root/radiance/ray/src/common/tonemap.c
Revision: 3.24
Committed: Wed May 10 15:34:17 2006 UTC (19 years, 3 months ago) by greg
Changes since 3.23: +6 -3 lines
Minor fixes to last change with IEEE float lookup function
2 static const char RCSid[] = "$Id: tonemap.c,v 3.23 2006/05/10 15:21:58 greg Exp $";
5 * Tone mapping functions.
6 * See tonemap.h for detailed function descriptions.
7 * Added von Kries white-balance calculations 10/01 (GW).
8 *
9 * Externals declared in tonemap.h
10 */
11
12 #include "copyright.h"
13
14 #include <stdio.h>
15 #include <math.h>
16 #include "tmprivat.h"
17 #include "tmerrmsg.h"
18
19 #define exp10(x) exp(M_LN10*(x))
20
21 /* our list of conversion packages */
22 struct tmPackage *tmPkg[TM_MAXPKG];
23 int tmNumPkgs = 0; /* number of registered packages */
24
25 /* luminance->brightness lookup */
26 static TMbright *tmFloat2BrtLUT = NULL;
27
28 #define tmCvLumLUfp(pf) tmFloat2BrtLUT[*(int32 *)(pf) >> 15]
29
30
31 TMstruct *
32 tmInit( /* initialize new tone mapping */
33 int flags,
34 RGBPRIMP monpri,
35 double gamval
36 )
37 {
38 COLORMAT cmat;
39 TMstruct *tmnew;
40 int i;
41 /* allocate structure */
42 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
43 if (tmnew == NULL)
44 return(NULL);
45
46 tmnew->flags = flags & ~TM_F_UNIMPL;
47 if (tmnew->flags & TM_F_BW)
48 tmnew->flags &= ~TM_F_MESOPIC;
49 /* set monitor transform */
50 if (monpri == NULL || monpri == stdprims || tmnew->flags & TM_F_BW) {
51 tmnew->monpri = stdprims;
52 tmnew->clf[RED] = rgb2xyzmat[1][0];
53 tmnew->clf[GRN] = rgb2xyzmat[1][1];
54 tmnew->clf[BLU] = rgb2xyzmat[1][2];
55 } else {
56 comprgb2xyzWBmat(cmat, tmnew->monpri=monpri);
57 tmnew->clf[RED] = cmat[1][0];
58 tmnew->clf[GRN] = cmat[1][1];
59 tmnew->clf[BLU] = cmat[1][2];
60 }
61 /* set gamma value */
62 if (gamval < MINGAM)
63 tmnew->mongam = DEFGAM;
64 else
65 tmnew->mongam = gamval;
66 /* set color divisors */
67 for (i = 0; i < 3; i++)
68 tmnew->cdiv[i] = 256.*pow(tmnew->clf[i], 1./tmnew->mongam);
69
70 /* set input transform */
71 tmnew->inppri = tmnew->monpri;
72 tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] =
73 tmnew->inpsf = WHTEFFICACY;
74 tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] =
75 tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.;
76 tmnew->inpdat = NULL;
77 tmnew->hbrmin = 10; tmnew->hbrmax = -10;
78 tmnew->histo = NULL;
79 tmnew->mbrmin = 10; tmnew->mbrmax = -10;
80 tmnew->lumap = NULL;
81 /* zero private data */
82 for (i = TM_MAXPKG; i--; )
83 tmnew->pd[i] = NULL;
84 tmnew->lastError = TM_E_OK;
85 tmnew->lastFunc = "NoErr";
86 /* return new TMstruct */
87 return(tmnew);
88 }
89
90
91 int
92 tmSetSpace( /* set input color space for conversions */
93 TMstruct *tms,
94 RGBPRIMP pri,
95 double sf,
96 MEM_PTR dat
97 )
98 {
99 static const char funcName[] = "tmSetSpace";
100 int i, j;
101 /* error check */
102 if (tms == NULL)
103 returnErr(TM_E_TMINVAL);
104 if (sf <= 1e-12)
105 returnErr(TM_E_ILLEGAL);
106 /* check if no change */
107 if (pri == tms->inppri && FEQ(sf, tms->inpsf) && dat == tms->inpdat)
108 returnOK;
109 tms->inppri = pri; /* let's set it */
110 tms->inpsf = sf;
