--- ray/src/common/tmesh.c 2003/11/14 17:22:06 2.4 +++ ray/src/common/tmesh.c 2006/03/02 17:16:56 2.5 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: tmesh.c,v 2.4 2003/11/14 17:22:06 schorsch Exp $"; +static const char RCSid[] = "$Id: tmesh.c,v 2.5 2006/03/02 17:16:56 greg Exp $"; #endif /* * Compute and print barycentric coordinates for triangle meshes @@ -55,8 +55,8 @@ RREAL *v1, *v2, *v3; VCROSS(va, vab, vcb); bcm->ax = ABS(va[0]) > ABS(va[1]) ? 0 : 1; bcm->ax = ABS(va[bcm->ax]) > ABS(va[2]) ? bcm->ax : 2; - ax0 = (bcm->ax + 1) % 3; - ax1 = (bcm->ax + 2) % 3; + if ((ax0 = bcm->ax + 1) >= 3) ax0 -= 3; + if ((ax1 = ax0 + 1) >= 3) ax1 -= 3; for (i = 0; i < 2; i++) { vab[0] = v1[ax0] - v2[ax0]; vcb[0] = v3[ax0] - v2[ax0]; @@ -92,9 +92,12 @@ FVECT p; register BARYCCM *bcm; { double u, v; + int i; - u = p[(bcm->ax + 1) % 3]; - v = p[(bcm->ax + 2) % 3]; + if ((i = bcm->ax + 1) >= 3) i -= 3; + u = p[i]; + if (++i >= 3) i -= 3; + v = p[i]; wt[0] = u*bcm->tm[0][0] + v*bcm->tm[0][1] + bcm->tm[0][2]; wt[1] = u*bcm->tm[1][0] + v*bcm->tm[1][1] + bcm->tm[1][2]; wt[2] = 1. - wt[1] - wt[0];
