root/radiance/ray/src/common/tonemap.c
Revision: 3.53
Committed: Fri Jan 7 23:01:01 2022 UTC (3 years, 6 months ago) by greg
Changes since 3.52: +4 -2 lines
perf: minor performance improvement in grayscale mode to 24-bit output
2 static const char RCSid[] = "$Id: tonemap.c,v 3.52 2021/05/26 17:50:26 greg Exp $";
5 * Tone mapping functions.
6 * See tonemap.h for detailed function descriptions.
7 * Added von Kries white-balance calculations 10/01 (GW).
8 *
9 * Externals declared in tonemap.h
10 */
11
12 #include "copyright.h"
13
14 #include <stdio.h>
15 #include <stdlib.h>
16 #include <math.h>
17 #include <string.h>
18 #include "tmprivat.h"
19 #include "tmerrmsg.h"
20
21 #define exp10(x) exp(M_LN10*(x))
22
23 /* our list of conversion packages */
24 struct tmPackage *tmPkg[TM_MAXPKG];
25 int tmNumPkgs = 0; /* number of registered packages */
26
27 /* luminance->brightness lookup */
28 static TMbright *tmFloat2BrtLUT = NULL;
29
30 #define tmCvLumLUfp(pf) tmFloat2BrtLUT[*(int32 *)(pf) >> 15]
31
32
33 TMstruct *
34 tmInit( /* initialize new tone mapping */
35 int flags,
36 RGBPRIMP monpri,
37 double gamval
38 )
39 {
40 COLORMAT cmat;
41 TMstruct *tmnew;
42 int i;
43 /* allocate structure */
44 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
45 if (tmnew == NULL)
46 return(NULL);
47
48 tmnew->flags = flags & ~TM_F_UNIMPL;
49 if (tmnew->flags & TM_F_BW)
50 tmnew->flags &= ~TM_F_MESOPIC;
51 /* set monitor transform */
52 if (monpri == NULL || monpri == stdprims || tmnew->flags & TM_F_BW) {
53 tmnew->monpri = stdprims;
54 tmnew->clf[RED] = rgb2xyzmat[1][0];
55 tmnew->clf[GRN] = rgb2xyzmat[1][1];
56 tmnew->clf[BLU] = rgb2xyzmat[1][2];
57 } else {
58 comprgb2xyzmat(cmat, tmnew->monpri=monpri);
59 tmnew->clf[RED] = cmat[1][0];
60 tmnew->clf[GRN] = cmat[1][1];
61 tmnew->clf[BLU] = cmat[1][2];
62 }
63 /* set gamma value */
64 if (gamval < MINGAM)
65 tmnew->mongam = DEFGAM;
66 else
67 tmnew->mongam = gamval;
68 /* set color divisors */
69 for (i = 0; i < 3; i++)
70 tmnew->cdiv[i] = TM_BRES*pow(tmnew->clf[i], 1./tmnew->mongam);
71
72 /* set input transform */
73 tmnew->inppri = tmnew->monpri;
74 tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] =
75 tmnew->inpsf = WHTEFFICACY;
76 tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] =
77 tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.;
78 tmnew->inpdat = NULL;
79 tmnew->hbrmin = 10; tmnew->hbrmax = -10;
80 tmnew->histo = NULL;
81 tmnew->mbrmin = 10; tmnew->mbrmax = -10;
82 tmnew->lumap = NULL;
83 /* zero private data */
84 for (i = TM_MAXPKG; i--; )
85 tmnew->pd[i] = NULL;
86 tmnew->lastError = TM_E_OK;
87 tmnew->lastFunc = "NoErr";
88 /* return new TMstruct */
89 return(tmnew);
90 }
91
92
93 int
94 tmSetSpace( /* set input color space for conversions */
95 TMstruct *tms,
