root/Development/ray/src/common/tonemap.c
Revision: 3.56
Committed: Mon Sep 1 07:50:45 2025 UTC (4 weeks, 1 day ago) by greg
Changes since 3.55: +12 -9 lines
perf: Took B&W color scan out of main loop for efficiency
2 static const char RCSid[] = "$Id: tonemap.c,v 3.55 2024/11/21 17:15:54 greg Exp $";
5 * Tone mapping functions.
6 * See tonemap.h for detailed function descriptions.
7 * Added von Kries white-balance calculations 10/01 (GW).
8 *
9 * Externals declared in tonemap.h
10 */
11
12 #include "copyright.h"
13
14 #include <stdio.h>
15 #include <stdlib.h>
16 #include <math.h>
17 #include <string.h>
18 #include "tmprivat.h"
19 #include "tmerrmsg.h"
20
21 #define exp10(x) exp(M_LN10*(x))
22
23 /* our list of conversion packages */
24 struct tmPackage *tmPkg[TM_MAXPKG];
25 int tmNumPkgs = 0; /* number of registered packages */
26
27 /* luminance->brightness lookup */
28 static TMbright *tmFloat2BrtLUT = NULL;
29
30 #define tmCvLumLUfp(pf) tmFloat2BrtLUT[*(int32 *)(pf) >> 15]
31
32
33 TMstruct *
34 tmInit( /* initialize new tone mapping */
35 int flags,
36 RGBPRIMP monpri,
37 double gamval
38 )
39 {
40 COLORMAT cmat;
41 TMstruct *tmnew;
42 int i;
43 /* allocate structure */
44 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
45 if (tmnew == NULL)
46 return(NULL);
47
48 tmnew->flags = flags & ~TM_F_UNIMPL;
49 if (tmnew->flags & TM_F_BW)
50 tmnew->flags &= ~TM_F_MESOPIC;
51 /* set monitor transform */
52 if (monpri == NULL || monpri == stdprims || tmnew->flags & TM_F_BW) {
53 tmnew->monpri = stdprims;
54 tmnew->clf[RED] = rgb2xyzmat[1][0];
55 tmnew->clf[GRN] = rgb2xyzmat[1][1];
56 tmnew->clf[BLU] = rgb2xyzmat[1][2];
57 } else {
58 comprgb2xyzmat(cmat, tmnew->monpri=monpri);
59 tmnew->clf[RED] = cmat[1][0];
60 tmnew->clf[GRN] = cmat[1][1];
61 tmnew->clf[BLU] = cmat[1][2];
62 }
63 /* set gamma value */
64 if (gamval < MINGAM)
65 tmnew->mongam = DEFGAM;
66 else
67 tmnew->mongam = gamval;
68 /* set color divisors */
69 for (i = 0; i < 3; i++)
70 tmnew->cdiv[i] = TM_BRES*pow(tmnew->clf[i], 1./tmnew->mongam);
71
72 /* set input transform */
73 tmnew->inppri = tmnew->monpri;
74 tmnew->cmat[0][0] = tmnew->cmat[1][1] = tmnew->cmat[2][2] =
75 tmnew->inpsf = WHTEFFICACY;
76 tmnew->cmat[0][1] = tmnew->cmat[0][2] = tmnew->cmat[1][0] =
77 tmnew->cmat[1][2] = tmnew->cmat[2][0] = tmnew->cmat[2][1] = 0.;
78 tmnew->hbrmin = 10; tmnew->hbrmax = -10;
79 tmnew->histo = NULL;
80 tmnew->mbrmin = 10; tmnew->mbrmax = -10;
81 tmnew->lumap = NULL;
82 /* zero private data */
83 for (i = TM_MAXPKG; i--; )
84 tmnew->pd[i] = NULL;
85 tmnew->lastError = TM_E_OK;
86 tmnew->lastFunc = "NoErr";
87 /* return new TMstruct */
88 return(tmnew);
89 }
90
91
92 int
93 tmSetSpace( /* set input color space for conversions */
94 TMstruct *tms,
95 RGBPRIMP pri,
