root/radiance/ray/src/common/tonemap.c
Revision: 3.41
Committed: Thu Jan 7 19:13:57 2021 UTC (4 years, 5 months ago) by greg
Changes since 3.40: +12 -8 lines
fix: fixed issue with last change and made it so TMAP_TYP can be float
2 static const char RCSid[] = "$Id: tonemap.c,v 3.40 2021/01/07 02:13:49 greg Exp $";
5 * Tone mapping functions.
6 * See tonemap.h for detailed function descriptions.
7 * Added von Kries white-balance calculations 10/01 (GW).
8 *
9 * Externals declared in tonemap.h
10 */
11
12 #include "copyright.h"
13
14 #include <stdio.h>
15 #include <stdlib.h>
16 #include <math.h>
17 #include <string.h>
18 #include "tmprivat.h"
19 #include "tmerrmsg.h"
20
21 #define exp10(x) exp(M_LN10*(x))
22
23 /* our list of conversion packages */
24 struct tmPackage *tmPkg[TM_MAXPKG];
25 int tmNumPkgs = 0; /* number of registered packages */
26
27 /* luminance->brightness lookup */
28 static TMbright *tmFloat2BrtLUT = NULL;
29
30 #define tmCvLumLUfp(pf) tmFloat2BrtLUT[*(int32 *)(pf) >> 15]
31
32
33 TMstruct *
34 tmInit( /* initialize new tone mapping */
35 int flags,
36 RGBPRIMP monpri,
37 double gamval
38 )
39 {
40 COLORMAT cmat;
41 TMstruct *tmnew;
42 int i;
43 /* allocate structure */
44 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
45 if (tmnew == NULL)
46 return(NULL);
47
48 tmnew->flags = flags & ~TM_F_UNIMPL;
49 if (tmnew->flags & TM_F_BW)
50 tmnew->flags &= ~TM_F_MESOPIC;
51 /* set monitor transform */
52 if (monpri == NULL || monpri == stdprims || tmnew->flags & TM_F_BW) {
53 tmnew->monpri = stdprims;
54 tmnew->clf[RED] = rgb2xyzmat[1][0];
55 tmnew->clf[GRN] = rgb2xyzmat[1][1];
56 tmnew->clf[BLU] = rgb2xyzmat[1][2];
57 } else {
58 comprgb2xyzmat(cmat, tmnew->monpri=monpri);
59 tmnew->clf[RED] = cmat[1][0];
60 tmnew->clf[GRN] = cmat[1][1];
61 tmnew->clf[BLU] = cmat[1][2];
62 }
63 /* set gamma value */
64 if (gamval < MINGAM)
65 tmnew->mongam = DEFGAM;
66 else
67 tmnew->mongam = gamval;
68 /* set color divisors */
69 for (i = 0; i < 3; i++)
70 tmnew->cdiv[i] = TM_BRES*pow(tmnew->clf[i], 1./tmnew->mongam);
71
72 /* set input transform */
73 tmnew->inppri = tmnew->monpri;
74 tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] =
75 tmnew->inpsf = WHTEFFICACY;
76 tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] =
77 tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.;
78 tmnew->inpdat = NULL;
79 tmnew->hbrmin = 10; tmnew->hbrmax = -10;
80 tmnew->histo = NULL;
81 tmnew->mbrmin = 10; tmnew->mbrmax = -10;
82 tmnew->lumap = NULL;
83 /* zero private data */
84 for (i = TM_MAXPKG; i--; )
85 tmnew->pd[i] = NULL;
86 tmnew->lastError = TM_E_OK;
87 tmnew->lastFunc = "NoErr";
88 /* return new TMstruct */
89 return(tmnew);
90 }
91
92
93 int