96 RGBPRIMP pri,
97 double sf,
98 MEM_PTR dat
99 )
100 {
101 static const char funcName[] = "tmSetSpace";
102 int i, j;
103 /* error check */
104 if (tms == NULL)
105 returnErr(TM_E_TMINVAL);
106 if (sf <= 1e-12)
107 returnErr(TM_E_ILLEGAL);
108 /* check if no change */
109 if (pri == tms->inppri && FEQ(sf, tms->inpsf) && dat == tms->inpdat)
110 returnOK;
111 tms->inppri = pri; /* let's set it */
112 tms->inpsf = sf;
113 tms->inpdat = dat;
114
115 if (tms->flags & TM_F_BW) { /* color doesn't matter */
116 tms->monpri = tms->inppri; /* eliminate xform */
117 if (tms->inppri == TM_XYZPRIM) {
118 tms->clf[CIEX] = tms->clf[CIEZ] = 0.;
119 tms->clf[CIEY] = 1.;
120 } else {
121 comprgb2xyzmat(tms->cmat, tms->monpri);
122 tms->clf[RED] = tms->cmat[1][0];
123 tms->clf[GRN] = tms->cmat[1][1];
124 tms->clf[BLU] = tms->cmat[1][2];
125 }
126 tms->cmat[0][0] = tms->cmat[1][1] = tms->cmat[2][2] = 1.;
127 tms->cmat[0][1] = tms->cmat[0][2] = tms->cmat[1][0] =
128 tms->cmat[1][2] = tms->cmat[2][0] = tms->cmat[2][1] = 0.;
129
130 } else if (tms->inppri == TM_XYZPRIM) { /* input is XYZ */
131 compxyz2rgbWBmat(tms->cmat, tms->monpri);
132
133 } else { /* input is RGB */
134 if (tms->inppri != tms->monpri &&
135 PRIMEQ(tms->inppri, tms->monpri))
136 tms->inppri = tms->monpri; /* no xform */
137 if (!comprgb2rgbWBmat(tms->cmat, tms->inppri, tms->monpri))
138 returnErr(TM_E_ILLEGAL);
139 }
140 for (i = 0; i < 3; i++)
141 for (j = 0; j < 3; j++)
142 tms->cmat[i][j] *= tms->inpsf;
143 /* set color divisors */
144 for (i = 0; i < 3; i++)
145 tms->cdiv[i] = TM_BRES*pow(tms->clf[i] < .001 ? .001 :
146 tms->clf[i], 1./tms->mongam);
147 /* notify packages */
148 for (i = tmNumPkgs; i--; )
149 if (tms->pd[i] != NULL && tmPkg[i]->NewSpace != NULL)
150 (*tmPkg[i]->NewSpace)(tms);
151 returnOK;
152 }
153
154
155 void
156 tmClearHisto( /* clear current histogram */
157 TMstruct *tms
158 )
159 {
160 if (tms == NULL || tms->histo == NULL)
161 return;
162 free(tms->histo);
163 tms->hbrmin = 10; tms->hbrmax = -10;
164 tms->histo = NULL;
165 }
166
167
168 TMbright
169 tmCvLuminance( /* convert a single luminance */
170 double lum
171 )
172 {
173 double d;
174
175 #ifdef isfinite
176 if (!isfinite(lum) || lum <= TM_NOLUM)
177 #else
178 if (lum <= TM_NOLUM)
179 #endif
180 return(TM_NOBRT);
181 d = TM_BRTSCALE*log(lum);
182 return((TMbright)(d + .5 - (d < 0.)));
183 }
184
185
186 int
187 tmCvLums( /* convert luminances using lookup */
188 TMbright *ls,
189 float *scan,
190 int len
191 )
192 {
193 if (tmFloat2BrtLUT == NULL) { /* initialize lookup table */
194 int32 i;
195 tmFloat2BrtLUT = (TMbright *)malloc(sizeof(TMbright)*0x10000);
196 if (tmFloat2BrtLUT == NULL)
197 return(TM_E_NOMEM);
198 for (i = 0; i < 0x10000; i++) {
199 int32 l = (i<<1 | 1) << 14;