96 double sf
97 )
98 {
99 static const char funcName[] = "tmSetSpace";
100 int i, j;
101 /* error check */
102 if (tms == NULL)
103 returnErr(TM_E_TMINVAL);
104 if (sf <= 1e-12)
105 returnErr(TM_E_ILLEGAL);
106 /* check if no change */
107 if (pri == tms->inppri && FEQ(sf, tms->inpsf))
108 returnOK;
109 tms->inppri = pri; /* let's set it */
110 tms->inpsf = sf;
111
112 if (tms->flags & TM_F_BW) { /* color doesn't matter */
113 tms->monpri = tms->inppri; /* eliminate xform */
114 if (tms->inppri == TM_XYZPRIM) {
115 tms->clf[CIEX] = tms->clf[CIEZ] = 0.;
116 tms->clf[CIEY] = 1.;
117 } else {
118 comprgb2xyzmat(tms->cmat, tms->monpri);
119 tms->clf[RED] = tms->cmat[1][0];
120 tms->clf[GRN] = tms->cmat[1][1];
121 tms->clf[BLU] = tms->cmat[1][2];
122 }
123 tms->cmat[0][0] = tms->cmat[1][1] = tms->cmat[2][2] = 1.;
124 tms->cmat[0][1] = tms->cmat[0][2] = tms->cmat[1][0] =
125 tms->cmat[1][2] = tms->cmat[2][0] = tms->cmat[2][1] = 0.;
126
127 } else if (tms->inppri == TM_XYZPRIM) { /* input is XYZ */
128 compxyz2rgbWBmat(tms->cmat, tms->monpri);
129
130 } else { /* input is RGB */
131 if (tms->inppri != tms->monpri &&
132 PRIMEQ(tms->inppri, tms->monpri))
133 tms->inppri = tms->monpri; /* no xform */
134 if (!comprgb2rgbWBmat(tms->cmat, tms->inppri, tms->monpri))
135 returnErr(TM_E_ILLEGAL);
136 }
137 for (i = 0; i < 3; i++)
138 for (j = 0; j < 3; j++)
139 tms->cmat[i][j] *= tms->inpsf;
140 /* set color divisors */
141 for (i = 0; i < 3; i++)
142 tms->cdiv[i] = TM_BRES*pow(tms->clf[i] < .001 ? .001 :
143 tms->clf[i], 1./tms->mongam);
144 /* notify packages */
145 for (i = tmNumPkgs; i--; )
146 if (tms->pd[i] != NULL && tmPkg[i]->NewSpace != NULL)
147 (*tmPkg[i]->NewSpace)(tms);
148 returnOK;
149 }
150
151
152 void
153 tmClearHisto( /* clear current histogram */
154 TMstruct *tms
155 )
156 {
157 if (tms == NULL || tms->histo == NULL)
158 return;
159 free(tms->histo);
160 tms->hbrmin = 10; tms->hbrmax = -10;
161 tms->histo = NULL;
162 }
163
164
165 TMbright
166 tmCvLuminance( /* convert a single luminance */
167 double lum
168 )
169 {
170 double d;
171
172 #ifdef isfinite
173 if (!isfinite(lum) || lum <= TM_NOLUM)
174 #else
175 if (lum <= TM_NOLUM)
176 #endif
177 return(TM_NOBRT);
178 d = TM_BRTSCALE*log(lum);
179 return((TMbright)(d + .5 - (d < 0.)));
180 }
181
182
183 int
184 tmCvLums( /* convert luminances using lookup */
185 TMbright *ls,
186 float *scan,
187 int len
188 )
189 {
190 if (tmFloat2BrtLUT == NULL) { /* initialize lookup table */
191 int32 i;
192 tmFloat2BrtLUT = (TMbright *)malloc(sizeof(TMbright)*0x10000);
193 if (tmFloat2BrtLUT == NULL)
194 return(TM_E_NOMEM);
195 for (i = 0; i < 0x10000; i++) {
196 int32 l = (i<<1 | 1) << 14;
197 #ifndef isfinite
198 if ((l & 0x7f800000) == 0x7f800000)
199 tmFloat2BrtLUT[i] = TM_NOBRT;
