root/Development/ray/src/common/tonemap.c
Revision: 3.28
Committed: Wed Aug 9 16:26:54 2006 UTC (19 years, 5 months ago) by greg
Changes since 3.27: +6 -4 lines
Fixed overflow condition on fixed linear tone-mapping
2 static const char RCSid[] = "$Id: tonemap.c,v 3.27 2006/06/07 17:52:03 schorsch Exp $";
5 * Tone mapping functions.
6 * See tonemap.h for detailed function descriptions.
7 * Added von Kries white-balance calculations 10/01 (GW).
8 *
9 * Externals declared in tonemap.h
10 */
11
12 #include "copyright.h"
13
14 #include <stdio.h>
15 #include <math.h>
16 #include "tmprivat.h"
17 #include "tmerrmsg.h"
18
19 #define exp10(x) exp(M_LN10*(x))
20
21 /* our list of conversion packages */
22 struct tmPackage *tmPkg[TM_MAXPKG];
23 int tmNumPkgs = 0; /* number of registered packages */
24
25 /* luminance->brightness lookup */
26 static TMbright *tmFloat2BrtLUT = NULL;
27
28 #define tmCvLumLUfp(pf) tmFloat2BrtLUT[*(int32 *)(pf) >> 15]
29
30
31 TMstruct *
32 tmInit( /* initialize new tone mapping */
33 int flags,
34 RGBPRIMP monpri,
35 double gamval
36 )
37 {
38 COLORMAT cmat;
39 TMstruct *tmnew;
40 int i;
41 /* allocate structure */
42 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
43 if (tmnew == NULL)
44 return(NULL);
45
46 tmnew->flags = flags & ~TM_F_UNIMPL;
47 if (tmnew->flags & TM_F_BW)
48 tmnew->flags &= ~TM_F_MESOPIC;
49 /* set monitor transform */
50 if (monpri == NULL || monpri == stdprims || tmnew->flags & TM_F_BW) {
51 tmnew->monpri = stdprims;
52 tmnew->clf[RED] = rgb2xyzmat[1][0];
53 tmnew->clf[GRN] = rgb2xyzmat[1][1];
54 tmnew->clf[BLU] = rgb2xyzmat[1][2];
55 } else {
56 comprgb2xyzmat(cmat, tmnew->monpri=monpri);
57 tmnew->clf[RED] = cmat[1][0];
58 tmnew->clf[GRN] = cmat[1][1];
59 tmnew->clf[BLU] = cmat[1][2];
60 }
61 /* set gamma value */
62 if (gamval < MINGAM)
63 tmnew->mongam = DEFGAM;
64 else
65 tmnew->mongam = gamval;
66 /* set color divisors */
67 for (i = 0; i < 3; i++)
68 tmnew->cdiv[i] = 256.*pow(tmnew->clf[i], 1./tmnew->mongam);
69
70 /* set input transform */
71 tmnew->inppri = tmnew->monpri;
72 tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] =
73 tmnew->inpsf = WHTEFFICACY;
74 tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] =
75 tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.;
76 tmnew->inpdat = NULL;
77 tmnew->hbrmin = 10; tmnew->hbrmax = -10;
78 tmnew->histo = NULL;
79 tmnew->mbrmin = 10; tmnew->mbrmax = -10;
80 tmnew->lumap = NULL;
81 /* zero private data */
82 for (i = TM_MAXPKG; i--; )
83 tmnew->pd[i] = NULL;
84 tmnew->lastError = TM_E_OK;
85 tmnew->lastFunc = "NoErr";
86 /* return new TMstruct */
87 return(tmnew);
88 }
89
90
91 int
92 tmSetSpace( /* set input color space for conversions */
93 TMstruct *tms,
94 RGBPRIMP pri,
95 double sf,
96 MEM_PTR dat
97 )
98 {
99 static const char funcName[] = "tmSetSpace";
100 int i, j;
101 /* error check */
102 if (tms == NULL)
103 returnErr(TM_E_TMINVAL);
104 if (sf <= 1e-12)
105 returnErr(TM_E_ILLEGAL);
106 /* check if no change */
107 if (pri == tms->inppri && FEQ(sf, tms->inpsf) && dat == tms->inpdat)
108 returnOK;
109 tms->inppri = pri; /* let's set it */
110 tms->inpsf = sf;
111 tms->inpdat = dat;
