1 |
/* RCSid $Id: tmesh.h,v 2.4 2003/06/06 16:38:47 schorsch Exp $ */ |
2 |
3 |
* Header file for triangle mesh routines using barycentric coordinates |
4 |
5 |
#ifndef _RAD_TMESH_H_ |
6 |
#define _RAD_TMESH_H_ |
7 |
#ifdef __cplusplus |
8 |
extern "C" { |
9 |
#endif |
10 |
11 |
12 |
#define TCALNAME "tmesh.cal" /* the name of our auxiliary file */ |
13 |
14 |
typedef struct { |
15 |
int ax; /* major axis */ |
16 |
RREAL tm[2][3]; /* transformation */ |
17 |
} BARYCCM; |
18 |
19 |
#ifndef COSTOL |
20 |
#define COSTOL 0.999995 /* cosine of tolerance for smoothing */ |
21 |
#endif |
22 |
23 |
/* flat_tri() return values */ |
24 |
#define ISBENT 0 /* is not flat */ |
25 |
#define ISFLAT 1 /* is flat */ |
26 |
#define RVBENT 2 /* reversed and not flat */ |
27 |
#define RVFLAT 3 /* reversed and flat */ |
28 |
#define DEGEN -1 /* degenerate (zero area) */ |
29 |
30 |
31 |
int flat_tri(FVECT v1, FVECT v2, FVECT v3, |
32 |
FVECT n1, FVECT n2, FVECT n3); |
33 |
int comp_baryc(BARYCCM *bcm, FVECT v1, FVECT v2, FVECT v3); |
34 |
void eval_baryc(RREAL wt[3], FVECT p, BARYCCM *bcm); |
35 |
int get_baryc(RREAL wt[3], FVECT p, FVECT v1, FVECT v2, FVECT v3); |
36 |
void put_baryc(BARYCCM *bcm, RREAL com[][3], int n); |
37 |
38 |
39 |
40 |
41 |
#endif |
42 |
#endif /* _RAD_TMESH_H_ */ |
43 |
