root/radiance/ray/src/common/tonemap.c
Revision: 3.47
Committed: Wed Apr 7 21:13:52 2021 UTC (4 years, 4 months ago) by greg
Changes since 3.46: +6 -6 lines
perf: changed default dynamic range from 32 to 100 to reflect modern displays
2 static const char RCSid[] = "$Id: tonemap.c,v 3.46 2021/03/02 20:09:14 greg Exp $";
5 * Tone mapping functions.
6 * See tonemap.h for detailed function descriptions.
7 * Added von Kries white-balance calculations 10/01 (GW).
8 *
9 * Externals declared in tonemap.h
10 */
11
12 #include "copyright.h"
13
14 #include <stdio.h>
15 #include <stdlib.h>
16 #include <math.h>
17 #include <string.h>
18 #include "tmprivat.h"
19 #include "tmerrmsg.h"
20
21 #define exp10(x) exp(M_LN10*(x))
22
23 /* our list of conversion packages */
24 struct tmPackage *tmPkg[TM_MAXPKG];
25 int tmNumPkgs = 0; /* number of registered packages */
26
27 /* luminance->brightness lookup */
28 static TMbright *tmFloat2BrtLUT = NULL;
29
30 #define tmCvLumLUfp(pf) tmFloat2BrtLUT[*(int32 *)(pf) >> 15]
31
32
33 TMstruct *
34 tmInit( /* initialize new tone mapping */
35 int flags,
36 RGBPRIMP monpri,
37 double gamval
38 )
39 {
40 COLORMAT cmat;
41 TMstruct *tmnew;
42 int i;
43 /* allocate structure */
44 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
45 if (tmnew == NULL)
46 return(NULL);
47
48 tmnew->flags = flags & ~TM_F_UNIMPL;
49 if (tmnew->flags & TM_F_BW)
50 tmnew->flags &= ~TM_F_MESOPIC;
51 /* set monitor transform */
52 if (monpri == NULL || monpri == stdprims || tmnew->flags & TM_F_BW) {
53 tmnew->monpri = stdprims;
54 tmnew->clf[RED] = rgb2xyzmat[1][0];
55 tmnew->clf[GRN] = rgb2xyzmat[1][1];
56 tmnew->clf[BLU] = rgb2xyzmat[1][2];
57 } else {
58 comprgb2xyzmat(cmat, tmnew->monpri=monpri);
59 tmnew->clf[RED] = cmat[1][0];
60 tmnew->clf[GRN] = cmat[1][1];
61 tmnew->clf[BLU] = cmat[1][2];
62 }
63 /* set gamma value */
64 if (gamval < MINGAM)
65 tmnew->mongam = DEFGAM;
66 else
67 tmnew->mongam = gamval;
68 /* set color divisors */
69 for (i = 0; i < 3; i++)
70 tmnew->cdiv[i] = TM_BRES*pow(tmnew->clf[i], 1./tmnew->mongam);
71
72 /* set input transform */
73 tmnew->inppri = tmnew->monpri;
74 tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] =
75 tmnew->inpsf = WHTEFFICACY;
76 tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] =
77 tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.;
78 tmnew->inpdat = NULL;
79 tmnew->hbrmin = 10; tmnew->hbrmax = -10;
80 tmnew->histo = NULL;
81 tmnew->mbrmin = 10; tmnew->mbrmax = -10;
82 tmnew->lumap = NULL;
83 /* zero private data */
84 for (i = TM_MAXPKG; i--; )
85 tmnew->pd[i] = NULL;
86 tmnew->lastError = TM_E_OK;
87 tmnew->lastFunc = "NoErr";
88 /* return new TMstruct */
89 return(tmnew);
90 }
91
92
93 int
94 tmSetSpace( /* set input color space for conversions */
