--- ray/src/common/tonemap.c 2004/07/22 17:48:52 3.15 +++ ray/src/common/tonemap.c 2011/04/22 14:35:54 3.36 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: tonemap.c,v 3.15 2004/07/22 17:48:52 greg Exp $"; +static const char RCSid[] = "$Id: tonemap.c,v 3.36 2011/04/22 14:35:54 greg Exp $"; #endif /* * Tone mapping functions. @@ -12,33 +12,35 @@ static const char RCSid[] = "$Id: tonemap.c,v 3.15 200 #include "copyright.h" #include +#include #include #include "tmprivat.h" #include "tmerrmsg.h" #define exp10(x) exp(M_LN10*(x)) -struct tmStruct *tmTop = NULL; /* current tone mapping stack */ - /* our list of conversion packages */ struct tmPackage *tmPkg[TM_MAXPKG]; int tmNumPkgs = 0; /* number of registered packages */ -int tmLastError; /* last error incurred by library */ -char *tmLastFunction; /* error-generating function name */ + /* luminance->brightness lookup */ +static TMbright *tmFloat2BrtLUT = NULL; +#define tmCvLumLUfp(pf) tmFloat2BrtLUT[*(int32 *)(pf) >> 15] -struct tmStruct * -tmInit(flags, monpri, gamval) /* initialize new tone mapping */ -int flags; -RGBPRIMP monpri; -double gamval; + +TMstruct * +tmInit( /* initialize new tone mapping */ +int flags, +RGBPRIMP monpri, +double gamval +) { COLORMAT cmat; - register struct tmStruct *tmnew; - register int i; + TMstruct *tmnew; + int i; /* allocate structure */ - tmnew = (struct tmStruct *)malloc(sizeof(struct tmStruct)); + tmnew = (TMstruct *)malloc(sizeof(TMstruct)); if (tmnew == NULL) return(NULL); @@ -52,7 +54,7 @@ double gamval; tmnew->clf[GRN] = rgb2xyzmat[1][1]; tmnew->clf[BLU] = rgb2xyzmat[1][2]; } else { - comprgb2xyzWBmat(cmat, tmnew->monpri=monpri); + comprgb2xyzmat(cmat, tmnew->monpri=monpri); tmnew->clf[RED] = cmat[1][0]; tmnew->clf[GRN] = cmat[1][1]; tmnew->clf[BLU] = cmat[1][2]; @@ -72,6 +74,7 @@ double gamval; tmnew->inpsf = WHTEFFICACY; tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] = tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.; + tmnew->inpdat = NULL; tmnew->hbrmin = 10; tmnew->hbrmax = -10; tmnew->histo = NULL; tmnew->mbrmin = 10; tmnew->mbrmax = -10; @@ -79,246 +82,321 @@ double gamval; /* zero private data */ for (i = TM_MAXPKG; i--; ) tmnew->pd[i] = NULL; - /* make tmnew current */ - tmnew->tmprev = tmTop; - return(tmTop = tmnew); + tmnew->lastError = TM_E_OK; + tmnew->lastFunc = "NoErr"; + /* return new TMstruct */ + return(tmnew); } int -tmSetSpace(pri, sf) /* set input color space for conversions */ -RGBPRIMP pri; -double sf; +tmSetSpace( /* set input color space for conversions */ +TMstruct *tms, +RGBPRIMP pri, +double sf, +MEM_PTR dat +) { - static char funcName[] = "tmSetSpace"; - register int i, j; + static const char funcName[] = "tmSetSpace"; + int i, j; /* error check */ - if (tmTop == NULL) + if (tms == NULL) returnErr(TM_E_TMINVAL); if (sf <= 1e-12) returnErr(TM_E_ILLEGAL); /* check if no change */ - if (pri == tmTop->inppri && FEQ(sf, tmTop->inpsf)) + if (pri == tms->inppri && FEQ(sf, tms->inpsf) && dat == tms->inpdat) returnOK; - tmTop->inppri = pri; /* let's set it */ - tmTop->inpsf = sf; + tms->inppri = pri; /* let's set it */ + tms->inpsf = sf; + tms->inpdat = dat; - if (tmTop->flags & TM_F_BW) { /* color doesn't matter */ - tmTop->monpri = tmTop->inppri; /* eliminate xform */ - if (tmTop->inppri == TM_XYZPRIM) { - tmTop->clf[CIEX] = tmTop->clf[CIEZ] = 0.; - tmTop->clf[CIEY] = 1.; + if (tms->flags & TM_F_BW) { /* color doesn't matter */ + tms->monpri = tms->inppri; /* eliminate xform */ + if (tms->inppri == TM_XYZPRIM) { + tms->clf[CIEX] = tms->clf[CIEZ] = 0.; + tms->clf[CIEY] = 1.; } else { - comprgb2xyzWBmat(tmTop->cmat, tmTop->monpri); - tmTop->clf[RED] = tmTop->cmat[1][0]; - tmTop->clf[GRN] = tmTop->cmat[1][1]; - tmTop->clf[BLU] = tmTop->cmat[1][2]; + comprgb2xyzmat(tms->cmat, tms->monpri); + tms->clf[RED] = tms->cmat[1][0]; + tms->clf[GRN] = tms->cmat[1][1]; + tms->clf[BLU] = tms->cmat[1][2]; } - tmTop->cmat[0][0] = tmTop->cmat[1][1] = tmTop->cmat[2][2] = - tmTop->inpsf; - tmTop->cmat[0][1] = tmTop->cmat[0][2] = tmTop->cmat[1][0] = - tmTop->cmat[1][2] = tmTop->cmat[2][0] = tmTop->cmat[2][1] = 0.; + tms->cmat[0][0] = tms->cmat[1][1] = tms->cmat[2][2] = + tms->inpsf; + tms->cmat[0][1] = tms->cmat[0][2] = tms->cmat[1][0] = + tms->cmat[1][2] = tms->cmat[2][0] = tms->cmat[2][1] = 0.; - } else if (tmTop->inppri == TM_XYZPRIM) /* input is XYZ */ - compxyz2rgbWBmat(tmTop->cmat, tmTop->monpri); + } else if (tms->inppri == TM_XYZPRIM) /* input is XYZ */ + compxyz2rgbWBmat(tms->cmat, tms->monpri); else { /* input is RGB */ - if (tmTop->inppri != tmTop->monpri && - PRIMEQ(tmTop->inppri, tmTop->monpri)) - tmTop->inppri = tmTop->monpri; /* no xform */ - comprgb2rgbWBmat(tmTop->cmat, tmTop->inppri, tmTop->monpri); + if (tms->inppri != tms->monpri && + PRIMEQ(tms->inppri, tms->monpri)) + tms->inppri = tms->monpri; /* no xform */ + if (!comprgb2rgbWBmat(tms->cmat, tms->inppri, tms->monpri)) + returnErr(TM_E_ILLEGAL); } for (i = 0; i < 3; i++) for (j = 0; j < 3; j++) - tmTop->cmat[i][j] *= tmTop->inpsf; + tms->cmat[i][j] *= tms->inpsf; /* set color divisors */ for (i = 0; i < 3; i++) - if (tmTop->clf[i] > .001) - tmTop->cdiv[i] = - 256.*pow(tmTop->clf[i], 1./tmTop->mongam); - else - tmTop->cdiv[i] = 1; + tms->cdiv[i] = 256.*pow(tms->clf[i] < .001 ? .001 : + tms->clf[i], 1./tms->mongam); /* notify packages */ for (i = tmNumPkgs; i--; ) - if (tmTop->pd[i] != NULL && tmPkg[i]->NewSpace != NULL) - (*tmPkg[i]->NewSpace)(tmTop); + if (tms->pd[i] != NULL && tmPkg[i]->NewSpace != NULL) + (*tmPkg[i]->NewSpace)(tms); returnOK; } void -tmClearHisto() /* clear current histogram */ +tmClearHisto( /* clear current histogram */ +TMstruct *tms +) { - if (tmTop == NULL || tmTop->histo == NULL) + if (tms == NULL || tms->histo == NULL) return; - free((MEM_PTR)tmTop->histo); - tmTop->histo = NULL; + free((MEM_PTR)tms->histo); + tms->histo = NULL; } +TMbright +tmCvLuminance( /* convert a single luminance */ +double lum +) +{ + double d; + +#ifdef isfinite + if (!isfinite(lum) || lum <= TM_NOLUM) +#else + if (lum <= TM_NOLUM) +#endif + return(TM_NOBRT); + d = TM_BRTSCALE*log(lum); + return((TMbright)(d + .5 - (d < 0.))); +} + + int -tmCvColors(ls, cs, scan, len) /* convert float colors */ -TMbright *ls; -BYTE *cs; -COLOR *scan; -int len; +tmCvLums( /* convert luminances using lookup */ +TMbright *ls, +float *scan, +int len +) { - static char funcName[] = "tmCvColors"; - static COLOR csmall = {.5*MINLUM, .5*MINLUM, .5*MINLUM}; + if (tmFloat2BrtLUT == NULL) { /* initialize lookup table */ + int32 i; + tmFloat2BrtLUT = (TMbright *)malloc(sizeof(TMbright)*0x10000); + if (tmFloat2BrtLUT == NULL) + return(TM_E_NOMEM); + for (i = 0; i < 0x10000; i++) { + int32 l = (i<<1 | 1) << 14; +#ifndef isfinite + if ((l & 0x7f800000) == 0x7f800000) + tmFloat2BrtLUT[i] = TM_NOBRT; + else +#endif + tmFloat2BrtLUT[i] = tmCvLuminance(*(float *)&l); + } + } + if (len <= 0) + return(TM_E_OK); + if ((ls == NULL) | (scan == NULL)) + return(TM_E_ILLEGAL); + while (len--) { + if (*scan <= TM_NOLUM) { + *ls++ = TM_NOBRT; + ++scan; + continue; + } + *ls++ = tmCvLumLUfp(scan++); + } + return(TM_E_OK); +} + + +int +tmCvGrays( /* convert float gray values */ +TMstruct *tms, +TMbright *ls, +float *scan, +int len +) +{ + static const char funcName[] = "tmCvGrays"; + int i; + + if (tms == NULL) + returnErr(TM_E_TMINVAL); + if ((ls == NULL) | (scan == NULL) | (len < 0)) + returnErr(TM_E_ILLEGAL); + if (tmFloat2BrtLUT == NULL) /* initialize */ + tmCvLums(NULL, NULL, 0); + for (i = len; i--; ) { + float lum = tms->inpsf * scan[i]; + if (lum <= TM_NOLUM) + ls[i] = TM_NOBRT; + else + ls[i] = tmCvLumLUfp(&lum); + } + returnOK; +} + + +int +tmCvColors( /* convert float colors */ +TMstruct *tms, +TMbright *ls, +BYTE *cs, +COLOR *scan, +int len +) +{ + static const char funcName[] = "tmCvColors"; + static BYTE gamtab[1024]; + static double curgam = .0; COLOR cmon; - double lum, slum; - register double d; - register int i; + float lum, slum, d; + int i; - if (tmTop == NULL) + if (tms == NULL) returnErr(TM_E_TMINVAL); if ((ls == NULL) | (scan == NULL) | (len < 0)) returnErr(TM_E_ILLEGAL); + if (tmFloat2BrtLUT == NULL) /* initialize */ + tmCvLums(NULL, NULL, 0); + if (cs != TM_NOCHROM && fabs(tms->mongam - curgam) > .02) { + curgam = tms->mongam; /* (re)build table */ + for (i = 1024; i--; ) + gamtab[i] = (int)(256.*pow((i+.5)/1024., 1./curgam)); + } for (i = len; i--; ) { - if (tmNeedMatrix(tmTop)) { /* get monitor RGB */ - colortrans(cmon, tmTop->cmat, scan[i]); + if (tmNeedMatrix(tms)) { /* get monitor RGB */ + colortrans(cmon, tms->cmat, scan[i]); } else { - cmon[RED] = tmTop->inpsf*scan[i][RED]; - cmon[GRN] = tmTop->inpsf*scan[i][GRN]; - cmon[BLU] = tmTop->inpsf*scan[i][BLU]; + cmon[RED] = tms->inpsf*scan[i][RED]; + cmon[GRN] = tms->inpsf*scan[i][GRN]; + cmon[BLU] = tms->inpsf*scan[i][BLU]; } +#ifdef isfinite + if (!isfinite(cmon[RED]) || cmon[RED] < .0f) cmon[RED] = .0f; + if (!isfinite(cmon[GRN]) || cmon[GRN] < .0f) cmon[GRN] = .0f; + if (!isfinite(cmon[BLU]) || cmon[BLU] < .0f) cmon[BLU] = .0f; +#else + if (cmon[RED] < .0f) cmon[RED] = .0f; + if (cmon[GRN] < .0f) cmon[GRN] = .0f; + if (cmon[BLU] < .0f) cmon[BLU] = .0f; +#endif /* world luminance */ - lum = tmTop->clf[RED]*cmon[RED] + - tmTop->clf[GRN]*cmon[GRN] + - tmTop->clf[BLU]*cmon[BLU] ; - /* check range */ - if (clipgamut(cmon, lum, CGAMUT_LOWER, csmall, cwhite)) - lum = tmTop->clf[RED]*cmon[RED] + - tmTop->clf[GRN]*cmon[GRN] + - tmTop->clf[BLU]*cmon[BLU] ; - if (lum < MINLUM) { - ls[i] = MINBRT-1; /* bogus value */ - lum = MINLUM; - } else { - d = TM_BRTSCALE*log(lum); /* encode it */ - ls[i] = d>0. ? (int)(d+.5) : (int)(d-.5); - } + lum = tms->clf[RED]*cmon[RED] + + tms->clf[GRN]*cmon[GRN] + + tms->clf[BLU]*cmon[BLU] ; + if (lum <= TM_NOLUM) { /* convert brightness */ + lum = cmon[RED] = cmon[GRN] = cmon[BLU] = TM_NOLUM; + ls[i] = TM_NOBRT; + } else + ls[i] = tmCvLumLUfp(&lum); if (cs == TM_NOCHROM) /* no color? */ continue; - if (tmTop->flags & TM_F_MESOPIC && lum < LMESUPPER) { + if (tms->flags & TM_F_MESOPIC && lum < LMESUPPER) { slum = scotlum(cmon); /* mesopic adj. */ - if (lum < LMESLOWER) + if (lum < LMESLOWER) { cmon[RED] = cmon[GRN] = cmon[BLU] = slum; - else { + } else { d = (lum - LMESLOWER)/(LMESUPPER - LMESLOWER); - if (tmTop->flags & TM_F_BW) + if (tms->flags & TM_F_BW) cmon[RED] = cmon[GRN] = cmon[BLU] = d*lum; else scalecolor(cmon, d); - d = (1.-d)*slum; + d = (1.f-d)*slum; cmon[RED] += d; cmon[GRN] += d; cmon[BLU] += d; } - } else if (tmTop->flags & TM_F_BW) { + } else if (tms->flags & TM_F_BW) { cmon[RED] = cmon[GRN] = cmon[BLU] = lum; } - d = tmTop->clf[RED]*cmon[RED]/lum; - cs[3*i ] = d>=.999 ? 255 : - (int)(256.*pow(d, 1./tmTop->mongam)); - d = tmTop->clf[GRN]*cmon[GRN]/lum; - cs[3*i+1] = d>=.999 ? 255 : - (int)(256.*pow(d, 1./tmTop->mongam)); - d = tmTop->clf[BLU]*cmon[BLU]/lum; - cs[3*i+2] = d>=.999 ? 255 : - (int)(256.*pow(d, 1./tmTop->mongam)); + d = tms->clf[RED]*cmon[RED]/lum; + cs[3*i ] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)]; + d = tms->clf[GRN]*cmon[GRN]/lum; + cs[3*i+1] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)]; + d = tms->clf[BLU]*cmon[BLU]/lum; + cs[3*i+2] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)]; } returnOK; } int -tmCvGrays(ls, scan, len) /* convert float gray values */ -TMbright *ls; -float *scan; -int len; +tmAddHisto( /* add values to histogram */ +TMstruct *tms, +TMbright *ls, +int len, +int wt +) { - static char funcName[] = "tmCvGrays"; - register double d; - register int i; - - if (tmTop == NULL) - returnErr(TM_E_TMINVAL); - if ((ls == NULL) | (scan == NULL) | (len < 0)) - returnErr(TM_E_ILLEGAL); - for (i = len; i--; ) - if (scan[i] <= TM_NOLUM) { - ls[i] = TM_NOBRT; /* bogus value */ - } else { - d = TM_BRTSCALE*log(scan[i]); /* encode it */ - ls[i] = d>0. ? (int)(d+.5) : (int)(d-.5); - } - returnOK; -} - - -int -tmAddHisto(ls, len, wt) /* add values to histogram */ -register TMbright *ls; -int len; -int wt; -{ - static char funcName[] = "tmAddHisto"; + static const char funcName[] = "tmAddHisto"; int oldorig=0, oldlen, horig, hlen; - register int i, j; + int i, j; - if (tmTop == NULL) + if (tms == NULL) returnErr(TM_E_TMINVAL); if (len < 0) returnErr(TM_E_ILLEGAL); if (len == 0) returnOK; /* first, grow limits */ - if (tmTop->histo == NULL) { + if (tms->histo == NULL) { for (i = len; i-- && ls[i] < MINBRT; ) ; if (i < 0) returnOK; - tmTop->hbrmin = tmTop->hbrmax = ls[i]; + tms->hbrmin = tms->hbrmax = ls[i]; oldlen = 0; } else { - oldorig = (tmTop->hbrmin-MINBRT)/HISTEP; - oldlen = (tmTop->hbrmax-MINBRT)/HISTEP + 1 - oldorig; + oldorig = HISTI(tms->hbrmin); + oldlen = HISTI(tms->hbrmax) + 1 - oldorig; } for (i = len; i--; ) { if ((j = ls[i]) < MINBRT) continue; - if (j < tmTop->hbrmin) - tmTop->hbrmin = j; - else if (j > tmTop->hbrmax) - tmTop->hbrmax = j; + if (j < tms->hbrmin) + tms->hbrmin = j; + else if (j > tms->hbrmax) + tms->hbrmax = j; } - horig = (tmTop->hbrmin-MINBRT)/HISTEP; - hlen = (tmTop->hbrmax-MINBRT)/HISTEP + 1 - horig; + horig = HISTI(tms->hbrmin); + hlen = HISTI(tms->hbrmax) + 1 - horig; if (hlen > oldlen) { /* (re)allocate histogram */ - register int *newhist = (int *)calloc(hlen, sizeof(int)); + int *newhist = (int *)calloc(hlen, sizeof(int)); if (newhist == NULL) returnErr(TM_E_NOMEM); if (oldlen) { /* copy and free old */ for (i = oldlen, j = i+oldorig-horig; i; ) - newhist[--j] = tmTop->histo[--i]; - free((MEM_PTR)tmTop->histo); + newhist[--j] = tms->histo[--i]; + free((MEM_PTR)tms->histo); } - tmTop->histo = newhist; + tms->histo = newhist; } if (wt == 0) returnOK; for (i = len; i--; ) /* add in new counts */ if (ls[i] >= MINBRT) - tmTop->histo[ (ls[i]-MINBRT)/HISTEP - horig ] += wt; + tms->histo[ HISTI(ls[i]) - horig ] += wt; returnOK; } static double -htcontrs(La) /* human threshold contrast sensitivity, dL(La) */ -double La; +htcontrs( /* human threshold contrast sensitivity, dL(La) */ +double La +) { double l10La, l10dL; /* formula taken from Ferwerda et al. [SG96] */ @@ -338,94 +416,79 @@ double La; } -static int -tmNewMap() -{ - if (tmTop->lumap != NULL && (tmTop->mbrmax - tmTop->mbrmin) != - (tmTop->hbrmax - tmTop->hbrmin)) { - free((MEM_PTR)tmTop->lumap); - tmTop->lumap = NULL; - } - tmTop->mbrmin = tmTop->hbrmin; - tmTop->mbrmax = tmTop->hbrmax; - if (tmTop->mbrmin > tmTop->mbrmax) - return 0; - if (tmTop->lumap == NULL) - tmTop->lumap = (unsigned short *)malloc(sizeof(unsigned short)* - (tmTop->mbrmax-tmTop->mbrmin+1)); - return(tmTop->lumap != NULL); -} - - int -tmFixedMapping(expmult, gamval) -double expmult; -double gamval; +tmFixedMapping( /* compute fixed, linear tone-mapping */ +TMstruct *tms, +double expmult, +double gamval +) { - static char funcName[] = "tmFixedMapping"; + static const char funcName[] = "tmFixedMapping"; double d; - register int i; + int i; - if (!tmNewMap()) + if (!tmNewMap(tms)) returnErr(TM_E_NOMEM); if (expmult <= .0) expmult = 1.; if (gamval < MINGAM) - gamval = tmTop->mongam; - d = log(expmult/tmTop->inpsf); - for (i = tmTop->mbrmax-tmTop->mbrmin+1; i--; ) - tmTop->lumap[i] = 256. * exp( - ( d + (tmTop->mbrmin+i)*(1./TM_BRTSCALE) ) - / gamval ); + gamval = tms->mongam; + d = log(expmult/tms->inpsf); + for (i = tms->mbrmax-tms->mbrmin+1; i--; ) { + double val = 256. * exp( + ( d + (tms->mbrmin+i)*(1./TM_BRTSCALE) ) + / gamval); + tms->lumap[i] = val >= (double)0xffff ? 