--- ray/src/common/tonemap.c 1997/04/15 20:04:43 3.2 +++ ray/src/common/tonemap.c 1997/04/18 13:59:43 3.4 @@ -18,7 +18,11 @@ static char SCCSid[] = "$SunId$ LBL"; struct tmStruct *tmTop = NULL; /* current tone mapping stack */ + /* our list of conversion packages */ +struct tmPackage *tmPkg[TM_MAXPKG]; +int tmNumPkgs = 0; /* number of registered packages */ + int tmErrorReturn(func, err) /* error return (with message) */ char *func; @@ -62,32 +66,28 @@ double gamval; tmnew->clf[GRN] = cmat[1][1]; tmnew->clf[BLU] = cmat[1][2]; } - tmnew->clfb[RED] = 256.*tmnew->clf[RED] + .5; - tmnew->clfb[GRN] = 256.*tmnew->clf[GRN] + .5; - tmnew->clfb[BLU] = 256.*tmnew->clf[BLU] + .5; - tmnew->clfb[EXP] = COLXS; /* set gamma value */ if (gamval < MINGAM) tmnew->mongam = DEFGAM; else tmnew->mongam = gamval; - for (i = TM_GAMTSZ; i--; ) - tmnew->gamb[i] = 256.*pow((i+.5)/TM_GAMTSZ, 1./tmnew->mongam); + /* set color divisors */ + for (i = 0; i < 3; i++) + tmnew->cdiv[i] = 256.*pow(tmnew->clf[i], 1./tmnew->mongam); + /* set input transform */ tmnew->inppri = tmnew->monpri; tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] = tmnew->inpsf = WHTEFFICACY; - tmnew->inpsfb = TM_BRTSCALE*log(tmnew->inpsf) + .5; tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] = tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.; - tmnew->flags &= ~TM_F_NEEDMAT; tmnew->brmin = tmnew->brmax = 0; tmnew->histo = NULL; tmnew->lumap = NULL; - tmnew->tmprev = NULL; - - tmnew->flags |= TM_F_INITED; - /* make it current */ + /* zero private data */ + for (i = TM_MAXPKG; i--; ) + tmnew->pd[i] = NULL; + /* make tmnew current */ tmnew->tmprev = tmTop; return(tmTop = tmnew); } @@ -110,15 +110,12 @@ double sf; returnOK; tmTop->inppri = pri; /* let's set it */ tmTop->inpsf = sf; - tmTop->inpsfb = TM_BRTSCALE*log(sf) + (sf>=1. ? .5 : -.5); if (tmTop->flags & TM_F_BW) { /* color doesn't matter */ tmTop->monpri = tmTop->inppri; /* eliminate xform */ if (tmTop->inppri == TM_XYZPRIM) { tmTop->clf[CIEX] = tmTop->clf[CIEZ] = 0.; tmTop->clf[CIEY] = 1.; - tmTop->clfb[CIEX] = tmTop->clfb[CIEZ] = 0; - tmTop->clfb[CIEY] = 255; } else { comprgb2xyzmat(tmTop->cmat, tmTop->monpri); tmTop->clf[RED] = tmTop->cmat[1][0]; @@ -142,10 +139,17 @@ double sf; for (i = 0; i < 3; i++) for (j = 0; j < 3; j++) tmTop->cmat[i][j] *= tmTop->inpsf; - if (tmTop->inppri != tmTop->monpri) - tmTop->flags |= TM_F_NEEDMAT; - else - tmTop->flags &= ~TM_F_NEEDMAT; + /* set color divisors */ + for (i = 0; i < 3; i++) + if (tmTop->clf[i] > .001) + tmTop->cdiv[i] = + 256.