root/radiance/ray/src/common/tonemap.c
Revision: 3.20
Committed: Sat Jan 14 20:25:51 2006 UTC (19 years, 5 months ago) by greg
Changes since 3.19: +11 -7 lines
Improved conversion speed for floating-point pixels with gamma lookup table
2 static const char RCSid[] = "$Id: tonemap.c,v 3.19 2005/11/15 06:53:00 greg Exp $";
5 * Tone mapping functions.
6 * See tonemap.h for detailed function descriptions.
7 * Added von Kries white-balance calculations 10/01 (GW).
8 *
9 * Externals declared in tonemap.h
10 */
11
12 #include "copyright.h"
13
14 #include <stdio.h>
15 #include <math.h>
16 #include "tmprivat.h"
17 #include "tmerrmsg.h"
18
19 #define exp10(x) exp(M_LN10*(x))
20
21 /* our list of conversion packages */
22 struct tmPackage *tmPkg[TM_MAXPKG];
23 int tmNumPkgs = 0; /* number of registered packages */
24
25
26 TMstruct *
27 tmInit( /* initialize new tone mapping */
28 int flags,
29 RGBPRIMP monpri,
30 double gamval
31 )
32 {
33 COLORMAT cmat;
34 TMstruct *tmnew;
35 int i;
36 /* allocate structure */
37 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
38 if (tmnew == NULL)
39 return(NULL);
40
41 tmnew->flags = flags & ~TM_F_UNIMPL;
42 if (tmnew->flags & TM_F_BW)
43 tmnew->flags &= ~TM_F_MESOPIC;
44 /* set monitor transform */
45 if (monpri == NULL || monpri == stdprims || tmnew->flags & TM_F_BW) {
46 tmnew->monpri = stdprims;
47 tmnew->clf[RED] = rgb2xyzmat[1][0];
48 tmnew->clf[GRN] = rgb2xyzmat[1][1];
49 tmnew->clf[BLU] = rgb2xyzmat[1][2];
50 } else {
51 comprgb2xyzWBmat(cmat, tmnew->monpri=monpri);
52 tmnew->clf[RED] = cmat[1][0];
53 tmnew->clf[GRN] = cmat[1][1];
54 tmnew->clf[BLU] = cmat[1][2];
55 }
56 /* set gamma value */
57 if (gamval < MINGAM)
58 tmnew->mongam = DEFGAM;
59 else
60 tmnew->mongam = gamval;
61 /* set color divisors */
62 for (i = 0; i < 3; i++)
63 tmnew->cdiv[i] = 256.*pow(tmnew->clf[i], 1./tmnew->mongam);
64
65 /* set input transform */
66 tmnew->inppri = tmnew->monpri;
67 tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] =
68 tmnew->inpsf = WHTEFFICACY;
69 tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] =
70 tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.;
71 tmnew->inpdat = NULL;
72 tmnew->hbrmin = 10; tmnew->hbrmax = -10;
73 tmnew->histo = NULL;
74 tmnew->mbrmin = 10; tmnew->mbrmax = -10;
75 tmnew->lumap = NULL;
76 /* zero private data */
77 for (i = TM_MAXPKG; i--; )
78 tmnew->pd[i] = NULL;
79 tmnew->lastError = TM_E_OK;
80 tmnew->lastFunc = "NoErr";
81 /* return new TMstruct */
82 return(tmnew);
83 }
84
85
86 int
87 tmSetSpace( /* set input color space for conversions */
88 TMstruct *tms,
89 RGBPRIMP pri,
90 double sf,
91 MEM_PTR dat
92 )
93 {
94 static const char funcName[] = "tmSetSpace";
95 int i, j;
96 /* error check */
97 if (tms == NULL)
98 returnErr(TM_E_TMINVAL);
99 if (sf <= 1e-12)
100 returnErr(TM_E_ILLEGAL);
101 /* check if no change */
102 if (pri == tms->inppri && FEQ(sf, tms->inpsf) && dat == tms->inpdat)