0xffff : (int)val; + } returnOK; } int -tmComputeMapping(gamval, Lddyn, Ldmax) -double gamval; -double Lddyn; -double Ldmax; +tmComputeMapping( /* compute histogram tone-mapping */ +TMstruct *tms, +double gamval, +double Lddyn, +double Ldmax +) { - static char funcName[] = "tmComputeMapping"; + static const char funcName[] = "tmComputeMapping"; int *histo; float *cumf; int brt0, histlen, threshold, ceiling, trimmings; double logLddyn, Ldmin, Ldavg, Lwavg, Tr, Lw, Ld; int32 histot; double sum; - register double d; - register int i, j; + double d; + int i, j; - if (tmTop == NULL || tmTop->histo == NULL) + if (tms == NULL || tms->histo == NULL) returnErr(TM_E_TMINVAL); /* check arguments */ if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN; if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX; - if (gamval < MINGAM) gamval = tmTop->mongam; + if (gamval < MINGAM) gamval = tms->mongam; /* compute handy values */ Ldmin = Ldmax/Lddyn; logLddyn = log(Lddyn); Ldavg = sqrt(Ldmax*Ldmin); - i = (tmTop->hbrmin-MINBRT)/HISTEP; - brt0 = MINBRT + HISTEP/2 + i*HISTEP; - histlen = (tmTop->hbrmax-MINBRT)/HISTEP + 1 - i; + i = HISTI(tms->hbrmin); + brt0 = HISTV(i); + histlen = HISTI(tms->hbrmax) + 1 - i; /* histogram total and mean */ histot = 0; sum = 0; j = brt0 + histlen*HISTEP; for (i = histlen; i--; ) { - histot += tmTop->histo[i]; - sum += (j -= HISTEP) * tmTop->histo[i]; + histot += tms->histo[i]; + sum += (double)(j -= HISTEP) * tms->histo[i]; } threshold = histot*0.005 + .5; - if (threshold < 4) + if (!histot) returnErr(TM_E_TMFAIL); Lwavg = tmLuminance( (double)sum / histot ); - /* allocate space for mapping */ - if (!tmNewMap()) - returnErr(TM_E_NOMEM); /* use linear tone mapping? */ - if (tmTop->flags & TM_F_LINEAR) + if (tms->flags & TM_F_LINEAR || threshold < 4 || + tms->hbrmax - tms->hbrmin < TM_BRTSCALE*logLddyn) goto linearmap; /* clamp histogram */ histo = (int *)malloc(histlen*sizeof(int)); @@ -434,7 +497,7 @@ double Ldmax; returnErr(TM_E_NOMEM); cumf[histlen+1] = 1.; /* guard for assignment code */ for (i = histlen; i--; ) /* make malleable copy */ - histo[i] = tmTop->histo[i]; + histo[i] = tms->histo[i]; do { /* iterate to solution */ sum = 0; /* cumulative probability */ for (i = 0; i < histlen; i++) { @@ -442,12 +505,12 @@ double Ldmax; sum += histo[i]; } cumf[histlen] = 1.; - Tr = histot * (double)(tmTop->hbrmax - tmTop->hbrmin) / + Tr = histot * (double)(tms->hbrmax - tms->hbrmin) / ((double)histlen*TM_BRTSCALE) / logLddyn; ceiling = Tr + 1.; trimmings = 0; /* clip to envelope */ for (i = histlen; i--; ) { - if (tmTop->flags & TM_F_HCONTR) { + if (tms->flags & TM_F_HCONTR) { Lw = tmLuminance(brt0 + i*HISTEP); Ld = Ldmin * exp( logLddyn * .5*(cumf[i]+cumf[i+1]) ); @@ -466,56 +529,61 @@ double Ldmax; goto linearmap; } } while (trimmings > threshold); + /* allocate space for mapping */ + if (!tmNewMap(tms)) + returnErr(TM_E_NOMEM); /* assign tone-mapping */ - for (i = tmTop->mbrmax-tmTop->mbrmin+1; i--; ) { - j = d = (double)i/(tmTop->mbrmax-tmTop->mbrmin)*histlen; + for (i = tms->mbrmax-tms->mbrmin+1; i--; ) { + j = d = (double)i/(tms->mbrmax-tms->mbrmin)*histlen; d -= (double)j; Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1])); d = (Ld - Ldmin)/(Ldmax - Ldmin); - tmTop->lumap[i] = 256.