root/radiance/ray/src/common/tmprivat.h
Sat Jan 15 16:57:46 2022 UTC (2 years, 4 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 3.25: +1 -4 lines
Diff to previous 3.25 , to selected 3.18
refactor: eliminated use of MEM_PTR and (char *) for untyped memory
Wed Apr 7 21:13:52 2021 UTC (3 years, 1 month ago) by greg
Diff to previous 3.24 , to selected 3.18
perf: changed default dynamic range from 32 to 100 to reflect modern displays
Fri May 20 02:06:38 2011 UTC (13 years ago) by greg
CVS Tags: rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Diff to previous 3.23 , to selected 3.18
Mon Mar 7 20:49:19 2011 UTC (13 years, 2 months ago) by greg
Diff to previous 3.22 , to selected 3.18
Minor improvement in round-off method
Wed Aug 18 15:25:03 2010 UTC (13 years, 9 months ago) by greg
Changes since 3.21: +2 -2 lines
Diff to previous 3.21 , to selected 3.18
Adjusted TM_BRTSCALE again (512 overflowed some operations)
Tue Jul 27 16:19:57 2010 UTC (13 years, 9 months ago) by greg
Changes since 3.20: +3 -2 lines
Diff to previous 3.20 , to selected 3.18
Increased HISTEP to correspond to increase in TM_BRTSCALE
Tue Jul 27 16:13:40 2010 UTC (13 years, 9 months ago) by greg
Changes since 3.19: +1 -6 lines
Diff to previous 3.19 , to selected 3.18
Increased TM_BRTSCALE for better luminance resolution
Mon Feb 9 20:48:08 2009 UTC (15 years, 3 months ago) by greg
Changes since 3.18: +1 -5 lines
Diff to previous 3.18
Eliminated redefinition of malloc(3)
Revision 3.18 - (view) (download) (annotate) - [selected]
Mon Feb 9 20:23:51 2009 UTC (15 years, 3 months ago) by greg
Changes since 3.17: +3 -1 lines
Diff to previous 3.17
Made tmNewMap() available to private callers
Thu Jul 3 03:35:10 2008 UTC (15 years, 10 months ago) by greg
Changes since 3.16: +2 -1 lines
Diff to previous 3.16 , to selected 3.18
Another cosmetic improvement similar to last
Thu Jul 3 03:30:21 2008 UTC (15 years, 10 months ago) by greg
Changes since 3.15: +3 -1 lines
Diff to previous 3.15 , to selected 3.18
Cosmetic simplification to history array access
Fri Jan 7 21:41:06 2005 UTC (19 years, 4 months ago) by greg
Diff to previous 3.14 , to selected 3.18
Moved error codes inside passed TMstruct
Fri Jan 7 20:33:02 2005 UTC (19 years, 4 months ago) by greg
Changes since 3.13: +3 -4 lines
Diff to previous 3.13 , to selected 3.18
Changes since 3.12: +3 -3 lines
Diff to previous 3.12 , to selected 3.18
Mon Jul 14 22:23:59 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 3.11: +5 -4 lines
Diff to previous 3.11 , to selected 3.18
Mon Jul 14 04:56:54 2003 UTC (20 years, 10 months ago) by greg
Changes since 3.10: +1 -2 lines
Diff to previous 3.10 , to selected 3.18
Changes since 3.9: +1 -3 lines
Diff to previous 3.9 , to selected 3.18
Changes since 3.8: +5 -8 lines
Diff to previous 3.8 , to selected 3.18
Fri Jun 6 16:38:47 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 3.7: +9 -5 lines
Diff to previous 3.7 , to selected 3.18
*** empty log message ***
Changes since 3.6: +2 -57 lines
Diff to previous 3.6 , to selected 3.18
Changes since 3.5: +77 -12 lines
Diff to previous 3.5 , to selected 3.18
Mon Aug 17 17:58:46 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 3.4: +3 -2 lines
Diff to previous 3.4 , to selected 3.18
took "color.h" include out of tonemap.h and put in tmprivat.h
changed routines so zero-length arrays don't return error
Fri Apr 18 13:59:51 1997 UTC (27 years, 1 month ago) by greg
Changes since 3.3: +5 -5 lines
Diff to previous 3.3 , to selected 3.18
added notion of conversion packages with private data
Thu Apr 17 19:09:33 1997 UTC (27 years, 1 month ago) by greg
Changes since 3.2: +6 -1 lines
Diff to previous 3.2 , to selected 3.18
put back old defn's of BMESLOWER and BMESUPPER
Wed Apr 16 20:28:09 1997 UTC (27 years, 1 month ago) by greg
Changes since 3.1: +10 -2 lines
Diff to previous 3.1 , to selected 3.18
minor bug fixes and added tmDup()
Tue Apr 15 16:53:05 1997 UTC (27 years, 1 month ago) by greg
Diff to selected 3.18