200 #ifndef isfinite
201 if ((l & 0x7f800000) == 0x7f800000)
202 tmFloat2BrtLUT[i] = TM_NOBRT;
203 else
204 #endif
205 tmFloat2BrtLUT[i] = tmCvLuminance(*(float *)&l);
206 }
207 }
208 if (len <= 0)
209 return(TM_E_OK);
210 if ((ls == NULL) | (scan == NULL))
211 return(TM_E_ILLEGAL);
212 while (len--) {
213 if (*scan <= TM_NOLUM) {
214 *ls++ = TM_NOBRT;
215 ++scan;
216 continue;
217 }
218 *ls++ = tmCvLumLUfp(scan++);
219 }
220 return(TM_E_OK);
221 }
222
223
224 int
225 tmCvGrays( /* convert float gray values */
226 TMstruct *tms,
227 TMbright *ls,
228 float *scan,
229 int len
230 )
231 {
232 static const char funcName[] = "tmCvGrays";
233 int i;
234
235 if (tms == NULL)
236 returnErr(TM_E_TMINVAL);
237 if ((ls == NULL) | (scan == NULL) | (len < 0))
238 returnErr(TM_E_ILLEGAL);
239 if (tmFloat2BrtLUT == NULL) /* initialize */
240 tmCvLums(NULL, NULL, 0);
241 for (i = len; i--; ) {
242 float lum = tms->inpsf * scan[i];
243 if (lum <= TM_NOLUM)
244 ls[i] = TM_NOBRT;
245 else
246 ls[i] = tmCvLumLUfp(&lum);
247 }
248 returnOK;
249 }
250
251
252 int
253 tmCvColors( /* convert float colors */
254 TMstruct *tms,
255 TMbright *ls,
256 uby8 *cs,
257 COLOR *scan,
258 int len
259 )
260 {
261 static const char funcName[] = "tmCvColors";
262 static uby8 gamtab[1024];
263 static double curgam = .0;
264 COLOR cmon;
265 float lum, slum, d;
266 int i;
267
268 if (tms == NULL)
269 returnErr(TM_E_TMINVAL);
270 if ((ls == NULL) | (scan == NULL) | (len < 0))
271 returnErr(TM_E_ILLEGAL);
272 if (tmFloat2BrtLUT == NULL) /* initialize */
273 tmCvLums(NULL, NULL, 0);
274 if (cs != TM_NOCHROM && fabs(tms->mongam - curgam) > .02) {
275 curgam = tms->mongam; /* (re)build table */
276 for (i = 1024; i--; )
277 gamtab[i] = (int)(256.*pow((i+.5)/1024., 1./curgam));
278 }
279 for (i = len; i--; ) {
280 if (tmNeedMatrix(tms)) { /* get monitor RGB */
281 colortrans(cmon, tms->cmat, scan[i]);
282 } else {
283 cmon[RED] = tms->inpsf*scan[i][RED];
284 cmon[GRN] = tms->inpsf*scan[i][GRN];
285 cmon[BLU] = tms->inpsf*scan[i][BLU];
286 }
287 #ifdef isfinite
288 if (!isfinite(cmon[RED]) || cmon[RED] < .0f) cmon[RED] = .0f;
289 if (!isfinite(cmon[GRN]) || cmon[GRN] < .0f) cmon[GRN] = .0f;
290 if (!isfinite(cmon[BLU]) || cmon[BLU] < .0f) cmon[BLU] = .0f;
291 #else
292 if (cmon[RED] < .0f) cmon[RED] = .0f;
293 if (cmon[GRN] < .0f) cmon[GRN] = .0f;
294 if (cmon[BLU] < .0f) cmon[BLU] = .0f;
295 #endif
296 /* world luminance */
297 lum = tms->clf[RED]*cmon[RED] +
298 tms->clf[GRN]*cmon[GRN] +
299 tms->clf[BLU]*cmon[BLU] ;
300 if (lum <= TM_NOLUM) { /* convert brightness */
301 lum = cmon[RED] = cmon[GRN] = cmon[BLU] = TM_NOLUM;
302 ls[i] = TM_NOBRT;
303 } else
304 ls[i] = tmCvLumLUfp(&lum);
305 if (cs == TM_NOCHROM) /* no color? */
306 continue;
307 if (tms->flags & TM_F_MESOPIC && lum < LMESUPPER) {