112
113 if (tms->flags & TM_F_BW) { /* color doesn't matter */
114 tms->monpri = tms->inppri; /* eliminate xform */
115 if (tms->inppri == TM_XYZPRIM) {
116 tms->clf[CIEX] = tms->clf[CIEZ] = 0.;
117 tms->clf[CIEY] = 1.;
118 } else {
119 comprgb2xyzmat(tms->cmat, tms->monpri);
120 tms->clf[RED] = tms->cmat[1][0];
121 tms->clf[GRN] = tms->cmat[1][1];
122 tms->clf[BLU] = tms->cmat[1][2];
123 }
124 tms->cmat[0][0] = tms->cmat[1][1] = tms->cmat[2][2] =
125 tms->inpsf;
126 tms->cmat[0][1] = tms->cmat[0][2] = tms->cmat[1][0] =
127 tms->cmat[1][2] = tms->cmat[2][0] = tms->cmat[2][1] = 0.;
128
129 } else if (tms->inppri == TM_XYZPRIM) /* input is XYZ */
130 compxyz2rgbWBmat(tms->cmat, tms->monpri);
131
132 else { /* input is RGB */
133 if (tms->inppri != tms->monpri &&
134 PRIMEQ(tms->inppri, tms->monpri))
135 tms->inppri = tms->monpri; /* no xform */
136 comprgb2rgbWBmat(tms->cmat, tms->inppri, tms->monpri);
137 }
138 for (i = 0; i < 3; i++)
139 for (j = 0; j < 3; j++)
140 tms->cmat[i][j] *= tms->inpsf;
141 /* set color divisors */
142 for (i = 0; i < 3; i++)
143 if (tms->clf[i] > .001)
144 tms->cdiv[i] =
145 256.*pow(tms->clf[i], 1./tms->mongam);
146 else
147 tms->cdiv[i] = 1;
148 /* notify packages */
149 for (i = tmNumPkgs; i--; )
150 if (tms->pd[i] != NULL && tmPkg[i]->NewSpace != NULL)
151 (*tmPkg[i]->NewSpace)(tms);
152 returnOK;
153 }
154
155
156 void
157 tmClearHisto( /* clear current histogram */
158 TMstruct *tms
159 )
160 {
161 if (tms == NULL || tms->histo == NULL)
162 return;
163 free((MEM_PTR)tms->histo);
164 tms->histo = NULL;
165 }
166
167
168 TMbright
169 tmCvLuminance( /* convert a single luminance */
170 double lum
171 )
172 {
173 double d;
174
175 #ifdef isfinite
176 if (!isfinite(lum) || lum <= TM_NOLUM)
177 #else
178 if (lum <= TM_NOLUM)
179 #endif
180 return(TM_NOBRT);
181 d = TM_BRTSCALE*log(lum);
182 if (d > 0.)
183 return((TMbright)(d+.5));
184 return((TMbright)(d-.5));
185 }
186
187
188 int
189 tmCvLums( /* convert luminances using lookup */
190 TMbright *ls,
191 float *scan,
192 int len
193 )
194 {
195 if (tmFloat2BrtLUT == NULL) { /* initialize lookup table */
196 int32 i;
197 tmFloat2BrtLUT = (TMbright *)malloc(sizeof(TMbright)*0x10000);
198 if (tmFloat2BrtLUT == NULL)
199 return(TM_E_NOMEM);
200 for (i = 0; i < 0x10000; i++) {
201 int32 l = (i<<1 | 1) << 14;
202 #ifndef isfinite
203 if ((l & 0x7f800000) == 0x7f800000)
204 tmFloat2BrtLUT[i] = TM_NOBRT;
205 else
206 #endif
207 tmFloat2BrtLUT[i] = tmCvLuminance(*(float *)&l);
208 }
209 }
210 if (len <= 0)
211 return(TM_E_OK);
212 if ((ls == NULL) | (scan == NULL))
213 return(TM_E_ILLEGAL);
214 while (len--) {
215 if (*scan <= TM_NOLUM) {
216 *ls++ = TM_NOBRT;
217 ++scan;
218 continue;
219 }
220 *ls++ = tmCvLumLUfp(scan++);
221 }
222 return(TM_E_OK);
223 }
224
225
226 int
227 tmCvGrays( /* convert float gray values */
228 TMstruct *tms,
229 TMbright *ls,
230 float *scan,
231 int len
232 )
233 {
234 static const char funcName[] = "tmCvGrays";
235 int i;
236
237 if (tms == NULL)
238 returnErr(TM_E_TMINVAL);
239 if ((ls == NULL) | (scan == NULL) | (len < 0))
240 returnErr(TM_E_ILLEGAL);
241 if (tmFloat2BrtLUT == NULL) /* initialize */