103 returnOK;
104 tms->inppri = pri; /* let's set it */
105 tms->inpsf = sf;
106 tms->inpdat = dat;
107
108 if (tms->flags & TM_F_BW) { /* color doesn't matter */
109 tms->monpri = tms->inppri; /* eliminate xform */
110 if (tms->inppri == TM_XYZPRIM) {
111 tms->clf[CIEX] = tms->clf[CIEZ] = 0.;
112 tms->clf[CIEY] = 1.;
113 } else {
114 comprgb2xyzWBmat(tms->cmat, tms->monpri);
115 tms->clf[RED] = tms->cmat[1][0];
116 tms->clf[GRN] = tms->cmat[1][1];
117 tms->clf[BLU] = tms->cmat[1][2];
118 }
119 tms->cmat[0][0] = tms->cmat[1][1] = tms->cmat[2][2] =
120 tms->inpsf;
121 tms->cmat[0][1] = tms->cmat[0][2] = tms->cmat[1][0] =
122 tms->cmat[1][2] = tms->cmat[2][0] = tms->cmat[2][1] = 0.;
123
124 } else if (tms->inppri == TM_XYZPRIM) /* input is XYZ */
125 compxyz2rgbWBmat(tms->cmat, tms->monpri);
126
127 else { /* input is RGB */
128 if (tms->inppri != tms->monpri &&
129 PRIMEQ(tms->inppri, tms->monpri))
130 tms->inppri = tms->monpri; /* no xform */
131 comprgb2rgbWBmat(tms->cmat, tms->inppri, tms->monpri);
132 }
133 for (i = 0; i < 3; i++)
134 for (j = 0; j < 3; j++)
135 tms->cmat[i][j] *= tms->inpsf;
136 /* set color divisors */
137 for (i = 0; i < 3; i++)
138 if (tms->clf[i] > .001)
139 tms->cdiv[i] =
140 256.*pow(tms->clf[i], 1./tms->mongam);
141 else
142 tms->cdiv[i] = 1;
143 /* notify packages */
144 for (i = tmNumPkgs; i--; )
145 if (tms->pd[i] != NULL && tmPkg[i]->NewSpace != NULL)
146 (*tmPkg[i]->NewSpace)(tms);
147 returnOK;
148 }
149
150
151 void
152 tmClearHisto( /* clear current histogram */
153 TMstruct *tms
154 )
155 {
156 if (tms == NULL || tms->histo == NULL)
157 return;
158 free((MEM_PTR)tms->histo);
159 tms->histo = NULL;
160 }
161
162
163 int
164 tmCvColors( /* convert float colors */
165 TMstruct *tms,
166 TMbright *ls,
167 BYTE *cs,
168 COLOR *scan,
169 int len
170 )
171 {
172 static const char funcName[] = "tmCvColors";
173 static COLOR csmall = {.5*MINLUM, .5*MINLUM, .5*MINLUM};
174 static BYTE gamtab[1024];
175 static double curgam = .0;
176 COLOR cmon;
177 double lum, slum;
178 double d;
179 int i;
180
181 if (tms == NULL)
182 returnErr(TM_E_TMINVAL);
183 if ((ls == NULL) | (scan == NULL) | (len < 0))
184 returnErr(TM_E_ILLEGAL);
185 if (cs != TM_NOCHROM && fabs(curgam - tms->mongam) < .02) {
186 curgam = tms->mongam; /* (re)build table */
187 for (i = 1024; i--; )
188 gamtab[i] = (int)(256.*pow((i+.5)/1024., 1./curgam));
189 }
190 for (i = len; i--; ) {
191 if (tmNeedMatrix(tms)) { /* get monitor RGB */
192 colortrans(cmon, tms->cmat, scan[i]);
193 } else {
194 cmon[RED] = tms->inpsf*scan[i][RED];
195 cmon[GRN] = tms->inpsf*scan[i][GRN];
196 cmon[BLU] = tms->inpsf*scan[i][BLU];
197 }
198 /* world luminance */
199 lum = tms->clf[RED]*cmon[RED] +
200 tms->clf[GRN]*cmon[GRN] +
201 tms->clf[BLU]*cmon[BLU] ;
202 /* check range */
203 if (clipgamut(cmon, lum, CGAMUT_LOWER, csmall, cwhite))
204 lum = tms->clf[RED]*cmon[RED] +
205 tms->clf[GRN]*cmon[GRN] +
206 tms->clf[BLU]*cmon[BLU] ;