95 TMstruct *tms,
96 RGBPRIMP pri,
97 double sf,
98 MEM_PTR dat
99 )
100 {
101 static const char funcName[] = "tmSetSpace";
102 int i, j;
103 /* error check */
104 if (tms == NULL)
105 returnErr(TM_E_TMINVAL);
106 if (sf <= 1e-12)
107 returnErr(TM_E_ILLEGAL);
108 /* check if no change */
109 if (pri == tms->inppri && FEQ(sf, tms->inpsf) && dat == tms->inpdat)
110 returnOK;
111 tms->inppri = pri; /* let's set it */
112 tms->inpsf = sf;
113 tms->inpdat = dat;
114
115 if (tms->flags & TM_F_BW) { /* color doesn't matter */
116 tms->monpri = tms->inppri; /* eliminate xform */
117 if (tms->inppri == TM_XYZPRIM) {
118 tms->clf[CIEX] = tms->clf[CIEZ] = 0.;
119 tms->clf[CIEY] = 1.;
120 } else {
121 comprgb2xyzmat(tms->cmat, tms->monpri);
122 tms->clf[RED] = tms->cmat[1][0];
123 tms->clf[GRN] = tms->cmat[1][1];
124 tms->clf[BLU] = tms->cmat[1][2];
125 }
126 tms->cmat[0][0] = tms->cmat[1][1] = tms->cmat[2][2] = 1.;
127 tms->cmat[0][1] = tms->cmat[0][2] = tms->cmat[1][0] =
128 tms->cmat[1][2] = tms->cmat[2][0] = tms->cmat[2][1] = 0.;
129
130 } else if (tms->inppri == TM_XYZPRIM) { /* input is XYZ */
131 compxyz2rgbWBmat(tms->cmat, tms->monpri);
132
133 } else { /* input is RGB */
134 if (tms->inppri != tms->monpri &&
135 PRIMEQ(tms->inppri, tms->monpri))
136 tms->inppri = tms->monpri; /* no xform */
137 if (!comprgb2rgbWBmat(tms->cmat, tms->inppri, tms->monpri))
138 returnErr(TM_E_ILLEGAL);
139 }
140 for (i = 0; i < 3; i++)
141 for (j = 0; j < 3; j++)
142 tms->cmat[i][j] *= tms->inpsf;
143 /* set color divisors */
144 for (i = 0; i < 3; i++)
145 tms->cdiv[i] = TM_BRES*pow(tms->clf[i] < .001 ? .001 :
146 tms->clf[i], 1./tms->mongam);
147 /* notify packages */
148 for (i = tmNumPkgs; i--; )
149 if (tms->pd[i] != NULL && tmPkg[i]->NewSpace != NULL)
150 (*tmPkg[i]->NewSpace)(tms);
151 returnOK;
152 }
153
154
155 void
156 tmClearHisto( /* clear current histogram */
157 TMstruct *tms
158 )
159 {
160 if (tms == NULL || tms->histo == NULL)
161 return;
162 free(tms->histo);
163 tms->histo = NULL;
164 }
165
166
167 TMbright
168 tmCvLuminance( /* convert a single luminance */
169 double lum
170 )
171 {
172 double d;
173
174 #ifdef isfinite
175 if (!isfinite(lum) || lum <= TM_NOLUM)
176 #else
177 if (lum <= TM_NOLUM)
178 #endif
179 return(TM_NOBRT);
180 d = TM_BRTSCALE*log(lum);
181 return((TMbright)(d + .5 - (d < 0.)));
182 }
183
184
185 int
186 tmCvLums( /* convert luminances using lookup */
187 TMbright *ls,
188 float *scan,
189 int len
190 )
191 {
192 if (tmFloat2BrtLUT == NULL) { /* initialize lookup table */
193 int32 i;
194 tmFloat2BrtLUT = (TMbright *)malloc(sizeof(TMbright)*0x10000);
195 if (tmFloat2BrtLUT == NULL)
196 return(TM_E_NOMEM);
197 for (i = 0; i < 0x10000; i++) {
198 int32 l = (i<<1 | 1) << 14;
199 #ifndef isfinite
