root/radiance/ray/src/common/tmesh.c
Thu Mar 2 17:16:56 2006 UTC (18 years, 2 months ago) by greg
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Changes since 2.4: +8 -5 lines
Replaced % operations with if statements (hopefully faster)
Changes since 2.2: +7 -7 lines
Changes since 2.1: +70 -12 lines
Mon Mar 10 19:38:19 2003 UTC (21 years, 2 months ago) by greg
Diff to selected 2.5
