1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: tonemap.c,v 3.22 2006/03/23 22:01:43 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Tone mapping functions. |
6 |
* See tonemap.h for detailed function descriptions. |
7 |
* Added von Kries white-balance calculations 10/01 (GW). |
8 |
9 |
* Externals declared in tonemap.h |
10 |
11 |
12 |
#include "copyright.h" |
13 |
14 |
#include <stdio.h> |
15 |
#include <math.h> |
16 |
#include "tmprivat.h" |
17 |
#include "tmerrmsg.h" |
18 |
19 |
#define exp10(x) exp(M_LN10*(x)) |
20 |
21 |
/* our list of conversion packages */ |
22 |
struct tmPackage *tmPkg[TM_MAXPKG]; |
23 |
int tmNumPkgs = 0; /* number of registered packages */ |
24 |
25 |
/* luminance->brightness lookup */ |
26 |
static TMbright *tmFloat2BrtLUT; |
27 |
28 |
#define tmCvLumLUfp(pf) tmFloat2BrtLUT[*(int32 *)(pf) >> 15] |
29 |
30 |
31 |
TMstruct * |
32 |
tmInit( /* initialize new tone mapping */ |
33 |
int flags, |
34 |
RGBPRIMP monpri, |
35 |
double gamval |
36 |
37 |
38 |
COLORMAT cmat; |
39 |
TMstruct *tmnew; |
40 |
int i; |
41 |
/* allocate structure */ |
42 |
tmnew = (TMstruct *)malloc(sizeof(TMstruct)); |
43 |
if (tmnew == NULL) |
44 |
return(NULL); |
45 |
46 |
tmnew->flags = flags & ~TM_F_UNIMPL; |
47 |
if (tmnew->flags & TM_F_BW) |
48 |
tmnew->flags &= ~TM_F_MESOPIC; |
49 |
/* set monitor transform */ |
50 |
if (monpri == NULL || monpri == stdprims || tmnew->flags & TM_F_BW) { |
51 |
tmnew->monpri = stdprims; |
52 |
tmnew->clf[RED] = rgb2xyzmat[1][0]; |
53 |
tmnew->clf[GRN] = rgb2xyzmat[1][1]; |
54 |
tmnew->clf[BLU] = rgb2xyzmat[1][2]; |
55 |
} else { |
56 |
comprgb2xyzWBmat(cmat, tmnew->monpri=monpri); |
57 |
tmnew->clf[RED] = cmat[1][0]; |
58 |
tmnew->clf[GRN] = cmat[1][1]; |
59 |
tmnew->clf[BLU] = cmat[1][2]; |
60 |
61 |
/* set gamma value */ |
62 |
if (gamval < MINGAM) |
63 |
tmnew->mongam = DEFGAM; |
64 |
else |
65 |
tmnew->mongam = gamval; |
66 |
/* set color divisors */ |
67 |
for (i = 0; i < 3; i++) |
68 |
tmnew->cdiv[i] = 256.*pow(tmnew->clf[i], 1./tmnew->mongam); |
69 |
70 |
/* set input transform */ |
71 |
tmnew->inppri = tmnew->monpri; |
72 |
tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] = |
73 |
tmnew->inpsf = WHTEFFICACY; |
74 |
tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] = |
75 |
tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.; |
76 |
tmnew->inpdat = NULL; |
77 |
tmnew->hbrmin = 10; tmnew->hbrmax = -10; |
78 |
tmnew->histo = NULL; |
79 |
tmnew->mbrmin = 10; tmnew->mbrmax = -10; |
80 |
tmnew->lumap = NULL; |
81 |
/* zero private data */ |
82 |
for (i = TM_MAXPKG; i--; ) |
83 |
tmnew->pd[i] = NULL; |
84 |
tmnew->lastError = TM_E_OK; |
85 |
tmnew->lastFunc = "NoErr"; |
86 |
/* return new TMstruct */ |
87 |
return(tmnew); |
88 |
89 |
90 |
91 |
int |
92 |
tmSetSpace( /* set input color space for conversions */ |
93 |
TMstruct *tms, |
