--- ray/src/common/tonemap.c 1997/04/16 20:28:03 3.3 +++ ray/src/common/tonemap.c 2006/03/23 22:01:43 3.22 @@ -1,14 +1,16 @@ -/* Copyright (c) 1997 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: tonemap.c,v 3.22 2006/03/23 22:01:43 greg Exp $"; #endif - /* * Tone mapping functions. * See tonemap.h for detailed function descriptions. + * Added von Kries white-balance calculations 10/01 (GW). + * + * Externals declared in tonemap.h */ +#include "copyright.h" + #include #include #include "tmprivat.h" @@ -16,40 +18,29 @@ static char SCCSid[] = "$SunId$ LBL"; #define exp10(x) exp(M_LN10*(x)) -struct tmStruct *tmTop = NULL; /* current tone mapping stack */ + /* our list of conversion packages */ +struct tmPackage *tmPkg[TM_MAXPKG]; +int tmNumPkgs = 0; /* number of registered packages */ -int -tmErrorReturn(func, err) /* error return (with message) */ -char *func; -int err; +TMstruct * +tmInit( /* initialize new tone mapping */ +int flags, +RGBPRIMP monpri, +double gamval +) { - if (tmTop != NULL && tmTop->flags & TM_F_NOSTDERR) - return(err); - fputs(func, stderr); - fputs(": ", stderr); - fputs(tmErrorMessage[err], stderr); - fputs("!\n", stderr); - return(err); -} - - -struct tmStruct * -tmInit(flags, monpri, gamval) /* initialize new tone mapping */ -int flags; -RGBPRIMP monpri; -double gamval; -{ - static char funcName[] = "tmInit"; COLORMAT cmat; - register struct tmStruct *tmnew; - register int i; + TMstruct *tmnew; + int i; /* allocate structure */ - tmnew = (struct tmStruct *)malloc(sizeof(struct tmStruct)); + tmnew = (TMstruct *)malloc(sizeof(TMstruct)); if (tmnew == NULL) return(NULL); tmnew->flags = flags & ~TM_F_UNIMPL; + if (tmnew->flags & TM_F_BW) + tmnew->flags &= ~TM_F_MESOPIC; /* set monitor transform */ if (monpri == NULL || monpri == stdprims || tmnew->flags & TM_F_BW) { tmnew->monpri = stdprims; @@ -57,143 +48,167 @@ double gamval; tmnew->clf[GRN] = rgb2xyzmat[1][1]; tmnew->clf[BLU] = rgb2xyzmat[1][2]; } else { - comprgb2xyzmat(cmat, tmnew->monpri=monpri); + comprgb2xyzWBmat(cmat, tmnew->monpri=monpri); tmnew->clf[RED] = cmat[1][0]; tmnew->clf[GRN] = cmat[1][1]; tmnew->clf[BLU] = cmat[1][2]; } - tmnew->clfb[RED] = 256.*tmnew->clf[RED] + .5; - tmnew->clfb[GRN] = 256.*tmnew->clf[GRN] + .5; - tmnew->clfb[BLU] = 256.*tmnew->clf[BLU] + .5; - tmnew->clfb[EXP] = COLXS; /* set gamma value */ if (gamval < MINGAM) tmnew->mongam = DEFGAM; else tmnew->mongam = gamval; - for (i = TM_GAMTSZ; i--; ) - tmnew->gamb[i] = 256.*pow((i+.5)/TM_GAMTSZ, 1./tmnew->mongam); + /* set color divisors */ + for (i = 0; i < 3; i++) + tmnew->cdiv[i] = 256.*pow(tmnew->clf[i], 1./tmnew->mongam); + /* set input transform */ tmnew->inppri = tmnew->monpri; tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] = tmnew->inpsf = WHTEFFICACY; - tmnew->inpsfb = TM_BRTSCALE*log(tmnew->inpsf) + .5; tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] = tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.; - tmnew->flags &= ~TM_F_NEEDMAT; - tmnew->brmin = tmnew->brmax = 0; + tmnew->inpdat = NULL; + tmnew->hbrmin = 10; tmnew->hbrmax = -10; tmnew->histo = NULL; + tmnew->mbrmin = 10; tmnew->mbrmax = -10; tmnew->lumap = NULL; - tmnew->tmprev = NULL; - - tmnew->flags |= TM_F_INITED; - /* make