--- ray/src/common/tonemap.c 1997/04/15 16:53:01 3.1 +++ ray/src/common/tonemap.c 2003/07/15 00:30:09 3.12 @@ -1,14 +1,16 @@ -/* Copyright (c) 1997 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: tonemap.c,v 3.12 2003/07/15 00:30:09 greg Exp $"; #endif - /* * Tone mapping functions. * See tonemap.h for detailed function descriptions. + * Added von Kries white-balance calculations 10/01 (GW). + * + * Externals declared in tonemap.h */ +#include "copyright.h" + #include #include #include "tmprivat.h" @@ -18,20 +20,12 @@ static char SCCSid[] = "$SunId$ LBL"; struct tmStruct *tmTop = NULL; /* current tone mapping stack */ + /* our list of conversion packages */ +struct tmPackage *tmPkg[TM_MAXPKG]; +int tmNumPkgs = 0; /* number of registered packages */ -int -tmErrorReturn(func, err) /* error return (with message) */ -char *func; -int err; -{ - if (tmTop != NULL && tmTop->flags & TM_F_NOERRS) - return(err); - fputs(func, stderr); - fputs(": ", stderr); - fputs(tmErrorMessage[err], stderr); - fputs("!\n", stderr); - return(err); -} +int tmLastError; /* last error incurred by library */ +char *tmLastFunction; /* error-generating function name */ struct tmStruct * @@ -40,7 +34,6 @@ int flags; RGBPRIMP monpri; double gamval; { - static char funcName[] = "tmInit"; COLORMAT cmat; register struct tmStruct *tmnew; register int i; @@ -57,37 +50,34 @@ double gamval; tmnew->clf[GRN] = rgb2xyzmat[1][1]; tmnew->clf[BLU] = rgb2xyzmat[1][2]; } else { - comprgb2xyzmat(cmat, tmnew->monpri=monpri); + comprgb2xyzWBmat(cmat, tmnew->monpri=monpri); tmnew->clf[RED] = cmat[1][0]; tmnew->clf[GRN] = cmat[1][1]; tmnew->clf[BLU] = cmat[1][2]; } - tmnew->clfb[RED] = 256.*tmnew->clf[RED] + .5; - tmnew->clfb[GRN] = 256.*tmnew->clf[GRN] + .5; - tmnew->clfb[BLU] = 256.*tmnew->clf[BLU] + .5; - tmnew->clfb[EXP] = COLXS; /* set gamma value */ if (gamval < MINGAM) tmnew->mongam = DEFGAM; else tmnew->mongam = gamval; - for (i = TM_GAMTSZ; i--; ) - tmnew->gamb[i] = 256.*pow((i+.5)/TM_GAMTSZ, 1./tmnew->mongam); + /* set color divisors */ + for (i = 0; i < 3; i++) + tmnew->cdiv[i] = 256.*pow(tmnew->clf[i], 1./tmnew->mongam); + /* set input transform */ tmnew->inppri = tmnew->monpri; tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] = tmnew->inpsf = WHTEFFICACY; - tmnew->inpsfb = TM_BRTSCALE*log(tmnew->inpsf) + .5; tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] = tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.; - tmnew->flags &= ~TM_F_NEEDMAT; - tmnew->brmin = tmnew->brmax = 0; + tmnew->hbrmin = 10; tmnew->hbrmax = -10; tmnew->histo = NULL; + tmnew->mbrmin = 10; tmnew->mbrmax = -10; tmnew->lumap = NULL; - tmnew->tmprev = NULL; - - tmnew->flags |= TM_F_INITED; - /* make it current */ + /* zero private data */ + for (i = TM_MAXPKG; i--; ) + tmnew->pd[i] = NULL; + /* make tmnew current */ tmnew->tmprev = tmTop; return(tmTop = tmnew); } @@ -110,17 +100,14 @@ double sf; returnOK; tmTop->inppri = pri; /* let's set it */ tmTop->inpsf = sf; - tmTop->inpsfb = TM_BRTSCALE*log(sf) + (sf>=1. ? .5 : -.5); if (tmTop->flags & TM_F_BW) { /* color doesn't matter */ tmTop->monpri = tmTop->inppri; /* eliminate xform */ if (tmTop->inppri == TM_XYZPRIM) { tmTop->clf[CIEX] = tmTop->clf[CIEZ] = 0.; tmTop->clf[CIEY] = 1.; - tmTop->clfb[CIEX] = tmTop->clfb[CIEZ] = 0; - tmTop->clfb[CIEY] = 255; } else { - comprgb2xyzmat(tmTop->cmat, tmTop->monpri); + comprgb2xyzWBmat(tmTop->cmat, tmTop->monpri); tmTop->clf[RED] = tmTop->cmat[1][0]; tmTop->clf[GRN] = tmTop->cmat[1][1]; tmTop->clf[BLU] = tmTop->cmat[1][2]; @@ -131,21 +118,28 @@ double sf; tmTop->cmat[1][2] = tmTop->cmat[2][0] = tmTop->cmat[2][1] = 0.; } else if (tmTop->inppri == TM_XYZPRIM) /* input is XYZ */ - compxyz2rgbmat(tmTop->cmat, tmTop->monpri); + compxyz2rgbWBmat(tmTop->cmat, tmTop->monpri); else { /* input is RGB */ if (tmTop->inppri != tmTop->monpri && PRIMEQ(tmTop->inppri, tmTop->monpri)) tmTop->inppri = tmTop->monpri; /* no xform */ - comprgb2rgbmat(tmTop->cmat, tmTop->inppri, tmTop->monpri); + comprgb2rgbWBmat(tmTop->cmat, tmTop->inppri, tmTop->monpri); } for (i = 0; i < 3; i++) for (j = 0; j < 3; j++) tmTop->cmat[i][j] *= tmTop->inpsf; - if (tmTop->inppri != tmTop->monpri) - tmTop->flags |= TM_F_NEEDMAT; - else - tmTop->flags &= ~TM_F_NEEDMAT; + /* set color divisors */ + for (i = 0; i < 3; i++) + if (tmTop->clf[i] > .001) + tmTop->cdiv[i] = + 256.*pow(tmTop->clf[i], 1./tmTop->mongam); + else + tmTop->cdiv[i] = 1; + /* notify packages */ + for (i = tmNumPkgs; i--; ) + if (tmTop->pd[i] != NULL && tmPkg[i]->NewSpace != NULL) + (*tmPkg[i]->NewSpace)(tmTop); returnOK; } @@ -155,7 +149,7 @@ tmClearHisto() /* clear current histogram */ { if (tmTop == NULL || tmTop->histo == NULL) return; - free((char *)tmTop->histo); + free((MEM_PTR)tmTop->histo); tmTop->histo = NULL; } @@ -168,6 +162,7 @@ COLOR *scan; int len; { static char funcName[] = "tmCvColors"; + static COLOR csmall = {.5*MINLUM, .5*MINLUM, .5*MINLUM}; COLOR cmon; double lum, slum; register double d; @@ -175,10 +170,10 @@ int len; if (tmTop == NULL) returnErr(TM_E_TMINVAL); - if (ls == NULL | scan == NULL | len <= 0) + if (ls == NULL | scan == NULL | len < 0) returnErr(TM_E_ILLEGAL); for (i = len; i--; ) { - if (tmTop->flags & TM_F_NEEDMAT) /* get monitor RGB */ + if (tmNeedMatrix(tmTop)) /* get monitor RGB */ colortrans(cmon, tmTop->cmat, scan[i]); else { cmon[RED] = tmTop->inpsf*scan[i][RED]; @@ -190,7 +185,7 @@ int len; tmTop->clf[GRN]*cmon[GRN] + tmTop->clf[BLU]*cmon[BLU] ; /* check range */ - if (clipgamut(cmon, lum, CGAMUT_LOWER, cblack, cwhite)) + if (clipgamut(cmon, lum, CGAMUT_LOWER, csmall, cwhite)) lum = tmTop->clf[RED]*cmon[RED] + tmTop->clf[GRN]*cmon[GRN] + tmTop->clf[BLU]*cmon[BLU] ; @@ -223,69 +218,92 @@ int len; cmon[RED] = cmon[GRN] = cmon[BLU] = lum; } d = tmTop->clf[RED]*cmon[RED]/lum; - /* cs[3*i ] = d>.999 ? 255 : 256.*pow(d, 1./tmTop->mongam); */ - cs[3*i ] = d>.999 ? 255 : tmTop->gamb[(int)(d*TM_GAMTSZ)]; + cs[3*i ] = d>=.999 ? 255 : + (int)(256.*pow(d, 1./tmTop->mongam)); d = tmTop->clf[GRN]*cmon[GRN]/lum; - /* cs[3*i+1] = d>.999 ? 255 : 256.