--- ray/src/common/tonemap.c 1997/04/18 13:59:43 3.4 +++ ray/src/common/tonemap.c 2004/07/22 17:48:52 3.15 @@ -1,14 +1,16 @@ -/* Copyright (c) 1997 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: tonemap.c,v 3.15 2004/07/22 17:48:52 greg Exp $"; #endif - /* * Tone mapping functions. * See tonemap.h for detailed function descriptions. + * Added von Kries white-balance calculations 10/01 (GW). + * + * Externals declared in tonemap.h */ +#include "copyright.h" + #include #include #include "tmprivat.h" @@ -22,29 +24,16 @@ struct tmStruct *tmTop = NULL; /* current tone mappin struct tmPackage *tmPkg[TM_MAXPKG]; int tmNumPkgs = 0; /* number of registered packages */ +int tmLastError; /* last error incurred by library */ +char *tmLastFunction; /* error-generating function name */ -int -tmErrorReturn(func, err) /* error return (with message) */ -char *func; -int err; -{ - if (tmTop != NULL && tmTop->flags & TM_F_NOSTDERR) - return(err); - fputs(func, stderr); - fputs(": ", stderr); - fputs(tmErrorMessage[err], stderr); - fputs("!\n", stderr); - return(err); -} - struct tmStruct * tmInit(flags, monpri, gamval) /* initialize new tone mapping */ int flags; RGBPRIMP monpri; double gamval; { - static char funcName[] = "tmInit"; COLORMAT cmat; register struct tmStruct *tmnew; register int i; @@ -54,6 +43,8 @@ double gamval; return(NULL); tmnew->flags = flags & ~TM_F_UNIMPL; + if (tmnew->flags & TM_F_BW) + tmnew->flags &= ~TM_F_MESOPIC; /* set monitor transform */ if (monpri == NULL || monpri == stdprims || tmnew->flags & TM_F_BW) { tmnew->monpri = stdprims; @@ -61,7 +52,7 @@ double gamval; tmnew->clf[GRN] = rgb2xyzmat[1][1]; tmnew->clf[BLU] = rgb2xyzmat[1][2]; } else { - comprgb2xyzmat(cmat, tmnew->monpri=monpri); + comprgb2xyzWBmat(cmat, tmnew->monpri=monpri); tmnew->clf[RED] = cmat[1][0]; tmnew->clf[GRN] = cmat[1][1]; tmnew->clf[BLU] = cmat[1][2]; @@ -81,8 +72,9 @@ double gamval; tmnew->inpsf = WHTEFFICACY; tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] = tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.; - tmnew->brmin = tmnew->brmax = 0; + tmnew->hbrmin = 10; tmnew->hbrmax = -10; tmnew->histo = NULL; + tmnew->mbrmin = 10; tmnew->mbrmax = -10; tmnew->lumap = NULL; /* zero private data */ for (i = TM_MAXPKG; i--; ) @@ -117,7 +109,7 @@ double sf; tmTop->clf[CIEX] = tmTop->clf[CIEZ] = 0.; tmTop->clf[CIEY] = 1.; } else { - comprgb2xyzmat(tmTop->cmat, tmTop->monpri); + comprgb2xyzWBmat(tmTop->cmat, tmTop->monpri); tmTop->clf[RED] = tmTop->cmat[1][0]; tmTop->clf[GRN] = tmTop->cmat[1][1]; tmTop->clf[BLU] = tmTop->cmat[1][2]; @@ -128,13 +120,13 @@ double sf; tmTop->cmat[1][2] = tmTop->cmat[2][0] = tmTop->cmat[2][1] = 0.; } else if (tmTop->inppri == TM_XYZPRIM) /* input is XYZ */ - compxyz2rgbmat(tmTop->cmat, tmTop->monpri); + compxyz2rgbWBmat(tmTop->cmat, tmTop->monpri); else { /* input is RGB */ if (tmTop->inppri != tmTop->monpri && PRIMEQ(tmTop->inppri, tmTop->monpri)) tmTop->inppri = tmTop->monpri; /* no xform */ - comprgb2rgbmat(tmTop->cmat, tmTop->inppri, tmTop->monpri); + comprgb2rgbWBmat(tmTop->cmat, tmTop->inppri, tmTop->monpri); } for (i = 0; i < 3; i++) for (j = 0; j < 3; j++) @@ -172,7 +164,7 @@ COLOR *scan; int len; { static char funcName[] = "tmCvColors"; - static COLOR csmall = {1e-6, 1e-6, 1e-6}; + static COLOR csmall = {.5*MINLUM, .5*MINLUM, .5*MINLUM}; COLOR cmon; double lum, slum; register double d; @@ -180,12 +172,12 @@ int len; if (tmTop == NULL) returnErr(TM_E_TMINVAL); - if (ls == NULL | scan == NULL | len <= 0) + if ((ls == NULL) | (scan == NULL) | (len < 0)) returnErr(TM_E_ILLEGAL); for (i = len; i--; ) { - if (tmNeedMatrix(tmTop)) /* get monitor RGB */ + if (tmNeedMatrix(tmTop)) { /* get monitor RGB */ colortrans(cmon, tmTop->cmat, scan[i]); - else { + } else { cmon[RED] = tmTop->inpsf*scan[i][RED]; cmon[GRN] = tmTop->inpsf*scan[i][GRN]; cmon[BLU] = tmTop->inpsf*scan[i][BLU]; @@ -242,41 +234,68 @@ int len; int +tmCvGrays(ls, scan, len) /* convert float gray values */ +TMbright *ls; +float *scan; +int len; +{ + static char funcName[] = "tmCvGrays"; + register double d; + register int i; + + if (tmTop == NULL) + returnErr(TM_E_TMINVAL); + if ((ls == NULL) | (scan == NULL) | (len < 0)) + returnErr(TM_E_ILLEGAL); + for (i = len; i--; ) + if (scan[i] <= TM_NOLUM) { + ls[i] = TM_NOBRT; /* bogus value */ + } else { + d = TM_BRTSCALE*log(scan[i]); /* encode it */ + ls[i] = d>0. ? (int)(d+.5) : (int)(d-.5); + } + returnOK; +} + + +int tmAddHisto(ls, len, wt) /* add values to histogram */ register TMbright *ls; int len; int wt; { static char funcName[] = "tmAddHisto"; - int sum, oldorig, oldlen, horig, hlen; + int oldorig=0, oldlen, horig, hlen; register int i, j; - if (len <= 0) - returnErr(TM_E_ILLEGAL); if (tmTop == NULL) returnErr(TM_E_TMINVAL); + if (len < 0) + returnErr(TM_E_ILLEGAL); + if (len == 0) + returnOK; /* first, grow limits */ if (tmTop->histo == NULL) { for (i = len; i-- && ls[i] < MINBRT; ) ; if (i < 0) returnOK; - tmTop->brmin = tmTop->brmax = ls[i]; + tmTop->hbrmin = tmTop->hbrmax = ls[i]; oldlen = 0; } else { - oldorig = (tmTop->brmin-MINBRT)/HISTEP; - oldlen = (tmTop->brmax-MINBRT)/HISTEP + 1 - oldorig; + oldorig = (tmTop->hbrmin-MINBRT)/HISTEP; + oldlen = (tmTop->hbrmax-MINBRT)/HISTEP + 1 - oldorig; } for (i = len; i--; ) { if ((j = ls[i]) < MINBRT) continue; - if (j < tmTop->brmin) - tmTop->brmin = j; - else if (j > tmTop->brmax) - tmTop->brmax = j; + if (j < tmTop->hbrmin) + tmTop->hbrmin = j; + else if (j > tmTop->hbrmax) + tmTop->hbrmax = j; } - horig = (tmTop->brmin-MINBRT)/HISTEP; - hlen = (tmTop->brmax-MINBRT)/HISTEP + 1 - horig; + horig = (tmTop->hbrmin-MINBRT)/HISTEP; + hlen = (tmTop->hbrmax-MINBRT)/HISTEP + 1 - horig; if (hlen > oldlen) { /* (re)allocate histogram */ register int *newhist = (int *)calloc(hlen, sizeof(int)); if (newhist == NULL) @@ -287,10 +306,6 @@ int wt; free((MEM_PTR)tmTop->histo); } tmTop->histo = newhist; - if (tmTop->lumap != NULL) { /* invalid tone map */ - free((MEM_PTR)tmTop->lumap); - tmTop->lumap = NULL; - } } if (wt == 0) returnOK; @@ -323,7 +338,50 @@ double La; } +static int +tmNewMap() +{ + if (tmTop->lumap != NULL && (tmTop->mbrmax - tmTop->mbrmin) != + (tmTop->hbrmax - tmTop->hbrmin)) { + free((MEM_PTR)tmTop->lumap); + tmTop->lumap = NULL; + } + tmTop->mbrmin = tmTop->hbrmin; + tmTop->mbrmax = tmTop->hbrmax; + if (tmTop->mbrmin > tmTop->mbrmax) + return 0; + if (tmTop->lumap == NULL) + tmTop->lumap = (unsigned short *)malloc(sizeof(unsigned short)* + (tmTop->mbrmax-tmTop->mbrmin+1)); + return(tmTop->lumap != NULL); +} + + int +tmFixedMapping(expmult, gamval) +double expmult; +double gamval; +{ + static char funcName[] = "tmFixedMapping"; + double d; + register int i; + + if (!tmNewMap()) + returnErr(TM_E_NOMEM); + if (expmult <= .0) + expmult = 1.; + if (gamval < MINGAM) + gamval = tmTop->mongam; + d = log(expmult/tmTop->inpsf); + for (i = tmTop->mbrmax-tmTop->mbrmin+1; i--; ) + tmTop->lumap[i] = 256. * exp( + ( d + (tmTop->mbrmin+i)*(1./TM_BRTSCALE) ) + / gamval ); + returnOK; +} + + +int tmComputeMapping(gamval, Lddyn, Ldmax) double gamval; double Lddyn; @@ -332,9 +390,10 @@ double Ldmax; static char funcName[] = "tmComputeMapping"; int *histo; float *cumf; - int brt0, histlen, histot, threshold, ceiling, trimmings; + int brt0, histlen, threshold, ceiling, trimmings; double logLddyn, Ldmin, Ldavg, Lwavg, Tr, Lw, Ld; - int4 sum; + int32 histot; + double sum; register double d; register int i, j; @@ -348,9 +407,9 @@ double Ldmax; Ldmin = Ldmax/Lddyn; logLddyn = log(Lddyn); Ldavg = sqrt(Ldmax*Ldmin); - i = (tmTop->brmin-MINBRT)/HISTEP; + i = (tmTop->hbrmin-MINBRT)/HISTEP; brt0 = MINBRT + HISTEP/2 + i*HISTEP; - histlen = (tmTop->brmax-MINBRT)/HISTEP + 1 - i; + histlen = (tmTop->hbrmax-MINBRT)/HISTEP + 1 - i; /* histogram total and mean */ histot = 0; sum = 0; j = brt0 + histlen*HISTEP; @@ -358,77 +417,72 @@ double Ldmax; histot += tmTop->histo[i]; sum += (j -= HISTEP) * tmTop->histo[i]; } - threshold = histot*.025 + .5; + threshold = histot*0.005 + .5; if (threshold < 4) returnErr(TM_E_TMFAIL); Lwavg = tmLuminance( (double)sum / histot ); - if (!(tmTop->flags & TM_F_LINEAR)) { /* clamp histogram */ - histo = (int *)malloc(histlen*sizeof(int)); - cumf = (float *)malloc((histlen+1)*sizeof(float)); - if (histo == NULL | cumf == NULL) - returnErr(TM_E_NOMEM); - for (i = histlen; i--; ) /* make malleable copy */ - histo[i] = tmTop->histo[i]; - do { /* iterate to solution */ - sum = 0; /* cumulative probability */ - for (i = 0; i < histlen; i++) { - cumf[i] = (double)sum/histot; - sum += histo[i]; + /* allocate space for mapping */ + if (!tmNewMap()) + returnErr(TM_E_NOMEM); + /* use linear tone mapping? */ + if (tmTop->flags & TM_F_LINEAR) + goto linearmap; + /* clamp