it current */ - tmnew->tmprev = tmTop; - return(tmTop = tmnew); + /* zero private data */ + for (i = TM_MAXPKG; i--; ) + tmnew->pd[i] = NULL; + tmnew->lastError = TM_E_OK; + tmnew->lastFunc = "NoErr"; + /* return new TMstruct */ + return(tmnew); } int -tmSetSpace(pri, sf) /* set input color space for conversions */ -RGBPRIMP pri; -double sf; +tmSetSpace( /* set input color space for conversions */ +TMstruct *tms, +RGBPRIMP pri, +double sf, +MEM_PTR dat +) { - static char funcName[] = "tmSetSpace"; - register int i, j; + static const char funcName[] = "tmSetSpace"; + int i, j; /* error check */ - if (tmTop == NULL) + if (tms == NULL) returnErr(TM_E_TMINVAL); if (sf <= 1e-12) returnErr(TM_E_ILLEGAL); /* check if no change */ - if (pri == tmTop->inppri && FEQ(sf, tmTop->inpsf)) + if (pri == tms->inppri && FEQ(sf, tms->inpsf) && dat == tms->inpdat) returnOK; - tmTop->inppri = pri; /* let's set it */ - tmTop->inpsf = sf; - tmTop->inpsfb = TM_BRTSCALE*log(sf) + (sf>=1. ? .5 : -.5); + tms->inppri = pri; /* let's set it */ + tms->inpsf = sf; + tms->inpdat = dat; - if (tmTop->flags & TM_F_BW) { /* color doesn't matter */ - tmTop->monpri = tmTop->inppri; /* eliminate xform */ - if (tmTop->inppri == TM_XYZPRIM) { - tmTop->clf[CIEX] = tmTop->clf[CIEZ] = 0.; - tmTop->clf[CIEY] = 1.; - tmTop->clfb[CIEX] = tmTop->clfb[CIEZ] = 0; - tmTop->clfb[CIEY] = 255; + if (tms->flags & TM_F_BW) { /* color doesn't matter */ + tms->monpri = tms->inppri; /* eliminate xform */ + if (tms->inppri == TM_XYZPRIM) { + tms->clf[CIEX] = tms->clf[CIEZ] = 0.; + tms->clf[CIEY] = 1.; } else { - comprgb2xyzmat(tmTop->cmat, tmTop->monpri); - tmTop->clf[RED] = tmTop->cmat[1][0]; - tmTop->clf[GRN] = tmTop->cmat[1][1]; - tmTop->clf[BLU] = tmTop->cmat[1][2]; + comprgb2xyzWBmat(tms->cmat, tms->monpri); + tms->clf[RED] = tms->cmat[1][0]; + tms->clf[GRN] = tms->cmat[1][1]; + tms->clf[BLU] = tms->cmat[1][2]; } - tmTop->cmat[0][0] = tmTop->cmat[1][1] = tmTop->cmat[2][2] = - tmTop->inpsf; - tmTop->cmat[0][1] = tmTop->cmat[0][2] = tmTop->cmat[1][0] = - tmTop->cmat[1][2] = tmTop->cmat[2][0] = tmTop->cmat[2][1] = 0.; + tms->cmat[0][0] = tms->cmat[1][1] = tms->cmat[2][2] = + tms->inpsf; + tms->cmat[0][1] = tms->cmat[0][2] = tms->cmat[1][0] = + tms->cmat[1][2] = tms->cmat[2][0] = tms->cmat[2][1] = 0.; - } else if (tmTop->inppri == TM_XYZPRIM) /* input is XYZ */ - compxyz2rgbmat(tmTop->cmat, tmTop->monpri); + } else if (tms->inppri == TM_XYZPRIM) /* input is XYZ */ + compxyz2rgbWBmat(tms->cmat, tms->monpri); else { /* input is RGB */ - if (tmTop->inppri != tmTop->monpri && - PRIMEQ(tmTop->inppri, tmTop->monpri)) - tmTop->inppri = tmTop->monpri; /* no xform */ - comprgb2rgbmat(tmTop->cmat, tmTop->inppri, tmTop->monpri); + if (tms->inppri != tms->monpri && + PRIMEQ(tms->inppri, tms->monpri)) + tms->inppri = tms->monpri; /* no xform */ + comprgb2rgbWBmat(tms->cmat, tms->inppri, tms->monpri); } for (i = 0; i < 3; i++) for (j = 0; j < 3; j++) - tmTop->cmat[i][j] *= tmTop->inpsf; - if (tmTop->inppri != tmTop->monpri) - tmTop->flags |= TM_F_NEEDMAT; - else - tmTop->flags &= ~TM_F_NEEDMAT; + tms->cmat[i][j] *= tms->inpsf; + /* set color divisors */ + for (i = 0; i < 3; i++) + if (tms->clf[i] > .001) + tms->cdiv[i] = + 256.