| 1 |
/* RCSid $Id: tmesh.h,v 2.4 2003/06/06 16:38:47 schorsch Exp $ */
| 2 |
| 3 |
* Header file for triangle mesh routines using barycentric coordinates
| 4 |
| 5 |
#ifndef _RAD_TMESH_H_
| 6 |
#define _RAD_TMESH_H_
| 7 |
#ifdef __cplusplus
| 8 |
extern "C" {
| 9 |
#endif
| 10 |
| 11 |
| 12 |
#define TCALNAME "tmesh.cal" /* the name of our auxiliary file */
| 13 |
| 14 |
typedef struct {
| 15 |
int ax; /* major axis */
| 16 |
RREAL tm[2][3]; /* transformation */
| 17 |
} BARYCCM;
| 18 |
| 19 |
#ifndef COSTOL
| 20 |
#define COSTOL 0.999995 /* cosine of tolerance for smoothing */
| 21 |
#endif
| 22 |
| 23 |
/* flat_tri() return values */
| 24 |
#define ISBENT 0 /* is not flat */
| 25 |
#define ISFLAT 1 /* is flat */
| 26 |
#define RVBENT 2 /* reversed and not flat */
| 27 |
#define RVFLAT 3 /* reversed and flat */
| 28 |
#define DEGEN -1 /* degenerate (zero area) */
| 29 |
| 30 |
| 31 |
int flat_tri(FVECT v1, FVECT v2, FVECT v3,
| 32 |
FVECT n1, FVECT n2, FVECT n3);
| 33 |
int comp_baryc(BARYCCM *bcm, FVECT v1, FVECT v2, FVECT v3);
| 34 |
void eval_baryc(RREAL wt[3], FVECT p, BARYCCM *bcm);
| 35 |
int get_baryc(RREAL wt[3], FVECT p, FVECT v1, FVECT v2, FVECT v3);
| 36 |
void put_baryc(BARYCCM *bcm, RREAL com[][3], int n);
| 37 |
| 38 |
| 39 |
#ifdef __cplusplus
| 40 |
| 41 |
#endif
| 42 |
#endif /* _RAD_TMESH_H_ */
| 43 |