*pow(d, 1./tmTop->mongam); */ - cs[3*i+1] = d>.999 ? 255 : tmTop->gamb[(int)(d*TM_GAMTSZ)]; + cs[3*i+1] = d>=.999 ? 255 : + (int)(256.*pow(d, 1./tmTop->mongam)); d = tmTop->clf[BLU]*cmon[BLU]/lum; - /* cs[3*i+2] = d>.999 ? 255 : 256.*pow(d, 1./tmTop->mongam); */ - cs[3*i+2] = d>.999 ? 255 : tmTop->gamb[(int)(d*TM_GAMTSZ)]; + cs[3*i+2] = d>=.999 ? 255 : + (int)(256.*pow(d, 1./tmTop->mongam)); } returnOK; } int +tmCvGrays(ls, scan, len) /* convert float gray values */ +TMbright *ls; +float *scan; +int len; +{ + static char funcName[] = "tmCvGrays"; + register double d; + register int i; + + if (tmTop == NULL) + returnErr(TM_E_TMINVAL); + if (ls == NULL | scan == NULL | len < 0) + returnErr(TM_E_ILLEGAL); + for (i = len; i--; ) + if (scan[i] <= TM_NOLUM) { + ls[i] = TM_NOBRT; /* bogus value */ + } else { + d = TM_BRTSCALE*log(scan[i]); /* encode it */ + ls[i] = d>0. ? (int)(d+.5) : (int)(d-.5); + } + returnOK; +} + + +int tmAddHisto(ls, len, wt) /* add values to histogram */ register TMbright *ls; int len; int wt; { static char funcName[] = "tmAddHisto"; - int sum, oldorig, oldlen, horig, hlen; + int oldorig=0, oldlen, horig, hlen; register int i, j; - if (len <= 0) - returnErr(TM_E_ILLEGAL); if (tmTop == NULL) returnErr(TM_E_TMINVAL); + if (len < 0) + returnErr(TM_E_ILLEGAL); + if (len == 0) + returnOK; /* first, grow limits */ if (tmTop->histo == NULL) { for (i = len; i-- && ls[i] < MINBRT; ) ; if (i < 0) returnOK; - tmTop->brmin = tmTop->brmax = ls[i]; + tmTop->hbrmin = tmTop->hbrmax = ls[i]; oldlen = 0; } else { - oldorig = (tmTop->brmin-MINBRT)/HISTEP; - oldlen = (tmTop->brmax-MINBRT)/HISTEP + 1 - oldorig; + oldorig = (tmTop->hbrmin-MINBRT)/HISTEP; + oldlen = (tmTop->hbrmax-MINBRT)/HISTEP + 1 - oldorig; } for (i = len; i--; ) { if ((j = ls[i]) < MINBRT) continue; - if (j < tmTop->brmin) - tmTop->brmin = j; - else if (j > tmTop->brmax) - tmTop->brmax = j; + if (j < tmTop->hbrmin) + tmTop->hbrmin = j; + else if (j > tmTop->hbrmax) + tmTop->hbrmax = j; } - horig = (tmTop->brmin-MINBRT)/HISTEP; - hlen = (tmTop->brmax-MINBRT)/HISTEP + 1 - horig; + horig = (tmTop->hbrmin-MINBRT)/HISTEP; + hlen = (tmTop->hbrmax-MINBRT)/HISTEP + 1 - horig; if (hlen > oldlen) { /* (re)allocate histogram */ register int *newhist = (int *)calloc(hlen, sizeof(int)); if (newhist == NULL) returnErr(TM_E_NOMEM); if (oldlen) { /* copy and free old */ - for (i = oldlen, j = i+oldorig-horig; i--; ) - newhist[--j] = tmTop->histo[i]; - free((char *)tmTop->histo); + for (i = oldlen, j = i+oldorig-horig; i; ) + newhist[--j] = tmTop->histo[--i]; + free((MEM_PTR)tmTop->histo); } tmTop->histo = newhist; - if (tmTop->lumap != NULL) { /* invalid tone map */ - free((char *)tmTop->lumap); - tmTop->lumap = NULL; - } } if (wt == 0) returnOK; @@ -318,7 +336,50 @@ double La; } +static int +tmNewMap() +{ + if (tmTop->lumap != NULL && (tmTop->mbrmax - tmTop->mbrmin) != + (tmTop->hbrmax - tmTop->hbrmin)) { + free((MEM_PTR)tmTop->lumap); + tmTop->lumap = NULL; + } + tmTop->mbrmin = tmTop->hbrmin; + tmTop->mbrmax = tmTop->hbrmax; + if (tmTop->mbrmin > tmTop->mbrmax) + return 0; + if (tmTop->lumap == NULL) + tmTop->lumap = (unsigned short *)malloc(sizeof(unsigned short)* + (tmTop->mbrmax-tmTop->mbrmin+1)); + return(tmTop->lumap != NULL); +} + + int +tmFixedMapping(expmult, gamval) +double expmult; +double gamval; +{ + static char funcName[] = "tmFixedMapping"; + double d; + register int i; + + if (!tmNewMap()) + returnErr(TM_E_NOMEM); + if (expmult <= .0) + expmult = 1.; + if (gamval < MINGAM) + gamval = tmTop->mongam; + d = log(expmult/tmTop->inpsf); + for (i = tmTop->mbrmax-tmTop->mbrmin+1; i--; ) + tmTop->lumap[i] = 256. * exp( + ( d + (tmTop->mbrmin+i)*(1./TM_BRTSCALE) ) + / gamval ); + returnOK; +} + + +int tmComputeMapping(gamval, Lddyn, Ldmax) double gamval; double Lddyn; @@ -327,9 +388,10 @@ double Ldmax; static char funcName[] = "tmComputeMapping"; int *histo; float *cumf; - int brt0, histlen, histot, threshold, ceiling, trimmings; + int brt0, histlen, threshold, ceiling, trimmings; double logLddyn, Ldmin, Ldavg, Lwavg, Tr, Lw, Ld; - int4 sum; + int32 histot; + double sum; register double d; register int i, j; @@ -343,81 +405,82 @@ double Ldmax; Ldmin = Ldmax/Lddyn; logLddyn = log(Lddyn); Ldavg = sqrt(Ldmax*Ldmin); - i = (tmTop->brmin-MINBRT)/HISTEP; + i = (tmTop->hbrmin-MINBRT)/HISTEP; brt0 = MINBRT + HISTEP/2 + i*HISTEP; - histlen = (tmTop->brmax-MINBRT)/HISTEP + 1 - i; - /* allocate temporary tables */ - histo = (int *)malloc(histlen*sizeof(int)); - cumf = (float *)malloc((histlen+1)*sizeof(float)); - if (histo == NULL | cumf == NULL) - returnErr(TM_E_NOMEM); + histlen = (tmTop->hbrmax-MINBRT)/HISTEP + 1 - i; /* histogram total and mean */ histot = 0; sum = 0; j = brt0 + histlen*HISTEP; for (i = histlen; i--; ) { - histot += (histo[i] = tmTop->histo[i]); - sum += (j -= HISTEP) * histo[i]; + histot += tmTop->histo[i]; + sum += (j -= HISTEP) * tmTop->histo[i]; } threshold = histot*.025 + .5; if (threshold < 4) returnErr(TM_E_TMFAIL); Lwavg = tmLuminance( (double)sum / histot ); + /* allocate space for mapping */ + if (!tmNewMap()) + returnErr(TM_E_NOMEM); + /* use linear tone mapping? */ + if (tmTop->flags & TM_F_LINEAR) + goto linearmap; + /* clamp histogram */ + histo = (int *)malloc(histlen*sizeof(int)); + cumf = (float *)malloc((histlen+2)*sizeof(float)); + if (histo == NULL | cumf == NULL) + returnErr(TM_E_NOMEM); + cumf[histlen+1] = 1.; /* guard for assignment code */ + for (i = histlen; i--; ) /* make malleable copy */ + histo[i] = tmTop->histo[i]; do { /* iterate to solution */ - sum = 0; /* compute cumulative probability */ + sum = 0; /* cumulative probability */ for (i = 0; i < histlen; i++) { cumf[i] = (double)sum/histot; sum += histo[i]; } - cumf[i] = 1.; - Tr = histot * (double)(tmTop->brmax - tmTop->brmin) / - ((double)histlen*TM_BRTSCALE) / logLddyn; + cumf[histlen] = 1.; + Tr = histot * (double)(tmTop->hbrmax - tmTop->hbrmin) / + ((double)histlen*TM_BRTSCALE) / logLddyn; ceiling = Tr + 1.; - trimmings = 0; /* clip to envelope */ + trimmings = 0; /* clip to envelope */ for (i = histlen; i--; ) { if (tmTop->flags & TM_F_HCONTR) { Lw = tmLuminance(brt0 + i*HISTEP); Ld = Ldmin * exp( logLddyn * - .5*(cumf[i]+cumf[i+1]) ); + .5*(cumf[i]+cumf[i+1]) ); ceiling = Tr * (htcontrs(Ld) * Lw) / - (htcontrs(Lw) * Ld) + 1.; + (htcontrs(Lw) * Ld) + 1.; } if (histo[i] > ceiling) { trimmings += histo[i] - ceiling; histo[i] = ceiling; } } - } while ((histot -= trimmings) > threshold && trimmings > threshold); - - if (tmTop->lumap == NULL) { /* allocate luminance map */ - tmTop->lumap = (unsigned short *)malloc( - (tmTop->brmax-tmTop->brmin+1)*sizeof(unsigned short) ); - if (tmTop->lumap == NULL) - returnErr(TM_E_NOMEM); - } - if (tmTop->flags & TM_F_LINEAR || histot <= threshold) { - /* linear tone mapping */ - if (tmTop->flags & TM_F_HCONTR) - d = htcontrs(Ldavg) / htcontrs(Lwavg); - else - d = Ldavg / Lwavg; - d = log(d/Ldmax); - for (i = tmTop->brmax-tmTop->brmin+1; i--; ) - tmTop->lumap[i] = 256. * exp( - ( d + (tmTop->brmin+i)/(double)TM_BRTSCALE ) - / gamval ); - } else { - /* histogram adjustment */ - for (i = tmTop->brmax-tmTop->brmin+1; i--; ) { - j = d = (double)i/(tmTop->brmax-tmTop->brmin)*histlen; - d -= (double)j; - Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1])); - d = (Ld - Ldmin)/(Ldmax - Ldmin); - tmTop->lumap[i] = 256.*pow(d, 1./gamval); + /* check if we're out of data */ + if ((histot -= trimmings) <= threshold) { + free((MEM_PTR)histo); + free((MEM_PTR)cumf); + goto linearmap; } + } while (trimmings > threshold); + /* assign tone-mapping */ + for (i = tmTop->mbrmax-tmTop->mbrmin+1; i--; ) { + j = d = (double)i/(tmTop->mbrmax-tmTop->mbrmin)*histlen; + d -= (double)j; + Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1])); + d = (Ld - Ldmin)/(Ldmax - Ldmin); + tmTop->lumap[i] = 256.*pow(d, 1./gamval); } - free((char *)histo); - free((char *)cumf); + free((MEM_PTR)histo); /* clean up and return */ + free((MEM_PTR)cumf); returnOK; +linearmap: /* linear tone-mapping */ + if (tmTop->flags & TM_F_HCONTR) + d = htcontrs(Ldavg) / htcontrs(Lwavg); + else + d = Ldavg / Lwavg; + return(tmFixedMapping(tmTop->inpsf*d/Ldmax, gamval)); } @@ -429,30 +492,28 @@ register BYTE *cs; int len; { static char funcName[] = "tmMapPixels"; - int rdiv, gdiv, bdiv; - register int li, pv; + register int32 li, pv; if (tmTop == NULL || tmTop->lumap == NULL) returnErr(TM_E_TMINVAL); - if (ps == NULL | ls == NULL | len <= 0) + if (ps == NULL | ls == NULL | len < 0) returnErr(TM_E_ILLEGAL); - rdiv = tmTop->gamb[((int4)TM_GAMTSZ*tmTop->clfb[RED])>>8]; - gdiv = tmTop->gamb[((int4)TM_GAMTSZ*tmTop->clfb[GRN])>>8]; - bdiv = tmTop->gamb[((int4)TM_GAMTSZ*tmTop->clfb[BLU])>>8]; while (len--) { - if ((li = *ls++) < tmTop->brmin) - li = tmTop->brmin; - else if (li > tmTop->brmax) - li = tmTop->brmax; - li = tmTop->lumap[li - tmTop->brmin]; + if ((li = *ls++) < tmTop->mbrmin) { + li = 0; + } else { + if (li > tmTop->mbrmax) + li = tmTop->mbrmax; + li = tmTop->lumap[li - tmTop->mbrmin]; + } if (cs == TM_NOCHROM) *ps++ = li>255 ? 255 : li; else { - pv = *cs++ * li / rdiv; + pv = *cs++ * li / tmTop->cdiv[RED]; *ps++ = pv>255 ? 