200 if ((l & 0x7f800000) == 0x7f800000)
201 tmFloat2BrtLUT[i] = TM_NOBRT;
202 else
203 #endif
204 tmFloat2BrtLUT[i] = tmCvLuminance(*(float *)&l);
205 }
206 }
207 if (len <= 0)
208 return(TM_E_OK);
209 if ((ls == NULL) | (scan == NULL))
210 return(TM_E_ILLEGAL);
211 while (len--) {
212 if (*scan <= TM_NOLUM) {
213 *ls++ = TM_NOBRT;
214 ++scan;
215 continue;
216 }
217 *ls++ = tmCvLumLUfp(scan++);
218 }
219 return(TM_E_OK);
220 }
221
222
223 int
224 tmCvGrays( /* convert float gray values */
225 TMstruct *tms,
226 TMbright *ls,
227 float *scan,
228 int len
229 )
230 {
231 static const char funcName[] = "tmCvGrays";
232 int i;
233
234 if (tms == NULL)
235 returnErr(TM_E_TMINVAL);
236 if ((ls == NULL) | (scan == NULL) | (len < 0))
237 returnErr(TM_E_ILLEGAL);
238 if (tmFloat2BrtLUT == NULL) /* initialize */
239 tmCvLums(NULL, NULL, 0);
240 for (i = len; i--; ) {
241 float lum = tms->inpsf * scan[i];
242 if (lum <= TM_NOLUM)
243 ls[i] = TM_NOBRT;
244 else
245 ls[i] = tmCvLumLUfp(&lum);
246 }
247 returnOK;
248 }
249
250
251 int
252 tmCvColors( /* convert float colors */
253 TMstruct *tms,
254 TMbright *ls,
255 uby8 *cs,
256 COLOR *scan,
257 int len
258 )
259 {
260 static const char funcName[] = "tmCvColors";
261 static uby8 gamtab[1024];
262 static double curgam = .0;
263 COLOR cmon;
264 float lum, slum, d;
265 int i;
266
267 if (tms == NULL)
268 returnErr(TM_E_TMINVAL);
269 if ((ls == NULL) | (scan == NULL) | (len < 0))
270 returnErr(TM_E_ILLEGAL);
271 if (tmFloat2BrtLUT == NULL) /* initialize */
272 tmCvLums(NULL, NULL, 0);
273 if (cs != TM_NOCHROM && fabs(tms->mongam - curgam) > .02) {
274 curgam = tms->mongam; /* (re)build table */
275 for (i = 1024; i--; )
276 gamtab[i] = (int)(256.*pow((i+.5)/1024., 1./curgam));
277 }
278 for (i = len; i--; ) {
279 if (tmNeedMatrix(tms)) { /* get monitor RGB */
280 colortrans(cmon, tms->cmat, scan[i]);
281 } else {
282 cmon[RED] = tms->inpsf*scan[i][RED];
283 cmon[GRN] = tms->inpsf*scan[i][GRN];
284 cmon[BLU] = tms->inpsf*scan[i][BLU];
285 }
286 #ifdef isfinite
287 if (!isfinite(cmon[RED]) || cmon[RED] < .0f) cmon[RED] = .0f;
288 if (!isfinite(cmon[GRN]) || cmon[GRN] < .0f) cmon[GRN] = .0f;
289 if (!isfinite(cmon[BLU]) || cmon[BLU] < .0f) cmon[BLU] = .0f;
290 #else
291 if (cmon[RED] < .0f) cmon[RED] = .0f;
292 if (cmon[GRN] < .0f) cmon[GRN] = .0f;
293 if (cmon[BLU] < .0f) cmon[BLU] = .0f;
294 #endif
295 /* world luminance */
296 lum = tms->clf[RED]*cmon[RED] +
297 tms->clf[GRN]*cmon[GRN] +
298 tms->clf[BLU]*cmon[BLU] ;
299 if (lum <= TM_NOLUM) { /* convert brightness */
300 lum = cmon[RED] = cmon[GRN] = cmon[BLU] = TM_NOLUM;
301 ls[i] = TM_NOBRT;
302 } else
303 ls[i] = tmCvLumLUfp(&lum);
304 if (cs == TM_NOCHROM) /* no color? */
305 continue;