*pow(tms->clf[i], 1./tms->mongam); + else + tms->cdiv[i] = 1; + /* notify packages */ + for (i = tmNumPkgs; i--; ) + if (tms->pd[i] != NULL && tmPkg[i]->NewSpace != NULL) + (*tmPkg[i]->NewSpace)(tms); returnOK; } void -tmClearHisto() /* clear current histogram */ +tmClearHisto( /* clear current histogram */ +TMstruct *tms +) { - if (tmTop == NULL || tmTop->histo == NULL) + if (tms == NULL || tms->histo == NULL) return; - free((char *)tmTop->histo); - tmTop->histo = NULL; + free((MEM_PTR)tms->histo); + tms->histo = NULL; } int -tmCvColors(ls, cs, scan, len) /* convert float colors */ -TMbright *ls; -BYTE *cs; -COLOR *scan; -int len; +tmCvColors( /* convert float colors */ +TMstruct *tms, +TMbright *ls, +BYTE *cs, +COLOR *scan, +int len +) { - static char funcName[] = "tmCvColors"; + static const char funcName[] = "tmCvColors"; + static COLOR csmall = {.5*MINLUM, .5*MINLUM, .5*MINLUM}; + static BYTE gamtab[1024]; + static double curgam = .0; COLOR cmon; double lum, slum; - register double d; - register int i; + double d; + int i; - if (tmTop == NULL) + if (tms == NULL) returnErr(TM_E_TMINVAL); - if (ls == NULL | scan == NULL | len <= 0) + if ((ls == NULL) | (scan == NULL) | (len < 0)) returnErr(TM_E_ILLEGAL); + if (cs != TM_NOCHROM && fabs(tms->mongam - curgam) > .02) { + curgam = tms->mongam; /* (re)build table */ + for (i = 1024; i--; ) + gamtab[i] = (int)(256.*pow((i+.5)/1024., 1./curgam)); + } for (i = len; i--; ) { - if (tmTop->flags & TM_F_NEEDMAT) /* get monitor RGB */ - colortrans(cmon, tmTop->cmat, scan[i]); - else { - cmon[RED] = tmTop->inpsf*scan[i][RED]; - cmon[GRN] = tmTop->inpsf*scan[i][GRN]; - cmon[BLU] = tmTop->inpsf*scan[i][BLU]; + if (tmNeedMatrix(tms)) { /* get monitor RGB */ + colortrans(cmon, tms->cmat, scan[i]); + } else { + cmon[RED] = tms->inpsf*scan[i][RED]; + cmon[GRN] = tms->inpsf*scan[i][GRN]; + cmon[BLU] = tms->inpsf*scan[i][BLU]; } +#ifdef isnan + if (isnan(cmon[RED]) || isinf(cmon[RED])) cmon[RED] = .0f; + if (isnan(cmon[GRN]) || isinf(cmon[GRN])) cmon[GRN] = .0f; + if (isnan(cmon[BLU]) || isinf(cmon[BLU])) cmon[BLU] = .0f; +#endif /* world luminance */ - lum = tmTop->clf[RED]*cmon[RED] + - tmTop->clf[GRN]*cmon[GRN] + - tmTop->clf[BLU]*cmon[BLU] ; + lum = tms->clf[RED]*cmon[RED] + + tms->clf[GRN]*cmon[GRN] + + tms->clf[BLU]*cmon[BLU] ; /* check range */ - if (clipgamut(cmon, lum, CGAMUT_LOWER, cblack, cwhite)) - lum = tmTop->clf[RED]*cmon[RED] + - tmTop->clf[GRN]*cmon[GRN] + - tmTop->clf[BLU]*cmon[BLU] ; + if (clipgamut(cmon, lum, CGAMUT_LOWER, csmall, cwhite)) + lum = tms->clf[RED]*cmon[RED] + + tms->clf[GRN]*cmon[GRN] + + tms->clf[BLU]*cmon[BLU] ; if (lum < MINLUM) { ls[i] = MINBRT-1; /* bogus value */ lum = MINLUM; @@ -203,13 +218,13 @@ int len; } if (cs == TM_NOCHROM) /* no color? */ continue; - if (tmTop->flags & TM_F_MESOPIC && lum < LMESUPPER) { + if (tms->flags & TM_F_MESOPIC && lum < LMESUPPER) { slum = scotlum(cmon); /* mesopic adj. */ if (lum < LMESLOWER) cmon[RED] = cmon[GRN] = cmon[BLU] = slum; else { d = (lum - LMESLOWER)/(LMESUPPER - LMESLOWER); - if (tmTop->flags & TM_F_BW) + if (tms->flags & TM_F_BW) cmon[RED] = cmon[GRN] = cmon[BLU] = d*lum; else @@ -219,86 +234,127 @@ int len; cmon[GRN] += d; cmon[BLU] += d; } - } else if (tmTop->flags & TM_F_BW) { + } else if (tms->flags & TM_F_BW) { cmon[RED] = cmon[GRN] = cmon[BLU] = lum; } - d = tmTop->clf[RED]*cmon[RED]/lum; - /* cs[3*i ] = d>.999 ? 