207 if (lum < MINLUM) {
208 ls[i] = MINBRT-1; /* bogus value */
209 lum = MINLUM;
210 } else {
211 d = TM_BRTSCALE*log(lum); /* encode it */
212 ls[i] = d>0. ? (int)(d+.5) : (int)(d-.5);
213 }
214 if (cs == TM_NOCHROM) /* no color? */
215 continue;
216 if (tms->flags & TM_F_MESOPIC && lum < LMESUPPER) {
217 slum = scotlum(cmon); /* mesopic adj. */
218 if (lum < LMESLOWER)
219 cmon[RED] = cmon[GRN] = cmon[BLU] = slum;
220 else {
221 d = (lum - LMESLOWER)/(LMESUPPER - LMESLOWER);
222 if (tms->flags & TM_F_BW)
223 cmon[RED] = cmon[GRN] =
224 cmon[BLU] = d*lum;
225 else
226 scalecolor(cmon, d);
227 d = (1.-d)*slum;
228 cmon[RED] += d;
229 cmon[GRN] += d;
230 cmon[BLU] += d;
231 }
232 } else if (tms->flags & TM_F_BW) {
233 cmon[RED] = cmon[GRN] = cmon[BLU] = lum;
234 }
235 d = tms->clf[RED]*cmon[RED]/lum;
236 cs[3*i ] = d>=.999 ? 255 : gamtab[(int)(1024.*d)];
237 d = tms->clf[GRN]*cmon[GRN]/lum;
238 cs[3*i+1] = d>=.999 ? 255 : gamtab[(int)(1024.*d)];
239 d = tms->clf[BLU]*cmon[BLU]/lum;
240 cs[3*i+2] = d>=.999 ? 255 : gamtab[(int)(1024.*d)];
241 }
242 returnOK;
243 }
244
245
246 TMbright
247 tmCvLuminance( /* convert a single luminance */
248 double lum
249 )
250 {
251 double d;
252
253 if (lum <= TM_NOLUM)
254 return(TM_NOBRT);
255 d = TM_BRTSCALE*log(lum);
256 if (d > 0.)
257 return((TMbright)(d+.5));
258 return((TMbright)(d-.5));
259 }
260
261
262 int
263 tmCvGrays( /* convert float gray values */
264 TMstruct *tms,
265 TMbright *ls,
266 float *scan,
267 int len
268 )
269 {
270 static const char funcName[] = "tmCvGrays";
271 double d;
272 int i;
273
274 if (tms == NULL)
275 returnErr(TM_E_TMINVAL);
276 if ((ls == NULL) | (scan == NULL) | (len < 0))
277 returnErr(TM_E_ILLEGAL);
278 for (i = len; i--; )
279 if (scan[i] <= TM_NOLUM) {
280 ls[i] = TM_NOBRT; /* bogus value */
281 } else {
282 d = TM_BRTSCALE*log(scan[i]); /* encode it */
283 ls[i] = d>0. ? (int)(d+.5) : (int)(d-.5);
284 }
285 returnOK;
286 }
287
288
289 int
290 tmAddHisto( /* add values to histogram */
291 TMstruct *tms,
292 TMbright *ls,
293 int len,
294 int wt
295 )
296 {
297 static const char funcName[] = "tmAddHisto";
298 int oldorig=0, oldlen, horig, hlen;
299 int i, j;
300
301 if (tms == NULL)
302 returnErr(TM_E_TMINVAL);
303 if (len < 0)
304 returnErr(TM_E_ILLEGAL);
305 if (len == 0)
306 returnOK;
307 /* first, grow limits */
308 if (tms->histo == NULL) {
309 for (i = len; i-- && ls[i] < MINBRT; )
310 ;
311 if (i < 0)
312 returnOK;
313 tms->hbrmin = tms->hbrmax = ls[i];
314 oldlen = 0;
315 } else {
316 oldorig = (tms->hbrmin-MINBRT)/HISTEP;
317 oldlen = (tms->hbrmax-MINBRT)/HISTEP + 1 - oldorig;
318 }
319 for (i = len; i--; ) {
320 if ((j = ls[i]) < MINBRT)
321 continue;
322 if (j < tms->hbrmin)
323 tms->hbrmin = j;
324 else if (j > tms->hbrmax)
325 tms->hbrmax = j;
326 }
327 horig = (tms->hbrmin-MINBRT)/HISTEP;
328 hlen = (tms->hbrmax-MINBRT)/HISTEP + 1 - horig;
329 if (hlen > oldlen) { /* (re)allocate histogram */