94 tmSetSpace( /* set input color space for conversions */
95 TMstruct *tms,
96 RGBPRIMP pri,
97 double sf,
98 MEM_PTR dat
99 )
100 {
101 static const char funcName[] = "tmSetSpace";
102 int i, j;
103 /* error check */
104 if (tms == NULL)
105 returnErr(TM_E_TMINVAL);
106 if (sf <= 1e-12)
107 returnErr(TM_E_ILLEGAL);
108 /* check if no change */
109 if (pri == tms->inppri && FEQ(sf, tms->inpsf) && dat == tms->inpdat)
110 returnOK;
111 tms->inppri = pri; /* let's set it */
112 tms->inpsf = sf;
113 tms->inpdat = dat;
114
115 if (tms->flags & TM_F_BW) { /* color doesn't matter */
116 tms->monpri = tms->inppri; /* eliminate xform */
117 if (tms->inppri == TM_XYZPRIM) {
118 tms->clf[CIEX] = tms->clf[CIEZ] = 0.;
119 tms->clf[CIEY] = 1.;
120 } else {
121 comprgb2xyzmat(tms->cmat, tms->monpri);
122 tms->clf[RED] = tms->cmat[1][0];
123 tms->clf[GRN] = tms->cmat[1][1];
124 tms->clf[BLU] = tms->cmat[1][2];
125 }
126 tms->cmat[0][0] = tms->cmat[1][1] = tms->cmat[2][2] =
127 tms->inpsf;
128 tms->cmat[0][1] = tms->cmat[0][2] = tms->cmat[1][0] =
129 tms->cmat[1][2] = tms->cmat[2][0] = tms->cmat[2][1] = 0.;
130
131 } else if (tms->inppri == TM_XYZPRIM) /* input is XYZ */
132 compxyz2rgbWBmat(tms->cmat, tms->monpri);
133
134 else { /* input is RGB */
135 if (tms->inppri != tms->monpri &&
136 PRIMEQ(tms->inppri, tms->monpri))
137 tms->inppri = tms->monpri; /* no xform */
138 if (!comprgb2rgbWBmat(tms->cmat, tms->inppri, tms->monpri))
139 returnErr(TM_E_ILLEGAL);
140 }
141 for (i = 0; i < 3; i++)
142 for (j = 0; j < 3; j++)
143 tms->cmat[i][j] *= tms->inpsf;
144 /* set color divisors */
145 for (i = 0; i < 3; i++)
146 tms->cdiv[i] = TM_BRES*pow(tms->clf[i] < .001 ? .001 :
147 tms->clf[i], 1./tms->mongam);
148 /* notify packages */
149 for (i = tmNumPkgs; i--; )
150 if (tms->pd[i] != NULL && tmPkg[i]->NewSpace != NULL)
151 (*tmPkg[i]->NewSpace)(tms);
152 returnOK;
153 }
154
155
156 void
157 tmClearHisto( /* clear current histogram */
158 TMstruct *tms
159 )
160 {
161 if (tms == NULL || tms->histo == NULL)
162 return;
163 free((MEM_PTR)tms->histo);
164 tms->histo = NULL;
165 }
166
167
168 TMbright
169 tmCvLuminance( /* convert a single luminance */
170 double lum
171 )
172 {
173 double d;
174
175 #ifdef isfinite
176 if (!isfinite(lum) || lum <= TM_NOLUM)
177 #else
178 if (lum <= TM_NOLUM)
179 #endif
180 return(TM_NOBRT);
181 d = TM_BRTSCALE*log(lum);
182 return((TMbright)(d + .5 - (d < 0.)));
183 }
184
185
186 int
187 tmCvLums( /* convert luminances using lookup */
188 TMbright *ls,
189 float *scan,
190 int len
191 )
192 {
193 if (tmFloat2BrtLUT == NULL) { /* initialize lookup table */
194 int32 i;
195 tmFloat2BrtLUT = (TMbright *)malloc(sizeof(TMbright)*0x10000);
196 if (tmFloat2BrtLUT == NULL)
197 return(TM_E_NOMEM);
