTop->hbrmax - tmTop->hbrmin)) {
| 346 |
free((MEM_PTR)tmTop->lumap);
| 347 |
tmTop->lumap = NULL;
| 348 |
| 349 |
tmTop->mbrmin = tmTop->hbrmin;
| 350 |
tmTop->mbrmax = tmTop->hbrmax;
| 351 |
if (tmTop->mbrmin > tmTop->mbrmax)
| 352 |
return 0;
| 353 |
if (tmTop->lumap == NULL)
| 354 |
tmTop->lumap = (unsigned short *)malloc(sizeof(unsigned short)*
| 355 |
(tmTop->mbrmax-tmTop->mbrmin+1));
| 356 |
return(tmTop->lumap != NULL);
| 357 |
| 358 |
| 359 |
| 360 |
int
| 361 |
tmFixedMapping(expmult, gamval)
| 362 |
double expmult;
| 363 |
double gamval;
| 364 |
| 365 |
static char funcName[] = "tmFixedMapping";
| 366 |
double d;
| 367 |
register int i;
| 368 |
| 369 |
if (!tmNewMap())
| 370 |
| 371 |
if (expmult <= .0)
| 372 |
expmult = 1.;
| 373 |
| 374 |
gamval = tmTop->mongam;
| 375 |
d = log(expmult/tmTop->inpsf);
| 376 |
for (i = tmTop->mbrmax-tmTop->mbrmin+1; i--; )
| 377 |
tmTop->lumap[i] = 256. * exp(
| 378 |
( d + (tmTop->mbrmin+i)*(1./TM_BRTSCALE) )
| 379 |
/ gamval );
| 380 |
returnOK;
| 381 |
| 382 |
| 383 |
| 384 |
int
| 385 |
tmComputeMapping(gamval, Lddyn, Ldmax)
| 386 |
double gamval;
| 387 |
double Lddyn;
| 388 |
double Ldmax;
| 389 |
| 390 |
static char funcName[] = "tmComputeMapping";
| 391 |
int *histo;
| 392 |
float *cumf;
| 393 |
int brt0, histlen, threshold, ceiling, trimmings;
| 394 |
double logLddyn, Ldmin, Ldavg, Lwavg, Tr, Lw, Ld;
| 395 |
int32 histot;
| 396 |
double sum;
| 397 |
register double d;
| 398 |
register int i, j;
| 399 |
| 400 |
| 401 |
| 402 |
/* check arguments */
| 403 |
if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN;
| 404 |
if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX;
| 405 |
if (gamval < MINGAM) gamval = tmTop->mongam;
| 406 |
/* compute handy values */
| 407 |
Ldmin = Ldmax/Lddyn;
| 408 |
logLddyn = log(Lddyn);
| 409 |
Ldavg = sqrt(Ldmax*Ldmin);
| 410 |
i = (tmTop->hbrmin-MINBRT)/HISTEP;
| 411 |
brt0 = MINBRT + HISTEP/2 + i*HISTEP;
| 412 |
histlen = (tmTop->hbrmax-MINBRT)/HISTEP + 1 - i;
| 413 |
/* histogram total and mean */
| 414 |
histot = 0; sum = 0;
| 415 |
j = brt0 + histlen*HISTEP;
| 416 |
for (i = histlen; i--; ) {
| 417 |
histot += tmTop->histo[i];
| 418 |
sum += (j -= HISTEP) * tmTop->histo[i];
| 419 |
| 420 |
threshold = histot*0.005 + .5;
| 421 |
if (threshold < 4)
| 422 |
returnErr(TM_E_TMFAIL);
| 423 |
Lwavg = tmLuminance( (double)sum / histot );
| 424 |
/* allocate space for mapping */
| 425 |
if (!tmNewMap())
| 426 |
| 427 |
/* use linear tone mapping? */
| 428 |
if (tmTop->flags & TM_F_LINEAR)
| 429 |
goto linearmap;
| 430 |
/* clamp histogram */
| 431 |
histo = (int *)malloc(histlen*sizeof(int));
| 432 |
cumf = (float *)malloc((histlen+2)*sizeof(float));
| 433 |
if ((histo == NULL) | (cumf == NULL))
| 434 |
| 435 |
cumf[histlen+1] = 1.; /* guard for assignment code */
| 436 |
for (i = histlen; i--; ) /* make malleable copy */
| 437 |
histo[i] = tmTop->histo[i];
| 438 |
do { /* iterate to solution */
| 439 |
sum = 0; /* cumulative probability */
| 440 |
for (i = 0; i < histlen; i++) {
| 441 |
cumf[i] = (double)sum/histot;
| 442 |
sum += histo[i];
| 443 |