330 int *newhist = (int *)calloc(hlen, sizeof(int));
331 if (newhist == NULL)
332 returnErr(TM_E_NOMEM);
333 if (oldlen) { /* copy and free old */
334 for (i = oldlen, j = i+oldorig-horig; i; )
335 newhist[--j] = tms->histo[--i];
336 free((MEM_PTR)tms->histo);
337 }
338 tms->histo = newhist;
339 }
340 if (wt == 0)
341 returnOK;
342 for (i = len; i--; ) /* add in new counts */
343 if (ls[i] >= MINBRT)
344 tms->histo[ (ls[i]-MINBRT)/HISTEP - horig ] += wt;
345 returnOK;
346 }
347
348
349 static double
350 htcontrs( /* human threshold contrast sensitivity, dL(La) */
351 double La
352 )
353 {
354 double l10La, l10dL;
355 /* formula taken from Ferwerda et al. [SG96] */
356 if (La < 1.148e-4)
357 return(1.38e-3);
358 l10La = log10(La);
359 if (l10La < -1.44) /* rod response regime */
360 l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86;
361 else if (l10La < -.0184)
362 l10dL = l10La - .395;
363 else if (l10La < 1.9) /* cone response regime */
364 l10dL = pow(.249*l10La + .65, 2.7) - .72;
365 else
366 l10dL = l10La - 1.255;
367
368 return(exp10(l10dL));
369 }
370
371
372 static int
373 tmNewMap( /* allocate new tone-mapping array */
374 TMstruct *tms
375 )
376 {
377 if (tms->lumap != NULL && (tms->mbrmax - tms->mbrmin) !=
378 (tms->hbrmax - tms->hbrmin)) {
379 free((MEM_PTR)tms->lumap);
380 tms->lumap = NULL;
381 }
382 tms->mbrmin = tms->hbrmin;
383 tms->mbrmax = tms->hbrmax;
384 if (tms->mbrmin > tms->mbrmax)
385 return 0;
386 if (tms->lumap == NULL)
387 tms->lumap = (unsigned short *)malloc(sizeof(unsigned short)*
388 (tms->mbrmax-tms->mbrmin+1));
389 return(tms->lumap != NULL);
390 }
391
392
393 int
394 tmFixedMapping( /* compute fixed, linear tone-mapping */
395 TMstruct *tms,
396 double expmult,
397 double gamval
398 )
399 {
400 static const char funcName[] = "tmFixedMapping";
401 double d;
402 int i;
403
404 if (!tmNewMap(tms))
405 returnErr(TM_E_NOMEM);
406 if (expmult <= .0)
407 expmult = 1.;
408 if (gamval < MINGAM)
409 gamval = tms->mongam;
410 d = log(expmult/tms->inpsf);
411 for (i = tms->mbrmax-tms->mbrmin+1; i--; )
412 tms->lumap[i] = 256. * exp(
413 ( d + (tms->mbrmin+i)*(1./TM_BRTSCALE) )
414 / gamval );
415 returnOK;
416 }
417
418
419 int
420 tmComputeMapping( /* compute histogram tone-mapping */
421 TMstruct *tms,
422 double gamval,
423 double Lddyn,
424 double Ldmax
425 )
426 {
427 static const char funcName[] = "tmComputeMapping";
428 int *histo;
429 float *cumf;
430 int brt0, histlen, threshold, ceiling, trimmings;
431 double logLddyn, Ldmin, Ldavg, Lwavg, Tr, Lw, Ld;
432 int32 histot;
433 double sum;
434 double d;
435 int i, j;
436
437 if (tms == NULL || tms->histo == NULL)
438 returnErr(TM_E_TMINVAL);
439 /* check arguments */
440 if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN;
441 if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX;
442 if (gamval < MINGAM) gamval = tms->mongam;
443 /* compute handy values */