198 for (i = 0; i < 0x10000; i++) {
199 int32 l = (i<<1 | 1) << 14;
200 #ifndef isfinite
201 if ((l & 0x7f800000) == 0x7f800000)
202 tmFloat2BrtLUT[i] = TM_NOBRT;
203 else
204 #endif
205 tmFloat2BrtLUT[i] = tmCvLuminance(*(float *)&l);
206 }
207 }
208 if (len <= 0)
209 return(TM_E_OK);
210 if ((ls == NULL) | (scan == NULL))
211 return(TM_E_ILLEGAL);
212 while (len--) {
213 if (*scan <= TM_NOLUM) {
214 *ls++ = TM_NOBRT;
215 ++scan;
216 continue;
217 }
218 *ls++ = tmCvLumLUfp(scan++);
219 }
220 return(TM_E_OK);
221 }
222
223
224 int
225 tmCvGrays( /* convert float gray values */
226 TMstruct *tms,
227 TMbright *ls,
228 float *scan,
229 int len
230 )
231 {
232 static const char funcName[] = "tmCvGrays";
233 int i;
234
235 if (tms == NULL)
236 returnErr(TM_E_TMINVAL);
237 if ((ls == NULL) | (scan == NULL) | (len < 0))
238 returnErr(TM_E_ILLEGAL);
239 if (tmFloat2BrtLUT == NULL) /* initialize */
240 tmCvLums(NULL, NULL, 0);
241 for (i = len; i--; ) {
242 float lum = tms->inpsf * scan[i];
243 if (lum <= TM_NOLUM)
244 ls[i] = TM_NOBRT;
245 else
246 ls[i] = tmCvLumLUfp(&lum);
247 }
248 returnOK;
249 }
250
251
252 int
253 tmCvColors( /* convert float colors */
254 TMstruct *tms,
255 TMbright *ls,
256 uby8 *cs,
257 COLOR *scan,
258 int len
259 )
260 {
261 static const char funcName[] = "tmCvColors";
262 static uby8 gamtab[1024];
263 static double curgam = .0;
264 COLOR cmon;
265 float lum, slum, d;
266 int i;
267
268 if (tms == NULL)
269 returnErr(TM_E_TMINVAL);
270 if ((ls == NULL) | (scan == NULL) | (len < 0))
271 returnErr(TM_E_ILLEGAL);
272 if (tmFloat2BrtLUT == NULL) /* initialize */
273 tmCvLums(NULL, NULL, 0);
274 if (cs != TM_NOCHROM && fabs(tms->mongam - curgam) > .02) {
275 curgam = tms->mongam; /* (re)build table */
276 for (i = 1024; i--; )
277 gamtab[i] = (int)(256.*pow((i+.5)/1024., 1./curgam));
278 }
279 for (i = len; i--; ) {
280 if (tmNeedMatrix(tms)) { /* get monitor RGB */
281 colortrans(cmon, tms->cmat, scan[i]);
282 } else {
283 cmon[RED] = tms->inpsf*scan[i][RED];
284 cmon[GRN] = tms->inpsf*scan[i][GRN];
285 cmon[BLU] = tms->inpsf*scan[i][BLU];
286 }
287 #ifdef isfinite
288 if (!isfinite(cmon[RED]) || cmon[RED] < .0f) cmon[RED] = .0f;
289 if (!isfinite(cmon[GRN]) || cmon[GRN] < .0f) cmon[GRN] = .0f;
290 if (!isfinite(cmon[BLU]) || cmon[BLU] < .0f) cmon[BLU] = .0f;
291 #else
292 if (cmon[RED] < .0f) cmon[RED] = .0f;
293 if (cmon[GRN] < .0f) cmon[GRN] = .0f;
294 if (cmon[BLU] < .0f) cmon[BLU] = .0f;
295 #endif
296 /* world luminance */
297 lum = tms->clf[RED]*cmon[RED] +
298 tms->clf[GRN]*cmon[GRN] +
299 tms->clf[BLU]*cmon[BLU] ;
300 if (lum <= TM_NOLUM) { /* convert brightness */
301 lum = cmon[RED] = cmon[GRN] = cmon[BLU] = TM_NOLUM;
302 ls[i] = TM_NOBRT;
303 } else