242 tmCvLums(NULL, NULL, 0);
243 for (i = len; i--; ) {
244 float lum = tms->inpsf * scan[i];
245 if (lum <= TM_NOLUM)
246 ls[i] = TM_NOBRT;
247 else
248 ls[i] = tmCvLumLUfp(&lum);
249 }
250 returnOK;
251 }
252
253
254 int
255 tmCvColors( /* convert float colors */
256 TMstruct *tms,
257 TMbright *ls,
258 BYTE *cs,
259 COLOR *scan,
260 int len
261 )
262 {
263 static const char funcName[] = "tmCvColors";
264 static BYTE gamtab[1024];
265 static double curgam = .0;
266 COLOR cmon;
267 float lum, slum, d;
268 int i;
269
270 if (tms == NULL)
271 returnErr(TM_E_TMINVAL);
272 if ((ls == NULL) | (scan == NULL) | (len < 0))
273 returnErr(TM_E_ILLEGAL);
274 if (tmFloat2BrtLUT == NULL) /* initialize */
275 tmCvLums(NULL, NULL, 0);
276 if (cs != TM_NOCHROM && fabs(tms->mongam - curgam) > .02) {
277 curgam = tms->mongam; /* (re)build table */
278 for (i = 1024; i--; )
279 gamtab[i] = (int)(256.*pow((i+.5)/1024., 1./curgam));
280 }
281 for (i = len; i--; ) {
282 if (tmNeedMatrix(tms)) { /* get monitor RGB */
283 colortrans(cmon, tms->cmat, scan[i]);
284 } else {
285 cmon[RED] = tms->inpsf*scan[i][RED];
286 cmon[GRN] = tms->inpsf*scan[i][GRN];
287 cmon[BLU] = tms->inpsf*scan[i][BLU];
288 }
289 #ifdef isfinite
290 if (!isfinite(cmon[RED]) || cmon[RED] < .0f) cmon[RED] = .0f;
291 if (!isfinite(cmon[GRN]) || cmon[GRN] < .0f) cmon[GRN] = .0f;
292 if (!isfinite(cmon[BLU]) || cmon[BLU] < .0f) cmon[BLU] = .0f;
293 #else
294 if (cmon[RED] < .0f) cmon[RED] = .0f;
295 if (cmon[GRN] < .0f) cmon[GRN] = .0f;
296 if (cmon[BLU] < .0f) cmon[BLU] = .0f;
297 #endif
298 /* world luminance */
299 lum = tms->clf[RED]*cmon[RED] +
300 tms->clf[GRN]*cmon[GRN] +
301 tms->clf[BLU]*cmon[BLU] ;
302 if (lum <= TM_NOLUM) { /* convert brightness */
303 lum = cmon[RED] = cmon[GRN] = cmon[BLU] = TM_NOLUM;
304 ls[i] = TM_NOBRT;
305 } else
306 ls[i] = tmCvLumLUfp(&lum);
307 if (cs == TM_NOCHROM) /* no color? */
308 continue;
309 if (tms->flags & TM_F_MESOPIC && lum < LMESUPPER) {
310 slum = scotlum(cmon); /* mesopic adj. */
311 if (lum < LMESLOWER) {
312 cmon[RED] = cmon[GRN] = cmon[BLU] = slum;
313 } else {
314 d = (lum - LMESLOWER)/(LMESUPPER - LMESLOWER);
315 if (tms->flags & TM_F_BW)
316 cmon[RED] = cmon[GRN] =
317 cmon[BLU] = d*lum;
318 else
319 scalecolor(cmon, d);
320 d = (1.f-d)*slum;
321 cmon[RED] += d;
322 cmon[GRN] += d;
323 cmon[BLU] += d;
324 }
325 } else if (tms->flags & TM_F_BW) {
326 cmon[RED] = cmon[GRN] = cmon[BLU] = lum;
327 }
328 d = tms->clf[RED]*cmon[RED]/lum;
329 cs[3*i ] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
330 d = tms->clf[GRN]*cmon[GRN]/lum;
331 cs[3*i+1] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
332 d = tms->clf[BLU]*cmon[BLU]/lum;
333 cs[3*i+2] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
334 }
335 returnOK;
336 }
337
338
339 int
340 tmAddHisto( /* add values to histogram */
341 TMstruct *tms,
342 TMbright *ls,
343 int len,
344 int wt
345 )
346 {
347 static const char funcName[] = "tmAddHisto";
348 int oldorig=0, oldlen, horig, hlen;
349 int i, j;
350
351 if (tms == NULL)
352 returnErr(TM_E_TMINVAL);
353 if (len < 0)
354 returnErr(TM_E_ILLEGAL);
355 if (len == 0)
356 returnOK;