200 else
201 #endif
202 tmFloat2BrtLUT[i] = tmCvLuminance(*(float *)&l);
203 }
204 }
205 if (len <= 0)
206 return(TM_E_OK);
207 if ((ls == NULL) | (scan == NULL))
208 return(TM_E_ILLEGAL);
209 while (len--) {
210 if (*scan <= TM_NOLUM) {
211 *ls++ = TM_NOBRT;
212 ++scan;
213 continue;
214 }
215 *ls++ = tmCvLumLUfp(scan++);
216 }
217 return(TM_E_OK);
218 }
219
220
221 int
222 tmCvGrays( /* convert float gray values */
223 TMstruct *tms,
224 TMbright *ls,
225 float *scan,
226 int len
227 )
228 {
229 static const char funcName[] = "tmCvGrays";
230 int i;
231
232 if (tms == NULL)
233 returnErr(TM_E_TMINVAL);
234 if ((ls == NULL) | (scan == NULL) | (len < 0))
235 returnErr(TM_E_ILLEGAL);
236 if (tmFloat2BrtLUT == NULL) /* initialize */
237 tmCvLums(NULL, NULL, 0);
238 for (i = len; i--; ) {
239 float lum = tms->inpsf * scan[i];
240 if (lum <= TM_NOLUM)
241 ls[i] = TM_NOBRT;
242 else
243 ls[i] = tmCvLumLUfp(&lum);
244 }
245 returnOK;
246 }
247
248
249 int
250 tmCvColors( /* convert float colors */
251 TMstruct *tms,
252 TMbright *ls,
253 uby8 *cs,
254 COLOR *scan,
255 int len
256 )
257 {
258 static const char funcName[] = "tmCvColors";
259 static uby8 gamtab[1024];
260 static double curgam = .0;
261 COLOR cmon;
262 float lum, slum, d;
263 int i;
264
265 if (tms == NULL)
266 returnErr(TM_E_TMINVAL);
267 if ((ls == NULL) | (scan == NULL) | (len < 0))
268 returnErr(TM_E_ILLEGAL);
269 if (tmFloat2BrtLUT == NULL) /* initialize */
270 tmCvLums(NULL, NULL, 0);
271 if (cs != TM_NOCHROM && fabs(tms->mongam - curgam) > .02) {
272 curgam = tms->mongam; /* (re)build table */
273 for (i = 1024; i--; )
274 gamtab[i] = (int)(256.*pow((i+.5)/1024., 1./curgam));
275 }
276 if (cs != TM_NOCHROM && tms->flags & TM_F_BW) { /* fill B&W chroma */
277 int j = 3;
278 while (j--) {
279 const int pv = (tms->cdiv[j]<<8)/TM_BRES;
280 for (i = len; i--; )
281 cs[3*i + j] = pv;
282 }
283 }
284 for (i = len; i--; ) {
285 if (tmNeedMatrix(tms)) { /* get monitor RGB */
286 colortrans(cmon, tms->cmat, scan[i]);
287 } else {
288 cmon[RED] = tms->inpsf*scan[i][RED];
289 cmon[GRN] = tms->inpsf*scan[i][GRN];
290 cmon[BLU] = tms->inpsf*scan[i][BLU];
291 }
292 #ifdef isfinite
293 if (!isfinite(cmon[RED]) || cmon[RED] < .0f) cmon[RED] = .0f;
294 if (!isfinite(cmon[GRN]) || cmon[GRN] < .0f) cmon[GRN] = .0f;
295 if (!isfinite(cmon[BLU]) || cmon[BLU] < .0f) cmon[BLU] = .0f;
296 #else
297 if (cmon[RED] < .0f) cmon[RED] = .0f;
298 if (cmon[GRN] < .0f) cmon[GRN] = .0f;
299 if (cmon[BLU] < .0f) cmon[BLU] = .0f;
300 #endif /* world luminance */
301 lum = tms->clf[RED]*cmon[RED] +
302 tms->clf[GRN]*cmon[GRN] +
303 tms->clf[BLU]*cmon[BLU] ;
304 if (lum <= TM_NOLUM) { /* convert brightness */
305 lum = cmon[RED] = cmon[GRN] = cmon[BLU] = TM_NOLUM;
306 ls[i] = TM_NOBRT;