*pow(tmTop->clf[i], 1./tmTop->mongam); + else + tmTop->cdiv[i] = 1; + /* notify packages */ + for (i = tmNumPkgs; i--; ) + if (tmTop->pd[i] != NULL && tmPkg[i]->NewSpace != NULL) + (*tmPkg[i]->NewSpace)(tmTop); returnOK; } @@ -155,7 +159,7 @@ tmClearHisto() /* clear current histogram */ { if (tmTop == NULL || tmTop->histo == NULL) return; - free((char *)tmTop->histo); + free((MEM_PTR)tmTop->histo); tmTop->histo = NULL; } @@ -168,6 +172,7 @@ COLOR *scan; int len; { static char funcName[] = "tmCvColors"; + static COLOR csmall = {1e-6, 1e-6, 1e-6}; COLOR cmon; double lum, slum; register double d; @@ -178,7 +183,7 @@ int len; if (ls == NULL | scan == NULL | len <= 0) returnErr(TM_E_ILLEGAL); for (i = len; i--; ) { - if (tmTop->flags & TM_F_NEEDMAT) /* get monitor RGB */ + if (tmNeedMatrix(tmTop)) /* get monitor RGB */ colortrans(cmon, tmTop->cmat, scan[i]); else { cmon[RED] = tmTop->inpsf*scan[i][RED]; @@ -190,7 +195,7 @@ int len; tmTop->clf[GRN]*cmon[GRN] + tmTop->clf[BLU]*cmon[BLU] ; /* check range */ - if (clipgamut(cmon, lum, CGAMUT_LOWER, cblack, cwhite)) + if (clipgamut(cmon, lum, CGAMUT_LOWER, csmall, cwhite)) lum = tmTop->clf[RED]*cmon[RED] + tmTop->clf[GRN]*cmon[GRN] + tmTop->clf[BLU]*cmon[BLU] ; @@ -223,14 +228,14 @@ int len; cmon[RED] = cmon[GRN] = cmon[BLU] = lum; } d = tmTop->clf[RED]*cmon[RED]/lum; - /* cs[3*i ] = d>.999 ? 255 : 256.*pow(d, 1./tmTop->mongam); */ - cs[3*i ] = d>.999 ? 255 : tmTop->gamb[(int)(d*TM_GAMTSZ)]; + cs[3*i ] = d>=.999 ? 255 : + (int)(256.*pow(d, 1./tmTop->mongam)); d = tmTop->clf[GRN]*cmon[GRN]/lum; - /* cs[3*i+1] = d>.999 ? 255 : 256.*pow(d, 1./tmTop->mongam); */ - cs[3*i+1] = d>.999 ? 255 : tmTop->gamb[(int)(d*TM_GAMTSZ)]; + cs[3*i+1] = d>=.999 ? 255 : + (int)(256.*pow(d, 1./tmTop->mongam)); d = tmTop->clf[BLU]*cmon[BLU]/lum; - /* cs[3*i+2] = d>.999 ? 255 : 256.*pow(d, 1./tmTop->mongam); */ - cs[3*i+2] = d>.999 ? 255 : tmTop->gamb[(int)(d*TM_GAMTSZ)]; + cs[3*i+2] = d>=.999 ? 255 : + (int)(256.*pow(d, 1./tmTop->mongam)); } returnOK; } @@ -279,11 +284,11 @@ int wt; if (oldlen) { /* copy and free old */ for (i = oldlen, j = i+oldorig-horig; i; ) newhist[--j] = tmTop->histo[--i]; - free((char *)tmTop->histo); + free((MEM_PTR)tmTop->histo); } tmTop->histo = newhist; if (tmTop->lumap != NULL) { /* invalid tone map */ - free((char *)tmTop->lumap); + free((MEM_PTR)tmTop->lumap); tmTop->lumap = NULL; } } @@ -420,8 +425,8 @@ double Ldmax; } } if (!(tmTop->flags & TM_F_LINEAR)) { - free((char *)histo); - free((char *)cumf); + free((MEM_PTR)histo); + free((MEM_PTR)cumf); } returnOK; } @@ -435,16 +440,12 @@ register BYTE *cs; int len; { static char funcName[] = "tmMapPixels"; - int rdiv, gdiv, bdiv; - register int li, pv; + register int4 li, pv; if (tmTop == NULL || tmTop->lumap == NULL) returnErr(TM_E_TMINVAL); if (ps == NULL | ls == NULL | len <= 0) returnErr(TM_E_ILLEGAL); - rdiv = tmTop->gamb[((int4)TM_GAMTSZ*tmTop->clfb[RED])>>8]; - gdiv = tmTop->gamb[((int4)TM_GAMTSZ*tmTop->clfb[GRN])>>8]; - bdiv = tmTop->gamb[((int4)TM_GAMTSZ*tmTop->clfb[BLU])>>8]; while (len--) { if ((li = *ls++) < tmTop->brmin) li = tmTop->brmin; @@ -454,11 +455,11 @@ int len; if (cs == TM_NOCHROM) *ps++ = li>255 ? 