root/Development/ray/src/common/tmesh.c
Revision: 2.1
Committed: Mon Mar 10 19:38:19 2003 UTC (22 years, 10 months ago) by greg
5 * Compute and print barycentric coordinates for triangle meshes
6 */
7
8 #include <stdio.h>
9
10 #include "fvect.h"
11
12 #include "tmesh.h"
13
14 #define ABS(x) ((x) >= 0 ? (x) : -(x))
15
16
17 int
18 flat_tri(v1, v2, v3, n1, n2, n3) /* determine if triangle is flat */
19 FVECT v1, v2, v3, n1, n2, n3;
20 {
21 double d1, d2, d3;
22 FVECT vt1, vt2, vn;
23 /* compute default normal */
24 vt1[0] = v2[0] - v1[0]; vt1[1] = v2[1] - v1[1]; vt1[2] = v2[2] - v1[2];
25 vt2[0] = v3[0] - v2[0]; vt2[1] = v3[1] - v2[1]; vt2[2] = v3[2] - v2[2];
26 fcross(vn, vt1, vt2);
27 if (normalize(vn) == 0.0)
28 return(DEGEN);
29 /* compare to supplied normals */
30 d1 = DOT(vn, n1); d2 = DOT(vn, n2); d3 = DOT(vn, n3);
31 if (d1 < 0 && d2 < 0 && d3 < 0) {
32 if (d1 > -COSTOL || d2 > -COSTOL || d3 > -COSTOL)
33 return(RVBENT);
34 return(RVFLAT);
35 }
36 if (d1 < COSTOL || d2 < COSTOL || d3 < COSTOL)
37 return(ISBENT);
38 return(ISFLAT);
39 }
40
41
42 int
43 comp_baryc(bcm, v1, v2, v3) /* compute barycentric vectors */
44 register BARYCCM *bcm;
45 FLOAT *v1, *v2, *v3;
46 {
47 FLOAT *vt;
48 FVECT va, vab, vcb;
49 double d;
50 int ax0, ax1;
51 register int i;
52 /* compute major axis */
53 for (i = 0; i < 3; i++) {
54 vab[i] = v1[i] - v2[i];
55 vcb[i] = v3[i] - v2[i];
56 }
57 fcross(va, vab, vcb);
58 bcm->ax = ABS(va[0]) > ABS(va[1]) ? 0 : 1;
59 bcm->ax = ABS(va[bcm->ax]) > ABS(va[2]) ? bcm->ax : 2;
60 ax0 = (bcm->ax + 1) % 3;
61 ax1 = (bcm->ax + 2) % 3;
62 for (i = 0; i < 2; i++) {
63 vab[0] = v1[ax0] - v2[ax0];
64 vcb[0] = v3[ax0] - v2[ax0];
65 vab[1] = v1[ax1] - v2[ax1];
66 vcb[1] = v3[ax1] - v2[ax1];
67 d = vcb[0]*vcb[0] + vcb[1]*vcb[1];
68 if (d <= FTINY*FTINY)
69 return(-1);
70 d = (vcb[0]*vab[0]+vcb[1]*vab[1])/d;
71 va[0] = vab[0] - vcb[0]*d;
72 va[1] = vab[1] - vcb[1]*d;
73 d = va[0]*va[0] + va[1]*va[1];
74 if (d <= FTINY*FTINY)
75 return(-1);
76 d = 1.0/d;
77 bcm->tm[i][0] = va[0] *= d;
78 bcm->tm[i][1] = va[1] *= d;
79 bcm->tm[i][2] = -(v2[ax0]*va[0]+v2[ax1]*va[1]);
80 /* rotate vertices */
81 vt = v1;
82 v1 = v2;
83 v2 = v3;
84 v3 = vt;
85 }
86 return(0);
87 }
88
89
90 put_baryc(bcm, com, n) /* put barycentric coord. vectors */
91 register BARYCCM *bcm;
92 register FLOAT com[][3];
93 int n;
94 {
95 double a, b;
96 register int i, j;
97
98 printf("%d\t%d\n", 1+3*n, bcm->ax);
99 for (i = 0; i < n; i++) {
100 a = com[i][0] - com[i][2];
101 b = com[i][1] - com[i][2];
102 printf("%14.8f %14.8f %14.8f\n",
103 bcm->tm[0][0]*a + bcm->tm[1][0]*b,
104 bcm->tm[0][1]*a + bcm->tm[1][1]*b,
105 bcm->tm[0][2]*a + bcm->tm[1][2]*b + com[i][2]);
106 }
107 }
