root/radiance/ray/src/common/tonemap.c
Tue Feb 25 02:47:22 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.9: +1 -56 lines
Diff to previous 3.9
Changes since 3.8: +238 -100 lines
Diff to previous 3.8
Mon Aug 17 17:58:47 1998 UTC (26 years, 9 months ago) by gwlarson
Changes since 3.7: +8 -6 lines
Diff to previous 3.7
took "color.h" include out of tonemap.h and put in tmprivat.h
changed routines so zero-length arrays don't return error
Mon Dec 1 09:52:00 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.6: +1 -1 lines
Diff to previous 3.6
got rid of unused variable
Mon Nov 17 14:02:12 1997 UTC (27 years, 6 months ago) by gregl
Changes since 3.5: +34 -35 lines
Diff to previous 3.5
changed behavior so that tmClearHisto() and tmAddHisto() do not
void computed tone mapping, even if brightness limits are exceeded
Wed Nov 12 13:25:48 1997 UTC (27 years, 7 months ago) by gregl
Changes since 3.4: +5 -0 lines
Diff to previous 3.4
added tmLastError and tmLastFunction globals (set by tmErrorReturn)
Fri Apr 18 13:59:43 1997 UTC (28 years, 1 month ago) by greg
Changes since 3.3: +53 -45 lines
Diff to previous 3.3
added notion of conversion packages with private data
Wed Apr 16 20:28:03 1997 UTC (28 years, 1 month ago) by greg
Changes since 3.2: +34 -0 lines
Diff to previous 3.2
minor bug fixes and added tmDup()
Tue Apr 15 20:04:43 1997 UTC (28 years, 1 month ago) by greg
Changes since 3.1: +41 -35 lines
Diff to previous 3.1
changed TM_F_NOERRS to TM_F_NOSTDERR
skipped histogram clipping for TM_F_LINEAR in tmComputeMapping()
Tue Apr 15 16:53:01 1997 UTC (28 years, 1 month ago) by greg