94 |
RGBPRIMP pri, |
95 |
double sf, |
96 |
MEM_PTR dat |
97 |
98 |
99 |
static const char funcName[] = "tmSetSpace"; |
100 |
int i, j; |
101 |
/* error check */ |
102 |
if (tms == NULL) |
103 |
returnErr(TM_E_TMINVAL); |
104 |
if (sf <= 1e-12) |
105 |
returnErr(TM_E_ILLEGAL); |
106 |
/* check if no change */ |
107 |
if (pri == tms->inppri && FEQ(sf, tms->inpsf) && dat == tms->inpdat) |
108 |
returnOK; |
109 |
tms->inppri = pri; /* let's set it */ |
110 |
tms->inpsf = sf; |
111 |
tms->inpdat = dat; |
112 |
113 |
if (tms->flags & TM_F_BW) { /* color doesn't matter */ |
114 |
tms->monpri = tms->inppri; /* eliminate xform */ |
115 |
if (tms->inppri == TM_XYZPRIM) { |
116 |
tms->clf[CIEX] = tms->clf[CIEZ] = 0.; |
117 |
tms->clf[CIEY] = 1.; |
118 |
} else { |
119 |
comprgb2xyzWBmat(tms->cmat, tms->monpri); |
120 |
tms->clf[RED] = tms->cmat[1][0]; |
121 |
tms->clf[GRN] = tms->cmat[1][1]; |
122 |
tms->clf[BLU] = tms->cmat[1][2]; |
123 |
124 |
tms->cmat[0][0] = tms->cmat[1][1] = tms->cmat[2][2] = |
125 |
tms->inpsf; |
126 |
tms->cmat[0][1] = tms->cmat[0][2] = tms->cmat[1][0] = |
127 |
tms->cmat[1][2] = tms->cmat[2][0] = tms->cmat[2][1] = 0.; |
128 |
129 |
} else if (tms->inppri == TM_XYZPRIM) /* input is XYZ */ |
130 |
compxyz2rgbWBmat(tms->cmat, tms->monpri); |
131 |
132 |
else { /* input is RGB */ |
133 |
if (tms->inppri != tms->monpri && |
134 |
PRIMEQ(tms->inppri, tms->monpri)) |
135 |
tms->inppri = tms->monpri; /* no xform */ |
136 |
comprgb2rgbWBmat(tms->cmat, tms->inppri, tms->monpri); |
137 |
138 |
139 |
for (j = 0; j < 3; j++) |
140 |
tms->cmat[i][j] *= tms->inpsf; |
141 |
142 |
143 |
if (tms->clf[i] > .001) |
144 |
tms->cdiv[i] = |
145 |
256.*pow(tms->clf[i], 1./tms->mongam); |
146 |
else |
147 |
tms->cdiv[i] = 1; |
148 |
/* notify packages */ |
149 |
for (i = tmNumPkgs; i--; ) |
150 |
if (tms->pd[i] != NULL && tmPkg[i]->NewSpace != NULL) |
151 |
(*tmPkg[i]->NewSpace)(tms); |
152 |
returnOK; |
153 |
154 |
155 |
156 |
void |
157 |
tmClearHisto( /* clear current histogram */ |
158 |
TMstruct *tms |
159 |
160 |
161 |
if (tms == NULL || tms->histo == NULL) |
162 |
return; |
163 |
free((MEM_PTR)tms->histo); |
164 |
tms->histo = NULL; |
165 |
166 |
167 |
168 |
TMbright |
169 |
tmCvLuminance( /* convert a single luminance */ |
170 |
double lum |
171 |
172 |
173 |
double d; |
174 |
175 |
#ifdef isfinite |
176 |
if (!isfinite(lum) || lum <= TM_NOLUM) |
177 |
#else |
178 |
if (lum <= TM_NOLUM) |
179 |
#endif |
180 |
return(TM_NOBRT); |
181 |
d = TM_BRTSCALE*log(lum); |
182 |
if (d > 0.) |
183 |
return((TMbright)(d+.5)); |
184 |
return((TMbright)(d-.5)); |
185 |
186 |
187 |
188 |
int |
189 |
tmCvLums( /* convert luminances using lookup */ |
190 |
TMbright *ls, |
191 |
float *scan, |
192 |
int len |
193 |
194 |
195 |
if (tmFloat2BrtLUT == NULL) { /* initialize lookup table */ |
196 |
int32 i; |
197 |