255 : pv; - pv = *cs++ * li / gdiv; + pv = *cs++ * li / tmTop->cdiv[GRN]; *ps++ = pv>255 ? 255 : pv; - pv = *cs++ * li / bdiv; + pv = *cs++ * li / tmTop->cdiv[BLU]; *ps++ = pv>255 ? 255 : pv; } } @@ -494,13 +555,50 @@ register struct tmStruct *tms; } +struct tmStruct * +tmDup() /* duplicate top tone mapping */ +{ + int len; + register int i; + register struct tmStruct *tmnew; + + if (tmTop == NULL) /* anything to duplicate? */ + return(NULL); + tmnew = (struct tmStruct *)malloc(sizeof(struct tmStruct)); + if (tmnew == NULL) + return(NULL); + *tmnew = *tmTop; /* copy everything */ + if (tmnew->histo != NULL) { /* duplicate histogram */ + len = (tmnew->hbrmax-MINBRT)/HISTEP + 1 - + (tmnew->hbrmin-MINBRT)/HISTEP; + tmnew->histo = (int *)malloc(len*sizeof(int)); + if (tmnew->histo != NULL) + for (i = len; i--; ) + tmnew->histo[i] = tmTop->histo[i]; + } + if (tmnew->lumap != NULL) { /* duplicate luminance mapping */ + len = tmnew->mbrmax-tmnew->mbrmin+1; + tmnew->lumap = (unsigned short *)malloc( + len*sizeof(unsigned short) ); + if (tmnew->lumap != NULL) + for (i = len; i--; ) + tmnew->lumap[i] = tmTop->lumap[i]; + } + /* clear package data */ + for (i = tmNumPkgs; i--; ) + tmnew->pd[i] = NULL; + tmnew->tmprev = tmTop; /* make copy current */ + return(tmTop = tmnew); +} + + int tmPush(tms) /* push tone mapping on top of stack */ register struct tmStruct *tms; { static char funcName[] = "tmPush"; /* check validity */ - if (tms == NULL || !(tms->flags & TM_F_INITED)) + if (tms == NULL) returnErr(TM_E_ILLEGAL); if (tms == tmTop) /* check necessity */ returnOK; @@ -517,6 +615,7 @@ void tmDone(tms) /* done with tone mapping -- destroy it */ register struct tmStruct *tms; { + register int i; /* NULL arg. is equiv. to tmTop */ if (tms == NULL && (tms = tmTop) == NULL) return; @@ -524,9 +623,47 @@ register struct tmStruct *tms; (void)tmPull(tms); /* free tables */ if (tms->histo != NULL) - free((char *)tms->histo); + free((MEM_PTR)tms->histo); if (tms->lumap != NULL) - free((char *)tms->lumap); - tms->flags = 0; - free((char *)tms); /* free basic structure */ + free((MEM_PTR)tms->lumap); + /* free private data */ + for (i = tmNumPkgs; i--; ) + if (tms->pd[i] != NULL) + (*tmPkg[i]->Free)(tms->pd[i]); + free((MEM_PTR)tms); /* free basic structure */ +} + +/******************** Shared but Private library routines *********************/ + +BYTE tmMesofact[BMESUPPER-BMESLOWER]; + +void +tmMkMesofact() /* build mesopic lookup factor table */ +{ + register int i; + + if (tmMesofact[BMESUPPER-BMESLOWER-1]) + return; + + for (i = BMESLOWER; i < BMESUPPER; i++) + tmMesofact[i-BMESLOWER] = 256. * + (tmLuminance(i) - LMESLOWER) / + (LMESUPPER - LMESLOWER); +} + + +int +tmErrorReturn(func, err) /* error return (with message) */ +char *func; +int err; +{ + tmLastFunction = func; + tmLastError = err; + if (tmTop != NULL && tmTop->flags & TM_F_NOSTDERR) + return(err); + fputs(func, stderr); + fputs(": ", stderr); + fputs(tmErrorMessage[err], stderr); + fputs("!\n", stderr); + return(err); }
