root/Development/ray/src/common/tonemap.c
Revision 3.56 - (view) (download) (annotate) - [select for diffs]
Mon Sep 1 07:50:45 2025 UTC (3 months, 2 weeks ago) by greg
Changes since 3.55: +12 -9 lines
Diff to previous 3.55
perf: Took B&W color scan out of main loop for efficiency
Revision 3.55 - (view) (download) (annotate) - [select for diffs]
Thu Nov 21 17:15:54 2024 UTC (12 months, 4 weeks ago) by greg
CVS Tags: rad6R0
Changes since 3.54: +3 -6 lines
Diff to previous 3.54
refactor: Removed unused client data parametr from tmSetSpace() call
Revision 3.54 - (view) (download) (annotate) - [select for diffs]
Sat Jan 15 16:57:46 2022 UTC (3 years, 11 months ago) by greg
Changes since 3.53: +2 -2 lines
Diff to previous 3.53
refactor: eliminated use of MEM_PTR and (char *) for untyped memory
Revision 3.53 - (view) (download) (annotate) - [select for diffs]
Fri Jan 7 23:01:01 2022 UTC (3 years, 11 months ago) by greg
Changes since 3.52: +4 -2 lines
Diff to previous 3.52
perf: minor performance improvement in grayscale mode to 24-bit output
Revision 3.52 - (view) (download) (annotate) - [select for diffs]
Wed May 26 17:50:26 2021 UTC (4 years, 6 months ago) by greg
Changes since 3.51: +3 -3 lines
Diff to previous 3.51
fix: corner case where much of histogram gets truncated
Revision 3.51 - (view) (download) (annotate) - [select for diffs]
Tue May 4 21:50:54 2021 UTC (4 years, 7 months ago) by greg
Changes since 3.50: +8 -7 lines
Diff to previous 3.50
fix: potential issue with tmNewMap() call after tmClearHisto()
Revision 3.50 - (view) (download) (annotate) - [select for diffs]
Tue Apr 13 02:42:31 2021 UTC (4 years, 8 months ago) by greg
Changes since 3.49: +3 -5 lines
Diff to previous 3.49
Added better termination criterion for linear tone curve
Revision 3.49 - (view) (download) (annotate) - [select for diffs]
Mon Apr 12 22:16:02 2021 UTC (4 years, 8 months ago) by greg
Changes since 3.48: +5 -3 lines
Diff to previous 3.48
perf: switched to more robust, moving threshold for near-linear tone curves
Revision 3.48 - (view) (download) (annotate) - [select for diffs]
Wed Apr 7 23:12:19 2021 UTC (4 years, 8 months ago) by greg
Changes since 3.47: +6 -4 lines
Diff to previous 3.47
perf: improved black crushing behavior for linear mapping
Revision 3.47 - (view) (download) (annotate) - [select for diffs]
Wed Apr 7 21:13:52 2021 UTC (4 years, 8 months ago) by greg
Changes since 3.46: +6 -6 lines
Diff to previous 3.46
perf: changed default dynamic range from 32 to 100 to reflect modern displays
Revision 3.46 - (view) (download) (annotate) - [select for diffs]
Tue Mar 2 20:09:14 2021 UTC (4 years, 9 months ago) by greg
Changes since 3.45: +41 -38 lines
Diff to previous 3.45
perf: added handling of blacks in linear tone-mapping
Revision 3.45 - (view) (download) (annotate) - [select for diffs]
Wed Feb 24 20:35:22 2021 UTC (4 years, 9 months ago) by greg
Changes since 3.44: +5 -5 lines
Diff to previous 3.44
fix: Further reduced threshold to handle some extreme corner cases
Revision 3.44 - (view) (download) (annotate) - [select for diffs]
Wed Feb 24 03:48:52 2021 UTC (4 years, 9 months ago) by greg
Changes since 3.43: +4 -5 lines
Diff to previous 3.43
perf: improved fall-back setting consistency for histogram adjustment
Revision 3.43 - (view) (download) (annotate) - [select for diffs]
Fri Feb 5 01:07:28 2021 UTC (4 years, 10 months ago) by greg