| 444 |
cumf[histlen] = 1.;
| 445 |
Tr = histot * (double)(tmTop->hbrmax - tmTop->hbrmin) /
| 446 |
((double)histlen*TM_BRTSCALE) / logLddyn;
| 447 |
ceiling = Tr + 1.;
| 448 |
trimmings = 0; /* clip to envelope */
| 449 |
| 450 |
if (tmTop->flags & TM_F_HCONTR) {
| 451 |
Lw = tmLuminance(brt0 + i*HISTEP);
| 452 |
Ld = Ldmin * exp( logLddyn *
| 453 |
.5*(cumf[i]+cumf[i+1]) );
| 454 |
ceiling = Tr * (htcontrs(Ld) * Lw) /
| 455 |
(htcontrs(Lw) * Ld) + 1.;
| 456 |
| 457 |
if (histo[i] > ceiling) {
| 458 |
trimmings += histo[i] - ceiling;
| 459 |
histo[i] = ceiling;
| 460 |
| 461 |
| 462 |
/* check if we're out of data */
| 463 |
if ((histot -= trimmings) <= threshold) {
| 464 |
free((MEM_PTR)histo);
| 465 |
free((MEM_PTR)cumf);
| 466 |
goto linearmap;
| 467 |
| 468 |
} while (trimmings > threshold);
| 469 |
/* assign tone-mapping */
| 470 |
for (i = tmTop->mbrmax-tmTop->mbrmin+1; i--; ) {
| 471 |
j = d = (double)i/(tmTop->mbrmax-tmTop->mbrmin)*histlen;
| 472 |
d -= (double)j;
| 473 |
Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1]));
| 474 |
d = (Ld - Ldmin)/(Ldmax - Ldmin);
| 475 |
tmTop->lumap[i] = 256.*pow(d, 1./gamval);
| 476 |
| 477 |
free((MEM_PTR)histo); /* clean up and return */
| 478 |
| 479 |
returnOK;
| 480 |
linearmap: /* linear tone-mapping */
| 481 |
| 482 |
d = htcontrs(Ldavg) / htcontrs(Lwavg);
| 483 |
else
| 484 |
d = Ldavg / Lwavg;
| 485 |
return(tmFixedMapping(tmTop->inpsf*d/Ldmax, gamval));
| 486 |
| 487 |
| 488 |
| 489 |
int
| 490 |
tmMapPixels(ps, ls, cs, len)
| 491 |
register BYTE *ps;
| 492 |
TMbright *ls;
| 493 |
register BYTE *cs;
| 494 |
int len;
| 495 |
| 496 |
static char funcName[] = "tmMapPixels";
| 497 |
register int32 li, pv;
| 498 |
| 499 |
if (tmTop == NULL || tmTop->lumap == NULL)
| 500 |
| 501 |
if ((ps == NULL) | (ls == NULL) | (len < 0))
| 502 |
| 503 |
while (len--) {
| 504 |
if ((li = *ls++) < tmTop->mbrmin) {
| 505 |
li = 0;
| 506 |
} else {
| 507 |
if (li > tmTop->mbrmax)
| 508 |
li = tmTop->mbrmax;
| 509 |
li = tmTop->lumap[li - tmTop->mbrmin];
| 510 |
| 511 |
| 512 |
*ps++ = li>255 ? 255 : li;
| 513 |
else {
| 514 |
pv = *cs++ * li / tmTop->cdiv[RED];
| 515 |
*ps++ = pv>255 ? 255 : pv;
| 516 |
pv = *cs++ * li / tmTop->cdiv[GRN];
| 517 |
| 518 |
pv = *cs++ * li / tmTop->cdiv[BLU];
| 519 |
| 520 |
| 521 |
| 522 |
returnOK;
| 523 |
| 524 |
| 525 |
| 526 |
struct tmStruct *
| 527 |
tmPop() /* pop top tone mapping off stack */
| 528 |
| 529 |
register struct tmStruct *tms;
| 530 |
| 531 |
if ((tms = tmTop) != NULL)
| 532 |
tmTop = tms->tmprev;
| 533 |
return(tms);
| 534 |
| 535 |
| 536 |
| 537 |
int
| 538 |
tmPull(tms) /* pull a tone mapping from stack */
| 539 |
| 540 |
| 541 |
register struct tmStruct *tms2;
| 542 |
/* special cases first */
| 543 |
if ((tms == NULL) | (tmTop == NULL))
| 544 |
return(0);
| 545 |
if (tms == tmTop) {
| 546 |
| 547 |
tms->tmprev = NULL;
| 548 |
return(1);
| 549 |
| 550 |
for (tms2 = tmTop; tms2->tmprev != NULL; tms2 = tms2->tmprev)
| 551 |
if (tms == tms2->tmprev) { /* remove it */
| 552 |
tms2->tmprev = tms->tmprev;
| 553 |
tms->tmprev = NULL;
| 554 |