306 if (tms->flags & TM_F_MESOPIC && lum < LMESUPPER) {
307 slum = scotlum(cmon); /* mesopic adj. */
308 if (lum < LMESLOWER) {
309 cmon[RED] = cmon[GRN] = cmon[BLU] = slum;
310 } else {
311 d = (lum - LMESLOWER)/(LMESUPPER - LMESLOWER);
312 if (tms->flags & TM_F_BW)
313 cmon[RED] = cmon[GRN] =
314 cmon[BLU] = d*lum;
315 else
316 scalecolor(cmon, d);
317 d = (1.f-d)*slum;
318 cmon[RED] += d;
319 cmon[GRN] += d;
320 cmon[BLU] += d;
321 }
322 } else if (tms->flags & TM_F_BW) {
323 cmon[RED] = cmon[GRN] = cmon[BLU] = lum;
324 }
325 d = tms->clf[RED]*cmon[RED]/lum;
326 cs[3*i ] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
327 d = tms->clf[GRN]*cmon[GRN]/lum;
328 cs[3*i+1] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
329 d = tms->clf[BLU]*cmon[BLU]/lum;
330 cs[3*i+2] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
331 }
332 returnOK;
333 }
334
335
336 int
337 tmAddHisto( /* add values to histogram */
338 TMstruct *tms,
339 TMbright *ls,
340 int len,
341 int wt
342 )
343 {
344 static const char funcName[] = "tmAddHisto";
345 int oldorig=0, oldlen, horig, hlen;
346 int i, j;
347
348 if (tms == NULL)
349 returnErr(TM_E_TMINVAL);
350 if (len < 0)
351 returnErr(TM_E_ILLEGAL);
352 if (len == 0)
353 returnOK;
354 /* first, grow limits */
355 if (tms->histo == NULL) {
356 for (i = len; i-- && ls[i] < MINBRT; )
357 ;
358 if (i < 0)
359 returnOK;
360 tms->hbrmin = tms->hbrmax = ls[i];
361 oldlen = 0;
362 } else {
363 oldorig = HISTI(tms->hbrmin);
364 oldlen = HISTI(tms->hbrmax) + 1 - oldorig;
365 }
366 for (i = len; i--; ) {
367 if ((j = ls[i]) < MINBRT)
368 continue;
369 if (j < tms->hbrmin)
370 tms->hbrmin = j;
371 else if (j > tms->hbrmax)
372 tms->hbrmax = j;
373 }
374 horig = HISTI(tms->hbrmin);
375 hlen = HISTI(tms->hbrmax) + 1 - horig;
376 if (hlen > oldlen) { /* (re)allocate histogram */
377 HIST_TYP *newhist = (HIST_TYP *)calloc(hlen, sizeof(HIST_TYP));
378 if (newhist == NULL)
379 returnErr(TM_E_NOMEM);
380 if (oldlen) { /* copy and free old */
381 memcpy(newhist+(oldorig-horig),
382 tms->histo, oldlen*sizeof(HIST_TYP));
383 free(tms->histo);
384 }
385 tms->histo = newhist;
386 }
387 if (wt == 0)
388 returnOK;
389 for (i = len; i--; ) /* add in new counts */
390 if (ls[i] >= MINBRT)
391 tms->histo[ HISTI(ls[i]) - horig ] += wt;
392 returnOK;
393 }
394
395
396 static double
397 htcontrs( /* human threshold contrast sensitivity, dL(La) */
398 double La
399 )
400 {
401 double l10La, l10dL;
402 /* formula taken from Ferwerda et al. [SG96] */
403 if (La < 1.148e-4)
404 return(1.38e-3);
405 l10La = log10(La);
406 if (l10La < -1.44) /* rod response regime */
407 l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86;
408 else if (l10La < -.0184)
409 l10dL = l10La - .395;
410 else if (l10La < 1.9) /* cone response regime */