111 tms->inpdat = dat;
112
113 if (tms->flags & TM_F_BW) { /* color doesn't matter */
114 tms->monpri = tms->inppri; /* eliminate xform */
115 if (tms->inppri == TM_XYZPRIM) {
116 tms->clf[CIEX] = tms->clf[CIEZ] = 0.;
117 tms->clf[CIEY] = 1.;
118 } else {
119 comprgb2xyzWBmat(tms->cmat, tms->monpri);
120 tms->clf[RED] = tms->cmat[1][0];
121 tms->clf[GRN] = tms->cmat[1][1];
122 tms->clf[BLU] = tms->cmat[1][2];
123 }
124 tms->cmat[0][0] = tms->cmat[1][1] = tms->cmat[2][2] =
125 tms->inpsf;
126 tms->cmat[0][1] = tms->cmat[0][2] = tms->cmat[1][0] =
127 tms->cmat[1][2] = tms->cmat[2][0] = tms->cmat[2][1] = 0.;
128
129 } else if (tms->inppri == TM_XYZPRIM) /* input is XYZ */
130 compxyz2rgbWBmat(tms->cmat, tms->monpri);
131
132 else { /* input is RGB */
133 if (tms->inppri != tms->monpri &&
134 PRIMEQ(tms->inppri, tms->monpri))
135 tms->inppri = tms->monpri; /* no xform */
136 comprgb2rgbWBmat(tms->cmat, tms->inppri, tms->monpri);
137 }
138 for (i = 0; i < 3; i++)
139 for (j = 0; j < 3; j++)
140 tms->cmat[i][j] *= tms->inpsf;
141 /* set color divisors */
142 for (i = 0; i < 3; i++)
143 if (tms->clf[i] > .001)
144 tms->cdiv[i] =
145 256.*pow(tms->clf[i], 1./tms->mongam);
146 else
147 tms->cdiv[i] = 1;
148 /* notify packages */
149 for (i = tmNumPkgs; i--; )
150 if (tms->pd[i] != NULL && tmPkg[i]->NewSpace != NULL)
151 (*tmPkg[i]->NewSpace)(tms);
152 returnOK;
153 }
154
155
156 void
157 tmClearHisto( /* clear current histogram */
158 TMstruct *tms
159 )
160 {
161 if (tms == NULL || tms->histo == NULL)
162 return;
163 free((MEM_PTR)tms->histo);
164 tms->histo = NULL;
165 }
166
167
168 TMbright
169 tmCvLuminance( /* convert a single luminance */
170 double lum
171 )
172 {
173 double d;
174
175 #ifdef isfinite
176 if (!isfinite(lum) || lum <= TM_NOLUM)
177 #else
178 if (lum <= TM_NOLUM)
179 #endif
180 return(TM_NOBRT);
181 d = TM_BRTSCALE*log(lum);
182 if (d > 0.)
183 return((TMbright)(d+.5));
184 return((TMbright)(d-.5));
185 }
186
187
188 int
189 tmCvLums( /* convert luminances using lookup */
190 TMbright *ls,
191 float *scan,
192 int len
193 )
194 {
195 if (tmFloat2BrtLUT == NULL) { /* initialize lookup table */
196 int32 i;
197 tmFloat2BrtLUT = (TMbright *)malloc(sizeof(TMbright)*0x10000);
198 if (tmFloat2BrtLUT == NULL)
199 return(TM_E_NOMEM);
200 for (i = 0; i < 0x10000; i++) {
201 int32 l = (i<<1 | 1) << 14;
202 #ifndef isfinite
203 if ((l & 0x7f800000) == 0x7f800000)
204 tmFloat2BrtLUT[i] = TM_NOBRT;
205 else
206 #endif
207 tmFloat2BrtLUT[i] = tmCvLuminance(*(float *)&l);
208 }
209 }
210 if (len <= 0)
211 return(TM_E_OK);
212 if ((ls == NULL) | (scan == NULL))
213 return(TM_E_ILLEGAL);
214 while (len--) {
215 if (*scan <= TM_NOLUM) {
216 *ls++ = TM_NOBRT;
217 ++scan;
218 continue;
219 }
220 *ls++ = tmCvLumLUfp(scan++);
221 }
222 return(TM_E_OK);
223 }
224
225
226 int
227 tmCvGrays( /* convert float gray values */
228 TMstruct *tms,
229 TMbright *ls,
230 float *scan,
231 int len
232 )
233 {
234 static const char funcName[] = "tmCvGrays";
235 double d;
236 int i;
237
238 if (tms == NULL)
239 returnErr(TM_E_TMINVAL);
240 if ((ls == NULL) | (scan == NULL) | (len < 0))
241 returnErr(TM_E_ILLEGAL);