Changes since 3.42: +8 -4 lines
Diff to previous 3.42
perf: minor optimization
Revision 3.42 - (view) (download) (annotate) - [select for diffs]
Thu Jan 7 20:34:45 2021 UTC (4 years, 11 months ago) by greg
Changes since 3.41: +4 -4 lines
Diff to previous 3.41
perf: missed a memcpy() opportunity
Thu Jan 7 19:13:57 2021 UTC (4 years, 11 months ago) by greg
Changes since 3.40: +12 -8 lines
Diff to previous 3.40
fix: fixed issue with last change and made it so TMAP_TYP can be float
Revision 3.40 - (view) (download) (annotate) - [select for diffs]
Thu Jan 7 02:13:49 2021 UTC (4 years, 11 months ago) by greg
Changes since 3.39: +5 -5 lines
Diff to previous 3.39
perf: increased accuracy of luminance map
Wed Jan 6 20:34:10 2021 UTC (4 years, 11 months ago) by greg
Changes since 3.38: +3 -4 lines
Diff to previous 3.38
fix: repair error in last change
Wed Jan 6 19:25:00 2021 UTC (4 years, 11 months ago) by greg
Changes since 3.37: +17 -16 lines
Diff to previous 3.37
refactor: added defined types for histogram and map tables
Fri May 20 02:06:38 2011 UTC (14 years, 7 months ago) by greg
CVS Tags: rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Changes since 3.36: +6 -6 lines
Diff to previous 3.36
Fri Apr 22 14:35:54 2011 UTC (14 years, 8 months ago) by greg
Changes since 3.35: +5 -7 lines
Diff to previous 3.35
Fixed bug in mapping to extreme monitor spaces
Mon Mar 7 20:49:19 2011 UTC (14 years, 9 months ago) by greg
Changes since 3.34: +2 -4 lines
Diff to previous 3.34
Minor improvement in round-off method
Mon Feb 9 20:48:08 2009 UTC (16 years, 10 months ago) by greg
Changes since 3.33: +2 -1 lines
Diff to previous 3.33
Eliminated redefinition of malloc(3)
Mon Feb 9 20:23:51 2009 UTC (16 years, 10 months ago) by greg
Changes since 3.32: +22 -24 lines
Diff to previous 3.32
Made tmNewMap() available to private callers
Thu Jul 3 03:35:10 2008 UTC (17 years, 5 months ago) by greg
Changes since 3.31: +2 -2 lines
Diff to previous 3.31
Another cosmetic improvement similar to last
Thu Jul 3 03:30:21 2008 UTC (17 years, 5 months ago) by greg
Changes since 3.30: +9 -10 lines
Diff to previous 3.30
Cosmetic simplification to history array access
Tue Nov 27 02:42:54 2007 UTC (18 years ago) by greg
Changes since 3.29: +7 -6 lines
Diff to previous 3.29
Fixed bug in linear tonemapping for some highly peaked histograms
Wed May 23 21:38:50 2007 UTC (18 years, 7 months ago) by greg
Changes since 3.28: +5 -5 lines
Diff to previous 3.28
Made tone-mapping function more robust for degenerate images
Wed Aug 9 16:26:54 2006 UTC (19 years, 4 months ago) by greg
Changes since 3.27: +6 -4 lines
Diff to previous 3.27
Fixed overflow condition on fixed linear tone-mapping
Wed Jun 7 17:52:03 2006 UTC (19 years, 6 months ago) by schorsch
Changes since 3.26: +1 -2 lines
Diff to previous 3.26
Thu May 18 01:58:18 2006 UTC (19 years, 7 months ago) by greg
Changes since 3.25: +3 -3 lines
Diff to previous 3.25
Minor improvements to luminance accuracy
Thu May 11 00:58:48 2006 UTC (19 years, 7 months ago) by greg
Changes since 3.24: +6 -6 lines
Diff to previous 3.24
Bug fix related to last change with non-positive colors in tmCvColors()
Wed May 10 15:34:17 2006 UTC (19 years, 7 months ago) by greg
Changes since 3.23: +6 -3 lines
Diff to previous 3.23
Minor fixes to last change with IEEE float lookup function
Wed May 10 15:21:58 2006 UTC (19 years, 7 months ago) by greg
