--- ray/src/common/tonemap.c 2005/01/07 20:33:02 3.16 +++ ray/src/common/tonemap.c 2006/05/10 15:34:17 3.24 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: tonemap.c,v 3.16 2005/01/07 20:33:02 greg Exp $"; +static const char RCSid[] = "$Id: tonemap.c,v 3.24 2006/05/10 15:34:17 greg Exp $"; #endif /* * Tone mapping functions. @@ -22,10 +22,12 @@ static const char RCSid[] = "$Id: tonemap.c,v 3.16 200 struct tmPackage *tmPkg[TM_MAXPKG]; int tmNumPkgs = 0; /* number of registered packages */ -int tmLastError; /* last error incurred by library */ -char *tmLastFunction; /* error-generating function name */ + /* luminance->brightness lookup */ +static TMbright *tmFloat2BrtLUT = NULL; +#define tmCvLumLUfp(pf) tmFloat2BrtLUT[*(int32 *)(pf) >> 15] + TMstruct * tmInit( /* initialize new tone mapping */ int flags, @@ -71,6 +73,7 @@ double gamval tmnew->inpsf = WHTEFFICACY; tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] = tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.; + tmnew->inpdat = NULL; tmnew->hbrmin = 10; tmnew->hbrmax = -10; tmnew->histo = NULL; tmnew->mbrmin = 10; tmnew->mbrmax = -10; @@ -78,6 +81,8 @@ double gamval /* zero private data */ for (i = TM_MAXPKG; i--; ) tmnew->pd[i] = NULL; + tmnew->lastError = TM_E_OK; + tmnew->lastFunc = "NoErr"; /* return new TMstruct */ return(tmnew); } @@ -87,10 +92,11 @@ int tmSetSpace( /* set input color space for conversions */ TMstruct *tms, RGBPRIMP pri, -double sf +double sf, +MEM_PTR dat ) { - static char funcName[] = "tmSetSpace"; + static const char funcName[] = "tmSetSpace"; int i, j; /* error check */ if (tms == NULL) @@ -98,10 +104,11 @@ double sf if (sf <= 1e-12) returnErr(TM_E_ILLEGAL); /* check if no change */ - if (pri == tms->inppri && FEQ(sf, tms->inpsf)) + if (pri == tms->inppri && FEQ(sf, tms->inpsf) && dat == tms->inpdat) returnOK; tms->inppri = pri; /* let's set it */ tms->inpsf = sf; + tms->inpdat = dat; if (tms->flags & TM_F_BW) { /* color doesn't matter */ tms->monpri = tms->inppri; /* eliminate xform */ @@ -147,7 +154,7 @@ double sf void -tmClearHisto( /* clear current histogram */ +tmClearHisto( /* clear current histogram */ TMstruct *tms ) { @@ -158,7 +165,94 @@ TMstruct *tms } +TMbright +tmCvLuminance( /* convert a single luminance */ +double lum +) +{ + double d; + +#ifdef isfinite + if (!isfinite(lum) || lum <= TM_NOLUM) +#else + if (lum <= TM_NOLUM) +#endif + return(TM_NOBRT); + d = TM_BRTSCALE*log(lum); + if (d > 0.) + return((TMbright)(d+.5)); + return((TMbright)(d-.5)); +} + + int +tmCvLums( /* convert luminances using lookup */ +TMbright *ls, +float *scan, +int len +) +{ + if (tmFloat2BrtLUT == NULL) { /* initialize lookup table */ + int32 i; + tmFloat2BrtLUT = (TMbright *)malloc(sizeof(TMbright)*0x10000); + if (tmFloat2BrtLUT == NULL) + return(TM_E_NOMEM); + for (i = 0; i < 0x10000; i++) { + int32 l = (i<<1 | 1) << 14; +#ifndef isfinite + if ((l & 0x7f800000) == 0x7f800000) + tmFloat2BrtLUT[i] = TM_NOBRT; + else +#endif + tmFloat2BrtLUT[i] = tmCvLuminance(*(float *)&l); + } + } + if (len <= 0) + return(TM_E_OK); + if ((ls == NULL) | (scan == NULL)) + return(TM_E_ILLEGAL); + while (len--) { + if (*scan <= TM_NOLUM) { + *ls++ = TM_NOBRT; + ++scan; + continue; + } + *ls++ = tmCvLumLUfp(scan++); + } + return(TM_E_OK); +} + + +int +tmCvGrays( /* convert float gray values */ +TMstruct *tms, +TMbright *ls, +float *scan, +int len +) +{ + static const char funcName[] = "tmCvGrays"; + double d; + int i; + + if (tms == NULL) + returnErr(TM_E_TMINVAL); + if ((ls == NULL) | (scan == NULL) | (len < 0)) + returnErr(TM_E_ILLEGAL); + if (tmFloat2BrtLUT == NULL) /* initialize */ + tmCvLums(NULL, NULL, 0); + for (i = len; i--; ) { + float lum = tms->inpsf * scan[i]; + if (lum <= TM_NOLUM) + ls[i] = TM_NOBRT; + else + ls[i] = tmCvLumLUfp(&lum); + } + returnOK; +} + + +int tmCvColors( /* convert float colors */ TMstruct *tms, TMbright *ls, @@ -167,17 +261,25 @@ COLOR *scan, int len ) { - static char funcName[] = "tmCvColors"; + static const char funcName[] = "tmCvColors"; static COLOR csmall = {.5*MINLUM, .5*MINLUM, .5*MINLUM}; + static BYTE gamtab[1024]; + static double curgam = .0; COLOR cmon; - double lum, slum; - double d; + float lum, slum, d; int i; if (tms == NULL) returnErr(TM_E_TMINVAL); if ((ls == NULL) | (scan == NULL) | (len < 0)) returnErr(TM_E_ILLEGAL); + if (tmFloat2BrtLUT == NULL) /* initialize */ + tmCvLums(NULL, NULL, 0); + if (cs != TM_NOCHROM && fabs(tms->mongam - curgam) > .02) { + curgam = tms->mongam; /* (re)build table */ + for (i = 1024; i--; ) + gamtab[i] = (int)(256.