357 /* first, grow limits */
358 if (tms->histo == NULL) {
359 for (i = len; i-- && ls[i] < MINBRT; )
360 ;
361 if (i < 0)
362 returnOK;
363 tms->hbrmin = tms->hbrmax = ls[i];
364 oldlen = 0;
365 } else {
366 oldorig = (tms->hbrmin-MINBRT)/HISTEP;
367 oldlen = (tms->hbrmax-MINBRT)/HISTEP + 1 - oldorig;
368 }
369 for (i = len; i--; ) {
370 if ((j = ls[i]) < MINBRT)
371 continue;
372 if (j < tms->hbrmin)
373 tms->hbrmin = j;
374 else if (j > tms->hbrmax)
375 tms->hbrmax = j;
376 }
377 horig = (tms->hbrmin-MINBRT)/HISTEP;
378 hlen = (tms->hbrmax-MINBRT)/HISTEP + 1 - horig;
379 if (hlen > oldlen) { /* (re)allocate histogram */
380 int *newhist = (int *)calloc(hlen, sizeof(int));
381 if (newhist == NULL)
382 returnErr(TM_E_NOMEM);
383 if (oldlen) { /* copy and free old */
384 for (i = oldlen, j = i+oldorig-horig; i; )
385 newhist[--j] = tms->histo[--i];
386 free((MEM_PTR)tms->histo);
387 }
388 tms->histo = newhist;
389 }
390 if (wt == 0)
391 returnOK;
392 for (i = len; i--; ) /* add in new counts */
393 if (ls[i] >= MINBRT)
394 tms->histo[ (ls[i]-MINBRT)/HISTEP - horig ] += wt;
395 returnOK;
396 }
397
398
399 static double
400 htcontrs( /* human threshold contrast sensitivity, dL(La) */
401 double La
402 )
403 {
404 double l10La, l10dL;
405 /* formula taken from Ferwerda et al. [SG96] */
406 if (La < 1.148e-4)
407 return(1.38e-3);
408 l10La = log10(La);
409 if (l10La < -1.44) /* rod response regime */
410 l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86;
411 else if (l10La < -.0184)
412 l10dL = l10La - .395;
413 else if (l10La < 1.9) /* cone response regime */
414 l10dL = pow(.249*l10La + .65, 2.7) - .72;
415 else
416 l10dL = l10La - 1.255;
417
418 return(exp10(l10dL));
419 }
420
421
422 static int
423 tmNewMap( /* allocate new tone-mapping array */
424 TMstruct *tms
425 )
426 {
427 if (tms->lumap != NULL && (tms->mbrmax - tms->mbrmin) !=
428 (tms->hbrmax - tms->hbrmin)) {
429 free((MEM_PTR)tms->lumap);
430 tms->lumap = NULL;
431 }
432 tms->mbrmin = tms->hbrmin;
433 tms->mbrmax = tms->hbrmax;
434 if (tms->mbrmin > tms->mbrmax)
435 return 0;
436 if (tms->lumap == NULL)
437 tms->lumap = (unsigned short *)malloc(sizeof(unsigned short)*
438 (tms->mbrmax-tms->mbrmin+1));
439 return(tms->lumap != NULL);
440 }
441
442
443 int
444 tmFixedMapping( /* compute fixed, linear tone-mapping */
445 TMstruct *tms,
446 double expmult,
447 double gamval
448 )
449 {
450 static const char funcName[] = "tmFixedMapping";
451 double d;
452 int i;
453
454 if (!tmNewMap(tms))
455 returnErr(TM_E_NOMEM);
456 if (expmult <= .0)
457 expmult = 1.;
458 if (gamval < MINGAM)
459 gamval = tms->mongam;
460 d = log(expmult/tms->inpsf);
461 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
462 double val = 256. * exp(
463 ( d + (tms->mbrmin+i)*(1./TM_BRTSCALE) )
464 / gamval);
465 tms->lumap[i] = val >= (double)0xffff ? 0xffff : (int)val;
466 }
467 returnOK;
468 }
469
470
471 int
472 tmComputeMapping( /* compute histogram tone-mapping */
473 TMstruct *tms,
474 double gamval,
475 double Lddyn,
476 double Ldmax
477 )
478 {
479 static const char funcName[] = "tmComputeMapping";
480 int *histo;
481 float *cumf;
482 int brt0, histlen, threshold, ceiling, trimmings;
