root/radiance/ray/src/common/tonemap.c
Fri Jan 7 22:05:30 2005 UTC (19 years, 4 months ago) by greg
Changes since 3.17: +6 -3 lines
Diff to previous 3.17 , to selected 3.13
Added client data pointer to tmSetSpace() call
Fri Jan 7 21:41:06 2005 UTC (19 years, 4 months ago) by greg
Changes since 3.16: +17 -16 lines
Diff to previous 3.16 , to selected 3.13
Moved error codes inside passed TMstruct
Fri Jan 7 20:33:02 2005 UTC (19 years, 4 months ago) by greg
Changes since 3.15: +211 -243 lines
Diff to previous 3.15 , to selected 3.13
Thu Jul 22 17:48:52 2004 UTC (19 years, 9 months ago) by greg
Changes since 3.14: +5 -3 lines
Diff to previous 3.14 , to selected 3.13
Added check for incompatible use of TM_F_MESOPIC with TM_F_BW
Thu Sep 18 20:18:19 2003 UTC (20 years, 7 months ago) by greg
Changes since 3.13: +2 -2 lines
Diff to previous 3.13
Revision 3.13 - (view) (download) (annotate) - [selected]
Changes since 3.12: +6 -6 lines
Diff to previous 3.12
Tue Jul 15 00:30:09 2003 UTC (20 years, 9 months ago) by greg
Diff to previous 3.11 , to selected 3.13
Fixed bug in tmCvColors for zero and negative values
Changes since 3.10: +3 -3 lines
Diff to previous 3.10 , to selected 3.13
Changes since 3.9: +1 -56 lines
Diff to previous 3.9 , to selected 3.13
Changes since 3.8: +238 -100 lines
Diff to previous 3.8 , to selected 3.13
Mon Aug 17 17:58:47 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 3.7: +8 -6 lines
Diff to previous 3.7 , to selected 3.13
took "color.h" include out of tonemap.h and put in tmprivat.h
changed routines so zero-length arrays don't return error
Mon Dec 1 09:52:00 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.6: +1 -1 lines
Diff to previous 3.6 , to selected 3.13
got rid of unused variable
Mon Nov 17 14:02:12 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.5: +34 -35 lines
Diff to previous 3.5 , to selected 3.13
changed behavior so that tmClearHisto() and tmAddHisto() do not
void computed tone mapping, even if brightness limits are exceeded
Wed Nov 12 13:25:48 1997 UTC (26 years, 5 months ago) by gregl
Changes since 3.4: +5 -0 lines
Diff to previous 3.4 , to selected 3.13
added tmLastError and tmLastFunction globals (set by tmErrorReturn)
Fri Apr 18 13:59:43 1997 UTC (27 years ago) by greg
Changes since 3.3: +53 -45 lines
Diff to previous 3.3 , to selected 3.13
added notion of conversion packages with private data
Wed Apr 16 20:28:03 1997 UTC (27 years ago) by greg
Changes since 3.2: +34 -0 lines
Diff to previous 3.2 , to selected 3.13
minor bug fixes and added tmDup()
Tue Apr 15 20:04:43 1997 UTC (27 years ago) by greg
Changes since 3.1: +41 -35 lines
Diff to previous 3.1 , to selected 3.13
changed TM_F_NOERRS to TM_F_NOSTDERR
skipped histogram clipping for TM_F_LINEAR in tmComputeMapping()
Tue Apr 15 16:53:01 1997 UTC (27 years ago) by greg
Diff to selected 3.13