*pow((i+.5)/1024., 1./curgam)); + } for (i = len; i--; ) { if (tmNeedMatrix(tms)) { /* get monitor RGB */ colortrans(cmon, tms->cmat, scan[i]); @@ -186,22 +288,23 @@ int len cmon[GRN] = tms->inpsf*scan[i][GRN]; cmon[BLU] = tms->inpsf*scan[i][BLU]; } +#ifdef isfinite + if (!isfinite(cmon[RED]) || cmon[RED] < .0f) cmon[RED] = .0f; + if (!isfinite(cmon[GRN]) || cmon[GRN] < .0f) cmon[GRN] = .0f; + if (!isfinite(cmon[BLU]) || cmon[BLU] < .0f) cmon[BLU] = .0f; +#else + if (cmon[RED] < .0f) cmon[RED] = .0f; + if (cmon[GRN] < .0f) cmon[GRN] = .0f; + if (cmon[BLU] < .0f) cmon[BLU] = .0f; +#endif /* world luminance */ lum = tms->clf[RED]*cmon[RED] + tms->clf[GRN]*cmon[GRN] + tms->clf[BLU]*cmon[BLU] ; - /* check range */ - if (clipgamut(cmon, lum, CGAMUT_LOWER, csmall, cwhite)) - lum = tms->clf[RED]*cmon[RED] + - tms->clf[GRN]*cmon[GRN] + - tms->clf[BLU]*cmon[BLU] ; - if (lum < MINLUM) { - ls[i] = MINBRT-1; /* bogus value */ - lum = MINLUM; - } else { - d = TM_BRTSCALE*log(lum); /* encode it */ - ls[i] = d>0. ? (int)(d+.5) : (int)(d-.5); - } + if (lum <= TM_NOLUM) /* convert brightness */ + ls[i] = TM_NOBRT; + else + ls[i] = tmCvLumLUfp(&lum); if (cs == TM_NOCHROM) /* no color? */ continue; if (tms->flags & TM_F_MESOPIC && lum < LMESUPPER) { @@ -215,7 +318,7 @@ int len cmon[BLU] = d*lum; else scalecolor(cmon, d); - d = (1.-d)*slum; + d = (1.f-d)*slum; cmon[RED] += d; cmon[GRN] += d; cmon[BLU] += d; @@ -224,47 +327,17 @@ int len cmon[RED] = cmon[GRN] = cmon[BLU] = lum; } d = tms->clf[RED]*cmon[RED]/lum; - cs[3*i ] = d>=.999 ? 255 : - (int)(256.*pow(d, 1./tms->mongam)); + cs[3*i ] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)]; d = tms->clf[GRN]*cmon[GRN]/lum; - cs[3*i+1] = d>=.999 ? 255 : - (int)(256.*pow(d, 1./tms->mongam)); + cs[3*i+1] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)]; d = tms->clf[BLU]*cmon[BLU]/lum; - cs[3*i+2] = d>=.999 ? 255 : - (int)(256.*pow(d, 1./tms->mongam)); + cs[3*i+2] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)]; } returnOK; } int -tmCvGrays( /* convert float gray values */ -TMstruct *tms, -TMbright *ls, -float *scan, -int len -) -{ - static char funcName[] = "tmCvGrays"; - double d; - int i; - - if (tms == NULL) - returnErr(TM_E_TMINVAL); - if ((ls == NULL) | (scan == NULL) | (len < 0)) - returnErr(TM_E_ILLEGAL); - for (i = len; i--; ) - if (scan[i] <= TM_NOLUM) { - ls[i] = TM_NOBRT; /* bogus value */ - } else { - d = TM_BRTSCALE*log(scan[i]); /* encode it */ - ls[i] = d>0. ? (int)(d+.5) : (int)(d-.5); - } - returnOK; -} - - -int tmAddHisto( /* add values to histogram */ TMstruct *tms, TMbright *ls, @@ -272,7 +345,7 @@ int len, int wt ) { - static char funcName[] = "tmAddHisto"; + static const char funcName[] = "tmAddHisto"; int oldorig=0, oldlen, horig, hlen; int i, j; @@ -375,7 +448,7 @@ double expmult, double gamval ) { - static char funcName[] = "tmFixedMapping"; + static const char funcName[] = "tmFixedMapping"; double d; int i; @@ -402,7 +475,7 @@ double Lddyn, double Ldmax ) { - static char funcName[] = "tmComputeMapping"; + static const char funcName[] = "tmComputeMapping"; int *histo; float *cumf; int brt0, histlen, threshold, ceiling, trimmings; @@ -510,7 +583,7 @@ BYTE *cs, int len ) { - static char funcName[] = "tmMapPixels"; + static const char funcName[] = "tmMapPixels"; int32 li, pv; if (tms == NULL || tms->lumap == NULL) @@ -622,15 +695,17 @@ tmMkMesofact() /* build mesopic lookup factor table int tmErrorReturn( /* error return (with message) */ -char *func, +const char *func, TMstruct *tms, int err ) { - tmLastFunction = func; - tmLastError = err; - if (tms != NULL && tms->flags & TM_F_NOSTDERR) - return(err); + if (tms != NULL) { + tms->lastFunc = func; + tms->lastError = err; + if (tms->flags & TM_F_NOSTDERR) + return(err); + } fputs(func, stderr); fputs(": ", stderr); fputs(tmErrorMessage[err], stderr);