*pow(d, 1./gamval); + tms->lumap[i] = 256.*pow(d, 1./gamval); } free((MEM_PTR)histo); /* clean up and return */ free((MEM_PTR)cumf); returnOK; linearmap: /* linear tone-mapping */ - if (tmTop->flags & TM_F_HCONTR) + if (tms->flags & TM_F_HCONTR) d = htcontrs(Ldavg) / htcontrs(Lwavg); else d = Ldavg / Lwavg; - return(tmFixedMapping(tmTop->inpsf*d/Ldmax, gamval)); + return(tmFixedMapping(tms, tms->inpsf*d/Ldmax, gamval)); } int -tmMapPixels(ps, ls, cs, len) -register BYTE *ps; -TMbright *ls; -register BYTE *cs; -int len; +tmMapPixels( /* apply tone-mapping to pixel(s) */ +TMstruct *tms, +BYTE *ps, +TMbright *ls, +BYTE *cs, +int len +) { - static char funcName[] = "tmMapPixels"; - register int32 li, pv; + static const char funcName[] = "tmMapPixels"; + int32 li, pv; - if (tmTop == NULL || tmTop->lumap == NULL) + if (tms == NULL || tms->lumap == NULL) returnErr(TM_E_TMINVAL); if ((ps == NULL) | (ls == NULL) | (len < 0)) returnErr(TM_E_ILLEGAL); while (len--) { - if ((li = *ls++) < tmTop->mbrmin) { + if ((li = *ls++) < tms->mbrmin) { li = 0; } else { - if (li > tmTop->mbrmax) - li = tmTop->mbrmax; - li = tmTop->lumap[li - tmTop->mbrmin]; + if (li > tms->mbrmax) + li = tms->mbrmax; + li = tms->lumap[li - tms->mbrmin]; } if (cs == TM_NOCHROM) *ps++ = li>255 ? 255 : li; else { - pv = *cs++ * li / tmTop->cdiv[RED]; + pv = *cs++ * li / tms->cdiv[RED]; *ps++ = pv>255 ? 255 : pv; - pv = *cs++ * li / tmTop->cdiv[GRN]; + pv = *cs++ * li / tms->cdiv[GRN]; *ps++ = pv>255 ? 255 : pv; - pv = *cs++ * li / tmTop->cdiv[BLU]; + pv = *cs++ * li / tms->cdiv[BLU]; *ps++ = pv>255 ? 255 : pv; } } @@ -523,60 +591,27 @@ int len; } -struct tmStruct * -tmPop() /* pop top tone mapping off stack */ +TMstruct * +tmDup( /* duplicate top tone mapping */ +TMstruct *tms +) { - register struct tmStruct *tms; - - if ((tms = tmTop) != NULL) - tmTop = tms->tmprev; - return(tms); -} - - -int -tmPull(tms) /* pull a tone mapping from stack */ -register struct tmStruct *tms; -{ - register struct tmStruct *tms2; - /* special cases first */ - if ((tms == NULL) | (tmTop == NULL)) - return(0); - if (tms == tmTop) { - tmTop = tms->tmprev; - tms->tmprev = NULL; - return(1); - } - for (tms2 = tmTop; tms2->tmprev != NULL; tms2 = tms2->tmprev) - if (tms == tms2->tmprev) { /* remove it */ - tms2->tmprev = tms->tmprev; - tms->tmprev = NULL; - return(1); - } - return(0); /* not found on stack */ -} - - -struct tmStruct * -tmDup() /* duplicate top tone mapping */ -{ int len; - register int i; - register struct tmStruct *tmnew; + int i; + TMstruct *tmnew; - if (tmTop == NULL) /* anything to duplicate? */ + if (tms == NULL) /* anything to duplicate? */ return(NULL); - tmnew = (struct tmStruct *)malloc(sizeof(struct tmStruct)); + tmnew = (TMstruct *)malloc(sizeof(TMstruct)); if (tmnew == NULL) return(NULL); - *tmnew = *tmTop; /* copy everything */ + *tmnew = *tms; /* copy everything */ if (tmnew->histo != NULL) { /* duplicate histogram */ - len = (tmnew->hbrmax-MINBRT)/HISTEP + 1 - - (tmnew->hbrmin-MINBRT)/HISTEP; + len = HISTI(tmnew->hbrmax) + 1 - HISTI(tmnew->hbrmin); tmnew->histo = (int *)malloc(len*sizeof(int)); if (tmnew->histo != NULL) for (i = len; i--; ) - tmnew->histo[i] = tmTop->histo[i]; + tmnew->histo[i] = tms->histo[i]; } if (tmnew->lumap != NULL) { /* duplicate luminance mapping */ len = tmnew->mbrmax-tmnew->mbrmin+1; @@ -584,45 +619,24 @@ tmDup() /* duplicate top tone mapping */ len*sizeof(unsigned short) ); if (tmnew->lumap != NULL) for (i = len; i--; ) - tmnew->lumap[i] = tmTop->lumap[i]; + tmnew->lumap[i] = tms->lumap[i]; } /* clear package data */ for (i = tmNumPkgs; i--; ) tmnew->pd[i] = NULL; - tmnew->tmprev = tmTop; /* make copy current */ - return(tmTop = tmnew); + /* return copy */ + return(tmnew); } -int -tmPush(tms) /* push tone mapping on top of stack */ -register struct tmStruct *tms; -{ - static char funcName[] = "tmPush"; - /* check validity */ - if (tms == NULL) - returnErr(TM_E_ILLEGAL); - if (tms == tmTop) /* check necessity */ - returnOK; - /* pull if already in stack */ - (void)tmPull(tms); - /* push it on top */ - tms->tmprev = tmTop; - tmTop = tms; - returnOK; -} - - void tmDone(tms) /* done with tone mapping -- destroy it */ -register struct tmStruct *tms; +TMstruct *tms; { - register int i; - /* NULL arg. is equiv. to tmTop */ - if (tms == NULL && (tms = tmTop) == NULL) + int i; + /* NULL arg. is equiv. to tms */ + if (tms == NULL) return; - /* take out of stack if present */ - (void)tmPull(tms); /* free tables */ if (tms->histo != NULL) free((MEM_PTR)tms->histo); @@ -642,7 +656,7 @@ BYTE tmMesofact[BMESUPPER-BMESLOWER]; void tmMkMesofact() /* build mesopic lookup factor table */ { - register int i; + int i; if (tmMesofact[BMESUPPER-BMESLOWER-1]) return; @@ -655,14 +669,39 @@ tmMkMesofact() /* build mesopic lookup factor table int -tmErrorReturn(func, err) /* error return (with message) */ -char *func; -int err; +tmNewMap( /* allocate new tone-mapping array */ +TMstruct *tms +) { - tmLastFunction = func; - tmLastError = err; - if (tmTop != NULL && tmTop->flags & TM_F_NOSTDERR) - return(err); + if (tms->lumap != NULL && (tms->mbrmax - tms->mbrmin) != + (tms->hbrmax - tms->hbrmin)) { + free((MEM_PTR)tms->lumap); + tms->lumap = NULL; + } + tms->mbrmin = tms->hbrmin; + tms->mbrmax = tms->hbrmax; + if (tms->mbrmin > tms->mbrmax) + return 0; + if (tms->lumap == NULL) + tms->lumap = (unsigned short *)malloc(sizeof(unsigned short)* + (tms->mbrmax-tms->mbrmin+1)); + return(tms->lumap != NULL); +} + + +int +tmErrorReturn( /* error return (with message) */ +const char *func, +TMstruct *tms, +int err +) +{ + if (tms != NULL) { + tms->lastFunc = func; + tms->lastError = err; + if (tms->flags & TM_F_NOSTDERR) + return(err); + } fputs(func, stderr); fputs(": ", stderr); fputs(tmErrorMessage[err], stderr);
