1 |
/* Copyright (c) 1997 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Tone mapping functions. |
9 |
* See tonemap.h for detailed function descriptions. |
10 |
11 |
12 |
#include <stdio.h> |
13 |
#include <math.h> |
14 |
#include "tmprivat.h" |
15 |
#include "tmerrmsg.h" |
16 |
17 |
#define exp10(x) exp(M_LN10*(x)) |
18 |
19 |
struct tmStruct *tmTop = NULL; /* current tone mapping stack */ |
20 |
21 |
/* our list of conversion packages */ |
22 |
struct tmPackage *tmPkg[TM_MAXPKG]; |
23 |
int tmNumPkgs = 0; /* number of registered packages */ |
24 |
25 |
int tmLastError; /* last error incurred by library */ |
26 |
char *tmLastFunction; /* error-generating function name */ |
27 |
28 |
29 |
int |
30 |
tmErrorReturn(func, err) /* error return (with message) */ |
31 |
char *func; |
32 |
int err; |
33 |
34 |
tmLastFunction = func; |
35 |
tmLastError = err; |
36 |
if (tmTop != NULL && tmTop->flags & TM_F_NOSTDERR) |
37 |
return(err); |
38 |
fputs(func, stderr); |
39 |
fputs(": ", stderr); |
40 |
fputs(tmErrorMessage[err], stderr); |
41 |
fputs("!\n", stderr); |
42 |
return(err); |
43 |
44 |
45 |
46 |
struct tmStruct * |
47 |
tmInit(flags, monpri, gamval) /* initialize new tone mapping */ |
48 |
int flags; |
49 |
RGBPRIMP monpri; |
50 |
double gamval; |
51 |
52 |
static char funcName[] = "tmInit"; |
53 |
COLORMAT cmat; |
54 |
register struct tmStruct *tmnew; |
55 |
register int i; |
56 |
/* allocate structure */ |
57 |
tmnew = (struct tmStruct *)malloc(sizeof(struct tmStruct)); |
58 |
if (tmnew == NULL) |
59 |
return(NULL); |
60 |
61 |
tmnew->flags = flags & ~TM_F_UNIMPL; |
62 |
/* set monitor transform */ |
63 |
if (monpri == NULL || monpri == stdprims || tmnew->flags & TM_F_BW) { |
64 |
tmnew->monpri = stdprims; |
65 |
tmnew->clf[RED] = rgb2xyzmat[1][0]; |
66 |
tmnew->clf[GRN] = rgb2xyzmat[1][1]; |
67 |
tmnew->clf[BLU] = rgb2xyzmat[1][2]; |
68 |
} else { |
69 |
comprgb2xyzmat(cmat, tmnew->monpri=monpri); |
70 |
tmnew->clf[RED] = cmat[1][0]; |
71 |
tmnew->clf[GRN] = cmat[1][1]; |
72 |
tmnew->clf[BLU] = cmat[1][2]; |
73 |
74 |
/* set gamma value */ |
75 |
if (gamval < MINGAM) |
76 |
tmnew->mongam = DEFGAM; |
77 |
else |
78 |
tmnew->mongam = gamval; |
79 |
/* set color divisors */ |
80 |
for (i = 0; i < 3; i++) |
81 |
tmnew->cdiv[i] = 256.*pow(tmnew->clf[i], 1./tmnew->mongam); |
82 |
83 |
/* set input transform */ |
84 |
tmnew->inppri = tmnew->monpri; |
85 |
tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] = |
86 |
tmnew->inpsf = WHTEFFICACY; |
87 |
tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] = |
88 |
tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.; |
89 |
tmnew->hbrmin = tmnew->hbrmax = 0; |
90 |
tmnew->histo = NULL; |
91 |
tmnew->mbrmin = tmnew->mbrmax = 0; |
92 |
tmnew->lumap = NULL; |
93 |
/* zero private data */ |
94 |
for (i = TM_MAXPKG; i--; ) |
95 |