483 double logLddyn, Ldmin, Ldavg, Lwavg, Tr, Lw, Ld;
484 int32 histot;
485 double sum;
486 double d;
487 int i, j;
488
489 if (tms == NULL || tms->histo == NULL)
490 returnErr(TM_E_TMINVAL);
491 /* check arguments */
492 if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN;
493 if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX;
494 if (gamval < MINGAM) gamval = tms->mongam;
495 /* compute handy values */
496 Ldmin = Ldmax/Lddyn;
497 logLddyn = log(Lddyn);
498 Ldavg = sqrt(Ldmax*Ldmin);
499 i = (tms->hbrmin-MINBRT)/HISTEP;
500 brt0 = MINBRT + HISTEP/2 + i*HISTEP;
501 histlen = (tms->hbrmax-MINBRT)/HISTEP + 1 - i;
502 /* histogram total and mean */
503 histot = 0; sum = 0;
504 j = brt0 + histlen*HISTEP;
505 for (i = histlen; i--; ) {
506 histot += tms->histo[i];
507 sum += (j -= HISTEP) * tms->histo[i];
508 }
509 threshold = histot*0.005 + .5;
510 if (threshold < 4)
511 returnErr(TM_E_TMFAIL);
512 Lwavg = tmLuminance( (double)sum / histot );
513 /* allocate space for mapping */
514 if (!tmNewMap(tms))
515 returnErr(TM_E_NOMEM);
516 /* use linear tone mapping? */
517 if (tms->flags & TM_F_LINEAR)
518 goto linearmap;
519 /* clamp histogram */
520 histo = (int *)malloc(histlen*sizeof(int));
521 cumf = (float *)malloc((histlen+2)*sizeof(float));
522 if ((histo == NULL) | (cumf == NULL))
523 returnErr(TM_E_NOMEM);
524 cumf[histlen+1] = 1.; /* guard for assignment code */
525 for (i = histlen; i--; ) /* make malleable copy */
526 histo[i] = tms->histo[i];
527 do { /* iterate to solution */
528 sum = 0; /* cumulative probability */
529 for (i = 0; i < histlen; i++) {
530 cumf[i] = (double)sum/histot;
531 sum += histo[i];
532 }
533 cumf[histlen] = 1.;
534 Tr = histot * (double)(tms->hbrmax - tms->hbrmin) /
535 ((double)histlen*TM_BRTSCALE) / logLddyn;
536 ceiling = Tr + 1.;
537 trimmings = 0; /* clip to envelope */
538 for (i = histlen; i--; ) {
539 if (tms->flags & TM_F_HCONTR) {
540 Lw = tmLuminance(brt0 + i*HISTEP);
541 Ld = Ldmin * exp( logLddyn *
542 .5*(cumf[i]+cumf[i+1]) );
543 ceiling = Tr * (htcontrs(Ld) * Lw) /
544 (htcontrs(Lw) * Ld) + 1.;
545 }
546 if (histo[i] > ceiling) {
547 trimmings += histo[i] - ceiling;
548 histo[i] = ceiling;
549 }
550 }
551 /* check if we're out of data */
552 if ((histot -= trimmings) <= threshold) {
553 free((MEM_PTR)histo);
554 free((MEM_PTR)cumf);
555 goto linearmap;
556 }
557 } while (trimmings > threshold);
558 /* assign tone-mapping */
559 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
560 j = d = (double)i/(tms->mbrmax-tms->mbrmin)*histlen;
561 d -= (double)j;
562 Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1]));
563 d = (Ld - Ldmin)/(Ldmax - Ldmin);
564 tms->lumap[i] = 256.*pow(d, 1./gamval);
565 }
566 free((MEM_PTR)histo); /* clean up and return */
567 free((MEM_PTR)cumf);
568 returnOK;
569 linearmap: /* linear tone-mapping */
570 if (tms->flags & TM_F_HCONTR)
571 d = htcontrs(Ldavg) / htcontrs(Lwavg);
572 else
573 d = Ldavg / Lwavg;
574 return(tmFixedMapping(tms, tms->inpsf*d/Ldmax, gamval));
575 }
576
577
578 int
579 tmMapPixels( /* apply tone-mapping to pixel(s) */
580 TMstruct *tms,
581 BYTE *ps,
582 TMbright *ls,