255 : li; else { - pv = *cs++ * li / rdiv; + pv = *cs++ * li / tmTop->cdiv[RED]; *ps++ = pv>255 ? 255 : pv; - pv = *cs++ * li / gdiv; + pv = *cs++ * li / tmTop->cdiv[GRN]; *ps++ = pv>255 ? 255 : pv; - pv = *cs++ * li / bdiv; + pv = *cs++ * li / tmTop->cdiv[BLU]; *ps++ = pv>255 ? 255 : pv; } } @@ -500,13 +501,50 @@ register struct tmStruct *tms; } +struct tmStruct * +tmDup() /* duplicate top tone mapping */ +{ + int len; + register int i; + register struct tmStruct *tmnew; + + if (tmTop == NULL) /* anything to duplicate? */ + return(NULL); + tmnew = (struct tmStruct *)malloc(sizeof(struct tmStruct)); + if (tmnew == NULL) + return(NULL); + *tmnew = *tmTop; /* copy everything */ + if (tmnew->histo != NULL) { /* duplicate histogram */ + len = (tmnew->brmax-MINBRT)/HISTEP + 1 - + (tmnew->brmin-MINBRT)/HISTEP; + tmnew->histo = (int *)malloc(len*sizeof(int)); + if (tmnew->histo != NULL) + for (i = len; i--; ) + tmnew->histo[i] = tmTop->histo[i]; + } + if (tmnew->lumap != NULL) { /* duplicate luminance mapping */ + len = tmnew->brmax-tmnew->brmin+1; + tmnew->lumap = (unsigned short *)malloc( + len*sizeof(unsigned short) ); + if (tmnew->lumap != NULL) + for (i = len; i--; ) + tmnew->lumap[i] = tmTop->lumap[i]; + } + /* clear package data */ + for (i = tmNumPkgs; i--; ) + tmnew->pd[i] = NULL; + tmnew->tmprev = tmTop; /* make copy current */ + return(tmTop = tmnew); +} + + int tmPush(tms) /* push tone mapping on top of stack */ register struct tmStruct *tms; { static char funcName[] = "tmPush"; /* check validity */ - if (tms == NULL || !(tms->flags & TM_F_INITED)) + if (tms == NULL) returnErr(TM_E_ILLEGAL); if (tms == tmTop) /* check necessity */ returnOK; @@ -523,6 +561,7 @@ void tmDone(tms) /* done with tone mapping -- destroy it */ register struct tmStruct *tms; { + register int i; /* NULL arg. is equiv. to tmTop */ if (tms == NULL && (tms = tmTop) == NULL) return; @@ -530,9 +569,12 @@ register struct tmStruct *tms; (void)tmPull(tms); /* free tables */ if (tms->histo != NULL) - free((char *)tms->histo); + free((MEM_PTR)tms->histo); if (tms->lumap != NULL) - free((char *)tms->lumap); - tms->flags = 0; - free((char *)tms); /* free basic structure */ + free((MEM_PTR)tms->lumap); + /* free private data */ + for (i = tmNumPkgs; i--; ) + if (tms->pd[i] != NULL) + (*tmPkg[i]->Free)(tms->pd[i]); + free((MEM_PTR)tms); /* free basic structure */ }