tmnew->pd[i] = NULL; |
96 |
/* make tmnew current */ |
97 |
tmnew->tmprev = tmTop; |
98 |
return(tmTop = tmnew); |
99 |
100 |
101 |
102 |
int |
103 |
tmSetSpace(pri, sf) /* set input color space for conversions */ |
104 |
RGBPRIMP pri; |
105 |
double sf; |
106 |
107 |
static char funcName[] = "tmSetSpace"; |
108 |
register int i, j; |
109 |
/* error check */ |
110 |
if (tmTop == NULL) |
111 |
returnErr(TM_E_TMINVAL); |
112 |
if (sf <= 1e-12) |
113 |
returnErr(TM_E_ILLEGAL); |
114 |
/* check if no change */ |
115 |
if (pri == tmTop->inppri && FEQ(sf, tmTop->inpsf)) |
116 |
returnOK; |
117 |
tmTop->inppri = pri; /* let's set it */ |
118 |
tmTop->inpsf = sf; |
119 |
120 |
if (tmTop->flags & TM_F_BW) { /* color doesn't matter */ |
121 |
tmTop->monpri = tmTop->inppri; /* eliminate xform */ |
122 |
if (tmTop->inppri == TM_XYZPRIM) { |
123 |
tmTop->clf[CIEX] = tmTop->clf[CIEZ] = 0.; |
124 |
tmTop->clf[CIEY] = 1.; |
125 |
} else { |
126 |
comprgb2xyzmat(tmTop->cmat, tmTop->monpri); |
127 |
tmTop->clf[RED] = tmTop->cmat[1][0]; |
128 |
tmTop->clf[GRN] = tmTop->cmat[1][1]; |
129 |
tmTop->clf[BLU] = tmTop->cmat[1][2]; |
130 |
131 |
tmTop->cmat[0][0] = tmTop->cmat[1][1] = tmTop->cmat[2][2] = |
132 |
tmTop->inpsf; |
133 |
tmTop->cmat[0][1] = tmTop->cmat[0][2] = tmTop->cmat[1][0] = |
134 |
tmTop->cmat[1][2] = tmTop->cmat[2][0] = tmTop->cmat[2][1] = 0.; |
135 |
136 |
} else if (tmTop->inppri == TM_XYZPRIM) /* input is XYZ */ |
137 |
compxyz2rgbmat(tmTop->cmat, tmTop->monpri); |
138 |
139 |
else { /* input is RGB */ |
140 |
if (tmTop->inppri != tmTop->monpri && |
141 |
PRIMEQ(tmTop->inppri, tmTop->monpri)) |
142 |
tmTop->inppri = tmTop->monpri; /* no xform */ |
143 |
comprgb2rgbmat(tmTop->cmat, tmTop->inppri, tmTop->monpri); |
144 |
145 |
146 |
for (j = 0; j < 3; j++) |
147 |
tmTop->cmat[i][j] *= tmTop->inpsf; |
148 |
149 |
150 |
if (tmTop->clf[i] > .001) |
151 |
tmTop->cdiv[i] = |
152 |
256.*pow(tmTop->clf[i], 1./tmTop->mongam); |
153 |
else |
154 |
tmTop->cdiv[i] = 1; |
155 |
/* notify packages */ |
156 |
for (i = tmNumPkgs; i--; ) |
157 |
if (tmTop->pd[i] != NULL && tmPkg[i]->NewSpace != NULL) |
158 |
(*tmPkg[i]->NewSpace)(tmTop); |
159 |
returnOK; |
160 |
161 |
162 |
163 |
void |
164 |
tmClearHisto() /* clear current histogram */ |
165 |
166 |
if (tmTop == NULL || tmTop->histo == NULL) |
167 |
return; |
168 |
free((MEM_PTR)tmTop->histo); |
169 |
tmTop->histo = NULL; |
170 |
171 |
172 |
173 |
int |
174 |
tmCvColors(ls, cs, scan, len) /* convert float colors */ |
175 |
TMbright *ls; |
176 |
BYTE *cs; |
177 |
COLOR *scan; |
178 |
int len; |
179 |
180 |
static char funcName[] = "tmCvColors"; |
181 |
static COLOR csmall = {1e-6, 1e-6, 1e-6}; |
182 |
COLOR cmon; |
183 |
double lum, slum; |
184 |
register double d; |
185 |
register int i; |
186 |
187 |
188 |
189 |
if (ls == NULL | scan == NULL | len <= 0) |
190 |
191 |