583 BYTE *cs,
584 int len
585 )
586 {
587 static const char funcName[] = "tmMapPixels";
588 int32 li, pv;
589
590 if (tms == NULL || tms->lumap == NULL)
591 returnErr(TM_E_TMINVAL);
592 if ((ps == NULL) | (ls == NULL) | (len < 0))
593 returnErr(TM_E_ILLEGAL);
594 while (len--) {
595 if ((li = *ls++) < tms->mbrmin) {
596 li = 0;
597 } else {
598 if (li > tms->mbrmax)
599 li = tms->mbrmax;
600 li = tms->lumap[li - tms->mbrmin];
601 }
602 if (cs == TM_NOCHROM)
603 *ps++ = li>255 ? 255 : li;
604 else {
605 pv = *cs++ * li / tms->cdiv[RED];
606 *ps++ = pv>255 ? 255 : pv;
607 pv = *cs++ * li / tms->cdiv[GRN];
608 *ps++ = pv>255 ? 255 : pv;
609 pv = *cs++ * li / tms->cdiv[BLU];
610 *ps++ = pv>255 ? 255 : pv;
611 }
612 }
613 returnOK;
614 }
615
616
617
618
619 TMstruct *
620 tmDup( /* duplicate top tone mapping */
621 TMstruct *tms
622 )
623 {
624 int len;
625 int i;
626 TMstruct *tmnew;
627
628 if (tms == NULL) /* anything to duplicate? */
629 return(NULL);
630 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
631 if (tmnew == NULL)
632 return(NULL);
633 *tmnew = *tms; /* copy everything */
634 if (tmnew->histo != NULL) { /* duplicate histogram */
635 len = (tmnew->hbrmax-MINBRT)/HISTEP + 1 -
636 (tmnew->hbrmin-MINBRT)/HISTEP;
637 tmnew->histo = (int *)malloc(len*sizeof(int));
638 if (tmnew->histo != NULL)
639 for (i = len; i--; )
640 tmnew->histo[i] = tms->histo[i];
641 }
642 if (tmnew->lumap != NULL) { /* duplicate luminance mapping */
643 len = tmnew->mbrmax-tmnew->mbrmin+1;
644 tmnew->lumap = (unsigned short *)malloc(
645 len*sizeof(unsigned short) );
646 if (tmnew->lumap != NULL)
647 for (i = len; i--; )
648 tmnew->lumap[i] = tms->lumap[i];
649 }
650 /* clear package data */
651 for (i = tmNumPkgs; i--; )
652 tmnew->pd[i] = NULL;
653 /* return copy */
654 return(tmnew);
655 }
656
657
658 void
659 tmDone(tms) /* done with tone mapping -- destroy it */
660 TMstruct *tms;
661 {
662 int i;
663 /* NULL arg. is equiv. to tms */
664 if (tms == NULL)
665 return;
666 /* free tables */
667 if (tms->histo != NULL)
668 free((MEM_PTR)tms->histo);
669 if (tms->lumap != NULL)
670 free((MEM_PTR)tms->lumap);
671 /* free private data */
672 for (i = tmNumPkgs; i--; )
673 if (tms->pd[i] != NULL)
674 (*tmPkg[i]->Free)(tms->pd[i]);
675 free((MEM_PTR)tms); /* free basic structure */
676 }
677
678 /******************** Shared but Private library routines *********************/
679
680 BYTE tmMesofact[BMESUPPER-BMESLOWER];
681
682 void
683 tmMkMesofact() /* build mesopic lookup factor table */
684 {
685 int i;
686
687 if (tmMesofact[BMESUPPER-BMESLOWER-1])
688 return;
689
690 for (i = BMESLOWER; i < BMESUPPER; i++)
691 tmMesofact[i-BMESLOWER] = 256. *
692 (tmLuminance(i) - LMESLOWER) /
693 (LMESUPPER - LMESLOWER);
694 }
695
696
697 int
698 tmErrorReturn( /* error return (with message) */
699 const char *func,
700 TMstruct *tms,
701 int err
702 )
703 {
704 if (tms != NULL) {
705 tms->lastFunc = func;
706 tms->lastError = err;
707 if (tms->flags & TM_F_NOSTDERR)
708 return(err);
709 }
710 fputs(func, stderr);
711 fputs(": ", stderr);
712 fputs(tmErrorMessage[err], stderr);
713 fputs("!\n", stderr);
714 return(err);
715 }