tmFloat2BrtLUT = (TMbright *)malloc(sizeof(TMbright)*0x10000); |
198 |
if (tmFloat2BrtLUT == NULL) |
199 |
return(TM_E_NOMEM); |
200 |
for (i = 0; i < 0x10000; i++) { |
201 |
int32 l = (i<<1 | 1) << 14; |
202 |
#ifndef isfinite |
203 |
if ((l & 0x7f800000) == 0x7f800000) |
204 |
tmFloat2BrtLUT[i] = TM_NOBRT; |
205 |
else |
206 |
#endif |
207 |
tmFloat2BrtLUT[i] = tmCvLuminance(*(float *)&l); |
208 |
209 |
210 |
if (len <= 0) |
211 |
return(TM_E_OK); |
212 |
if ((ls == NULL) | (scan == NULL)) |
213 |
return(TM_E_ILLEGAL); |
214 |
while (len--) { |
215 |
if (*scan <= TM_NOLUM) { |
216 |
*ls++ = TM_NOBRT; |
217 |
++scan; |
218 |
continue; |
219 |
220 |
*ls++ = tmCvLumLUfp(scan++); |
221 |
222 |
return(TM_E_OK); |
223 |
224 |
225 |
226 |
int |
227 |
tmCvGrays( /* convert float gray values */ |
228 |
TMstruct *tms, |
229 |
TMbright *ls, |
230 |
float *scan, |
231 |
int len |
232 |
233 |
234 |
static const char funcName[] = "tmCvGrays"; |
235 |
double d; |
236 |
int i; |
237 |
238 |
if (tms == NULL) |
239 |
240 |
if ((ls == NULL) | (scan == NULL) | (len < 0)) |
241 |
242 |
for (i = len; i--; ) { |
243 |
float lum = tms->inpsf * scan[i]; |
244 |
245 |
ls[i] = TM_NOBRT; |
246 |
else |
247 |
ls[i] = tmCvLumLUfp(&lum); |
248 |
249 |
returnOK; |
250 |
251 |
252 |
253 |
int |
254 |
tmCvColors( /* convert float colors */ |
255 |
TMstruct *tms, |
256 |
TMbright *ls, |
257 |
BYTE *cs, |
258 |
COLOR *scan, |
259 |
int len |
260 |
261 |
262 |
static const char funcName[] = "tmCvColors"; |
263 |
static COLOR csmall = {.5*MINLUM, .5*MINLUM, .5*MINLUM}; |
264 |
static BYTE gamtab[1024]; |
265 |
static double curgam = .0; |
266 |
COLOR cmon; |
267 |
float lum, slum, d; |
268 |
int i; |
269 |
270 |
if (tms == NULL) |
271 |
272 |
273 |
274 |
tmCvLums(NULL, NULL, 0); /* initialize */ |
275 |
if (cs != TM_NOCHROM && fabs(tms->mongam - curgam) > .02) { |
276 |
curgam = tms->mongam; /* (re)build table */ |
277 |
for (i = 1024; i--; ) |
278 |
gamtab[i] = (int)(256.*pow((i+.5)/1024., 1./curgam)); |
279 |
280 |
281 |
if (tmNeedMatrix(tms)) { /* get monitor RGB */ |
282 |
colortrans(cmon, tms->cmat, scan[i]); |
283 |
} else { |
284 |
cmon[RED] = tms->inpsf*scan[i][RED]; |
285 |
cmon[GRN] = tms->inpsf*scan[i][GRN]; |
286 |
cmon[BLU] = tms->inpsf*scan[i][BLU]; |
287 |
288 |
#ifdef isfinite |
289 |
if (!isfinite(cmon[RED]) || cmon[RED] < .0f) cmon[RED] = .0f; |
290 |
if (!isfinite(cmon[GRN]) || cmon[GRN] < .0f) cmon[GRN] = .0f; |
291 |
if (!isfinite(cmon[BLU]) || cmon[BLU] < .0f) cmon[BLU] = .0f; |
292 |
#else |
293 |
if (cmon[RED] < .0f) cmon[RED] = .0f; |
294 |
if (cmon[GRN] < .0f) cmon[GRN] = .0f; |
295 |
if (cmon[BLU] < .0f) cmon[BLU] = .0f; |
296 |
#endif |
297 |
/* world luminance */ |
298 |
lum = tms->clf[RED]*cmon[RED] + |
299 |
tms->clf[GRN]*cmon[GRN] + |
300 |
tms->clf[BLU]*cmon[BLU] ; |
301 |
if (lum <= TM_NOLUM) /* convert brightness */ |