for (i = len; i--; ) { |
192 |
if (tmNeedMatrix(tmTop)) /* get monitor RGB */ |
193 |
colortrans(cmon, tmTop->cmat, scan[i]); |
194 |
else { |
195 |
cmon[RED] = tmTop->inpsf*scan[i][RED]; |
196 |
cmon[GRN] = tmTop->inpsf*scan[i][GRN]; |
197 |
cmon[BLU] = tmTop->inpsf*scan[i][BLU]; |
198 |
199 |
/* world luminance */ |
200 |
lum = tmTop->clf[RED]*cmon[RED] + |
201 |
tmTop->clf[GRN]*cmon[GRN] + |
202 |
tmTop->clf[BLU]*cmon[BLU] ; |
203 |
/* check range */ |
204 |
if (clipgamut(cmon, lum, CGAMUT_LOWER, csmall, cwhite)) |
205 |
206 |
207 |
208 |
if (lum < MINLUM) { |
209 |
ls[i] = MINBRT-1; /* bogus value */ |
210 |
lum = MINLUM; |
211 |
} else { |
212 |
d = TM_BRTSCALE*log(lum); /* encode it */ |
213 |
ls[i] = d>0. ? (int)(d+.5) : (int)(d-.5); |
214 |
215 |
if (cs == TM_NOCHROM) /* no color? */ |
216 |
continue; |
217 |
if (tmTop->flags & TM_F_MESOPIC && lum < LMESUPPER) { |
218 |
slum = scotlum(cmon); /* mesopic adj. */ |
219 |
if (lum < LMESLOWER) |
220 |
cmon[RED] = cmon[GRN] = cmon[BLU] = slum; |
221 |
else { |
222 |
d = (lum - LMESLOWER)/(LMESUPPER - LMESLOWER); |
223 |
if (tmTop->flags & TM_F_BW) |
224 |
cmon[RED] = cmon[GRN] = |
225 |
cmon[BLU] = d*lum; |
226 |
else |
227 |
scalecolor(cmon, d); |
228 |
d = (1.-d)*slum; |
229 |
cmon[RED] += d; |
230 |
cmon[GRN] += d; |
231 |
cmon[BLU] += d; |
232 |
233 |
} else if (tmTop->flags & TM_F_BW) { |
234 |
cmon[RED] = cmon[GRN] = cmon[BLU] = lum; |
235 |
236 |
d = tmTop->clf[RED]*cmon[RED]/lum; |
237 |
cs[3*i ] = d>=.999 ? 255 : |
238 |
(int)(256.*pow(d, 1./tmTop->mongam)); |
239 |
d = tmTop->clf[GRN]*cmon[GRN]/lum; |
240 |
cs[3*i+1] = d>=.999 ? 255 : |
241 |
242 |
d = tmTop->clf[BLU]*cmon[BLU]/lum; |
243 |
cs[3*i+2] = d>=.999 ? 255 : |
244 |
245 |
246 |
returnOK; |
247 |
248 |
249 |
250 |
int |
251 |
tmAddHisto(ls, len, wt) /* add values to histogram */ |
252 |
register TMbright *ls; |
253 |
int len; |
254 |
int wt; |
255 |
256 |
static char funcName[] = "tmAddHisto"; |
257 |
int sum, oldorig, oldlen, horig, hlen; |
258 |
259 |
260 |
if (len <= 0) |
261 |
262 |
263 |
264 |
/* first, grow limits */ |
265 |
if (tmTop->histo == NULL) { |
266 |
for (i = len; i-- && ls[i] < MINBRT; ) |
267 |
268 |
if (i < 0) |
269 |
returnOK; |
270 |
tmTop->hbrmin = tmTop->hbrmax = ls[i]; |
271 |
oldlen = 0; |
272 |
} else { |
273 |
oldorig = (tmTop->hbrmin-MINBRT)/HISTEP; |
274 |
oldlen = (tmTop->hbrmax-MINBRT)/HISTEP + 1 - oldorig; |
275 |
276 |
277 |
if ((j = ls[i]) < MINBRT) |
278 |
continue; |
279 |
if (j < tmTop->hbrmin) |
280 |
tmTop->hbrmin = j; |
281 |
else if (j > tmTop->hbrmax) |
282 |
tmTop->hbrmax = j; |
283 |
284 |
horig = (tmTop->hbrmin-MINBRT)/HISTEP; |
285 |
hlen = (tmTop->hbrmax-MINBRT)/HISTEP + 1 - horig; |
286 |
if (hlen > oldlen) { /* (re)allocate histogram */ |
287 |
register int *newhist = (int *)calloc(hlen, sizeof(int)); |
288 |
if (newhist == NULL) |