Changes since 3.22: +110 -67 lines
Diff to previous 3.22
Made COLOR conversion faster with lookup and fixed scale bug in tmCvGrays()
Thu Mar 23 22:01:43 2006 UTC (19 years, 9 months ago) by greg
Changes since 3.21: +6 -1 lines
Diff to previous 3.21
Fixed problems with NaN and Inf floating point color values
Wed Jan 18 00:24:38 2006 UTC (19 years, 11 months ago) by greg
Diff to previous 3.20
Bug fix in last change
Sat Jan 14 20:25:51 2006 UTC (19 years, 11 months ago) by greg
Changes since 3.19: +11 -7 lines
Diff to previous 3.19
Improved conversion speed for floating-point pixels with gamma lookup table
Tue Nov 15 06:53:00 2005 UTC (20 years, 1 month ago) by greg
Changes since 3.18: +17 -1 lines
Diff to previous 3.18
Added tmCvLuminance() call
Fri Jan 7 22:05:30 2005 UTC (20 years, 11 months ago) by greg
Changes since 3.17: +6 -3 lines
Diff to previous 3.17
Added client data pointer to tmSetSpace() call
Fri Jan 7 21:41:06 2005 UTC (20 years, 11 months ago) by greg
Changes since 3.16: +17 -16 lines
Diff to previous 3.16
Moved error codes inside passed TMstruct
Fri Jan 7 20:33:02 2005 UTC (20 years, 11 months ago) by greg
Changes since 3.15: +211 -243 lines
Diff to previous 3.15
Thu Jul 22 17:48:52 2004 UTC (21 years, 5 months ago) by greg
Changes since 3.14: +5 -3 lines
Diff to previous 3.14
Added check for incompatible use of TM_F_MESOPIC with TM_F_BW
Thu Sep 18 20:18:19 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.13: +2 -2 lines
Diff to previous 3.13
Sun Jul 27 22:12:01 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 3.12: +6 -6 lines
Diff to previous 3.12
Tue Jul 15 00:30:09 2003 UTC (22 years, 5 months ago) by greg
Diff to previous 3.11
Fixed bug in tmCvColors for zero and negative values
Fri Jun 20 00:25:49 2003 UTC (22 years, 6 months ago) by greg
Changes since 3.10: +3 -3 lines
Diff to previous 3.10
Tue Feb 25 02:47:22 2003 UTC (22 years, 10 months ago) by greg
Changes since 3.9: +1 -56 lines
Diff to previous 3.9
Sat Feb 22 02:07:22 2003 UTC (22 years, 10 months ago) by greg
Changes since 3.8: +238 -100 lines
Diff to previous 3.8
Mon Aug 17 17:58:47 1998 UTC (27 years, 4 months ago) by gwlarson
Changes since 3.7: +8 -6 lines
Diff to previous 3.7
took "color.h" include out of tonemap.h and put in tmprivat.h
changed routines so zero-length arrays don't return error
Mon Dec 1 09:52:00 1997 UTC (28 years ago) by gregl
Changes since 3.6: +1 -1 lines
Diff to previous 3.6
got rid of unused variable
Mon Nov 17 14:02:12 1997 UTC (28 years, 1 month ago) by gregl
Changes since 3.5: +34 -35 lines
changed behavior so that tmClearHisto() and tmAddHisto() do not
void computed tone mapping, even if brightness limits are exceeded
Wed Nov 12 13:25:48 1997 UTC (28 years, 1 month ago) by gregl
Changes since 3.4: +5 -0 lines
added tmLastError and tmLastFunction globals (set by tmErrorReturn)
Fri Apr 18 13:59:43 1997 UTC (28 years, 8 months ago) by greg
Changes since 3.3: +53 -45 lines
added notion of conversion packages with private data
Wed Apr 16 20:28:03 1997 UTC (28 years, 8 months ago) by greg
Changes since 3.2: +34 -0 lines
minor bug fixes and added tmDup()
Tue Apr 15 20:04:43 1997 UTC (28 years, 8 months ago) by greg
Changes since 3.1: +41 -35 lines
changed TM_F_NOERRS to TM_F_NOSTDERR
skipped histogram clipping for TM_F_LINEAR in tmComputeMapping()
Tue Apr 15 16:53:01 1997 UTC (28 years, 8 months ago) by greg