308 slum = scotlum(cmon); /* mesopic adj. */
309 if (lum < LMESLOWER) {
310 cmon[RED] = cmon[GRN] = cmon[BLU] = slum;
311 } else {
312 d = (lum - LMESLOWER)/(LMESUPPER - LMESLOWER);
313 if (tms->flags & TM_F_BW)
314 cmon[RED] = cmon[GRN] =
315 cmon[BLU] = d*lum;
316 else
317 scalecolor(cmon, d);
318 d = (1.f-d)*slum;
319 cmon[RED] += d;
320 cmon[GRN] += d;
321 cmon[BLU] += d;
322 }
323 } else if (tms->flags & TM_F_BW) {
324 int j = 3;
325 while (j--) cs[3*i+j] = tms->cdiv[j]/(TM_BRES>>8);
326 continue;
327 }
328 d = tms->clf[RED]*cmon[RED]/lum;
329 cs[3*i ] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
330 d = tms->clf[GRN]*cmon[GRN]/lum;
331 cs[3*i+1] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
332 d = tms->clf[BLU]*cmon[BLU]/lum;
333 cs[3*i+2] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
334 }
335 returnOK;
336 }
337
338
339 int
340 tmAddHisto( /* add values to histogram */
341 TMstruct *tms,
342 TMbright *ls,
343 int len,
344 int wt
345 )
346 {
347 static const char funcName[] = "tmAddHisto";
348 int oldorig=0, oldlen, horig, hlen;
349 int i;
350
351 if (tms == NULL)
352 returnErr(TM_E_TMINVAL);
353 if (len < 0)
354 returnErr(TM_E_ILLEGAL);
355 if (len == 0)
356 returnOK;
357 /* first, grow limits */
358 if (tms->histo == NULL) {
359 for (i = len; i-- && ls[i] < MINBRT; )
360 ;
361 if (i < 0)
362 returnOK;
363 tms->hbrmin = tms->hbrmax = ls[i];
364 oldlen = 0;
365 } else {
366 oldorig = HISTI(tms->hbrmin);
367 oldlen = HISTI(tms->hbrmax) + 1 - oldorig;
368 }
369 for (i = len; i--; ) {
370 if (ls[i] < MINBRT)
371 continue;
372 if (ls[i] < tms->hbrmin)
373 tms->hbrmin = ls[i];
374 else if (ls[i] > tms->hbrmax)
375 tms->hbrmax = ls[i];
376 }
377 horig = HISTI(tms->hbrmin);
378 hlen = HISTI(tms->hbrmax) + 1 - horig;
379 if (hlen > oldlen) { /* (re)allocate histogram */
380 HIST_TYP *newhist = (HIST_TYP *)calloc(hlen, sizeof(HIST_TYP));
381 if (newhist == NULL)
382 returnErr(TM_E_NOMEM);
383 if (oldlen) { /* copy and free old */
384 memcpy(newhist+(oldorig-horig),
385 tms->histo, oldlen*sizeof(HIST_TYP));
386 free(tms->histo);
387 }
388 tms->histo = newhist;
389 }
390 if (wt == 0)
391 returnOK;
392 for (i = len; i--; ) /* add in new counts */
393 if (ls[i] >= MINBRT)
394 tms->histo[ HISTI(ls[i]) - horig ] += wt;
395 returnOK;
396 }
397
398
399 static double
400 htcontrs( /* human threshold contrast sensitivity, dL(La) */
401 double La
402 )
403 {
404 double l10La, l10dL;
405 /* formula taken from Ferwerda et al. [SG96] */
406 if (La < 1.148e-4)
407 return(1.38e-3);
408 l10La = log10(La);
409 if (l10La < -1.44) /* rod response regime */
410 l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86;
411 else if (l10La < -.0184)
412 l10dL = l10La - .395;