411 l10dL = pow(.249*l10La + .65, 2.7) - .72;
412 else
413 l10dL = l10La - 1.255;
414
415 return(exp10(l10dL));
416 }
417
418
419 int
420 tmFixedMapping( /* compute fixed, linear tone-mapping */
421 TMstruct *tms,
422 double expmult,
423 double gamval,
424 double Lddyn
425 )
426 {
427 static const char funcName[] = "tmFixedMapping";
428 const int maxV = (1L<<(8*sizeof(TMAP_TYP))) - 1;
429 double minD;
430 int i;
431
432 if (!tmNewMap(tms))
433 returnErr(TM_E_NOMEM);
434 /* check arguments */
435 if (expmult <= .0) expmult = 1.;
436 if (gamval < MINGAM) gamval = tms->mongam;
437 if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN;
438 minD = 1./Lddyn;
439 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
440 double d;
441 d = expmult/tms->inpsf * tmLuminance(tms->mbrmin + i);
442 if (d <= minD)
443 break; /* map initialized to zeroes */
444 d = (d - minD)/(1. - minD);
445 d = TM_BRES*pow(d, 1./gamval);
446 tms->lumap[i] = (d > maxV) ? maxV : (int)d;
447 }
448 returnOK;
449 }
450
451
452 int
453 tmComputeMapping( /* compute histogram tone-mapping */
454 TMstruct *tms,
455 double gamval,
456 double Lddyn,
457 double Ldmax
458 )
459 {
460 static const char funcName[] = "tmComputeMapping";
461 HIST_TYP *histo;
462 float *cumf;
463 int brt0, histlen;
464 HIST_TYP threshold, ceiling, trimmings, histot;
465 double logLddyn, Ldmin, Lwavg, Tr, Lw, Ld;
466 double sum;
467 double d;
468 int i, j;
469
470 if (tms == NULL || tms->histo == NULL)
471 returnErr(TM_E_TMINVAL);
472 /* check arguments */
473 if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN;
474 if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX;
475 if (gamval < MINGAM) gamval = tms->mongam;
476 /* compute handy values */
477 Ldmin = Ldmax/Lddyn;
478 logLddyn = log(Lddyn);
479 i = HISTI(tms->hbrmin);
480 brt0 = HISTV(i);
481 histlen = HISTI(tms->hbrmax) + 1 - i;
482 /* histogram total and mean */
483 histot = 0; sum = 0;
484 j = brt0 + histlen*HISTEP;
485 for (i = histlen; i--; ) {
486 histot += tms->histo[i];
487 sum += (double)(j -= HISTEP) * tms->histo[i];
488 }
489 threshold = histot*0.002 + .5;
490 if (!histot)
491 returnErr(TM_E_TMFAIL);
492 Lwavg = tmLuminance( (double)sum / histot );
493 /* use linear tone mapping? */
494 if (tms->flags & TM_F_LINEAR || threshold < 4 ||
495 tms->hbrmax - tms->hbrmin < TM_BRTSCALE*logLddyn)
496 goto linearmap;
497 /* clamp histogram */
498 histo = (HIST_TYP *)malloc(histlen*sizeof(HIST_TYP));
499 cumf = (float *)malloc((histlen+2)*sizeof(float));
500 if ((histo == NULL) | (cumf == NULL))
501 returnErr(TM_E_NOMEM);
502 cumf[histlen+1] = 1.; /* guard for assignment code */
503 /* make malleable copy */
504 memcpy(histo, tms->histo, histlen*sizeof(HIST_TYP));
505 do { /* iterate to solution */