307 } else
308 ls[i] = tmCvLumLUfp(&lum);
309 if ((cs == TM_NOCHROM) | (tms->flags & TM_F_BW))
310 continue; /* no color */
311 if (tms->flags & TM_F_MESOPIC && lum < LMESUPPER) {
312 slum = scotlum(cmon); /* mesopic adj. */
313 if (lum < LMESLOWER) {
314 cmon[RED] = cmon[GRN] = cmon[BLU] = slum;
315 } else {
316 d = (lum - LMESLOWER)/(LMESUPPER - LMESLOWER);
317 if (tms->flags & TM_F_BW)
318 cmon[RED] = cmon[GRN] =
319 cmon[BLU] = d*lum;
320 else
321 scalecolor(cmon, d);
322 d = (1.f-d)*slum;
323 cmon[RED] += d;
324 cmon[GRN] += d;
325 cmon[BLU] += d;
326 }
327 }
328 d = tms->clf[RED]*cmon[RED]/lum;
329 cs[3*i ] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
330 d = tms->clf[GRN]*cmon[GRN]/lum;
331 cs[3*i+1] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
332 d = tms->clf[BLU]*cmon[BLU]/lum;
333 cs[3*i+2] = d>=.999f ? 255 : gamtab[(int)(1024.f*d)];
334 }
335 returnOK;
336 }
337
338
339 int
340 tmAddHisto( /* add values to histogram */
341 TMstruct *tms,
342 TMbright *ls,
343 int len,
344 int wt
345 )
346 {
347 static const char funcName[] = "tmAddHisto";
348 int oldorig=0, oldlen, horig, hlen;
349 int i;
350
351 if (tms == NULL)
352 returnErr(TM_E_TMINVAL);
353 if (len < 0)
354 returnErr(TM_E_ILLEGAL);
355 if (len == 0)
356 returnOK;
357 /* first, grow limits */
358 if (tms->histo == NULL) {
359 for (i = len; i-- && ls[i] < MINBRT; )
360 ;
361 if (i < 0)
362 returnOK;
363 tms->hbrmin = tms->hbrmax = ls[i];
364 oldlen = 0;
365 } else {
366 oldorig = HISTI(tms->hbrmin);
367 oldlen = HISTI(tms->hbrmax) + 1 - oldorig;
368 }
369 for (i = len; i--; ) {
370 if (ls[i] < MINBRT)
371 continue;
372 if (ls[i] < tms->hbrmin)
373 tms->hbrmin = ls[i];
374 else if (ls[i] > tms->hbrmax)
375 tms->hbrmax = ls[i];
376 }
377 horig = HISTI(tms->hbrmin);
378 hlen = HISTI(tms->hbrmax) + 1 - horig;
379 if (hlen > oldlen) { /* (re)allocate histogram */
380 HIST_TYP *newhist = (HIST_TYP *)calloc(hlen, sizeof(HIST_TYP));
381 if (newhist == NULL)
382 returnErr(TM_E_NOMEM);
383 if (oldlen) { /* copy and free old */
384 memcpy(newhist+(oldorig-horig),
385 tms->histo, oldlen*sizeof(HIST_TYP));
386 free(tms->histo);
387 }
388 tms->histo = newhist;
389 }
390 if (wt == 0)
391 returnOK;
392 for (i = len; i--; ) /* add in new counts */
393 if (ls[i] >= MINBRT)
394 tms->histo[ HISTI(ls[i]) - horig ] += wt;
395 returnOK;
396 }
397
398
399 static double
400 htcontrs( /* human threshold contrast sensitivity, dL(La) */
401 double La
402 )
403 {
404 double l10La, l10dL;
405 /* formula taken from Ferwerda et al. [SG96] */
406 if (La < 1.148e-4)
407 return(1.38e-3);
408 l10La = log10(La);
409 if (l10La < -1.44) /* rod response regime */
410 l10dL = pow(.405*l10La + 1.6, 2.18) - 2.86;
411 else if (l10La < -.0184)
412 l10dL = l10La - .395;