255 : 256.*pow(d, 1./tmTop->mongam); */ - cs[3*i ] = d>.999 ? 255 : tmTop->gamb[(int)(d*TM_GAMTSZ)]; - d = tmTop->clf[GRN]*cmon[GRN]/lum; - /* cs[3*i+1] = d>.999 ? 255 : 256.*pow(d, 1./tmTop->mongam); */ - cs[3*i+1] = d>.999 ? 255 : tmTop->gamb[(int)(d*TM_GAMTSZ)]; - d = tmTop->clf[BLU]*cmon[BLU]/lum; - /* cs[3*i+2] = d>.999 ? 255 : 256.*pow(d, 1./tmTop->mongam); */ - cs[3*i+2] = d>.999 ? 255 : tmTop->gamb[(int)(d*TM_GAMTSZ)]; + d = tms->clf[RED]*cmon[RED]/lum; + cs[3*i ] = d>=.999 ? 255 : gamtab[(int)(1024.*d)]; + d = tms->clf[GRN]*cmon[GRN]/lum; + cs[3*i+1] = d>=.999 ? 255 : gamtab[(int)(1024.*d)]; + d = tms->clf[BLU]*cmon[BLU]/lum; + cs[3*i+2] = d>=.999 ? 255 : gamtab[(int)(1024.*d)]; } returnOK; } +TMbright +tmCvLuminance( /* convert a single luminance */ +double lum +) +{ + double d; + + if (lum <= TM_NOLUM) + return(TM_NOBRT); + d = TM_BRTSCALE*log(lum); + if (d > 0.) + return((TMbright)(d+.5)); + return((TMbright)(d-.5)); +} + + int -tmAddHisto(ls, len, wt) /* add values to histogram */ -register TMbright *ls; -int len; -int wt; +tmCvGrays( /* convert float gray values */ +TMstruct *tms, +TMbright *ls, +float *scan, +int len +) { - static char funcName[] = "tmAddHisto"; - int sum, oldorig, oldlen, horig, hlen; - register int i, j; + static const char funcName[] = "tmCvGrays"; + double d; + int i; - if (len <= 0) + if (tms == NULL) + returnErr(TM_E_TMINVAL); + if ((ls == NULL) | (scan == NULL) | (len < 0)) returnErr(TM_E_ILLEGAL); - if (tmTop == NULL) + for (i = len; i--; ) + if (scan[i] <= TM_NOLUM) { + ls[i] = TM_NOBRT; /* bogus value */ + } else { + d = TM_BRTSCALE*log(scan[i]); /* encode it */ + ls[i] = d>0. ? (int)(d+.5) : (int)(d-.5); + } + returnOK; +} + + +int +tmAddHisto( /* add values to histogram */ +TMstruct *tms, +TMbright *ls, +int len, +int wt +) +{ + static const char funcName[] = "tmAddHisto"; + int oldorig=0, oldlen, horig, hlen; + int i, j; + + if (tms == NULL) returnErr(TM_E_TMINVAL); + if (len < 0) + returnErr(TM_E_ILLEGAL); + if (len == 0) + returnOK; /* first, grow limits */ - if (tmTop->histo == NULL) { + if (tms->histo == NULL) { for (i = len; i-- && ls[i] < MINBRT; ) ; if (i < 0) returnOK; - tmTop->brmin = tmTop->brmax = ls[i]; + tms->hbrmin = tms->hbrmax = ls[i]; oldlen = 0; } else { - oldorig = (tmTop->brmin-MINBRT)/HISTEP; - oldlen = (tmTop->brmax-MINBRT)/HISTEP + 1 - oldorig; + oldorig = (tms->hbrmin-MINBRT)/HISTEP; + oldlen = (tms->hbrmax-MINBRT)/HISTEP + 1 - oldorig; } for (i = len; i--; ) { if ((j = ls[i]) < MINBRT) continue; - if (j < tmTop->brmin) - tmTop->brmin = j; - else if (j > tmTop->brmax) - tmTop->brmax = j; + if (j < tms->hbrmin) + tms->hbrmin = j; + else if (j > tms->hbrmax) + tms->hbrmax = j; } - horig = (tmTop->brmin-MINBRT)/HISTEP; - hlen = (tmTop->brmax-MINBRT)/HISTEP + 1 - horig; + horig = (tms->hbrmin-MINBRT)/HISTEP; + hlen = (tms->hbrmax-MINBRT)/HISTEP + 1 - horig; if (hlen > oldlen) { /* (re)allocate histogram */ - register int *newhist = (int *)calloc(hlen, sizeof(int)); + int *newhist = (int *)calloc(hlen, sizeof(int)); if (newhist == NULL) returnErr(TM_E_NOMEM); if (oldlen) { /* copy and free old */ for (i = oldlen, j = i+oldorig-horig; i; ) - newhist[--j] = tmTop->histo[--i]; - free((char *)tmTop->histo); + newhist[--j] = tms->histo[--i]; + free((MEM_PTR)tms->histo); } - tmTop->histo = newhist; - if (tmTop->lumap != NULL) { /* invalid tone map */ - free((char *)tmTop->lumap); - tmTop->lumap = NULL; - } + tms->histo = newhist; } if (wt == 0) returnOK; for (i = len; i--; ) /* add in new counts */ if (ls[i] >= MINBRT) - tmTop->histo[ (ls[i]-MINBRT)/HISTEP - horig ] += wt; + tms->histo[ (ls[i]-MINBRT)/HISTEP - horig ] += wt; returnOK; } static double -htcontrs(La) /* human threshold contrast sensitivity, dL(La) */ -double La; +htcontrs( /* human threshold contrast sensitivity, dL(La) */ +double La +) { double l10La, l10dL; /* formula taken from Ferwerda et al. [SG96] */ @@ -318,147 +374,192 @@ double La; } +static int +tmNewMap( /* allocate new tone-mapping array */ +TMstruct *tms +) +{ + if (tms->lumap != NULL && (tms->mbrmax - tms->mbrmin) != + (tms->hbrmax - tms->hbrmin)) { + free((MEM_PTR)tms->lumap); + tms->lumap = NULL; + } + tms->mbrmin = tms->hbrmin; + tms->mbrmax = tms->hbrmax; + if (tms->mbrmin > tms->mbrmax) + return 0; + if (tms->lumap == NULL) + tms->lumap = (unsigned short *)malloc(sizeof(unsigned short)* + (tms->mbrmax-tms->mbrmin+1)); + return(tms->lumap != NULL); +} + + int -tmComputeMapping(gamval, Lddyn, Ldmax) -double gamval; -double Lddyn; -double Ldmax; +tmFixedMapping( /* compute fixed, linear tone-mapping */ +TMstruct *tms, +double expmult, +double gamval +) { - static char funcName[] = "tmComputeMapping"; + static const char funcName[] = "tmFixedMapping"; + double d; + int i; + + if (!tmNewMap(tms)) + returnErr(TM_E_NOMEM); + if (expmult <= .0) + expmult = 1.; + if (gamval < MINGAM) + gamval = tms->mongam; + d = log(expmult/tms->inpsf); + for (i = tms->mbrmax-tms->mbrmin+1; i--; ) + tms->lumap[i] = 256. * exp( + ( d + (tms->mbrmin+i)*(1./TM_BRTSCALE) ) + / gamval ); + returnOK; +} + + +int +tmComputeMapping( /* compute histogram tone-mapping */ +TMstruct *tms, +double gamval, +double Lddyn, +double Ldmax +) +{ + static const char funcName[] = "tmComputeMapping"; int *histo; float *cumf; - int brt0, histlen, histot, threshold, ceiling, trimmings; + int brt0, histlen, threshold, ceiling, trimmings; double logLddyn, Ldmin, Ldavg, Lwavg, Tr, Lw, Ld; - int4 sum; - register double d; - register int i, j; + int32 histot; + double sum; + double d; + int i, j; - if (tmTop == NULL || tmTop->histo == NULL) + if (tms == NULL || tms->histo == NULL) returnErr(TM_E_TMINVAL); /* check arguments */ if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN; if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX; - if (gamval < MINGAM) gamval = tmTop->mongam; + if (gamval < MINGAM) gamval = tms->mongam; /* compute handy values */ Ldmin = Ldmax/Lddyn; logLddyn = log(Lddyn); Ldavg = sqrt(Ldmax*Ldmin); - i = (tmTop->brmin-MINBRT)/HISTEP; + i = (tms->hbrmin-MINBRT)/HISTEP; brt0 = MINBRT + HISTEP/2 + i*HISTEP; - histlen = (tmTop->brmax-MINBRT)/HISTEP + 1 - i; + histlen = (tms->hbrmax-MINBRT)/HISTEP + 1 - i; /* histogram total and mean */ histot = 0; sum = 0; j = brt0 + histlen*HISTEP; for (i = histlen; i--; ) { - histot += tmTop->histo[i]; - sum += (j -= HISTEP) * tmTop->histo[i]; + histot += tms->histo[i]; + sum += (j -= HISTEP) * tms->histo[i]; } - threshold = histot*.025 + .5; + threshold = histot*0.005 + .5; if (threshold < 4) returnErr(TM_E_TMFAIL); Lwavg = tmLuminance( (double)sum / histot ); - if (!