289 |
returnErr(TM_E_NOMEM); |
290 |
if (oldlen) { /* copy and free old */ |
291 |
for (i = oldlen, j = i+oldorig-horig; i; ) |
292 |
newhist[--j] = tmTop->histo[--i]; |
293 |
294 |
295 |
tmTop->histo = newhist; |
296 |
297 |
if (wt == 0) |
298 |
returnOK; |
299 |
for (i = len; i--; ) /* add in new counts */ |
300 |
if (ls[i] >= MINBRT) |
301 |
tmTop->histo[ (ls[i]-MINBRT)/HISTEP - horig ] += wt; |
302 |
returnOK; |
303 |
304 |
305 |
306 |
static double |
307 |
htcontrs(La) /* human threshold contrast sensitivity, dL(La) */ |
308 |
double La; |
309 |
310 |
double l10La, l10dL; |
311 |
/* formula taken from Ferwerda et al. [SG96] */ |
312 |
if (La < 1.148e-4) |
313 |
return(1.38e-3); |
314 |
l10La = log10(La); |
315 |
if (l10La < -1.44) /* rod response regime */ |
316 |
l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86; |
317 |
else if (l10La < -.0184) |
318 |
l10dL = l10La - .395; |
319 |
else if (l10La < 1.9) /* cone response regime */ |
320 |
l10dL = pow(.249*l10La + .65, 2.7) - .72; |
321 |
else |
322 |
l10dL = l10La - 1.255; |
323 |
324 |
return(exp10(l10dL)); |
325 |
326 |
327 |
328 |
int |
329 |
tmComputeMapping(gamval, Lddyn, Ldmax) |
330 |
double gamval; |
331 |
double Lddyn; |
332 |
double Ldmax; |
333 |
334 |
static char funcName[] = "tmComputeMapping"; |
335 |
int *histo; |
336 |
float *cumf; |
337 |
int brt0, histlen, histot, threshold, ceiling, trimmings; |
338 |
double logLddyn, Ldmin, Ldavg, Lwavg, Tr, Lw, Ld; |
339 |
int4 sum; |
340 |
341 |
342 |
343 |
344 |
345 |
/* check arguments */ |
346 |
if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN; |
347 |
if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX; |
348 |
if (gamval < MINGAM) gamval = tmTop->mongam; |
349 |
/* compute handy values */ |
350 |
Ldmin = Ldmax/Lddyn; |
351 |
logLddyn = log(Lddyn); |
352 |
Ldavg = sqrt(Ldmax*Ldmin); |
353 |
i = (tmTop->hbrmin-MINBRT)/HISTEP; |
354 |
brt0 = MINBRT + HISTEP/2 + i*HISTEP; |
355 |
histlen = (tmTop->hbrmax-MINBRT)/HISTEP + 1 - i; |
356 |
/* histogram total and mean */ |
357 |
histot = 0; sum = 0; |
358 |
j = brt0 + histlen*HISTEP; |
359 |
for (i = histlen; i--; ) { |
360 |
histot += tmTop->histo[i]; |
361 |
sum += (j -= HISTEP) * tmTop->histo[i]; |
362 |
363 |
threshold = histot*.025 + .5; |
364 |
if (threshold < 4) |
365 |
returnErr(TM_E_TMFAIL); |
366 |
Lwavg = tmLuminance( (double)sum / histot ); |
367 |
if (!(tmTop->flags & TM_F_LINEAR)) { /* clamp histogram */ |
368 |
histo = (int *)malloc(histlen*sizeof(int)); |
369 |
cumf = (float *)malloc((histlen+1)*sizeof(float)); |
370 |
if (histo == NULL | cumf == NULL) |
371 |
372 |
for (i = histlen; i--; ) /* make malleable copy */ |
373 |
histo[i] = tmTop->histo[i]; |
374 |
do { /* iterate to solution */ |
375 |
sum = 0; /* cumulative probability */ |
376 |
for (i = 0; i < histlen; i++) { |
377 |