302 |
ls[i] = TM_NOBRT; |
303 |
else |
304 |
305 |
if (cs == TM_NOCHROM) /* no color? */ |
306 |
continue; |
307 |
if (tms->flags & TM_F_MESOPIC && lum < LMESUPPER) { |
308 |
slum = scotlum(cmon); /* mesopic adj. */ |
309 |
if (lum < LMESLOWER) |
310 |
cmon[RED] = cmon[GRN] = cmon[BLU] = slum; |
311 |
else { |
312 |
d = (lum - LMESLOWER)/(LMESUPPER - LMESLOWER); |
313 |
if (tms->flags & TM_F_BW) |
314 |
cmon[RED] = cmon[GRN] = |
315 |
cmon[BLU] = d*lum; |
316 |
else |
317 |
scalecolor(cmon, d); |
318 |
d = (1.f-d)*slum; |
319 |
cmon[RED] += d; |
320 |
cmon[GRN] += d; |
321 |
cmon[BLU] += d; |
322 |
323 |
} else if (tms->flags & TM_F_BW) { |
324 |
cmon[RED] = cmon[GRN] = cmon[BLU] = lum; |
325 |
326 |
d = tms->clf[RED]*cmon[RED]/lum; |
327 |
cs[3*i ] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)]; |
328 |
d = tms->clf[GRN]*cmon[GRN]/lum; |
329 |
cs[3*i+1] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)]; |
330 |
d = tms->clf[BLU]*cmon[BLU]/lum; |
331 |
cs[3*i+2] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)]; |
332 |
333 |
returnOK; |
334 |
335 |
336 |
337 |
int |
338 |
tmAddHisto( /* add values to histogram */ |
339 |
TMstruct *tms, |
340 |
TMbright *ls, |
341 |
int len, |
342 |
int wt |
343 |
344 |
345 |
static const char funcName[] = "tmAddHisto"; |
346 |
int oldorig=0, oldlen, horig, hlen; |
347 |
int i, j; |
348 |
349 |
if (tms == NULL) |
350 |
351 |
if (len < 0) |
352 |
353 |
if (len == 0) |
354 |
returnOK; |
355 |
/* first, grow limits */ |
356 |
if (tms->histo == NULL) { |
357 |
for (i = len; i-- && ls[i] < MINBRT; ) |
358 |
359 |
if (i < 0) |
360 |
returnOK; |
361 |
tms->hbrmin = tms->hbrmax = ls[i]; |
362 |
oldlen = 0; |
363 |
} else { |
364 |
oldorig = (tms->hbrmin-MINBRT)/HISTEP; |
365 |
oldlen = (tms->hbrmax-MINBRT)/HISTEP + 1 - oldorig; |
366 |
367 |
368 |
if ((j = ls[i]) < MINBRT) |
369 |
continue; |
370 |
if (j < tms->hbrmin) |
371 |
tms->hbrmin = j; |
372 |
else if (j > tms->hbrmax) |
373 |
tms->hbrmax = j; |
374 |
375 |
horig = (tms->hbrmin-MINBRT)/HISTEP; |
376 |
hlen = (tms->hbrmax-MINBRT)/HISTEP + 1 - horig; |
377 |
if (hlen > oldlen) { /* (re)allocate histogram */ |
378 |
int *newhist = (int *)calloc(hlen, sizeof(int)); |
379 |
if (newhist == NULL) |
380 |
returnErr(TM_E_NOMEM); |
381 |
if (oldlen) { /* copy and free old */ |
382 |
for (i = oldlen, j = i+oldorig-horig; i; ) |
383 |
newhist[--j] = tms->histo[--i]; |
384 |
385 |
386 |
tms->histo = newhist; |
387 |
388 |
if (wt == 0) |
389 |
returnOK; |
390 |
for (i = len; i--; ) /* add in new counts */ |
391 |
if (ls[i] >= MINBRT) |
392 |
tms->histo[ (ls[i]-MINBRT)/HISTEP - horig ] += wt; |
393 |
returnOK; |
394 |
395 |
396 |
397 |
static double |
398 |
htcontrs( /* human threshold contrast sensitivity, dL(La) */ |
399 |
double La |
400 |
401 |
402 |
double l10La, l10dL; |
403 |