413 else if (l10La < 1.9) /* cone response regime */
414 l10dL = pow(.249*l10La + .65, 2.7) - .72;
415 else
416 l10dL = l10La - 1.255;
417
418 return(exp10(l10dL));
419 }
420
421
422 int
423 tmFixedMapping( /* compute fixed, linear tone-mapping */
424 TMstruct *tms,
425 double expmult,
426 double gamval,
427 double Lddyn
428 )
429 {
430 static const char funcName[] = "tmFixedMapping";
431 const int maxV = (1L<<(8*sizeof(TMAP_TYP))) - 1;
432 double minD;
433 int i;
434
435 if (!tmNewMap(tms))
436 returnErr(TM_E_NOMEM);
437 /* check arguments */
438 if (expmult <= .0) expmult = 1.;
439 if (gamval < MINGAM) gamval = tms->mongam;
440 if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN;
441 minD = 1./Lddyn;
442 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
443 double d;
444 d = expmult/tms->inpsf * tmLuminance(tms->mbrmin + i);
445 if (d >= 2.*minD)
446 d -= minD;
447 else /* soft black crushing */
448 d *= d/(4.*minD);
449 d /= 1. - minD;
450 d = TM_BRES*pow(d, 1./gamval);
451 tms->lumap[i] = (d > maxV) ? maxV : (int)d;
452 }
453 returnOK;
454 }
455
456
457 int
458 tmComputeMapping( /* compute histogram tone-mapping */
459 TMstruct *tms,
460 double gamval,
461 double Lddyn,
462 double Ldmax
463 )
464 {
465 static const char funcName[] = "tmComputeMapping";
466 HIST_TYP *histo;
467 float *cumf;
468 int brt0, histlen;
469 HIST_TYP threshold, ceiling, trimmings, histot;
470 double logLddyn, Ldmin, Lwavg, Tr, Lw, Ld;
471 double sum;
472 double d;
473 int i, j;
474
475 if (tms == NULL || tms->histo == NULL)
476 returnErr(TM_E_TMINVAL);
477 /* check arguments */
478 if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN;
479 if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX;
480 if (gamval < MINGAM) gamval = tms->mongam;
481 /* compute handy values */
482 Ldmin = Ldmax/Lddyn;
483 logLddyn = log(Lddyn);
484 i = HISTI(tms->hbrmin);
485 brt0 = HISTV(i);
486 histlen = HISTI(tms->hbrmax) + 1 - i;
487 /* histogram total and mean */
488 histot = 0; sum = 0;
489 j = brt0 + histlen*HISTEP;
490 for (i = histlen; i--; ) {
491 histot += tms->histo[i];
492 sum += (double)(j -= HISTEP) * tms->histo[i];
493 }
494 if (!histot)
495 returnErr(TM_E_TMFAIL);
496 threshold = histot/500 + 1;
497 Lwavg = tmLuminance( (double)sum / histot );
498 /* use linear tone mapping? */
499 if (tms->flags & TM_F_LINEAR ||
500 tms->hbrmax - tms->hbrmin < TM_BRTSCALE*logLddyn)
501 goto linearmap;
502 /* clamp histogram */
503 histo = (HIST_TYP *)malloc(histlen*sizeof(HIST_TYP));
504 cumf = (float *)malloc((histlen+2)*sizeof(float));
505 if ((histo == NULL) | (cumf == NULL))
506 returnErr(TM_E_NOMEM);
507 cumf[histlen+1] = 1.; /* guard for assignment code */
508 /* make malleable copy */
509 memcpy(histo, tms->histo, histlen*sizeof(HIST_TYP));
510 do { /* iterate to solution */