cumf[i] = (double)sum/histot; |
378 |
sum += histo[i]; |
379 |
380 |
cumf[i] = 1.; |
381 |
Tr = histot * (double)(tmTop->hbrmax - tmTop->hbrmin) / |
382 |
((double)histlen*TM_BRTSCALE) / logLddyn; |
383 |
ceiling = Tr + 1.; |
384 |
trimmings = 0; /* clip to envelope */ |
385 |
386 |
if (tmTop->flags & TM_F_HCONTR) { |
387 |
Lw = tmLuminance(brt0 + i*HISTEP); |
388 |
Ld = Ldmin * exp( logLddyn * |
389 |
.5*(cumf[i]+cumf[i+1]) ); |
390 |
ceiling = Tr * (htcontrs(Ld) * Lw) / |
391 |
(htcontrs(Lw) * Ld) + 1.; |
392 |
393 |
if (histo[i] > ceiling) { |
394 |
trimmings += histo[i] - ceiling; |
395 |
histo[i] = ceiling; |
396 |
397 |
398 |
} while ((histot -= trimmings) > threshold && |
399 |
trimmings > threshold); |
400 |
401 |
/* allocate luminance map */ |
402 |
if (tmTop->lumap != NULL) |
403 |
free((MEM_PTR)tmTop->lumap); |
404 |
tmTop->mbrmin = tmTop->hbrmin; |
405 |
tmTop->mbrmax = tmTop->hbrmax; |
406 |
tmTop->lumap = (unsigned short *)malloc( |
407 |
(tmTop->mbrmax-tmTop->mbrmin+1)*sizeof(unsigned short) ); |
408 |
if (tmTop->lumap == NULL) |
409 |
410 |
if (tmTop->flags & TM_F_LINEAR || histot <= threshold) { |
411 |
/* linear tone mapping */ |
412 |
if (tmTop->flags & TM_F_HCONTR) |
413 |
d = htcontrs(Ldavg) / htcontrs(Lwavg); |
414 |
else |
415 |
d = Ldavg / Lwavg; |
416 |
d = log(d/Ldmax); |
417 |
for (i = tmTop->mbrmax-tmTop->mbrmin+1; i--; ) |
418 |
tmTop->lumap[i] = 256. * exp( |
419 |
( d + (tmTop->mbrmin+i)/(double)TM_BRTSCALE ) |
420 |
/ gamval ); |
421 |
} else { |
422 |
/* histogram adjustment */ |
423 |
for (i = tmTop->mbrmax-tmTop->mbrmin+1; i--; ) { |
424 |
j = d = (double)i/(tmTop->mbrmax-tmTop->mbrmin)*histlen; |
425 |
d -= (double)j; |
426 |
Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1])); |
427 |
d = (Ld - Ldmin)/(Ldmax - Ldmin); |
428 |
tmTop->lumap[i] = 256.*pow(d, 1./gamval); |
429 |
430 |
431 |
if (!(tmTop->flags & TM_F_LINEAR)) { |
432 |
free((MEM_PTR)histo); |
433 |
free((MEM_PTR)cumf); |
434 |
435 |
returnOK; |
436 |
437 |
438 |
439 |
int |
440 |
tmMapPixels(ps, ls, cs, len) |
441 |
register BYTE *ps; |
442 |
TMbright *ls; |
443 |
register BYTE *cs; |
444 |
int len; |
445 |
446 |
static char funcName[] = "tmMapPixels"; |
447 |
register int4 li, pv; |
448 |
449 |
if (tmTop == NULL || tmTop->lumap == NULL) |
450 |
451 |
if (ps == NULL | ls == NULL | len <= 0) |
452 |
453 |
while (len--) { |
454 |
if ((li = *ls++) < tmTop->mbrmin) |
455 |
li = tmTop->mbrmin; |
456 |
else if (li > tmTop->mbrmax) |
457 |
li = tmTop->mbrmax; |
458 |
li = tmTop->lumap[li - tmTop->mbrmin]; |
459 |
if (cs == TM_NOCHROM) |
460 |
*ps++ = li>255 ? 255 : li; |
461 |
else { |
462 |
pv = *cs++ * li / tmTop->cdiv[RED]; |
463 |
*ps++ = pv>255 ? 255 : pv; |
464 |
pv = *cs++ * li / tmTop->cdiv[GRN]; |
465 |
466 |
pv = *cs++ * li / tmTop->cdiv[BLU]; |
467 |
468 |
469 |
470 |
returnOK; |
471 |
472 |
473 |