242 if (tmFloat2BrtLUT == NULL) /* initialize */
243 tmCvLums(NULL, NULL, 0);
244 for (i = len; i--; ) {
245 float lum = tms->inpsf * scan[i];
246 if (lum <= TM_NOLUM)
247 ls[i] = TM_NOBRT;
248 else
249 ls[i] = tmCvLumLUfp(&lum);
250 }
251 returnOK;
252 }
253
254
255 int
256 tmCvColors( /* convert float colors */
257 TMstruct *tms,
258 TMbright *ls,
259 BYTE *cs,
260 COLOR *scan,
261 int len
262 )
263 {
264 static const char funcName[] = "tmCvColors";
265 static COLOR csmall = {.5*MINLUM, .5*MINLUM, .5*MINLUM};
266 static BYTE gamtab[1024];
267 static double curgam = .0;
268 COLOR cmon;
269 float lum, slum, d;
270 int i;
271
272 if (tms == NULL)
273 returnErr(TM_E_TMINVAL);
274 if ((ls == NULL) | (scan == NULL) | (len < 0))
275 returnErr(TM_E_ILLEGAL);
276 if (tmFloat2BrtLUT == NULL) /* initialize */
277 tmCvLums(NULL, NULL, 0);
278 if (cs != TM_NOCHROM && fabs(tms->mongam - curgam) > .02) {
279 curgam = tms->mongam; /* (re)build table */
280 for (i = 1024; i--; )
281 gamtab[i] = (int)(256.*pow((i+.5)/1024., 1./curgam));
282 }
283 for (i = len; i--; ) {
284 if (tmNeedMatrix(tms)) { /* get monitor RGB */
285 colortrans(cmon, tms->cmat, scan[i]);
286 } else {
287 cmon[RED] = tms->inpsf*scan[i][RED];
288 cmon[GRN] = tms->inpsf*scan[i][GRN];
289 cmon[BLU] = tms->inpsf*scan[i][BLU];
290 }
291 #ifdef isfinite
292 if (!isfinite(cmon[RED]) || cmon[RED] < .0f) cmon[RED] = .0f;
293 if (!isfinite(cmon[GRN]) || cmon[GRN] < .0f) cmon[GRN] = .0f;
294 if (!isfinite(cmon[BLU]) || cmon[BLU] < .0f) cmon[BLU] = .0f;
295 #else
296 if (cmon[RED] < .0f) cmon[RED] = .0f;
297 if (cmon[GRN] < .0f) cmon[GRN] = .0f;
298 if (cmon[BLU] < .0f) cmon[BLU] = .0f;
299 #endif
300 /* world luminance */
301 lum = tms->clf[RED]*cmon[RED] +
302 tms->clf[GRN]*cmon[GRN] +
303 tms->clf[BLU]*cmon[BLU] ;
304 if (lum <= TM_NOLUM) /* convert brightness */
305 ls[i] = TM_NOBRT;
306 else
307 ls[i] = tmCvLumLUfp(&lum);
308 if (cs == TM_NOCHROM) /* no color? */
309 continue;
310 if (tms->flags & TM_F_MESOPIC && lum < LMESUPPER) {
311 slum = scotlum(cmon); /* mesopic adj. */
312 if (lum < LMESLOWER)
313 cmon[RED] = cmon[GRN] = cmon[BLU] = slum;
314 else {
315 d = (lum - LMESLOWER)/(LMESUPPER - LMESLOWER);
316 if (tms->flags & TM_F_BW)
317 cmon[RED] = cmon[GRN] =
318 cmon[BLU] = d*lum;
319 else
320 scalecolor(cmon, d);
321 d = (1.f-d)*slum;
322 cmon[RED] += d;
323 cmon[GRN] += d;
324 cmon[BLU] += d;
325 }
326 } else if (tms->flags & TM_F_BW) {
327 cmon[RED] = cmon[GRN] = cmon[BLU] = lum;
328 }
329 d = tms->clf[RED]*cmon[RED]/lum;
330 cs[3*i ] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
331 d = tms->clf[GRN]*cmon[GRN]/lum;
332 cs[3*i+1] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
333 d = tms->clf[BLU]*cmon[BLU]/lum;
334 cs[3*i+2] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
335 }
336 returnOK;
337 }
338
339
340 int
341 tmAddHisto( /* add values to histogram */
342 TMstruct *tms,
343 TMbright *ls,
344 int len,
345 int wt
346 )
347 {
348 static const char funcName[] = "tmAddHisto";
349 int oldorig=0, oldlen, horig, hlen;
350 int i, j;
351
352 if (tms == NULL)
353 returnErr(TM_E_TMINVAL);
354 if (len < 0)
355 returnErr(TM_E_ILLEGAL);
