Minor improvement in round-off method
Adjusted TM_BRTSCALE again (512 overflowed some operations)
Increased HISTEP to correspond to increase in TM_BRTSCALE
Increased TM_BRTSCALE for better luminance resolution
Eliminated redefinition of malloc(3)
Made tmNewMap() available to private callers
Another cosmetic improvement similar to last
Cosmetic simplification to history array access
Moved error codes inside passed TMstruct
Added prototypes and includes from patch by Randolph Fritz. Added more required includes and reduced other compile warnings.
Instrumented headers against multiple inclusion and for use from C++. Moved includes in headers out of "C" scope.
*** empty log message ***
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
took "color.h" include out of tonemap.h and put in tmprivat.h changed routines so zero-length arrays don't return error
added notion of conversion packages with private data
put back old defn's of BMESLOWER and BMESUPPER
minor bug fixes and added tmDup()