return(1);
| 555 |
| 556 |
return(0); /* not found on stack */
| 557 |
| 558 |
| 559 |
| 560 |
struct tmStruct *
| 561 |
tmDup() /* duplicate top tone mapping */
| 562 |
| 563 |
int len;
| 564 |
register int i;
| 565 |
| 566 |
| 567 |
if (tmTop == NULL) /* anything to duplicate? */
| 568 |
return(NULL);
| 569 |
| 570 |
if (tmnew == NULL)
| 571 |
return(NULL);
| 572 |
*tmnew = *tmTop; /* copy everything */
| 573 |
if (tmnew->histo != NULL) { /* duplicate histogram */
| 574 |
len = (tmnew->hbrmax-MINBRT)/HISTEP + 1 -
| 575 |
(tmnew->hbrmin-MINBRT)/HISTEP;
| 576 |
tmnew->histo = (int *)malloc(len*sizeof(int));
| 577 |
| 578 |
| 579 |
tmnew->histo[i] = tmTop->histo[i];
| 580 |
| 581 |
if (tmnew->lumap != NULL) { /* duplicate luminance mapping */
| 582 |
len = tmnew->mbrmax-tmnew->mbrmin+1;
| 583 |
tmnew->lumap = (unsigned short *)malloc(
| 584 |
len*sizeof(unsigned short) );
| 585 |
| 586 |
| 587 |
tmnew->lumap[i] = tmTop->lumap[i];
| 588 |
| 589 |
/* clear package data */
| 590 |
| 591 |
| 592 |
tmnew->tmprev = tmTop; /* make copy current */
| 593 |
| 594 |
| 595 |
| 596 |
| 597 |
int
| 598 |
tmPush(tms) /* push tone mapping on top of stack */
| 599 |
| 600 |
| 601 |
static char funcName[] = "tmPush";
| 602 |
/* check validity */
| 603 |
if (tms == NULL)
| 604 |
| 605 |
if (tms == tmTop) /* check necessity */
| 606 |
returnOK;
| 607 |
/* pull if already in stack */
| 608 |
(void)tmPull(tms);
| 609 |
/* push it on top */
| 610 |
tms->tmprev = tmTop;
| 611 |
tmTop = tms;
| 612 |
returnOK;
| 613 |
| 614 |
| 615 |
| 616 |
void
| 617 |
tmDone(tms) /* done with tone mapping -- destroy it */
| 618 |
| 619 |
| 620 |
register int i;
| 621 |
/* NULL arg. is equiv. to tmTop */
| 622 |
if (tms == NULL && (tms = tmTop) == NULL)
| 623 |
return;
| 624 |
/* take out of stack if present */
| 625 |
(void)tmPull(tms);
| 626 |
/* free tables */
| 627 |
if (tms->histo != NULL)
| 628 |
free((MEM_PTR)tms->histo);
| 629 |
if (tms->lumap != NULL)
| 630 |
free((MEM_PTR)tms->lumap);
| 631 |
/* free private data */
| 632 |
| 633 |
if (tms->pd[i] != NULL)
| 634 |
(*tmPkg[i]->Free)(tms->pd[i]);
| 635 |
free((MEM_PTR)tms); /* free basic structure */
| 636 |
| 637 |
| 638 |
/******************** Shared but Private library routines *********************/
| 639 |
| 640 |
BYTE tmMesofact[BMESUPPER-BMESLOWER];
| 641 |
| 642 |
void
| 643 |
tmMkMesofact() /* build mesopic lookup factor table */
| 644 |
| 645 |
register int i;
| 646 |
| 647 |
if (tmMesofact[BMESUPPER-BMESLOWER-1])
| 648 |
return;
| 649 |
| 650 |
for (i = BMESLOWER; i < BMESUPPER; i++)
| 651 |
tmMesofact[i-BMESLOWER] = 256. *
| 652 |
(tmLuminance(i) - LMESLOWER) /
| 653 |
| 654 |
| 655 |
| 656 |
| 657 |
int
| 658 |
tmErrorReturn(func, err) /* error return (with message) */
| 659 |
char *func;
| 660 |
int err;
| 661 |
| 662 |
tmLastFunction = func;
| 663 |
tmLastError = err;
| 664 |
if (tmTop != NULL && tmTop->flags & TM_F_NOSTDERR)
| 665 |
return(err);
| 666 |
fputs(func, stderr);
| 667 |
fputs(": ", stderr);
| 668 |
fputs(tmErrorMessage[err], stderr);
| 669 |
fputs("!\n", stderr);
| 670 |
return(err);
| 671 |