444 Ldmin = Ldmax/Lddyn;
445 logLddyn = log(Lddyn);
446 Ldavg = sqrt(Ldmax*Ldmin);
447 i = (tms->hbrmin-MINBRT)/HISTEP;
448 brt0 = MINBRT + HISTEP/2 + i*HISTEP;
449 histlen = (tms->hbrmax-MINBRT)/HISTEP + 1 - i;
450 /* histogram total and mean */
451 histot = 0; sum = 0;
452 j = brt0 + histlen*HISTEP;
453 for (i = histlen; i--; ) {
454 histot += tms->histo[i];
455 sum += (j -= HISTEP) * tms->histo[i];
456 }
457 threshold = histot*0.005 + .5;
458 if (threshold < 4)
459 returnErr(TM_E_TMFAIL);
460 Lwavg = tmLuminance( (double)sum / histot );
461 /* allocate space for mapping */
462 if (!tmNewMap(tms))
463 returnErr(TM_E_NOMEM);
464 /* use linear tone mapping? */
465 if (tms->flags & TM_F_LINEAR)
466 goto linearmap;
467 /* clamp histogram */
468 histo = (int *)malloc(histlen*sizeof(int));
469 cumf = (float *)malloc((histlen+2)*sizeof(float));
470 if ((histo == NULL) | (cumf == NULL))
471 returnErr(TM_E_NOMEM);
472 cumf[histlen+1] = 1.; /* guard for assignment code */
473 for (i = histlen; i--; ) /* make malleable copy */
474 histo[i] = tms->histo[i];
475 do { /* iterate to solution */
476 sum = 0; /* cumulative probability */
477 for (i = 0; i < histlen; i++) {
478 cumf[i] = (double)sum/histot;
479 sum += histo[i];
480 }
481 cumf[histlen] = 1.;
482 Tr = histot * (double)(tms->hbrmax - tms->hbrmin) /
483 ((double)histlen*TM_BRTSCALE) / logLddyn;
484 ceiling = Tr + 1.;
485 trimmings = 0; /* clip to envelope */
486 for (i = histlen; i--; ) {
487 if (tms->flags & TM_F_HCONTR) {
488 Lw = tmLuminance(brt0 + i*HISTEP);
489 Ld = Ldmin * exp( logLddyn *
490 .5*(cumf[i]+cumf[i+1]) );
491 ceiling = Tr * (htcontrs(Ld) * Lw) /
492 (htcontrs(Lw) * Ld) + 1.;
493 }
494 if (histo[i] > ceiling) {
495 trimmings += histo[i] - ceiling;
496 histo[i] = ceiling;
497 }
498 }
499 /* check if we're out of data */
500 if ((histot -= trimmings) <= threshold) {
501 free((MEM_PTR)histo);
502 free((MEM_PTR)cumf);
503 goto linearmap;
504 }
505 } while (trimmings > threshold);
506 /* assign tone-mapping */
507 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
508 j = d = (double)i/(tms->mbrmax-tms->mbrmin)*histlen;
509 d -= (double)j;
510 Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1]));
511 d = (Ld - Ldmin)/(Ldmax - Ldmin);
512 tms->lumap[i] = 256.*pow(d, 1./gamval);
513 }
514 free((MEM_PTR)histo); /* clean up and return */
515 free((MEM_PTR)cumf);
516 returnOK;
517 linearmap: /* linear tone-mapping */
518 if (tms->flags & TM_F_HCONTR)
519 d = htcontrs(Ldavg) / htcontrs(Lwavg);
520 else
521 d = Ldavg / Lwavg;
522 return(tmFixedMapping(tms, tms->inpsf*d/Ldmax, gamval));
523 }
524
525
526 int
527 tmMapPixels( /* apply tone-mapping to pixel(s) */
528 TMstruct *tms,
529 BYTE *ps,
530 TMbright *ls,
531 BYTE *cs,
532 int len
533 )
534 {
535 static const char funcName[] = "tmMapPixels";
536 int32 li, pv;
537
538 if (tms == NULL || tms->lumap == NULL)
539 returnErr(TM_E_TMINVAL);
540 if ((ps == NULL) | (ls == NULL) | (len < 0))