/* formula taken from Ferwerda et al. [SG96] */ |
404 |
if (La < 1.148e-4) |
405 |
return(1.38e-3); |
406 |
l10La = log10(La); |
407 |
if (l10La < -1.44) /* rod response regime */ |
408 |
l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86; |
409 |
else if (l10La < -.0184) |
410 |
l10dL = l10La - .395; |
411 |
else if (l10La < 1.9) /* cone response regime */ |
412 |
l10dL = pow(.249*l10La + .65, 2.7) - .72; |
413 |
else |
414 |
l10dL = l10La - 1.255; |
415 |
416 |
return(exp10(l10dL)); |
417 |
418 |
419 |
420 |
static int |
421 |
tmNewMap( /* allocate new tone-mapping array */ |
422 |
TMstruct *tms |
423 |
424 |
425 |
if (tms->lumap != NULL && (tms->mbrmax - tms->mbrmin) != |
426 |
(tms->hbrmax - tms->hbrmin)) { |
427 |
free((MEM_PTR)tms->lumap); |
428 |
tms->lumap = NULL; |
429 |
430 |
tms->mbrmin = tms->hbrmin; |
431 |
tms->mbrmax = tms->hbrmax; |
432 |
if (tms->mbrmin > tms->mbrmax) |
433 |
return 0; |
434 |
if (tms->lumap == NULL) |
435 |
tms->lumap = (unsigned short *)malloc(sizeof(unsigned short)* |
436 |
(tms->mbrmax-tms->mbrmin+1)); |
437 |
return(tms->lumap != NULL); |
438 |
439 |
440 |
441 |
int |
442 |
tmFixedMapping( /* compute fixed, linear tone-mapping */ |
443 |
TMstruct *tms, |
444 |
double expmult, |
445 |
double gamval |
446 |
447 |
448 |
static const char funcName[] = "tmFixedMapping"; |
449 |
double d; |
450 |
int i; |
451 |
452 |
if (!tmNewMap(tms)) |
453 |
454 |
if (expmult <= .0) |
455 |
expmult = 1.; |
456 |
457 |
gamval = tms->mongam; |
458 |
d = log(expmult/tms->inpsf); |
459 |
for (i = tms->mbrmax-tms->mbrmin+1; i--; ) |
460 |
tms->lumap[i] = 256. * exp( |
461 |
( d + (tms->mbrmin+i)*(1./TM_BRTSCALE) ) |
462 |
/ gamval ); |
463 |
returnOK; |
464 |
465 |
466 |
467 |
int |
468 |
tmComputeMapping( /* compute histogram tone-mapping */ |
469 |
TMstruct *tms, |
470 |
double gamval, |
471 |
double Lddyn, |
472 |
double Ldmax |
473 |
474 |
475 |
static const char funcName[] = "tmComputeMapping"; |
476 |
int *histo; |
477 |
float *cumf; |
478 |
int brt0, histlen, threshold, ceiling, trimmings; |
479 |
double logLddyn, Ldmin, Ldavg, Lwavg, Tr, Lw, Ld; |
480 |
int32 histot; |
481 |
double sum; |
482 |
double d; |
483 |
int i, j; |
484 |
485 |
486 |
487 |
/* check arguments */ |
488 |
if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN; |
489 |
if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX; |
490 |
if (gamval < MINGAM) gamval = tms->mongam; |
491 |
/* compute handy values */ |
492 |
Ldmin = Ldmax/Lddyn; |
493 |
logLddyn = log(Lddyn); |
494 |
Ldavg = sqrt(Ldmax*Ldmin); |
495 |
i = (tms->hbrmin-MINBRT)/HISTEP; |
496 |
brt0 = MINBRT + HISTEP/2 + i*HISTEP; |
497 |
histlen = (tms->hbrmax-MINBRT)/HISTEP + 1 - i; |
498 |
/* histogram total and mean */ |
499 |
histot = 0; sum = 0; |
500 |
j = brt0 + histlen*HISTEP; |
501 |
for (i = histlen; i--; ) { |
502 |
histot += tms->histo[i]; |