413 else if (l10La < 1.9) /* cone response regime */
414 l10dL = pow(.249*l10La + .65, 2.7) - .72;
415 else
416 l10dL = l10La - 1.255;
417
418 return(exp10(l10dL));
419 }
420
421
422 int
423 tmFixedMapping( /* compute fixed, linear tone-mapping */
424 TMstruct *tms,
425 double expmult,
426 double gamval,
427 double Lddyn
428 )
429 {
430 static const char funcName[] = "tmFixedMapping";
431 const int maxV = (1L<<(8*sizeof(TMAP_TYP))) - 1;
432 double minD;
433 int i;
434
435 if (!tmNewMap(tms))
436 returnErr(TM_E_NOMEM);
437 /* check arguments */
438 if (expmult <= .0) expmult = 1.;
439 if (gamval < MINGAM) gamval = tms->mongam;
440 if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN;
441 minD = 1./Lddyn;
442 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
443 double d;
444 d = expmult/tms->inpsf * tmLuminance(tms->mbrmin + i);
445 if (d >= 2.*minD)
446 d -= minD;
447 else /* soft black crushing */
448 d *= d/(4.*minD);
449 d /= 1. - minD;
450 d = TM_BRES*pow(d, 1./gamval);
451 tms->lumap[i] = (d > maxV) ? maxV : (int)d;
452 }
453 returnOK;
454 }
455
456
457 int
458 tmComputeMapping( /* compute histogram tone-mapping */
459 TMstruct *tms,
460 double gamval,
461 double Lddyn,
462 double Ldmax
463 )
464 {
465 static const char funcName[] = "tmComputeMapping";
466 HIST_TYP *histo;
467 float *cumf;
468 int brt0, histlen;
469 HIST_TYP threshold, ceiling, trimmings, histot;
470 double logLddyn, Ldmin, Lwavg, Tr, Lw, Ld;
471 double sum;
472 double d;
473 int i, j;
474
475 if (tms == NULL || tms->histo == NULL)
476 returnErr(TM_E_TMINVAL);
477 /* check arguments */
478 if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN;
479 if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX;
480 if (gamval < MINGAM) gamval = tms->mongam;
481 /* compute handy values */
482 Ldmin = Ldmax/Lddyn;
483 logLddyn = log(Lddyn);
484 i = HISTI(tms->hbrmin);
485 brt0 = HISTV(i);
486 histlen = HISTI(tms->hbrmax) + 1 - i;
487 /* histogram total and mean */
488 histot = 0; sum = 0;
489 j = brt0 + histlen*HISTEP;
490 for (i = histlen; i--; ) {
491 histot += tms->histo[i];
492 sum += (double)(j -= HISTEP) * tms->histo[i];
493 }
494 if (!histot)
495 returnErr(TM_E_TMFAIL);
496 threshold = histot/500 + 1;
497 Lwavg = tmLuminance( (double)sum / histot );
498 /* use linear tone mapping? */
499 if (tms->flags & TM_F_LINEAR ||
500 tms->hbrmax - tms->hbrmin < TM_BRTSCALE*logLddyn)
501 goto linearmap;
502 /* clamp histogram */
503 histo = (HIST_TYP *)malloc(histlen*sizeof(HIST_TYP));
504 cumf = (float *)malloc((histlen+2)*sizeof(float));
505 if ((histo == NULL) | (cumf == NULL))
506 returnErr(TM_E_NOMEM);
507 cumf[histlen+1] = 1.; /* guard for assignment code */
508 /* make malleable copy */
509 memcpy(histo, tms->histo, histlen*sizeof(HIST_TYP));