(tmTop->flags & TM_F_LINEAR)) { /* clamp histogram */ - histo = (int *)malloc(histlen*sizeof(int)); - cumf = (float *)malloc((histlen+1)*sizeof(float)); - if (histo == NULL | cumf == NULL) - returnErr(TM_E_NOMEM); - for (i = histlen; i--; ) /* make malleable copy */ - histo[i] = tmTop->histo[i]; - do { /* iterate to solution */ - sum = 0; /* cumulative probability */ - for (i = 0; i < histlen; i++) { - cumf[i] = (double)sum/histot; - sum += histo[i]; + /* allocate space for mapping */ + if (!tmNewMap(tms)) + returnErr(TM_E_NOMEM); + /* use linear tone mapping? */ + if (tms->flags & TM_F_LINEAR) + goto linearmap; + /* clamp histogram */ + histo = (int *)malloc(histlen*sizeof(int)); + cumf = (float *)malloc((histlen+2)*sizeof(float)); + if ((histo == NULL) | (cumf == NULL)) + returnErr(TM_E_NOMEM); + cumf[histlen+1] = 1.; /* guard for assignment code */ + for (i = histlen; i--; ) /* make malleable copy */ + histo[i] = tms->histo[i]; + do { /* iterate to solution */ + sum = 0; /* cumulative probability */ + for (i = 0; i < histlen; i++) { + cumf[i] = (double)sum/histot; + sum += histo[i]; + } + cumf[histlen] = 1.; + Tr = histot * (double)(tms->hbrmax - tms->hbrmin) / + ((double)histlen*TM_BRTSCALE) / logLddyn; + ceiling = Tr + 1.; + trimmings = 0; /* clip to envelope */ + for (i = histlen; i--; ) { + if (tms->flags & TM_F_HCONTR) { + Lw = tmLuminance(brt0 + i*HISTEP); + Ld = Ldmin * exp( logLddyn * + .5*(cumf[i]+cumf[i+1]) ); + ceiling = Tr * (htcontrs(Ld) * Lw) / + (htcontrs(Lw) * Ld) + 1.; } - cumf[i] = 1.; - Tr = histot * (double)(tmTop->brmax - tmTop->brmin) / - ((double)histlen*TM_BRTSCALE) / logLddyn; - ceiling = Tr + 1.; - trimmings = 0; /* clip to envelope */ - for (i = histlen; i--; ) { - if (tmTop->flags & TM_F_HCONTR) { - Lw = tmLuminance(brt0 + i*HISTEP); - Ld = Ldmin * exp( logLddyn * - .5*(cumf[i]+cumf[i+1]) ); - ceiling = Tr * (htcontrs(Ld) * Lw) / - (htcontrs(Lw) * Ld) + 1.; - } - if (histo[i] > ceiling) { - trimmings += histo[i] - ceiling; - histo[i] = ceiling; - } + if (histo[i] > ceiling) { + trimmings += histo[i] - ceiling; + histo[i] = ceiling; } - } while ((histot -= trimmings) > threshold && - trimmings > threshold); - } - /* allocate luminance map */ - if (tmTop->lumap == NULL) { - tmTop->lumap = (unsigned short *)malloc( - (tmTop->brmax-tmTop->brmin+1)*sizeof(unsigned short) ); - if (tmTop->lumap == NULL) - returnErr(TM_E_NOMEM); - } - if (tmTop->flags & TM_F_LINEAR || histot <= threshold) { - /* linear tone mapping */ - if (tmTop->flags & TM_F_HCONTR) - d = htcontrs(Ldavg) / htcontrs(Lwavg); - else - d = Ldavg / Lwavg; - d = log(d/Ldmax); - for (i = tmTop->brmax-tmTop->brmin+1; i--; ) - tmTop->lumap[i] = 256. * exp( - ( d + (tmTop->brmin+i)/(double)TM_BRTSCALE ) - / gamval ); - } else { - /* histogram adjustment */ - for (i = tmTop->brmax-tmTop->brmin+1; i--; ) { - j = d = (double)i/(tmTop->brmax-tmTop->brmin)*histlen; - d -= (double)j; - Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1])); - d = (Ld - Ldmin)/(Ldmax - Ldmin); - tmTop->lumap[i] = 256.