474 |
struct tmStruct * |
475 |
tmPop() /* pop top tone mapping off stack */ |
476 |
477 |
register struct tmStruct *tms; |
478 |
479 |
if ((tms = tmTop) != NULL) |
480 |
tmTop = tms->tmprev; |
481 |
return(tms); |
482 |
483 |
484 |
485 |
int |
486 |
tmPull(tms) /* pull a tone mapping from stack */ |
487 |
488 |
489 |
register struct tmStruct *tms2; |
490 |
/* special cases first */ |
491 |
if (tms == NULL | tmTop == NULL) |
492 |
return(0); |
493 |
if (tms == tmTop) { |
494 |
495 |
tms->tmprev = NULL; |
496 |
return(1); |
497 |
498 |
for (tms2 = tmTop; tms2->tmprev != NULL; tms2 = tms2->tmprev) |
499 |
if (tms == tms2->tmprev) { /* remove it */ |
500 |
tms2->tmprev = tms->tmprev; |
501 |
502 |
return(1); |
503 |
504 |
return(0); /* not found on stack */ |
505 |
506 |
507 |
508 |
struct tmStruct * |
509 |
tmDup() /* duplicate top tone mapping */ |
510 |
511 |
int len; |
512 |
register int i; |
513 |
514 |
515 |
if (tmTop == NULL) /* anything to duplicate? */ |
516 |
return(NULL); |
517 |
518 |
519 |
return(NULL); |
520 |
*tmnew = *tmTop; /* copy everything */ |
521 |
if (tmnew->histo != NULL) { /* duplicate histogram */ |
522 |
len = (tmnew->hbrmax-MINBRT)/HISTEP + 1 - |
523 |
(tmnew->hbrmin-MINBRT)/HISTEP; |
524 |
tmnew->histo = (int *)malloc(len*sizeof(int)); |
525 |
if (tmnew->histo != NULL) |
526 |
for (i = len; i--; ) |
527 |
tmnew->histo[i] = tmTop->histo[i]; |
528 |
529 |
if (tmnew->lumap != NULL) { /* duplicate luminance mapping */ |
530 |
len = tmnew->mbrmax-tmnew->mbrmin+1; |
531 |
tmnew->lumap = (unsigned short *)malloc( |
532 |
len*sizeof(unsigned short) ); |
533 |
if (tmnew->lumap != NULL) |
534 |
535 |
tmnew->lumap[i] = tmTop->lumap[i]; |
536 |
537 |
/* clear package data */ |
538 |
539 |
540 |
tmnew->tmprev = tmTop; /* make copy current */ |
541 |
542 |
543 |
544 |
545 |
int |
546 |
tmPush(tms) /* push tone mapping on top of stack */ |
547 |
548 |
549 |
static char funcName[] = "tmPush"; |
550 |
/* check validity */ |
551 |
if (tms == NULL) |
552 |
553 |
if (tms == tmTop) /* check necessity */ |
554 |
returnOK; |
555 |
/* pull if already in stack */ |
556 |
(void)tmPull(tms); |
557 |
/* push it on top */ |
558 |
tms->tmprev = tmTop; |
559 |
tmTop = tms; |
560 |
returnOK; |
561 |
562 |
563 |
564 |
void |
565 |
tmDone(tms) /* done with tone mapping -- destroy it */ |
566 |
567 |
568 |
register int i; |
569 |
/* NULL arg. is equiv. to tmTop */ |
570 |
if (tms == NULL && (tms = tmTop) == NULL) |
571 |
return; |
572 |
/* take out of stack if present */ |
573 |
574 |
/* free tables */ |
575 |
if (tms->histo != NULL) |
576 |
free((MEM_PTR)tms->histo); |
577 |
if (tms->lumap != NULL) |
578 |
free((MEM_PTR)tms->lumap); |
579 |
/* free private data */ |
580 |
581 |
if (tms->pd[i] != NULL) |
582 |
(*tmPkg[i]->Free)(tms->pd[i]); |
583 |
free((MEM_PTR)tms); /* free basic structure */ |
584 |