506 sum = 0; /* cumulative probability */
507 for (i = 0; i < histlen; i++) {
508 cumf[i] = sum/histot;
509 sum += (double)histo[i];
510 }
511 cumf[histlen] = 1.;
512 Tr = histot * (double)(tms->hbrmax - tms->hbrmin) /
513 ((double)TM_BRTSCALE*histlen*logLddyn);
514 ceiling = Tr + 1.;
515 trimmings = 0; /* clip to envelope */
516 for (i = histlen; i--; ) {
517 if (tms->flags & TM_F_HCONTR) {
518 Lw = tmLuminance(brt0 + i*HISTEP);
519 Ld = Ldmin * exp( logLddyn *
520 .5*(cumf[i]+cumf[i+1]) );
521 ceiling = Tr * (htcontrs(Ld) * Lw) /
522 (htcontrs(Lw) * Ld) + 1.;
523 }
524 if (histo[i] > ceiling) {
525 trimmings += histo[i] - ceiling;
526 histo[i] = ceiling;
527 }
528 }
529 /* check if we're out of data */
530 if ((histot -= trimmings) <= threshold) {
531 free(histo);
532 free(cumf);
533 goto linearmap;
534 }
535 } while (trimmings > threshold);
536 /* allocate space for mapping */
537 if (!tmNewMap(tms))
538 returnErr(TM_E_NOMEM);
539 /* assign tone-mapping */
540 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
541 j = d = (double)i/(tms->mbrmax-tms->mbrmin)*histlen;
542 d -= (double)j;
543 Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1]));
544 d = (Ld - Ldmin)/(Ldmax - Ldmin);
545 tms->lumap[i] = TM_BRES*pow(d, 1./gamval);
546 }
547 free(histo); /* clean up and return */
548 free(cumf);
549 returnOK;
550 linearmap: /* linear tone-mapping */
551 if (tms->flags & TM_F_HCONTR)
552 d = htcontrs(sqrt(Ldmax*Ldmin)) / htcontrs(Lwavg);
553 else
554 d = Ldmax / tmLuminance(tms->hbrmax);
555 return(tmFixedMapping(tms, tms->inpsf*d/Ldmax, gamval, Lddyn));
556 }
557
558
559 int
560 tmMapPixels( /* apply tone-mapping to pixel(s) */
561 TMstruct *tms,
562 uby8 *ps,
563 TMbright *ls,
564 uby8 *cs,
565 int len
566 )
567 {
568 static const char funcName[] = "tmMapPixels";
569 TMbright lv;
570 TMAP_TYP li;
571 int pv;
572
573 if (tms == NULL || tms->lumap == NULL)
574 returnErr(TM_E_TMINVAL);
575 if ((ps == NULL) | (ls == NULL) | (len < 0))
576 returnErr(TM_E_ILLEGAL);
577 while (len--) {
578 if ((lv = *ls++) < tms->mbrmin) {
579 li = 0;
580 } else {
581 if (lv > tms->mbrmax)
582 lv = tms->mbrmax;
583 li = tms->lumap[lv - tms->mbrmin];
584 }
585 if (cs == TM_NOCHROM) {
586 #if !(TM_BRES & 0xff)
587 *ps++ = li>=TM_BRES ? 255 : li/(TM_BRES>>8);
588 #else
589 *ps++ = li>=TM_BRES ? 255 : (li<<8)/TM_BRES;
590 #endif
591 } else {
592 pv = *cs++ * li / tms->cdiv[RED];
593 *ps++ = pv>255 ? 255 : pv;
594 pv = *cs++ * li / tms->cdiv[GRN];
595 *ps++ = pv>255 ? 255 : pv;
596 pv = *cs++ * li / tms->cdiv[BLU];
597 *ps++ = pv>255 ? 255 : pv;
598 }
599 }
600 returnOK;
601 }
602
603
604 TMstruct *
605 tmDup( /* duplicate tone mapping */
606 TMstruct *tms
607 )
608 {
609 int len;
610 int i;
611 TMstruct *tmnew;
612
613 if (tms == NULL) /* anything to duplicate? */
