| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id$";
| 3 |
#endif
| 4 |
| 5 |
* Compute and print barycentric coordinates for triangle meshes
| 6 |
| 7 |
| 8 |
#include <stdio.h>
| 9 |
| 10 |
#include "fvect.h"
| 11 |
| 12 |
#include "tmesh.h"
| 13 |
| 14 |
#define ABS(x) ((x) >= 0 ? (x) : -(x))
| 15 |
| 16 |
| 17 |
int
| 18 |
flat_tri(v1, v2, v3, n1, n2, n3) /* determine if triangle is flat */
| 19 |
FVECT v1, v2, v3, n1, n2, n3;
| 20 |
| 21 |
double d1, d2, d3;
| 22 |
FVECT vt1, vt2, vn;
| 23 |
/* compute default normal */
| 24 |
VSUB(vt1, v2, v1);
| 25 |
VSUB(vt2, v3, v2);
| 26 |
VCROSS(vn, vt1, vt2);
| 27 |
if (normalize(vn) == 0.0)
| 28 |
return(DEGEN);
| 29 |
/* compare to supplied normals */
| 30 |
d1 = DOT(vn, n1); d2 = DOT(vn, n2); d3 = DOT(vn, n3);
| 31 |
if (d1 < 0 && d2 < 0 && d3 < 0) {
| 32 |
if (d1 > -COSTOL || d2 > -COSTOL || d3 > -COSTOL)
| 33 |
return(RVBENT);
| 34 |
return(RVFLAT);
| 35 |
| 36 |
if (d1 < COSTOL || d2 < COSTOL || d3 < COSTOL)
| 37 |
return(ISBENT);
| 38 |
return(ISFLAT);
| 39 |
| 40 |
| 41 |
| 42 |
int
| 43 |
comp_baryc(bcm, v1, v2, v3) /* compute barycentric vectors */
| 44 |
register BARYCCM *bcm;
| 45 |
FLOAT *v1, *v2, *v3;
| 46 |
| 47 |
FLOAT *vt;
| 48 |
FVECT va, vab, vcb;
| 49 |
double d;
| 50 |
int ax0, ax1;
| 51 |
register int i;
| 52 |
/* compute major axis */
| 53 |
VSUB(vab, v1, v2);
| 54 |
VSUB(vcb, v3, v2);
| 55 |
VCROSS(va, vab, vcb);
| 56 |
bcm->ax = ABS(va[0]) > ABS(va[1]) ? 0 : 1;
| 57 |
bcm->ax = ABS(va[bcm->ax]) > ABS(va[2]) ? bcm->ax : 2;
| 58 |
ax0 = (bcm->ax + 1) % 3;
| 59 |
ax1 = (bcm->ax + 2) % 3;
| 60 |
for (i = 0; i < 2; i++) {
| 61 |
vab[0] = v1[ax0] - v2[ax0];
| 62 |
vcb[0] = v3[ax0] - v2[ax0];
| 63 |
vab[1] = v1[ax1] - v2[ax1];
| 64 |
vcb[1] = v3[ax1] - v2[ax1];
| 65 |
d = vcb[0]*vcb[0] + vcb[1]*vcb[1];
| 66 |
if (d <= FTINY*FTINY)
| 67 |
return(-1);
| 68 |
d = (vcb[0]*vab[0]+vcb[1]*vab[1])/d;
| 69 |
va[0] = vab[0] - vcb[0]*d;
| 70 |
va[1] = vab[1] - vcb[1]*d;
| 71 |
d = va[0]*va[0] + va[1]*va[1];
| 72 |
| 73 |
return(-1);
| 74 |
d = 1.0/d;
| 75 |
bcm->tm[i][0] = va[0] *= d;
| 76 |
bcm->tm[i][1] = va[1] *= d;
| 77 |
bcm->tm[i][2] = -(v2[ax0]*va[0]+v2[ax1]*va[1]);
| 78 |
/* rotate vertices */
| 79 |
vt = v1;
| 80 |
v1 = v2;
| 81 |
v2 = v3;
| 82 |
v3 = vt;
| 83 |
| 84 |
return(0);
| 85 |
| 86 |
| 87 |
| 88 |
void
| 89 |
eval_baryc(wt, p, bcm) /* evaluate barycentric weights at p */
| 90 |
FLOAT wt[3];
| 91 |
FVECT p;
| 92 |
| 93 |
| 94 |
double u, v;
| 95 |
| 96 |
u = p[(bcm->ax + 1) % 3];
| 97 |
v = p[(bcm->ax + 2) % 3];
| 98 |
wt[0] = u*bcm->tm[0][0] + v*bcm->tm[0][1] + bcm->tm[0][2];
| 99 |
wt[1] = u*bcm->tm[1][0] + v*bcm->tm[1][1] + bcm->tm[1][2];
| 100 |
wt[2] = 1. - wt[1] - wt[0];
| 101 |
| 102 |
| 103 |
| 104 |
int
| 105 |
get_baryc(wt, p, v1, v2, v3) /* compute barycentric weights at p */
| 106 |
FLOAT wt[3];
| 107 |
FVECT p;
| 108 |
FVECT v1, v2, v3;
| 109 |
| 110 |
BARYCCM bcm;
| 111 |
| 112 |
if (comp_baryc(&bcm, v1, v2, v3) < 0)
| 113 |
return(-1);
| 114 |
eval_baryc(wt, p, &bcm);
| 115 |
return(0);
| 116 |
| 117 |
| 118 |
| 119 |
#if 0
| 120 |
int
| 121 |
| 122 |
FLOAT wt[3];
| 123 |
FVECT p;
| 124 |
FVECT v1, v2, v3;
| 125 |
| 126 |
FVECT ac, bc, pc, cros;
| 127 |
double normf;
| 128 |
/* area formula w/o 2-D optimization */
| 129 |
VSUB(ac, v1, v3);
| 130 |
VSUB(bc, v2, v3);
| 131 |
VSUB(pc, p, v3);
| 132 |
VCROSS(cros, ac, bc);
| 133 |
normf = DOT(cros,cros)
| 134 |
if (normf <= 0.0)
| 135 |
return(-1);
| 136 |
normf = 1./sqrt(normf);
| 137 |
VCROSS(cros, bc, pc);
| 138 |
wt[0] = VLEN(cros) * normf;
| 139 |
VCROSS(cros, ac, pc);
| 140 |
wt[1] = VLEN(cros) * normf;
| 141 |
| 142 |
return(0);
| 143 |
| 144 |
#endif
| 145 |
| 146 |
| 147 |
void
| 148 |
put_baryc(bcm, com, n) /* put barycentric coord. vectors */
| 149 |
| 150 |
register FLOAT com[][3];
| 151 |
int n;
| 152 |
| 153 |
double a, b;
| 154 |
register int i, j;
| 155 |
| 156 |
printf("%d\t%d\n", 1+3*n, bcm->ax);
| 157 |
for (i = 0; i < n; i++) {
| 158 |
a = com[i][0] - com[i][2];
| 159 |
b = com[i][1] - com[i][2];
| 160 |
printf("%14.8f %14.8f %14.8f\n",
| 161 |
bcm->tm[0][0]*a + bcm->tm[1][0]*b,
| 162 |
bcm->tm[0][1]*a + bcm->tm[1][1]*b,
| 163 |
bcm->tm[0][2]*a + bcm->tm[1][2]*b + com[i][2]);
| 164 |
| 165 |