*pow(d, 1./gamval); } + /* check if we're out of data */ + if ((histot -= trimmings) <= threshold) { + free((MEM_PTR)histo); + free((MEM_PTR)cumf); + goto linearmap; + } + } while (trimmings > threshold); + /* assign tone-mapping */ + for (i = tms->mbrmax-tms->mbrmin+1; i--; ) { + j = d = (double)i/(tms->mbrmax-tms->mbrmin)*histlen; + d -= (double)j; + Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1])); + d = (Ld - Ldmin)/(Ldmax - Ldmin); + tms->lumap[i] = 256.*pow(d, 1./gamval); } - if (!(tmTop->flags & TM_F_LINEAR)) { - free((char *)histo); - free((char *)cumf); - } + free((MEM_PTR)histo); /* clean up and return */ + free((MEM_PTR)cumf); returnOK; +linearmap: /* linear tone-mapping */ + if (tms->flags & TM_F_HCONTR) + d = htcontrs(Ldavg) / htcontrs(Lwavg); + else + d = Ldavg / Lwavg; + return(tmFixedMapping(tms, tms->inpsf*d/Ldmax, gamval)); } int -tmMapPixels(ps, ls, cs, len) -register BYTE *ps; -TMbright *ls; -register BYTE *cs; -int len; +tmMapPixels( /* apply tone-mapping to pixel(s) */ +TMstruct *tms, +BYTE *ps, +TMbright *ls, +BYTE *cs, +int len +) { - static char funcName[] = "tmMapPixels"; - int rdiv, gdiv, bdiv; - register int li, pv; + static const char funcName[] = "tmMapPixels"; + int32 li, pv; - if (tmTop == NULL || tmTop->lumap == NULL) + if (tms == NULL || tms->lumap == NULL) returnErr(TM_E_TMINVAL); - if (ps == NULL | ls == NULL | len <= 0) + if ((ps == NULL) | (ls == NULL) | (len < 0)) returnErr(TM_E_ILLEGAL); - rdiv = tmTop->gamb[((int4)TM_GAMTSZ*tmTop->clfb[RED])>>8]; - gdiv = tmTop->gamb[((int4)TM_GAMTSZ*tmTop->clfb[GRN])>>8]; - bdiv = tmTop->gamb[((int4)TM_GAMTSZ*tmTop->clfb[BLU])>>8]; while (len--) { - if ((li = *ls++) < tmTop->brmin) - li = tmTop->brmin; - else if (li > tmTop->brmax) - li = tmTop->brmax; - li = tmTop->lumap[li - tmTop->brmin]; + if ((li = *ls++) < tms->mbrmin) { + li = 0; + } else { + if (li > tms->mbrmax) + li = tms->mbrmax; + li = tms->lumap[li - tms->mbrmin]; + } if (cs == TM_NOCHROM) *ps++ = li>255 ? 255 : li; else { - pv = *cs++ * li / rdiv; + pv = *cs++ * li / tms->cdiv[RED]; *ps++ = pv>255 ? 255 : pv; - pv = *cs++ * li / gdiv; + pv = *cs++ * li / tms->cdiv[GRN]; *ps++ = pv>255 ? 255 : pv; - pv = *cs++ * li / bdiv; + pv = *cs++ * li / tms->cdiv[BLU]; *ps++ = pv>255 ? 255 : pv; } } @@ -466,107 +567,102 @@ int len; } -struct tmStruct * -tmPop() /* pop top tone mapping off stack */ -{ - register struct tmStruct *tms; - if ((tms = tmTop) != NULL) - tmTop = tms->tmprev; - return(tms); -} - -int -tmPull(tms) /* pull a tone mapping from stack */ -register struct tmStruct *tms; +TMstruct * +tmDup( /* duplicate top tone mapping */ +TMstruct *tms +) { - register struct tmStruct *tms2; - /* special cases first */ - if (tms == NULL | tmTop == NULL) - return(0); - if (tms == tmTop) { - tmTop = tms->tmprev; - tms->tmprev = NULL; - return(1); - } - for (tms2 = tmTop; tms2->tmprev != NULL; tms2 = tms2->tmprev) - if (tms == tms2->tmprev) { /* remove it */ - tms2->tmprev = tms->tmprev; - tms->tmprev = NULL; - return(1); - } - return(0); /* not found on stack */ -} - - -struct tmStruct * -tmDup() /* duplicate top tone mapping */ -{ int len; - register int i; - register struct tmStruct *tmnew; + int i; + TMstruct *tmnew; - if (tmTop == NULL) /* anything to duplicate? */ + if (tms == NULL) /* anything to duplicate? */ return(NULL); - tmnew = (struct tmStruct *)malloc(sizeof(struct tmStruct)); + tmnew = (TMstruct *)malloc(sizeof(TMstruct)); if (tmnew == NULL) return(NULL); - *tmnew = *tmTop; /* copy everything */ + *tmnew = *tms; /* copy everything */ if (tmnew->histo != NULL) { /* duplicate histogram */ - len = (tmnew->brmax-MINBRT)/HISTEP + 1 - - (tmnew->brmin-MINBRT)/HISTEP; + len = (tmnew->hbrmax-MINBRT)/HISTEP + 1 - + (tmnew->hbrmin-MINBRT)/HISTEP; tmnew->histo = (int *)malloc(len*sizeof(int)); if (tmnew->histo != NULL) for (i = len; i--; ) - tmnew->histo[i] = tmTop->histo[i]; + tmnew->histo[i] = tms->histo[i]; } if (tmnew->lumap != NULL) { /* duplicate luminance mapping */ - len = tmnew->brmax-tmnew->brmin+1; + len = tmnew->mbrmax-tmnew->mbrmin+1; tmnew->lumap = (unsigned short *)malloc( len*sizeof(unsigned short) ); if (tmnew->lumap != NULL) for (i = len; i--; ) - tmnew->lumap[i] = tmTop->lumap[i]; + tmnew->lumap[i] = tms->lumap[i]; } - tmnew->tmprev = tmTop; /* make copy current */ - return(tmTop = tmnew); + /* clear package data */ + for (i = tmNumPkgs; i--; ) + tmnew->pd[i] = NULL; + /* return copy */ + return(tmnew); } -int -tmPush(tms) /* push tone mapping on top of stack */ -register struct tmStruct *tms; -{ - static char funcName[] = "tmPush"; - /* check validity */ - if (tms == NULL || !(tms->flags & TM_F_INITED)) - returnErr(TM_E_ILLEGAL); - if (tms == tmTop) /* check necessity */ - returnOK; - /* pull if already in stack */ - (void)tmPull(tms); - /* push it on top */ - tms->tmprev = tmTop; - tmTop = tms; - returnOK; -} - - void tmDone(tms) /* done with tone mapping -- destroy it */ -register struct tmStruct *tms; +TMstruct *tms; { - /* NULL arg. is equiv. to tmTop */ - if (tms == NULL && (tms = tmTop) == NULL) + int i; + /* NULL arg. is equiv. to tms */ + if (tms == NULL) return; - /* take out of stack if present */ - (void)tmPull(tms); /* free tables */ if (tms->histo != NULL) - free((char *)tms->histo); + free((MEM_PTR)tms->histo); if (tms->lumap != NULL) - free((char *)tms->lumap); - tms->flags = 0; - free((char *)tms); /* free basic structure */ + free((MEM_PTR)tms->lumap); + /* free private data */ + for (i = tmNumPkgs; i--; ) + if (tms->pd[i] != NULL) + (*tmPkg[i]->Free)(tms->pd[i]); + free((MEM_PTR)tms); /* free basic structure */ +} + +/******************** Shared but Private library routines *********************/ + +BYTE tmMesofact[BMESUPPER-BMESLOWER]; + +void +tmMkMesofact() /* build mesopic lookup factor table */ +{ + int i; + + if (tmMesofact[BMESUPPER-BMESLOWER-1]) + return; + + for (i = BMESLOWER; i < BMESUPPER; i++) + tmMesofact[i-BMESLOWER] = 256. * + (tmLuminance(i) - LMESLOWER) / + (LMESUPPER - LMESLOWER); +} + + +int +tmErrorReturn( /* error return (with message) */ +const char *func, +TMstruct *tms, +int err +) +{ + if (tms != NULL) { + tms->lastFunc = func; + tms->lastError = err; + if (tms->flags & TM_F_NOSTDERR) + return(err); + } + fputs(func, stderr); + fputs(": ", stderr); + fputs(tmErrorMessage[err], stderr); + fputs("!\n", stderr); + return(err); }