614 return(NULL);
615 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
616 if (tmnew == NULL)
617 return(NULL);
618 *tmnew = *tms; /* copy everything */
619 if (tmnew->histo != NULL) { /* duplicate histogram */
620 len = HISTI(tmnew->hbrmax) + 1 - HISTI(tmnew->hbrmin);
621 tmnew->histo = (HIST_TYP *)malloc(len*sizeof(HIST_TYP));
622 if (tmnew->histo != NULL)
623 memcpy(tmnew->histo, tms->histo, len*sizeof(HIST_TYP));
624 }
625 if (tmnew->lumap != NULL) { /* duplicate luminance mapping */
626 len = tmnew->mbrmax-tmnew->mbrmin+1;
627 tmnew->lumap = (TMAP_TYP *)malloc(len*sizeof(TMAP_TYP));
628 if (tmnew->lumap != NULL)
629 memcpy(tmnew->lumap, tms->lumap, len*sizeof(TMAP_TYP));
630 }
631 /* clear package data */
632 for (i = tmNumPkgs; i--; )
633 tmnew->pd[i] = NULL;
634 /* return copy */
635 return(tmnew);
636 }
637
638
639 void
640 tmDone(tms) /* done with tone mapping -- destroy it */
641 TMstruct *tms;
642 {
643 int i;
644 /* NULL arg. is equiv. to tms */
645 if (tms == NULL)
646 return;
647 /* free tables */
648 if (tms->histo != NULL)
649 free(tms->histo);
650 if (tms->lumap != NULL)
651 free(tms->lumap);
652 /* free private data */
653 for (i = tmNumPkgs; i--; )
654 if (tms->pd[i] != NULL)
655 (*tmPkg[i]->Free)(tms->pd[i]);
656 free(tms); /* free basic structure */
657 }
658
659 /******************** Shared but Private library routines *********************/
660
661 uby8 tmMesofact[BMESUPPER-BMESLOWER];
662
663 void
664 tmMkMesofact() /* build mesopic lookup factor table */
665 {
666 int i;
667
668 if (tmMesofact[BMESUPPER-BMESLOWER-1])
669 return;
670
671 for (i = BMESLOWER; i < BMESUPPER; i++)
672 tmMesofact[i-BMESLOWER] = 256. *
673 (tmLuminance(i) - LMESLOWER) /
674 (LMESUPPER - LMESLOWER);
675 }
676
677
678 int
679 tmNewMap( /* allocate new tone-mapping array */
680 TMstruct *tms
681 )
682 {
683 if (tms->lumap != NULL && (tms->mbrmax - tms->mbrmin) !=
684 (tms->hbrmax - tms->hbrmin)) {
685 free(tms->lumap);
686 tms->lumap = NULL;
687 }
688 tms->mbrmin = tms->hbrmin;
689 tms->mbrmax = tms->hbrmax;
690 if (tms->mbrmin > tms->mbrmax)
691 return(0);
692 if (tms->lumap == NULL)
693 tms->lumap = (TMAP_TYP *)calloc(tms->mbrmax-tms->mbrmin+1,
694 sizeof(TMAP_TYP));
695 else
696 memset(tms->lumap, 0, (tms->mbrmax-tms->mbrmin+1)*sizeof(TMAP_TYP));
697
698 return(tms->lumap != NULL);
699 }
700
701
702 int
703 tmErrorReturn( /* error return (with message) */
704 const char *func,
705 TMstruct *tms,
706 int err
707 )
708 {
709 if (tms != NULL) {
710 tms->lastFunc = func;
711 tms->lastError = err;
712 if (tms->flags & TM_F_NOSTDERR)
713 return(err);
714 }
715 fputs(func, stderr);
716 fputs(": ", stderr);
717 fputs(tmErrorMessage[err], stderr);
718 fputs("!\n", stderr);
719 return(err);
720 }