304 ls[i] = tmCvLumLUfp(&lum);
305 if (cs == TM_NOCHROM) /* no color? */
306 continue;
307 if (tms->flags & TM_F_MESOPIC && lum < LMESUPPER) {
308 slum = scotlum(cmon); /* mesopic adj. */
309 if (lum < LMESLOWER) {
310 cmon[RED] = cmon[GRN] = cmon[BLU] = slum;
311 } else {
312 d = (lum - LMESLOWER)/(LMESUPPER - LMESLOWER);
313 if (tms->flags & TM_F_BW)
314 cmon[RED] = cmon[GRN] =
315 cmon[BLU] = d*lum;
316 else
317 scalecolor(cmon, d);
318 d = (1.f-d)*slum;
319 cmon[RED] += d;
320 cmon[GRN] += d;
321 cmon[BLU] += d;
322 }
323 } else if (tms->flags & TM_F_BW) {
324 cmon[RED] = cmon[GRN] = cmon[BLU] = lum;
325 }
326 d = tms->clf[RED]*cmon[RED]/lum;
327 cs[3*i ] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
328 d = tms->clf[GRN]*cmon[GRN]/lum;
329 cs[3*i+1] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
330 d = tms->clf[BLU]*cmon[BLU]/lum;
331 cs[3*i+2] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
332 }
333 returnOK;
334 }
335
336
337 int
338 tmAddHisto( /* add values to histogram */
339 TMstruct *tms,
340 TMbright *ls,
341 int len,
342 int wt
343 )
344 {
345 static const char funcName[] = "tmAddHisto";
346 int oldorig=0, oldlen, horig, hlen;
347 int i, j;
348
349 if (tms == NULL)
350 returnErr(TM_E_TMINVAL);
351 if (len < 0)
352 returnErr(TM_E_ILLEGAL);
353 if (len == 0)
354 returnOK;
355 /* first, grow limits */
356 if (tms->histo == NULL) {
357 for (i = len; i-- && ls[i] < MINBRT; )
358 ;
359 if (i < 0)
360 returnOK;
361 tms->hbrmin = tms->hbrmax = ls[i];
362 oldlen = 0;
363 } else {
364 oldorig = HISTI(tms->hbrmin);
365 oldlen = HISTI(tms->hbrmax) + 1 - oldorig;
366 }
367 for (i = len; i--; ) {
368 if ((j = ls[i]) < MINBRT)
369 continue;
370 if (j < tms->hbrmin)
371 tms->hbrmin = j;
372 else if (j > tms->hbrmax)
373 tms->hbrmax = j;
374 }
375 horig = HISTI(tms->hbrmin);
376 hlen = HISTI(tms->hbrmax) + 1 - horig;
377 if (hlen > oldlen) { /* (re)allocate histogram */
378 HIST_TYP *newhist = (HIST_TYP *)calloc(hlen, sizeof(HIST_TYP));
379 if (newhist == NULL)
380 returnErr(TM_E_NOMEM);
381 if (oldlen) { /* copy and free old */
382 memcpy((MEM_PTR)(newhist+(oldorig-horig)),
383 (MEM_PTR)tms->histo, oldlen*sizeof(HIST_TYP));
384 free((MEM_PTR)tms->histo);
385 }
386 tms->histo = newhist;
387 }
388 if (wt == 0)
389 returnOK;
390 for (i = len; i--; ) /* add in new counts */
391 if (ls[i] >= MINBRT)
392 tms->histo[ HISTI(ls[i]) - horig ] += wt;
393 returnOK;
394 }
395
396
397 static double
398 htcontrs( /* human threshold contrast sensitivity, dL(La) */
399 double La
400 )
401 {
402 double l10La, l10dL;
403 /* formula taken from Ferwerda et al. [SG96] */
404 if (La < 1.148e-4)
405 return(1.38e-3);
406 l10La = log10(La);
407 if (l10La < -1.44) /* rod response regime */
