--- ray/src/common/tmprivat.h 2003/07/14 04:56:54 3.11 +++ ray/src/common/tmprivat.h 2011/05/20 02:06:38 3.24 @@ -1,12 +1,9 @@ -/* RCSid $Id: tmprivat.h,v 3.11 2003/07/14 04:56:54 greg Exp $ */ +/* RCSid $Id: tmprivat.h,v 3.24 2011/05/20 02:06:38 greg Exp $ */ /* * Private header file for tone mapping routines. */ #ifndef _RAD_TMPRIVAT_H_ #define _RAD_TMPRIVAT_H_ -#ifdef __cplusplus -extern "C" { -#endif #ifndef MEM_PTR #define MEM_PTR void * @@ -14,6 +11,10 @@ extern "C" { #include "color.h" #include "tonemap.h" +#ifdef __cplusplus +extern "C" { +#endif + /* required constants */ #ifndef M_LN2 #define M_LN2 0.69314718055994530942 @@ -29,22 +30,21 @@ extern "C" { #define MINLDMAX 1. #define DEFLDMAX 100. -#define BRT2SCALE(l2) (int)(M_LN2*TM_BRTSCALE*(l2) + ((l2)>0 ? .5 : -.5)) +#define BRT2SCALE(l2) (int)(M_LN2*TM_BRTSCALE*(l2) + .5 - ((l2) < 0)) -#define HISTEP 8 /* steps in BRTSCALE for each bin */ +#define HISTEP 16 /* steps in BRTSCALE for each bin */ #define MINBRT (-16*TM_BRTSCALE) /* minimum usable brightness */ #define MINLUM (1.125352e-7) /* tmLuminance(MINBRT) */ +#define HISTI(li) (((li)-MINBRT)/HISTEP) +#define HISTV(i) (MINBRT + HISTEP/2 + (i)*HISTEP) + #define LMESLOWER (5.62e-3) /* lower mesopic limit */ #define LMESUPPER (5.62) /* upper mesopic limit */ -#if (TM_BRTSCALE==128) -#define BMESLOWER (-663) /* encoded LMESLOWER */ -#define BMESUPPER (221) /* encoded LMESUPPER */ -#else #define BMESLOWER ((int)(-5.18*TM_BRTSCALE-.5)) #define BMESUPPER ((int)(1.73*TM_BRTSCALE+.5)) -#endif + /* approximate scotopic lum. */ #define SCO_rf 0.062 #define SCO_gf 0.608 @@ -54,18 +54,16 @@ extern "C" { (int32)(SCO_gf*256.+.5)*(c)[GRN] + \ (int32)(SCO_bf*256.+.5)*(c)[BLU] ) >> 8 ) -#ifndef malloc -MEM_PTR malloc(); -MEM_PTR calloc(); -#endif -extern int tmErrorReturn(); +extern int tmNewMap(TMstruct *tms); /* allocate new tone-mapping */ +extern int tmErrorReturn(const char *, TMstruct *, int); + /* lookup for mesopic scaling */ -extern BYTE tmMesofact[BMESUPPER-BMESLOWER]; +extern uby8 tmMesofact[BMESUPPER-BMESLOWER]; -extern void tmMkMesofact(); /* build tmMesofact */ +extern void tmMkMesofact(void); /* build tmMesofact */ -#define returnErr(code) return(tmErrorReturn(funcName,code)) +#define returnErr(code) return(tmErrorReturn(funcName,tms,code)) #define returnOK return(TM_E_OK) #define FEQ(a,b) ((a) < (b)+1e-5 && (b) < (a)+1e-5) @@ -74,7 +72,6 @@ extern void tmMkMesofact(); /* build tmMesofact */ &&FEQ((p1)[1][0],(p2)[1][0])&&FEQ((p1)[1][1],(p2)[1][1])\ &&FEQ((p1)[2][0],(p2)[2][0])&&FEQ((p1)[2][1],(p2)[2][1])\ &&FEQ((p1)[3][0],(p2)[3][0])&&FEQ((p1)[3][1],(p2)[3][1])) - #ifdef __cplusplus }