356 if (len == 0)
357 returnOK;
358 /* first, grow limits */
359 if (tms->histo == NULL) {
360 for (i = len; i-- && ls[i] < MINBRT; )
361 ;
362 if (i < 0)
363 returnOK;
364 tms->hbrmin = tms->hbrmax = ls[i];
365 oldlen = 0;
366 } else {
367 oldorig = (tms->hbrmin-MINBRT)/HISTEP;
368 oldlen = (tms->hbrmax-MINBRT)/HISTEP + 1 - oldorig;
369 }
370 for (i = len; i--; ) {
371 if ((j = ls[i]) < MINBRT)
372 continue;
373 if (j < tms->hbrmin)
374 tms->hbrmin = j;
375 else if (j > tms->hbrmax)
376 tms->hbrmax = j;
377 }
378 horig = (tms->hbrmin-MINBRT)/HISTEP;
379 hlen = (tms->hbrmax-MINBRT)/HISTEP + 1 - horig;
380 if (hlen > oldlen) { /* (re)allocate histogram */
381 int *newhist = (int *)calloc(hlen, sizeof(int));
382 if (newhist == NULL)
383 returnErr(TM_E_NOMEM);
384 if (oldlen) { /* copy and free old */
385 for (i = oldlen, j = i+oldorig-horig; i; )
386 newhist[--j] = tms->histo[--i];
387 free((MEM_PTR)tms->histo);
388 }
389 tms->histo = newhist;
390 }
391 if (wt == 0)
392 returnOK;
393 for (i = len; i--; ) /* add in new counts */
394 if (ls[i] >= MINBRT)
395 tms->histo[ (ls[i]-MINBRT)/HISTEP - horig ] += wt;
396 returnOK;
397 }
398
399
400 static double
401 htcontrs( /* human threshold contrast sensitivity, dL(La) */
402 double La
403 )
404 {
405 double l10La, l10dL;
406 /* formula taken from Ferwerda et al. [SG96] */
407 if (La < 1.148e-4)
408 return(1.38e-3);
409 l10La = log10(La);
410 if (l10La < -1.44) /* rod response regime */
411 l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86;
412 else if (l10La < -.0184)
413 l10dL = l10La - .395;
414 else if (l10La < 1.9) /* cone response regime */
415 l10dL = pow(.249*l10La + .65, 2.7) - .72;
416 else
417 l10dL = l10La - 1.255;
418
419 return(exp10(l10dL));
420 }
421
422
423 static int
424 tmNewMap( /* allocate new tone-mapping array */
425 TMstruct *tms
426 )
427 {
428 if (tms->lumap != NULL && (tms->mbrmax - tms->mbrmin) !=
429 (tms->hbrmax - tms->hbrmin)) {
430 free((MEM_PTR)tms->lumap);
431 tms->lumap = NULL;
432 }
433 tms->mbrmin = tms->hbrmin;
434 tms->mbrmax = tms->hbrmax;
435 if (tms->mbrmin > tms->mbrmax)
436 return 0;
437 if (tms->lumap == NULL)
438 tms->lumap = (unsigned short *)malloc(sizeof(unsigned short)*
439 (tms->mbrmax-tms->mbrmin+1));
440 return(tms->lumap != NULL);
441 }
442
443
444 int
445 tmFixedMapping( /* compute fixed, linear tone-mapping */
446 TMstruct *tms,
447 double expmult,
448 double gamval
449 )
450 {
451 static const char funcName[] = "tmFixedMapping";
452 double d;
453 int i;
454
455 if (!tmNewMap(tms))
456 returnErr(TM_E_NOMEM);
457 if (expmult <= .0)
458 expmult = 1.;
459 if (gamval < MINGAM)
460 gamval = tms->mongam;
461 d = log(expmult/tms->inpsf);
462 for (i = tms->mbrmax-tms->mbrmin+1; i--; )
463 tms->lumap[i] = 256. * exp(
464 ( d + (tms->mbrmin+i)*(1./TM_BRTSCALE) )
465 / gamval );
466 returnOK;
467 }
468
469
470 int
471 tmComputeMapping( /* compute histogram tone-mapping */
472 TMstruct *tms,
473 double gamval,
474 double Lddyn,
475 double Ldmax
476 )
477 {
478 static const char funcName[] = "tmComputeMapping";
479 int *histo;
480 float *cumf;
481 int brt0, histlen, threshold, ceiling, trimmings;
