root/radiance/ray/src/common/tmesh.c
Revision: 2.6
Committed: Thu Apr 15 23:51:04 2021 UTC (3 years, 1 month ago) by greg
CVS Tags: rad5R4, HEAD
Changes since 2.5: +43 -32 lines
Error occurred while calculating annotation data.
2 static const char RCSid[] = "$Id: tmesh.c,v 2.5 2006/03/02 17:16:56 greg Exp $";
5 * Compute and print barycentric coordinates for triangle meshes
6 */
7
8 #include <stdio.h>
9 #include "fvect.h"
10 #include "tmesh.h"
11
12
13 int
14 flat_tri( /* determine if triangle is flat */
15 FVECT v1,
16 FVECT v2,
17 FVECT v3,
18 FVECT n1,
19 FVECT n2,
20 FVECT n3
21 )
22 {
23 double d1, d2, d3;
24 FVECT vt1, vt2, vn;
25 /* compute default normal */
26 VSUB(vt1, v2, v1);
27 VSUB(vt2, v3, v2);
28 VCROSS(vn, vt1, vt2);
29 if (normalize(vn) == 0.0)
30 return(DEGEN);
31 /* compare to supplied normals */
32 d1 = DOT(vn, n1); d2 = DOT(vn, n2); d3 = DOT(vn, n3);
33 if (d1 < 0 && d2 < 0 && d3 < 0) {
34 if (d1 > -COSTOL || d2 > -COSTOL || d3 > -COSTOL)
35 return(RVBENT);
36 return(RVFLAT);
37 }
38 if (d1 < COSTOL || d2 < COSTOL || d3 < COSTOL)
39 return(ISBENT);
40 return(ISFLAT);
41 }
42
43
44 int
45 comp_baryc( /* compute barycentric vectors */
46 BARYCCM *bcm,
47 RREAL *v1,
48 RREAL *v2,
49 RREAL *v3
50 )
51 {
52 RREAL *vt;
53 FVECT va, vab, vcb;
54 double d;
55 int ax0, ax1;
56 int i;
57 /* compute major axis */
58 VSUB(vab, v1, v2);
59 VSUB(vcb, v3, v2);
60 VCROSS(va, vab, vcb);
61 bcm->ax = (va[1]*va[1] > va[0]*va[0]);
62 if (va[2]*va[2] > va[bcm->ax]*va[bcm->ax]) bcm->ax = 2;
63 ax0 = (bcm->ax + 1)%3;
64 ax1 = (bcm->ax + 2)%3;
65 for (i = 0; i < 2; i++) {
66 vab[0] = v1[ax0] - v2[ax0];
67 vcb[0] = v3[ax0] - v2[ax0];
68 vab[1] = v1[ax1] - v2[ax1];
69 vcb[1] = v3[ax1] - v2[ax1];
70 d = vcb[0]*vcb[0] + vcb[1]*vcb[1];
71 if (d <= FTINY*FTINY)
72 return(-1);
73 d = (vcb[0]*vab[0] + vcb[1]*vab[1])/d;
74 va[0] = vab[0] - vcb[0]*d;
75 va[1] = vab[1] - vcb[1]*d;
76 d = va[0]*va[0] + va[1]*va[1];
77 if (d <= FTINY*FTINY)
78 return(-1);
79 d = 1.0/d;
80 bcm->tm[i][0] = va[0] *= d;
81 bcm->tm[i][1] = va[1] *= d;
82 bcm->tm[i][2] = -(v2[ax0]*va[0] + v2[ax1]*va[1]);
83 /* rotate vertices */
84 vt = v1;
85 v1 = v2;
86 v2 = v3;
87 v3 = vt;
88 }
89 return(0);
90 }
91
92
93 void
94 eval_baryc( /* evaluate barycentric weights at p */
95 RREAL wt[3],
96 FVECT p,
97 BARYCCM *bcm
98 )
99 {
100 double u, v;
101 int i;
102
103 if ((i = bcm->ax + 1) >= 3) i -= 3;
104 u = p[i];
105 if (++i >= 3) i -= 3;
106 v = p[i];
107 wt[0] = u*bcm->tm[0][0] + v*bcm->tm[0][1] + bcm->tm[0][2];
108 wt[1] = u*bcm->tm[1][0] + v*bcm->tm[1][1] + bcm->tm[1][2];
109 wt[2] = 1. - wt[1] - wt[0];
110 }
111
112
113 int
114 get_baryc( /* compute barycentric weights at p */
115 RREAL wt[3],
116 FVECT p,
117 FVECT v1,
118 FVECT v2,
119 FVECT v3
120 )
121 {
122 BARYCCM bcm;
123
124 if (comp_baryc(&bcm, v1, v2, v3) < 0)
125 return(-1);
126 eval_baryc(wt, p, &bcm);
127 return(0);
128 }
129
130
131 #if 0
132 int
133 get_baryc(wt, p, v1, v2, v3) /* compute barycentric weights at p */
134 RREAL wt[3];
135 FVECT p;
136 FVECT v1, v2, v3;
137 {
138 FVECT ac, bc, pc, cros;
139 double normf;
140 /* area formula w/o 2-D optimization */
141 VSUB(ac, v1, v3);
142 VSUB(bc, v2, v3);
143 VSUB(pc, p, v3);
144 VCROSS(cros, ac, bc);
145 normf = DOT(cros,cros)
146 if (normf <= 0.0)
147 return(-1);
148 normf = 1./sqrt(normf);
149 VCROSS(cros, bc, pc);
150 wt[0] = VLEN(cros) * normf;
151 VCROSS(cros, ac, pc);
152 wt[1] = VLEN(cros) * normf;
153 wt[2] = 1. - wt[1] - wt[0];
154 return(0);
155 }
156 #endif
157
158
159 void
160 fput_baryc( /* put barycentric coord. vectors */
161 BARYCCM *bcm,
162 RREAL com[][3],
163 int n,
164 FILE *fp
165 )
166 {
167 double a, b;
168 int i;
169
170 fprintf(fp, "%d\t%d\n", 1+3*n, bcm->ax);
171 for (i = 0; i < n; i++) {
172 a = com[i][0] - com[i][2];
173 b = com[i][1] - com[i][2];
174 fprintf(fp, "%14.8f %14.8f %14.8f\n",
175 bcm->tm[0][0]*a + bcm->tm[1][0]*b,
176 bcm->tm[0][1]*a + bcm->tm[1][1]*b,
177 bcm->tm[0][2]*a + bcm->tm[1][2]*b + com[i][2]);
178 }
179 }