503 |
sum += (j -= HISTEP) * tms->histo[i]; |
504 |
505 |
threshold = histot*0.005 + .5; |
506 |
if (threshold < 4) |
507 |
returnErr(TM_E_TMFAIL); |
508 |
Lwavg = tmLuminance( (double)sum / histot ); |
509 |
/* allocate space for mapping */ |
510 |
511 |
512 |
/* use linear tone mapping? */ |
513 |
if (tms->flags & TM_F_LINEAR) |
514 |
goto linearmap; |
515 |
/* clamp histogram */ |
516 |
histo = (int *)malloc(histlen*sizeof(int)); |
517 |
cumf = (float *)malloc((histlen+2)*sizeof(float)); |
518 |
if ((histo == NULL) | (cumf == NULL)) |
519 |
520 |
cumf[histlen+1] = 1.; /* guard for assignment code */ |
521 |
for (i = histlen; i--; ) /* make malleable copy */ |
522 |
histo[i] = tms->histo[i]; |
523 |
do { /* iterate to solution */ |
524 |
sum = 0; /* cumulative probability */ |
525 |
for (i = 0; i < histlen; i++) { |
526 |
cumf[i] = (double)sum/histot; |
527 |
sum += histo[i]; |
528 |
529 |
cumf[histlen] = 1.; |
530 |
Tr = histot * (double)(tms->hbrmax - tms->hbrmin) / |
531 |
((double)histlen*TM_BRTSCALE) / logLddyn; |
532 |
ceiling = Tr + 1.; |
533 |
trimmings = 0; /* clip to envelope */ |
534 |
535 |
if (tms->flags & TM_F_HCONTR) { |
536 |
Lw = tmLuminance(brt0 + i*HISTEP); |
537 |
Ld = Ldmin * exp( logLddyn * |
538 |
.5*(cumf[i]+cumf[i+1]) ); |
539 |
ceiling = Tr * (htcontrs(Ld) * Lw) / |
540 |
(htcontrs(Lw) * Ld) + 1.; |
541 |
542 |
if (histo[i] > ceiling) { |
543 |
trimmings += histo[i] - ceiling; |
544 |
histo[i] = ceiling; |
545 |
546 |
547 |
/* check if we're out of data */ |
548 |
if ((histot -= trimmings) <= threshold) { |
549 |
free((MEM_PTR)histo); |
550 |
free((MEM_PTR)cumf); |
551 |
goto linearmap; |
552 |
553 |
} while (trimmings > threshold); |
554 |
/* assign tone-mapping */ |
555 |
for (i = tms->mbrmax-tms->mbrmin+1; i--; ) { |
556 |
j = d = (double)i/(tms->mbrmax-tms->mbrmin)*histlen; |
557 |
d -= (double)j; |
558 |
Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1])); |
559 |
d = (Ld - Ldmin)/(Ldmax - Ldmin); |
560 |
tms->lumap[i] = 256.*pow(d, 1./gamval); |
561 |
562 |
free((MEM_PTR)histo); /* clean up and return */ |
563 |
564 |
returnOK; |
565 |
linearmap: /* linear tone-mapping */ |
566 |
if (tms->flags & TM_F_HCONTR) |
567 |
d = htcontrs(Ldavg) / htcontrs(Lwavg); |
568 |
else |
569 |
d = Ldavg / Lwavg; |
570 |
return(tmFixedMapping(tms, tms->inpsf*d/Ldmax, gamval)); |
571 |
572 |
573 |
574 |
int |
575 |
tmMapPixels( /* apply tone-mapping to pixel(s) */ |
576 |
TMstruct *tms, |
577 |
BYTE *ps, |
578 |
TMbright *ls, |
579 |
BYTE *cs, |
580 |
int len |
581 |
582 |
583 |
static const char funcName[] = "tmMapPixels"; |
584 |
int32 li, pv; |
585 |
586 |
if (tms == NULL || tms->lumap == NULL) |
587 |
588 |
if ((ps == NULL) | (ls == NULL) | (len < 0)) |
589 |
590 |
while (len--) { |
591 |
if ((li = *ls++) < tms->mbrmin) { |
592 |
li = 0; |
593 |
} else { |
594 |