histogram */ + histo = (int *)malloc(histlen*sizeof(int)); + cumf = (float *)malloc((histlen+2)*sizeof(float)); + if ((histo == NULL) | (cumf == NULL)) + returnErr(TM_E_NOMEM); + cumf[histlen+1] = 1.; /* guard for assignment code */ + for (i = histlen; i--; ) /* make malleable copy */ + histo[i] = tmTop->histo[i]; + do { /* iterate to solution */ + sum = 0; /* cumulative probability */ + for (i = 0; i < histlen; i++) { + cumf[i] = (double)sum/histot; + sum += histo[i]; + } + cumf[histlen] = 1.; + Tr = histot * (double)(tmTop->hbrmax - tmTop->hbrmin) / + ((double)histlen*TM_BRTSCALE) / logLddyn; + ceiling = Tr + 1.; + trimmings = 0; /* clip to envelope */ + for (i = histlen; i--; ) { + if (tmTop->flags & TM_F_HCONTR) { + Lw = tmLuminance(brt0 + i*HISTEP); + Ld = Ldmin * exp( logLddyn * + .5*(cumf[i]+cumf[i+1]) ); + ceiling = Tr * (htcontrs(Ld) * Lw) / + (htcontrs(Lw) * Ld) + 1.; } - cumf[i] = 1.; - Tr = histot * (double)(tmTop->brmax - tmTop->brmin) / - ((double)histlen*TM_BRTSCALE) / logLddyn; - ceiling = Tr + 1.; - trimmings = 0; /* clip to envelope */ - for (i = histlen; i--; ) { - if (tmTop->flags & TM_F_HCONTR) { - Lw = tmLuminance(brt0 + i*HISTEP); - Ld = Ldmin * exp( logLddyn * - .5*(cumf[i]+cumf[i+1]) ); - ceiling = Tr * (htcontrs(Ld) * Lw) / - (htcontrs(Lw) * Ld) + 1.; - } - if (histo[i] > ceiling) { - trimmings += histo[i] - ceiling; - histo[i] = ceiling; - } + if (histo[i] > ceiling) { + trimmings += histo[i] - ceiling; + histo[i] = ceiling; } - } while ((histot -= trimmings) > threshold && - trimmings > threshold); - } - /* allocate luminance map */ - if (tmTop->lumap == NULL) { - tmTop->lumap = (unsigned short *)malloc( - (tmTop->brmax-tmTop->brmin+1)*sizeof(unsigned short) ); - if (tmTop->lumap == NULL) - returnErr(TM_E_NOMEM); - } - if (tmTop->flags & TM_F_LINEAR || histot <= threshold) { - /* linear tone mapping */ - if (tmTop->flags & TM_F_HCONTR) - d = htcontrs(Ldavg) / htcontrs(Lwavg); - else - d = Ldavg / Lwavg; - d = log(d/Ldmax); - for (i = tmTop->brmax-tmTop->brmin+1; i--; ) - tmTop->lumap[i] = 256. * exp( - ( d + (tmTop->brmin+i)/(double)TM_BRTSCALE ) - / gamval ); - } else { - /* histogram adjustment */ - for (i = tmTop->brmax-tmTop->brmin+1; i--; ) { - j = d = (double)i/(tmTop->brmax-tmTop->brmin)*histlen; - d -= (double)j; - Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1])); - d = (Ld - Ldmin)/(Ldmax - Ldmin); - tmTop->lumap[i] = 256.*pow(d, 1./gamval); } + /* check if we're out of data */ + if ((histot -= trimmings) <= threshold) { + free((MEM_PTR)histo); + free((MEM_PTR)cumf); + goto linearmap; + } + } while (trimmings > threshold); + /* assign tone-mapping */ + for (i = tmTop->mbrmax-tmTop->mbrmin+1; i--; ) { + j = d = (double)i/(tmTop->mbrmax-tmTop->mbrmin)*histlen; + d -= (double)j; + Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1])); + d = (Ld - Ldmin)/(Ldmax - Ldmin); + tmTop->lumap[i] = 256.