408 l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86;
409 else if (l10La < -.0184)
410 l10dL = l10La - .395;
411 else if (l10La < 1.9) /* cone response regime */
412 l10dL = pow(.249*l10La + .65, 2.7) - .72;
413 else
414 l10dL = l10La - 1.255;
415
416 return(exp10(l10dL));
417 }
418
419
420 int
421 tmFixedMapping( /* compute fixed, linear tone-mapping */
422 TMstruct *tms,
423 double expmult,
424 double gamval
425 )
426 {
427 static const char funcName[] = "tmFixedMapping";
428 double d;
429 int i;
430
431 if (!tmNewMap(tms))
432 returnErr(TM_E_NOMEM);
433 if (expmult <= .0)
434 expmult = 1.;
435 if (gamval < MINGAM)
436 gamval = tms->mongam;
437 d = log(expmult/tms->inpsf);
438 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
439 double val = TM_BRES * exp(
440 ( d + (tms->mbrmin+i)*(1./TM_BRTSCALE) )
441 / gamval);
442 tms->lumap[i] = val;
443 if (sizeof(TMAP_TYP) == 2 && val >= 0xffff)
444 tms->lumap[i] = 0xffff;
445 }
446 returnOK;
447 }
448
449
450 int
451 tmComputeMapping( /* compute histogram tone-mapping */
452 TMstruct *tms,
453 double gamval,
454 double Lddyn,
455 double Ldmax
456 )
457 {
458 static const char funcName[] = "tmComputeMapping";
459 HIST_TYP *histo;
460 float *cumf;
461 int brt0, histlen;
462 HIST_TYP threshold, ceiling, trimmings, histot;
463 double logLddyn, Ldmin, Ldavg, Lwavg, Tr, Lw, Ld;
464 double sum;
465 double d;
466 int i, j;
467
468 if (tms == NULL || tms->histo == NULL)
469 returnErr(TM_E_TMINVAL);
470 /* check arguments */
471 if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN;
472 if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX;
473 if (gamval < MINGAM) gamval = tms->mongam;
474 /* compute handy values */
475 Ldmin = Ldmax/Lddyn;
476 logLddyn = log(Lddyn);
477 Ldavg = sqrt(Ldmax*Ldmin);
478 i = HISTI(tms->hbrmin);
479 brt0 = HISTV(i);
480 histlen = HISTI(tms->hbrmax) + 1 - i;
481 /* histogram total and mean */
482 histot = 0; sum = 0;
483 j = brt0 + histlen*HISTEP;
484 for (i = histlen; i--; ) {
485 histot += tms->histo[i];
486 sum += (double)(j -= HISTEP) * tms->histo[i];
487 }
488 threshold = histot*0.005 + .5;
489 if (!histot)
490 returnErr(TM_E_TMFAIL);
491 Lwavg = tmLuminance( (double)sum / histot );
492 /* use linear tone mapping? */
493 if (tms->flags & TM_F_LINEAR || threshold < 4 ||
494 tms->hbrmax - tms->hbrmin < TM_BRTSCALE*logLddyn)
495 goto linearmap;
496 /* clamp histogram */
497 histo = (HIST_TYP *)malloc(histlen*sizeof(HIST_TYP));
498 cumf = (float *)malloc((histlen+2)*sizeof(float));
499 if ((histo == NULL) | (cumf == NULL))
500 returnErr(TM_E_NOMEM);
501 cumf[histlen+1] = 1.; /* guard for assignment code */
502 for (i = histlen; i--; ) /* make malleable copy */
503 histo[i] = tms->histo[i];