541 returnErr(TM_E_ILLEGAL);
542 while (len--) {
543 if ((li = *ls++) < tms->mbrmin) {
544 li = 0;
545 } else {
546 if (li > tms->mbrmax)
547 li = tms->mbrmax;
548 li = tms->lumap[li - tms->mbrmin];
549 }
550 if (cs == TM_NOCHROM)
551 *ps++ = li>255 ? 255 : li;
552 else {
553 pv = *cs++ * li / tms->cdiv[RED];
554 *ps++ = pv>255 ? 255 : pv;
555 pv = *cs++ * li / tms->cdiv[GRN];
556 *ps++ = pv>255 ? 255 : pv;
557 pv = *cs++ * li / tms->cdiv[BLU];
558 *ps++ = pv>255 ? 255 : pv;
559 }
560 }
561 returnOK;
562 }
563
564
565
566
567 TMstruct *
568 tmDup( /* duplicate top tone mapping */
569 TMstruct *tms
570 )
571 {
572 int len;
573 int i;
574 TMstruct *tmnew;
575
576 if (tms == NULL) /* anything to duplicate? */
577 return(NULL);
578 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
579 if (tmnew == NULL)
580 return(NULL);
581 *tmnew = *tms; /* copy everything */
582 if (tmnew->histo != NULL) { /* duplicate histogram */
583 len = (tmnew->hbrmax-MINBRT)/HISTEP + 1 -
584 (tmnew->hbrmin-MINBRT)/HISTEP;
585 tmnew->histo = (int *)malloc(len*sizeof(int));
586 if (tmnew->histo != NULL)
587 for (i = len; i--; )
588 tmnew->histo[i] = tms->histo[i];
589 }
590 if (tmnew->lumap != NULL) { /* duplicate luminance mapping */
591 len = tmnew->mbrmax-tmnew->mbrmin+1;
592 tmnew->lumap = (unsigned short *)malloc(
593 len*sizeof(unsigned short) );
594 if (tmnew->lumap != NULL)
595 for (i = len; i--; )
596 tmnew->lumap[i] = tms->lumap[i];
597 }
598 /* clear package data */
599 for (i = tmNumPkgs; i--; )
600 tmnew->pd[i] = NULL;
601 /* return copy */
602 return(tmnew);
603 }
604
605
606 void
607 tmDone(tms) /* done with tone mapping -- destroy it */
608 TMstruct *tms;
609 {
610 int i;
611 /* NULL arg. is equiv. to tms */
612 if (tms == NULL)
613 return;
614 /* free tables */
615 if (tms->histo != NULL)
616 free((MEM_PTR)tms->histo);
617 if (tms->lumap != NULL)
618 free((MEM_PTR)tms->lumap);
619 /* free private data */
620 for (i = tmNumPkgs; i--; )
621 if (tms->pd[i] != NULL)
622 (*tmPkg[i]->Free)(tms->pd[i]);
623 free((MEM_PTR)tms); /* free basic structure */
624 }
625
626 /******************** Shared but Private library routines *********************/
627
628 BYTE tmMesofact[BMESUPPER-BMESLOWER];
629
630 void
631 tmMkMesofact() /* build mesopic lookup factor table */
632 {
633 int i;
634
635 if (tmMesofact[BMESUPPER-BMESLOWER-1])
636 return;
637
638 for (i = BMESLOWER; i < BMESUPPER; i++)
639 tmMesofact[i-BMESLOWER] = 256. *
640 (tmLuminance(i) - LMESLOWER) /
641 (LMESUPPER - LMESLOWER);
642 }
643
644
645 int
646 tmErrorReturn( /* error return (with message) */
647 const char *func,
648 TMstruct *tms,
649 int err
650 )
651 {
652 if (tms != NULL) {
653 tms->lastFunc = func;
654 tms->lastError = err;
655 if (tms->flags & TM_F_NOSTDERR)
656 return(err);
657 }
658 fputs(func, stderr);
659 fputs(": ", stderr);
660 fputs(tmErrorMessage[err], stderr);
661 fputs("!\n", stderr);
662 return(err);
663 }