510 do { /* iterate to solution */
511 sum = 0; /* cumulative probability */
512 for (i = 0; i < histlen; i++) {
513 cumf[i] = sum/histot;
514 sum += (double)histo[i];
515 }
516 cumf[histlen] = 1.;
517 Tr = histot * (double)(tms->hbrmax - tms->hbrmin) /
518 ((double)TM_BRTSCALE*histlen*logLddyn);
519 ceiling = Tr + 1.;
520 trimmings = 0; /* clip to envelope */
521 for (i = histlen; i--; ) {
522 if (tms->flags & TM_F_HCONTR) {
523 Lw = tmLuminance(brt0 + i*HISTEP);
524 Ld = Ldmin * exp( logLddyn *
525 .5*(cumf[i]+cumf[i+1]) );
526 ceiling = Tr * (htcontrs(Ld) * Lw) /
527 (htcontrs(Lw) * Ld) + 1.;
528 }
529 if (histo[i] > ceiling) {
530 trimmings += histo[i] - ceiling;
531 histo[i] = ceiling;
532 }
533 }
534 /* check if we're out of data */
535 if ((histot -= trimmings) <= threshold) {
536 free(histo);
537 free(cumf);
538 goto linearmap;
539 }
540 } while (40*trimmings > histot);
541 /* allocate space for mapping */
542 if (!tmNewMap(tms))
543 returnErr(TM_E_NOMEM);
544 /* assign tone-mapping */
545 for (i = tms->mbrmax-tms->mbrmin+1; i--; ) {
546 j = d = (double)i/(tms->mbrmax-tms->mbrmin)*histlen;
547 d -= (double)j;
548 Ld = Ldmin*exp(logLddyn*((1.-d)*cumf[j]+d*cumf[j+1]));
549 d = (Ld - Ldmin)/(Ldmax - Ldmin);
550 tms->lumap[i] = TM_BRES*pow(d, 1./gamval);
551 }
552 free(histo); /* clean up and return */
553 free(cumf);
554 returnOK;
555 linearmap: /* linear tone-mapping */
556 if (tms->flags & TM_F_HCONTR)
557 d = htcontrs(sqrt(Ldmax*Ldmin)) / htcontrs(Lwavg);
558 else
559 d = Ldmax / tmLuminance(tms->hbrmax);
560 return(tmFixedMapping(tms, tms->inpsf*d/Ldmax, gamval, Lddyn));
561 }
562
563
564 int
565 tmMapPixels( /* apply tone-mapping to pixel(s) */
566 TMstruct *tms,
567 uby8 *ps,
568 TMbright *ls,
569 uby8 *cs,
570 int len
571 )
572 {
573 static const char funcName[] = "tmMapPixels";
574 TMbright lv;
575 TMAP_TYP li;
576 int pv;
577
578 if (tms == NULL || tms->lumap == NULL)
579 returnErr(TM_E_TMINVAL);
580 if ((ps == NULL) | (ls == NULL) | (len < 0))
581 returnErr(TM_E_ILLEGAL);
582 while (len--) {
583 if ((lv = *ls++) < tms->mbrmin) {
584 li = 0;
585 } else {
586 if (lv > tms->mbrmax)
587 lv = tms->mbrmax;
588 li = tms->lumap[lv - tms->mbrmin];
589 }
590 if (cs == TM_NOCHROM) {
591 #if !(TM_BRES & 0xff)
592 *ps++ = li>=TM_BRES ? 255 : li/(TM_BRES>>8);
593 #else
594 *ps++ = li>=TM_BRES ? 255 : (li<<8)/TM_BRES;
595 #endif
596 } else {
597 pv = *cs++ * li / tms->cdiv[RED];
598 *ps++ = pv>255 ? 255 : pv;
599 pv = *cs++ * li / tms->cdiv[GRN];
600 *ps++ = pv>255 ? 255 : pv;
601 pv = *cs++ * li / tms->cdiv[BLU];
602 *ps++ = pv>255 ? 255 : pv;
603 }
604 }
605 returnOK;
606 }
607
608
609 TMstruct *
610 tmDup( /* duplicate tone mapping */
611 TMstruct *tms
612 )
613 {
614 int len;
615 int i;
616 TMstruct *tmnew;
617