504 do { /* iterate to solution */
505 sum = 0; /* cumulative probability */
506 for (i = 0; i < histlen; i++) {
507 cumf[i] = (double)sum/histot;
508 sum += histo[i];
509 }
510 cumf[histlen] = 1.;
511 Tr = histot * (double)(tms->hbrmax - tms->hbrmin) /
512 ((double)histlen*TM_BRTSCALE) / logLddyn;
513 ceiling = Tr + 1.;
514 trimmings = 0; /* clip to envelope */
515 for (i = histlen; i--; ) {
516 if (tms->flags & TM_F_HCONTR) {
517 Lw = tmLuminance(brt0 + i*HISTEP);
518 Ld = Ldmin * exp( logLddyn *
519 .5*(cumf[i]+cumf[i+1]) );
520 ceiling = Tr * (htcontrs(Ld) * Lw) /
521 (htcontrs(Lw) * Ld) + 1.;
522 }
523 if (histo[i] > ceiling) {
524 trimmings += histo[i] - ceiling;
525 histo[i] = ceiling;
526 }
527 }
528 /* check if we're out of data */
529 if ((histot -= trimmings) <= threshold) {
530 free((MEM_PTR)histo);
531 free((MEM_PTR)cumf);
532 goto linearmap;
533 }
534 } while (trimmings > threshold);
535 /* allocate space for mapping */
536 if (!tmNewMap(tms))
537 returnErr(TM_E_NOMEM);
538 /* assign tone-mapping */
539 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
540 j = d = (double)i/(tms->mbrmax-tms->mbrmin)*histlen;
541 d -= (double)j;
542 Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1]));
543 d = (Ld - Ldmin)/(Ldmax - Ldmin);
544 tms->lumap[i] = TM_BRES*pow(d, 1./gamval);
545 }
546 free((MEM_PTR)histo); /* clean up and return */
547 free((MEM_PTR)cumf);
548 returnOK;
549 linearmap: /* linear tone-mapping */
550 if (tms->flags & TM_F_HCONTR)
551 d = htcontrs(Ldavg) / htcontrs(Lwavg);
552 else
553 d = Ldavg / Lwavg;
554 return(tmFixedMapping(tms, tms->inpsf*d/Ldmax, gamval));
555 }
556
557
558 int
559 tmMapPixels( /* apply tone-mapping to pixel(s) */
560 TMstruct *tms,
561 uby8 *ps,
562 TMbright *ls,
563 uby8 *cs,
564 int len
565 )
566 {
567 static const char funcName[] = "tmMapPixels";
568 TMbright lv;
569 TMAP_TYP li;
570 int pv;
571
572 if (tms == NULL || tms->lumap == NULL)
573 returnErr(TM_E_TMINVAL);
574 if ((ps == NULL) | (ls == NULL) | (len < 0))
575 returnErr(TM_E_ILLEGAL);
576 while (len--) {
577 if ((lv = *ls++) < tms->mbrmin) {
578 li = 0;
579 } else {
580 if (lv > tms->mbrmax)
581 lv = tms->mbrmax;
582 li = tms->lumap[lv - tms->mbrmin];
583 }
584 if (cs == TM_NOCHROM)
585 *ps++ = li>=TM_BRES ? 255 : (int)(256*li/TM_BRES);
586 else {
587 pv = *cs++ * li / tms->cdiv[RED];
588 *ps++ = pv>255 ? 255 : pv;
589 pv = *cs++ * li / tms->cdiv[GRN];
590 *ps++ = pv>255 ? 255 : pv;
591 pv = *cs++ * li / tms->cdiv[BLU];
592 *ps++ = pv>255 ? 255 : pv;
593 }
594 }
595 returnOK;
596 }
597
598
599 TMstruct *
600 tmDup( /* duplicate top tone mapping */
601 TMstruct *tms
602 )
603 {
604 int len;
605 int i;
606 TMstruct *tmnew;
607
608 if (tms == NULL) /* anything to duplicate? */