*pow(d, 1./gamval); } - if (!(tmTop->flags & TM_F_LINEAR)) { - free((MEM_PTR)histo); - free((MEM_PTR)cumf); - } + free((MEM_PTR)histo); /* clean up and return */ + free((MEM_PTR)cumf); returnOK; +linearmap: /* linear tone-mapping */ + if (tmTop->flags & TM_F_HCONTR) + d = htcontrs(Ldavg) / htcontrs(Lwavg); + else + d = Ldavg / Lwavg; + return(tmFixedMapping(tmTop->inpsf*d/Ldmax, gamval)); } @@ -440,18 +494,20 @@ register BYTE *cs; int len; { static char funcName[] = "tmMapPixels"; - register int4 li, pv; + register int32 li, pv; if (tmTop == NULL || tmTop->lumap == NULL) returnErr(TM_E_TMINVAL); - if (ps == NULL | ls == NULL | len <= 0) + if ((ps == NULL) | (ls == NULL) | (len < 0)) returnErr(TM_E_ILLEGAL); while (len--) { - if ((li = *ls++) < tmTop->brmin) - li = tmTop->brmin; - else if (li > tmTop->brmax) - li = tmTop->brmax; - li = tmTop->lumap[li - tmTop->brmin]; + if ((li = *ls++) < tmTop->mbrmin) { + li = 0; + } else { + if (li > tmTop->mbrmax) + li = tmTop->mbrmax; + li = tmTop->lumap[li - tmTop->mbrmin]; + } if (cs == TM_NOCHROM) *ps++ = li>255 ? 255 : li; else { @@ -484,7 +540,7 @@ register struct tmStruct *tms; { register struct tmStruct *tms2; /* special cases first */ - if (tms == NULL | tmTop == NULL) + if ((tms == NULL) | (tmTop == NULL)) return(0); if (tms == tmTop) { tmTop = tms->tmprev; @@ -515,15 +571,15 @@ tmDup() /* duplicate top tone mapping */ return(NULL); *tmnew = *tmTop; /* copy everything */ if (tmnew->histo != NULL) { /* duplicate histogram */ - len = (tmnew->brmax-MINBRT)/HISTEP + 1 - - (tmnew->brmin-MINBRT)/HISTEP; + len = (tmnew->hbrmax-MINBRT)/HISTEP + 1 - + (tmnew->hbrmin-MINBRT)/HISTEP; tmnew->histo = (int *)malloc(len*sizeof(int)); if (tmnew->histo != NULL) for (i = len; i--; ) tmnew->histo[i] = tmTop->histo[i]; } if (tmnew->lumap != NULL) { /* duplicate luminance mapping */ - len = tmnew->brmax-tmnew->brmin+1; + len = tmnew->mbrmax-tmnew->mbrmin+1; tmnew->lumap = (unsigned short *)malloc( len*sizeof(unsigned short) ); if (tmnew->lumap != NULL) @@ -577,4 +633,39 @@ register struct tmStruct *tms; if (tms->pd[i] != NULL) (*tmPkg[i]->Free)(tms->pd[i]); free((MEM_PTR)tms); /* free basic structure */ +} + +/******************** Shared but Private library routines *********************/ + +BYTE tmMesofact[BMESUPPER-BMESLOWER]; + +void +tmMkMesofact() /* build mesopic lookup factor table */ +{ + register int i; + + if (tmMesofact[BMESUPPER-BMESLOWER-1]) + return; + + for (i = BMESLOWER; i < BMESUPPER; i++) + tmMesofact[i-BMESLOWER] = 256. * + (tmLuminance(i) - LMESLOWER) / + (LMESUPPER - LMESLOWER); +} + + +int +tmErrorReturn(func, err) /* error return (with message) */ +char *func; +int err; +{ + tmLastFunction = func; + tmLastError = err; + if (tmTop != NULL && tmTop->flags & TM_F_NOSTDERR) + return(err); + fputs(func, stderr); + fputs(": ", stderr); + fputs(tmErrorMessage[err], stderr); + fputs("!\n", stderr); + return(err); }