511 sum = 0; /* cumulative probability */
512 for (i = 0; i < histlen; i++) {
513 cumf[i] = sum/histot;
514 sum += (double)histo[i];
515 }
516 cumf[histlen] = 1.;
517 Tr = histot * (double)(tms->hbrmax - tms->hbrmin) /
518 ((double)TM_BRTSCALE*histlen*logLddyn);
519 ceiling = Tr + 1.;
520 trimmings = 0; /* clip to envelope */
521 for (i = histlen; i--; ) {
522 if (tms->flags & TM_F_HCONTR) {
523 Lw = tmLuminance(brt0 + i*HISTEP);
524 Ld = Ldmin * exp( logLddyn *
525 .5*(cumf[i]+cumf[i+1]) );
526 ceiling = Tr * (htcontrs(Ld) * Lw) /
527 (htcontrs(Lw) * Ld) + 1.;
528 }
529 if (histo[i] > ceiling) {
530 trimmings += histo[i] - ceiling;
531 histo[i] = ceiling;
532 }
533 }
534 /* check if we're out of data */
535 if ((histot -= trimmings) <= threshold) {
536 free(histo);
537 free(cumf);
538 goto linearmap;
539 }
540 } while (40*trimmings > histot);
541 /* allocate space for mapping */
542 if (!tmNewMap(tms))
543 returnErr(TM_E_NOMEM);
544 /* assign tone-mapping */
545 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
546 j = d = (double)i/(tms->mbrmax-tms->mbrmin)*histlen;
547 d -= (double)j;
548 Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1]));
549 d = (Ld - Ldmin)/(Ldmax - Ldmin);
550 tms->lumap[i] = TM_BRES*pow(d, 1./gamval);
551 }
552 free(histo); /* clean up and return */
553 free(cumf);
554 returnOK;
555 linearmap: /* linear tone-mapping */
556 if (tms->flags & TM_F_HCONTR)
557 d = htcontrs(sqrt(Ldmax*Ldmin)) / htcontrs(Lwavg);
558 else
559 d = Ldmax / tmLuminance(tms->hbrmax);
560 return(tmFixedMapping(tms, tms->inpsf*d/Ldmax, gamval, Lddyn));
561 }
562
563
564 int
565 tmMapPixels( /* apply tone-mapping to pixel(s) */
566 TMstruct *tms,
567 uby8 *ps,
568 TMbright *ls,
569 uby8 *cs,
570 int len
571 )
572 {
573 static const char funcName[] = "tmMapPixels";
574 TMbright lv;
575 TMAP_TYP li;
576 int pv;
577
578 if (tms == NULL || tms->lumap == NULL)
579 returnErr(TM_E_TMINVAL);
580 if ((ps == NULL) | (ls == NULL) | (len < 0))
581 returnErr(TM_E_ILLEGAL);
582 while (len--) {
583 if ((lv = *ls++) < tms->mbrmin) {
584 li = 0;
585 } else {
586 if (lv > tms->mbrmax)
587 lv = tms->mbrmax;
588 li = tms->lumap[lv - tms->mbrmin];
589 }
590 if (cs == TM_NOCHROM) {
591 #if !(TM_BRES & 0xff)
592 *ps++ = li>=TM_BRES ? 255 : li/(TM_BRES>>8);
593 #else
594 *ps++ = li>=TM_BRES ? 255 : (li<<8)/TM_BRES;
595 #endif
596 } else {
597 pv = *cs++ * li / tms->cdiv[RED];
598 *ps++ = pv>255 ? 255 : pv;
599 pv = *cs++ * li / tms->cdiv[GRN];
600 *ps++ = pv>255 ? 255 : pv;
601 pv = *cs++ * li / tms->cdiv[BLU];
602 *ps++ = pv>255 ? 255 : pv;
603 }
604 }
605 returnOK;
606 }
607
608
609 TMstruct *
610 tmDup( /* duplicate tone mapping */
611 TMstruct *tms
612 )
613 {
614 int len;
615 int i;
616 TMstruct *tmnew;
617