609 return(NULL);
610 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
611 if (tmnew == NULL)
612 return(NULL);
613 *tmnew = *tms; /* copy everything */
614 if (tmnew->histo != NULL) { /* duplicate histogram */
615 len = HISTI(tmnew->hbrmax) + 1 - HISTI(tmnew->hbrmin);
616 tmnew->histo = (HIST_TYP *)malloc(len*sizeof(HIST_TYP));
617 if (tmnew->histo != NULL)
618 memcpy((MEM_PTR)tmnew->histo, (MEM_PTR)tms->histo,
619 len*sizeof(HIST_TYP));
620 }
621 if (tmnew->lumap != NULL) { /* duplicate luminance mapping */
622 len = tmnew->mbrmax-tmnew->mbrmin+1;
623 tmnew->lumap = (TMAP_TYP *)malloc(len*sizeof(TMAP_TYP));
624 if (tmnew->lumap != NULL)
625 memcpy((MEM_PTR)tmnew->lumap, (MEM_PTR)tms->lumap,
626 len*sizeof(TMAP_TYP));
627 }
628 /* clear package data */
629 for (i = tmNumPkgs; i--; )
630 tmnew->pd[i] = NULL;
631 /* return copy */
632 return(tmnew);
633 }
634
635
636 void
637 tmDone(tms) /* done with tone mapping -- destroy it */
638 TMstruct *tms;
639 {
640 int i;
641 /* NULL arg. is equiv. to tms */
642 if (tms == NULL)
643 return;
644 /* free tables */
645 if (tms->histo != NULL)
646 free((MEM_PTR)tms->histo);
647 if (tms->lumap != NULL)
648 free((MEM_PTR)tms->lumap);
649 /* free private data */
650 for (i = tmNumPkgs; i--; )
651 if (tms->pd[i] != NULL)
652 (*tmPkg[i]->Free)(tms->pd[i]);
653 free((MEM_PTR)tms); /* free basic structure */
654 }
655
656 /******************** Shared but Private library routines *********************/
657
658 uby8 tmMesofact[BMESUPPER-BMESLOWER];
659
660 void
661 tmMkMesofact() /* build mesopic lookup factor table */
662 {
663 int i;
664
665 if (tmMesofact[BMESUPPER-BMESLOWER-1])
666 return;
667
668 for (i = BMESLOWER; i < BMESUPPER; i++)
669 tmMesofact[i-BMESLOWER] = 256. *
670 (tmLuminance(i) - LMESLOWER) /
671 (LMESUPPER - LMESLOWER);
672 }
673
674
675 int
676 tmNewMap( /* allocate new tone-mapping array */
677 TMstruct *tms
678 )
679 {
680 if (tms->lumap != NULL && (tms->mbrmax - tms->mbrmin) !=
681 (tms->hbrmax - tms->hbrmin)) {
682 free((MEM_PTR)tms->lumap);
683 tms->lumap = NULL;
684 }
685 tms->mbrmin = tms->hbrmin;
686 tms->mbrmax = tms->hbrmax;
687 if (tms->mbrmin > tms->mbrmax)
688 return 0;
689 if (tms->lumap == NULL)
690 tms->lumap = (TMAP_TYP *)malloc(sizeof(TMAP_TYP)*
691 (tms->mbrmax-tms->mbrmin+1));
692 return(tms->lumap != NULL);
693 }
694
695
696 int
697 tmErrorReturn( /* error return (with message) */
698 const char *func,
699 TMstruct *tms,
700 int err
701 )
702 {
703 if (tms != NULL) {
704 tms->lastFunc = func;
705 tms->lastError = err;
706 if (tms->flags & TM_F_NOSTDERR)
707 return(err);
708 }
709 fputs(func, stderr);
710 fputs(": ", stderr);
711 fputs(tmErrorMessage[err], stderr);
712 fputs("!\n", stderr);
713 return(err);
714 }
