root/radiance/ray/src/common/tmprivat.h
Revision: 3.6
Committed: Sat Feb 22 02:07:22 2003 UTC (21 years, 3 months ago) by greg
Changes since 3.5: +77 -12 lines
1 /* RCSid: $Id$ */
2 /*
3 * Private header file for tone mapping routines.
4 */
5
6 /* ====================================================================
7 * The Radiance Software License, Version 1.0
8 *
9 * Copyright (c) 1990 - 2002 The Regents of the University of California,
10 * through Lawrence Berkeley National Laboratory. All rights reserved.
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 *
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 *
19 * 2. Redistributions in binary form must reproduce the above copyright
20 * notice, this list of conditions and the following disclaimer in
21 * the documentation and/or other materials provided with the
22 * distribution.
23 *
24 * 3. The end-user documentation included with the redistribution,
25 * if any, must include the following acknowledgment:
26 * "This product includes Radiance software
27 * (http://radsite.lbl.gov/)
28 * developed by the Lawrence Berkeley National Laboratory
29 * (http://www.lbl.gov/)."
30 * Alternately, this acknowledgment may appear in the software itself,
31 * if and wherever such third-party acknowledgments normally appear.
32 *
33 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
34 * and "The Regents of the University of California" must
35 * not be used to endorse or promote products derived from this
36 * software without prior written permission. For written
37 * permission, please contact [email protected].
38 *
39 * 5. Products derived from this software may not be called "Radiance",
40 * nor may "Radiance" appear in their name, without prior written
41 * permission of Lawrence Berkeley National Laboratory.
42 *
43 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
44 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
45 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
46 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
47 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
48 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
49 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
50 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
51 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
52 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
53 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
54 * SUCH DAMAGE.
55 * ====================================================================
56 *
57 * This software consists of voluntary contributions made by many
58 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
59 * information on Lawrence Berkeley National Laboratory, please see
60 * <http://www.lbl.gov/>.
61 */
62
63 #ifndef MEM_PTR
64 #define MEM_PTR void *
65 #endif
66 #include "color.h"
67 #include "tonemap.h"
68
69 #ifdef __cplusplus
70 extern "C" {
71 #endif
72
73 /* required constants */
74 #ifndef M_LN2
75 #define M_LN2 0.69314718055994530942
76 #endif
77 #ifndef M_LN10
78 #define M_LN10 2.30258509299404568402
79 #endif
80 /* minimum values and defaults */
81 #define MINGAM 0.75
82 #define DEFGAM 2.2
83 #define MINLDDYN 2.
84 #define DEFLDDYN 32.
85 #define MINLDMAX 1.
86 #define DEFLDMAX 100.
87
88 #define BRT2SCALE(l2) (int)(M_LN2*TM_BRTSCALE*(l2) + ((l2)>0 ? .5 : -.5))
89
90 #define HISTEP 8 /* steps in BRTSCALE for each bin */
91
92 #define MINBRT (-16*TM_BRTSCALE) /* minimum usable brightness */
93 #define MINLUM (1.125352e-7) /* tmLuminance(MINBRT) */
94
95 #define LMESLOWER (5.62e-3) /* lower mesopic limit */
96 #define LMESUPPER (5.62) /* upper mesopic limit */
97 #if (TM_BRTSCALE==128)
98 #define BMESLOWER (-663) /* encoded LMESLOWER */
99 #define BMESUPPER (221) /* encoded LMESUPPER */
100 #else
101 #define BMESLOWER ((int)(-5.18*TM_BRTSCALE-.5))
102 #define BMESUPPER ((int)(1.73*TM_BRTSCALE+.5))
103 #endif
104
105 #ifndef int4
106 #define int4 int /* assume 32-bit integers */
107 #endif
108 /* approximate scotopic lum. */
109 #define SCO_rf 0.062
110 #define SCO_gf 0.608
111 #define SCO_bf 0.330
112 #define scotlum(c) (SCO_rf*(c)[RED] + SCO_gf*(c)[GRN] + SCO_bf*(c)[BLU])
113 #define normscot(c) ( ( (int4)(SCO_rf*256.+.5)*(c)[RED] + \
114 (int4)(SCO_gf*256.+.5)*(c)[GRN] + \
115 (int4)(SCO_bf*256.+.5)*(c)[BLU] ) >> 8 )
116
117 #ifndef malloc
118 MEM_PTR malloc();
119 MEM_PTR calloc();
120 #endif
121 extern int tmErrorReturn();
122
123 /* lookup for mesopic scaling */
124 extern BYTE tmMesofact[BMESUPPER-BMESLOWER];
125
126 extern void tmMkMesofact(); /* build tmMesofact */
127
128 #define returnErr(code) return(tmErrorReturn(funcName,code))
129 #define returnOK return(TM_E_OK)
130
131 #define FEQ(a,b) ((a) < (b)+1e-5 && (b) < (a)+1e-5)
132
133 #define PRIMEQ(p1,p2) (FEQ((p1)[0][0],(p2)[0][0])&&FEQ((p1)[0][1],(p2)[0][1])\
134 &&FEQ((p1)[1][0],(p2)[1][0])&&FEQ((p1)[1][1],(p2)[1][1])\
135 &&FEQ((p1)[2][0],(p2)[2][0])&&FEQ((p1)[2][1],(p2)[2][1])\
136 &&FEQ((p1)[3][0],(p2)[3][0])&&FEQ((p1)[3][1],(p2)[3][1]))
137
138 #ifdef __cplusplus
139 }
140 #endif