618 if (tms == NULL) /* anything to duplicate? */
619 return(NULL);
620 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
621 if (tmnew == NULL)
622 return(NULL);
623 *tmnew = *tms; /* copy everything */
624 if (tmnew->histo != NULL) { /* duplicate histogram */
625 len = HISTI(tmnew->hbrmax) + 1 - HISTI(tmnew->hbrmin);
626 tmnew->histo = (HIST_TYP *)malloc(len*sizeof(HIST_TYP));
627 if (tmnew->histo != NULL)
628 memcpy(tmnew->histo, tms->histo, len*sizeof(HIST_TYP));
629 }
630 if (tmnew->lumap != NULL) { /* duplicate luminance mapping */
631 len = tmnew->mbrmax-tmnew->mbrmin+1;
632 tmnew->lumap = (TMAP_TYP *)malloc(len*sizeof(TMAP_TYP));
633 if (tmnew->lumap != NULL)
634 memcpy(tmnew->lumap, tms->lumap, len*sizeof(TMAP_TYP));
635 }
636 /* clear package data */
637 for (i = tmNumPkgs; i--; )
638 tmnew->pd[i] = NULL;
639 /* return copy */
640 return(tmnew);
641 }
642
643
644 void
645 tmDone(tms) /* done with tone mapping -- destroy it */
646 TMstruct *tms;
647 {
648 int i;
649 /* NULL arg. is equiv. to tms */
650 if (tms == NULL)
651 return;
652 /* free tables */
653 if (tms->histo != NULL)
654 free(tms->histo);
655 if (tms->lumap != NULL)
656 free(tms->lumap);
657 /* free private data */
658 for (i = tmNumPkgs; i--; )
659 if (tms->pd[i] != NULL)
660 (*tmPkg[i]->Free)(tms->pd[i]);
661 free(tms); /* free basic structure */
662 }
663
664 /******************** Shared but Private library routines *********************/
665
666 uby8 tmMesofact[BMESUPPER-BMESLOWER];
667
668 void
669 tmMkMesofact() /* build mesopic lookup factor table */
670 {
671 int i;
672
673 if (tmMesofact[BMESUPPER-BMESLOWER-1])
674 return;
675
676 for (i = BMESLOWER; i < BMESUPPER; i++)
677 tmMesofact[i-BMESLOWER] = 256. *
678 (tmLuminance(i) - LMESLOWER) /
679 (LMESUPPER - LMESLOWER);
680 }
681
682
683 int
684 tmNewMap( /* allocate new tone-mapping array */
685 TMstruct *tms
686 )
687 {
688 if (tms->lumap != NULL && (tms->mbrmax - tms->mbrmin) !=
689 (tms->hbrmax - tms->hbrmin)) {
690 free(tms->lumap);
691 tms->lumap = NULL;
692 }
693 tms->mbrmin = tms->hbrmin;
694 tms->mbrmax = tms->hbrmax;
695 if (tms->mbrmin > tms->mbrmax)
696 return(0);
697 if (tms->lumap == NULL)
698 tms->lumap = (TMAP_TYP *)calloc(tms->mbrmax-tms->mbrmin+1,
699 sizeof(TMAP_TYP));
700 else
701 memset(tms->lumap, 0, (tms->mbrmax-tms->mbrmin+1)*sizeof(TMAP_TYP));
702
703 return(tms->lumap != NULL);
704 }
705
706
707 int
708 tmErrorReturn( /* error return (with message) */
709 const char *func,
710 TMstruct *tms,
711 int err
712 )
713 {
714 if (tms != NULL) {
715 tms->lastFunc = func;
716 tms->lastError = err;
717 if (tms->flags & TM_F_NOSTDERR)
718 return(err);
719 }
720 fputs(func, stderr);
721 fputs(": ", stderr);
722 fputs(tmErrorMessage[err], stderr);
723 fputs("!\n", stderr);
724 return(err);
725 }