482 double logLddyn, Ldmin, Ldavg, Lwavg, Tr, Lw, Ld;
483 int32 histot;
484 double sum;
485 double d;
486 int i, j;
487
488 if (tms == NULL || tms->histo == NULL)
489 returnErr(TM_E_TMINVAL);
490 /* check arguments */
491 if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN;
492 if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX;
493 if (gamval < MINGAM) gamval = tms->mongam;
494 /* compute handy values */
495 Ldmin = Ldmax/Lddyn;
496 logLddyn = log(Lddyn);
497 Ldavg = sqrt(Ldmax*Ldmin);
498 i = (tms->hbrmin-MINBRT)/HISTEP;
499 brt0 = MINBRT + HISTEP/2 + i*HISTEP;
500 histlen = (tms->hbrmax-MINBRT)/HISTEP + 1 - i;
501 /* histogram total and mean */
502 histot = 0; sum = 0;
503 j = brt0 + histlen*HISTEP;
504 for (i = histlen; i--; ) {
505 histot += tms->histo[i];
506 sum += (j -= HISTEP) * tms->histo[i];
507 }
508 threshold = histot*0.005 + .5;
509 if (threshold < 4)
510 returnErr(TM_E_TMFAIL);
511 Lwavg = tmLuminance( (double)sum / histot );
512 /* allocate space for mapping */
513 if (!tmNewMap(tms))
514 returnErr(TM_E_NOMEM);
515 /* use linear tone mapping? */
516 if (tms->flags & TM_F_LINEAR)
517 goto linearmap;
518 /* clamp histogram */
519 histo = (int *)malloc(histlen*sizeof(int));
520 cumf = (float *)malloc((histlen+2)*sizeof(float));
521 if ((histo == NULL) | (cumf == NULL))
522 returnErr(TM_E_NOMEM);
523 cumf[histlen+1] = 1.; /* guard for assignment code */
524 for (i = histlen; i--; ) /* make malleable copy */
525 histo[i] = tms->histo[i];
526 do { /* iterate to solution */
527 sum = 0; /* cumulative probability */
528 for (i = 0; i < histlen; i++) {
529 cumf[i] = (double)sum/histot;
530 sum += histo[i];
531 }
532 cumf[histlen] = 1.;
533 Tr = histot * (double)(tms->hbrmax - tms->hbrmin) /
534 ((double)histlen*TM_BRTSCALE) / logLddyn;
535 ceiling = Tr + 1.;
536 trimmings = 0; /* clip to envelope */
537 for (i = histlen; i--; ) {
538 if (tms->flags & TM_F_HCONTR) {
539 Lw = tmLuminance(brt0 + i*HISTEP);
540 Ld = Ldmin * exp( logLddyn *
541 .5*(cumf[i]+cumf[i+1]) );
542 ceiling = Tr * (htcontrs(Ld) * Lw) /
543 (htcontrs(Lw) * Ld) + 1.;
544 }
545 if (histo[i] > ceiling) {
546 trimmings += histo[i] - ceiling;
547 histo[i] = ceiling;
548 }
549 }
550 /* check if we're out of data */
551 if ((histot -= trimmings) <= threshold) {
552 free((MEM_PTR)histo);
553 free((MEM_PTR)cumf);
554 goto linearmap;
555 }
556 } while (trimmings > threshold);
557 /* assign tone-mapping */
558 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
559 j = d = (double)i/(tms->mbrmax-tms->mbrmin)*histlen;
560 d -= (double)j;
561 Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1]));
562 d = (Ld - Ldmin)/(Ldmax - Ldmin);
563 tms->lumap[i] = 256.*pow(d, 1./gamval);
564 }
565 free((MEM_PTR)histo); /* clean up and return */
566 free((MEM_PTR)cumf);
567 returnOK;
568 linearmap: /* linear tone-mapping */
569 if (tms->flags & TM_F_HCONTR)
570 d = htcontrs(Ldavg) / htcontrs(Lwavg);
571 else
572 d = Ldavg / Lwavg;
573 return(tmFixedMapping(tms, tms->inpsf*d/Ldmax, gamval));
574 }
575
576
577 int
578 tmMapPixels( /* apply tone-mapping to pixel(s) */
579 TMstruct *tms,
580 BYTE *ps,
581 TMbright *ls,