618 if (tms == NULL) /* anything to duplicate? */
619 return(NULL);
620 tmnew = (TMstruct *)malloc(sizeof(TMstruct));
621 if (tmnew == NULL)
622 return(NULL);
623 *tmnew = *tms; /* copy everything */
624 if (tmnew->histo != NULL) { /* duplicate histogram */
625 len = HISTI(tmnew->hbrmax) + 1 - HISTI(tmnew->hbrmin);
626 tmnew->histo = (HIST_TYP *)malloc(len*sizeof(HIST_TYP));
627 if (tmnew->histo != NULL)
628 memcpy(tmnew->histo, tms->histo, len*sizeof(HIST_TYP));
629 }
630 if (tmnew->lumap != NULL) { /* duplicate luminance mapping */
631 len = tmnew->mbrmax-tmnew->mbrmin+1;
632 tmnew->lumap = (TMAP_TYP *)malloc(len*sizeof(TMAP_TYP));
633 if (tmnew->lumap != NULL)
634 memcpy(tmnew->lumap, tms->lumap, len*sizeof(TMAP_TYP));
635 }
636 /* clear package data */
637 for (i = tmNumPkgs; i--; )
638 tmnew->pd[i] = NULL;
639 /* return copy */
640 return(tmnew);
641 }
642
643
644 void
645 tmDone(tms) /* done with tone mapping -- destroy it */
646 TMstruct *tms;
647 {
648 int i;
649 /* NULL arg. is equiv. to tms */
650 if (tms == NULL)
651 return;
652 /* free tables */
653 if (tms->histo != NULL)
654 free(tms->histo);
655 if (tms->lumap != NULL)
656 free(tms->lumap);
657 /* free private data */
658 for (i = tmNumPkgs; i--; )
659 if (tms->pd[i] != NULL)
660 (*tmPkg[i]->Free)(tms->pd[i]);
661 free(tms); /* free basic structure */
662 }
663
664 /******************** Shared but Private library routines *********************/
665
666 uby8 tmMesofact[BMESUPPER-BMESLOWER];
667
668 void
669 tmMkMesofact() /* build mesopic lookup factor table */
670 {
671 int i;
672
673 if (tmMesofact[BMESUPPER-BMESLOWER-1])
674 return;
675
676 for (i = BMESLOWER; i < BMESUPPER; i++)
677 tmMesofact[i-BMESLOWER] = 256. *
678 (tmLuminance(i) - LMESLOWER) /
679 (LMESUPPER - LMESLOWER);
680 }
681
682
683 int
684 tmNewMap( /* allocate new tone-mapping array */
685 TMstruct *tms
686 )
687 {
688 if (tms->lumap != NULL && (tms->mbrmax - tms->mbrmin) !=
689 (tms->hbrmax - tms->hbrmin)) {
690 free(tms->lumap);
691 tms->lumap = NULL;
692 }
693 tms->mbrmin = tms->hbrmin;
694 tms->mbrmax = tms->hbrmax;
695 if (tms->mbrmin > tms->mbrmax)
696 return(0);
697 if (tms->lumap == NULL)
698 tms->lumap = (TMAP_TYP *)calloc(tms->mbrmax-tms->mbrmin+1,
699 sizeof(TMAP_TYP));
700 else
701 memset(tms->lumap, 0, (tms->mbrmax-tms->mbrmin+1)*sizeof(TMAP_TYP));
702
703 return(tms->lumap != NULL);
704 }
705
706
707 int
708 tmErrorReturn( /* error return (with message) */
709 const char *func,
710 TMstruct *tms,
711 int err
712 )
713 {
714 if (tms != NULL) {
715 tms->lastFunc = func;
716 tms->lastError = err;
717 if (tms->flags & TM_F_NOSTDERR)
718 return(err);
719 }
720 fputs(func, stderr);
721 fputs(": ", stderr);
722 fputs(tmErrorMessage[err], stderr);
723 fputs("!\n", stderr);
724 return(err);
725 }