if (li > tms->mbrmax) |
595 |
li = tms->mbrmax; |
596 |
li = tms->lumap[li - tms->mbrmin]; |
597 |
598 |
if (cs == TM_NOCHROM) |
599 |
*ps++ = li>255 ? 255 : li; |
600 |
else { |
601 |
pv = *cs++ * li / tms->cdiv[RED]; |
602 |
*ps++ = pv>255 ? 255 : pv; |
603 |
pv = *cs++ * li / tms->cdiv[GRN]; |
604 |
605 |
pv = *cs++ * li / tms->cdiv[BLU]; |
606 |
607 |
608 |
609 |
returnOK; |
610 |
611 |
612 |
613 |
614 |
615 |
TMstruct * |
616 |
tmDup( /* duplicate top tone mapping */ |
617 |
TMstruct *tms |
618 |
619 |
620 |
int len; |
621 |
int i; |
622 |
TMstruct *tmnew; |
623 |
624 |
if (tms == NULL) /* anything to duplicate? */ |
625 |
return(NULL); |
626 |
627 |
628 |
return(NULL); |
629 |
*tmnew = *tms; /* copy everything */ |
630 |
if (tmnew->histo != NULL) { /* duplicate histogram */ |
631 |
len = (tmnew->hbrmax-MINBRT)/HISTEP + 1 - |
632 |
(tmnew->hbrmin-MINBRT)/HISTEP; |
633 |
tmnew->histo = (int *)malloc(len*sizeof(int)); |
634 |
if (tmnew->histo != NULL) |
635 |
for (i = len; i--; ) |
636 |
tmnew->histo[i] = tms->histo[i]; |
637 |
638 |
if (tmnew->lumap != NULL) { /* duplicate luminance mapping */ |
639 |
len = tmnew->mbrmax-tmnew->mbrmin+1; |
640 |
tmnew->lumap = (unsigned short *)malloc( |
641 |
len*sizeof(unsigned short) ); |
642 |
if (tmnew->lumap != NULL) |
643 |
644 |
tmnew->lumap[i] = tms->lumap[i]; |
645 |
646 |
/* clear package data */ |
647 |
648 |
649 |
/* return copy */ |
650 |
return(tmnew); |
651 |
652 |
653 |
654 |
void |
655 |
tmDone(tms) /* done with tone mapping -- destroy it */ |
656 |
TMstruct *tms; |
657 |
658 |
int i; |
659 |
/* NULL arg. is equiv. to tms */ |
660 |
if (tms == NULL) |
661 |
return; |
662 |
/* free tables */ |
663 |
if (tms->histo != NULL) |
664 |
665 |
if (tms->lumap != NULL) |
666 |
667 |
/* free private data */ |
668 |
669 |
if (tms->pd[i] != NULL) |
670 |
(*tmPkg[i]->Free)(tms->pd[i]); |
671 |
free((MEM_PTR)tms); /* free basic structure */ |
672 |
673 |
674 |
/******************** Shared but Private library routines *********************/ |
675 |
676 |
BYTE tmMesofact[BMESUPPER-BMESLOWER]; |
677 |
678 |
void |
679 |
tmMkMesofact() /* build mesopic lookup factor table */ |
680 |
681 |
int i; |
682 |
683 |
if (tmMesofact[BMESUPPER-BMESLOWER-1]) |
684 |
return; |
685 |
686 |
for (i = BMESLOWER; i < BMESUPPER; i++) |
687 |
tmMesofact[i-BMESLOWER] = 256. * |
688 |
(tmLuminance(i) - LMESLOWER) / |
689 |
690 |
691 |
692 |
693 |
int |
694 |
tmErrorReturn( /* error return (with message) */ |
695 |
const char *func, |
696 |
TMstruct *tms, |
697 |
int err |
698 |
699 |
700 |
if (tms != NULL) { |
701 |
tms->lastFunc = func; |
702 |
tms->lastError = err; |
703 |
if (tms->flags & TM_F_NOSTDERR) |
704 |
return(err); |
705 |
706 |
fputs(func, stderr); |
707 |
fputs(": ", stderr); |
708 |
fputs(tmErrorMessage[err], stderr); |
709 |
fputs("!\n", stderr); |
710 |
return(err); |
711 |
