root/Development/ray/src/common/tmesh.c
Revision: 2.5
Committed: Thu Mar 2 17:16:56 2006 UTC (19 years, 9 months ago) by greg
CVS Tags: rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8
Changes since 2.4: +8 -5 lines
Replaced % operations with if statements (hopefully faster)
2 static const char RCSid[] = "$Id: tmesh.c,v 2.4 2003/11/14 17:22:06 schorsch Exp $";
5 * Compute and print barycentric coordinates for triangle meshes
6 */
7
8 #include <stdio.h>
9
10 #include "fvect.h"
11
12 #include "tmesh.h"
13
14 #define ABS(x) ((x) >= 0 ? (x) : -(x))
15
16
17 int
18 flat_tri(v1, v2, v3, n1, n2, n3) /* determine if triangle is flat */
19 FVECT v1, v2, v3, n1, n2, n3;
20 {
21 double d1, d2, d3;
22 FVECT vt1, vt2, vn;
23 /* compute default normal */
24 VSUB(vt1, v2, v1);
25 VSUB(vt2, v3, v2);
26 VCROSS(vn, vt1, vt2);
27 if (normalize(vn) == 0.0)
28 return(DEGEN);
29 /* compare to supplied normals */
30 d1 = DOT(vn, n1); d2 = DOT(vn, n2); d3 = DOT(vn, n3);
31 if (d1 < 0 && d2 < 0 && d3 < 0) {
32 if (d1 > -COSTOL || d2 > -COSTOL || d3 > -COSTOL)
33 return(RVBENT);
34 return(RVFLAT);
35 }
36 if (d1 < COSTOL || d2 < COSTOL || d3 < COSTOL)
37 return(ISBENT);
38 return(ISFLAT);
39 }
40
41
42 int
43 comp_baryc(bcm, v1, v2, v3) /* compute barycentric vectors */
44 register BARYCCM *bcm;
45 RREAL *v1, *v2, *v3;
46 {
47 RREAL *vt;
48 FVECT va, vab, vcb;
49 double d;
50 int ax0, ax1;
51 register int i;
52 /* compute major axis */
53 VSUB(vab, v1, v2);
54 VSUB(vcb, v3, v2);
55 VCROSS(va, vab, vcb);
56 bcm->ax = ABS(va[0]) > ABS(va[1]) ? 0 : 1;
57 bcm->ax = ABS(va[bcm->ax]) > ABS(va[2]) ? bcm->ax : 2;
58 if ((ax0 = bcm->ax + 1) >= 3) ax0 -= 3;
59 if ((ax1 = ax0 + 1) >= 3) ax1 -= 3;
60 for (i = 0; i < 2; i++) {
61 vab[0] = v1[ax0] - v2[ax0];
62 vcb[0] = v3[ax0] - v2[ax0];
63 vab[1] = v1[ax1] - v2[ax1];
64 vcb[1] = v3[ax1] - v2[ax1];
65 d = vcb[0]*vcb[0] + vcb[1]*vcb[1];
66 if (d <= FTINY*FTINY)
67 return(-1);
68 d = (vcb[0]*vab[0]+vcb[1]*vab[1])/d;
69 va[0] = vab[0] - vcb[0]*d;
70 va[1] = vab[1] - vcb[1]*d;
71 d = va[0]*va[0] + va[1]*va[1];
72 if (d <= FTINY*FTINY)
73 return(-1);
74 d = 1.0/d;
75 bcm->tm[i][0] = va[0] *= d;
76 bcm->tm[i][1] = va[1] *= d;
77 bcm->tm[i][2] = -(v2[ax0]*va[0]+v2[ax1]*va[1]);
78 /* rotate vertices */
79 vt = v1;
80 v1 = v2;
81 v2 = v3;
82 v3 = vt;
83 }
84 return(0);
85 }
86
87
88 void
89 eval_baryc(wt, p, bcm) /* evaluate barycentric weights at p */
90 RREAL wt[3];
91 FVECT p;
92 register BARYCCM *bcm;
93 {
94 double u, v;
95 int i;
96
97 if ((i = bcm->ax + 1) >= 3) i -= 3;
98 u = p[i];
99 if (++i >= 3) i -= 3;
100 v = p[i];
101 wt[0] = u*bcm->tm[0][0] + v*bcm->tm[0][1] + bcm->tm[0][2];
102 wt[1] = u*bcm->tm[1][0] + v*bcm->tm[1][1] + bcm->tm[1][2];
103 wt[2] = 1. - wt[1] - wt[0];
104 }
105
106
107 int
108 get_baryc(wt, p, v1, v2, v3) /* compute barycentric weights at p */
109 RREAL wt[3];
110 FVECT p;
111 FVECT v1, v2, v3;
112 {
113 BARYCCM bcm;
114
115 if (comp_baryc(&bcm, v1, v2, v3) < 0)
116 return(-1);
117 eval_baryc(wt, p, &bcm);
118 return(0);
119 }
120
121
122 #if 0
123 int
124 get_baryc(wt, p, v1, v2, v3) /* compute barycentric weights at p */
125 RREAL wt[3];
126 FVECT p;
127 FVECT v1, v2, v3;
128 {
129 FVECT ac, bc, pc, cros;
130 double normf;
131 /* area formula w/o 2-D optimization */
132 VSUB(ac, v1, v3);
133 VSUB(bc, v2, v3);
134 VSUB(pc, p, v3);
135 VCROSS(cros, ac, bc);
136 normf = DOT(cros,cros)
137 if (normf <= 0.0)
138 return(-1);
139 normf = 1./sqrt(normf);
140 VCROSS(cros, bc, pc);
141 wt[0] = VLEN(cros) * normf;
142 VCROSS(cros, ac, pc);
143 wt[1] = VLEN(cros) * normf;
144 wt[2] = 1. - wt[1] - wt[0];
145 return(0);
146 }
147 #endif
148
149
150 void
151 put_baryc(bcm, com, n) /* put barycentric coord. vectors */
152 register BARYCCM *bcm;
153 register RREAL com[][3];
154 int n;
155 {
156 double a, b;
157 register int i;
158
159 printf("%d\t%d\n", 1+3*n, bcm->ax);
160 for (i = 0; i < n; i++) {
161 a = com[i][0] - com[i][2];
162 b = com[i][1] - com[i][2];
163 printf("%14.8f %14.8f %14.8f\n",
164 bcm->tm[0][0]*a + bcm->tm[1][0]*b,
165 bcm->tm[0][1]*a + bcm->tm[1][1]*b,
166 bcm->tm[0][2]*a + bcm->tm[1][2]*b + com[i][2]);
167 }
168 }