582 BYTE *cs,
583 int len
584 )
585 {
586 static const char funcName[] = "tmMapPixels";
587 int32 li, pv;
588
589 if (tms == NULL || tms->lumap == NULL)
590 returnErr(TM_E_TMINVAL);
591 if ((ps == NULL) | (ls == NULL) | (len < 0))
592 returnErr(TM_E_ILLEGAL);
593 while (len--) {
594 if ((li = *ls++) < tms->mbrmin) {
595 li = 0;
596 } else {
597 if (li > tms->mbrmax)
598 li = tms->mbrmax;
599 li = tms->lumap[li - tms->mbrmin];
600 }
601 if (cs == TM_NOCHROM)
602 *ps++ = li>255 ? 255 : li;
603 else {
604 pv = *cs++ * li / tms->cdiv[RED];
605 *ps++ = pv>255 ? 255 : pv;
606 pv = *cs++ * li / tms->cdiv[GRN];
607 *ps++ = pv>255 ? 255 : pv;
608 pv = *cs++ * li / tms->cdiv[BLU];
609 *ps++ = pv>255 ? 255 : pv;
610 }
611 }
612 returnOK;
613 }
614
615
616
617
618 TMstruct *
619 tmDup( /* duplicate top tone mapping */
620 TMstruct *tms
621 )
622 {
623 int len;
624 int i;
625 TMstruct *tmnew;
626
627 if (tms == NULL) /* anything to duplicate? */
628 return(NULL);
629 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
630 if (tmnew == NULL)
631 return(NULL);
632 *tmnew = *tms; /* copy everything */
633 if (tmnew->histo != NULL) { /* duplicate histogram */
634 len = (tmnew->hbrmax-MINBRT)/HISTEP + 1 -
635 (tmnew->hbrmin-MINBRT)/HISTEP;
636 tmnew->histo = (int *)malloc(len*sizeof(int));
637 if (tmnew->histo != NULL)
638 for (i = len; i--; )
639 tmnew->histo[i] = tms->histo[i];
640 }
641 if (tmnew->lumap != NULL) { /* duplicate luminance mapping */
642 len = tmnew->mbrmax-tmnew->mbrmin+1;
643 tmnew->lumap = (unsigned short *)malloc(
644 len*sizeof(unsigned short) );
645 if (tmnew->lumap != NULL)
646 for (i = len; i--; )
647 tmnew->lumap[i] = tms->lumap[i];
648 }
649 /* clear package data */
650 for (i = tmNumPkgs; i--; )
651 tmnew->pd[i] = NULL;
652 /* return copy */
653 return(tmnew);
654 }
655
656
657 void
658 tmDone(tms) /* done with tone mapping -- destroy it */
659 TMstruct *tms;
660 {
661 int i;
662 /* NULL arg. is equiv. to tms */
663 if (tms == NULL)
664 return;
665 /* free tables */
666 if (tms->histo != NULL)
667 free((MEM_PTR)tms->histo);
668 if (tms->lumap != NULL)
669 free((MEM_PTR)tms->lumap);
670 /* free private data */
671 for (i = tmNumPkgs; i--; )
672 if (tms->pd[i] != NULL)
673 (*tmPkg[i]->Free)(tms->pd[i]);
674 free((MEM_PTR)tms); /* free basic structure */
675 }
676
677 /******************** Shared but Private library routines *********************/
678
679 BYTE tmMesofact[BMESUPPER-BMESLOWER];
680
681 void
682 tmMkMesofact() /* build mesopic lookup factor table */
683 {
684 int i;
685
686 if (tmMesofact[BMESUPPER-BMESLOWER-1])
687 return;
688
689 for (i = BMESLOWER; i < BMESUPPER; i++)
690 tmMesofact[i-BMESLOWER] = 256. *
691 (tmLuminance(i) - LMESLOWER) /
692 (LMESUPPER - LMESLOWER);
693 }
694
695
696 int
697 tmErrorReturn( /* error return (with message) */
698 const char *func,
699 TMstruct *tms,
700 int err
701 )
702 {
703 if (tms != NULL) {
704 tms->lastFunc = func;
705 tms->lastError = err;
706 if (tms->flags & TM_F_NOSTDERR)
707 return(err);
708 }
709 fputs(func, stderr);
710 fputs(": ", stderr);
711 fputs(tmErrorMessage[err], stderr);
712 fputs("!\n", stderr);
713 return(err);
714 }
