1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: tmaptiff.c,v 3.2 2003/02/25 02:47:22 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Perform tone mapping on TIFF input. |
6 |
7 |
* Externals declared in tmaptiff.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include <stdio.h> |
13 |
#include "tiffio.h" |
14 |
#include "tmprivat.h" |
15 |
#include "tmaptiff.h" |
16 |
17 |
/* input cases we handle */ |
18 |
#define TC_LOGLUV32 1 |
19 |
#define TC_LOGLUV24 2 |
20 |
#define TC_LOGL16 3 |
21 |
#define TC_GRYFLOAT 4 |
22 |
#define TC_RGBFLOAT 5 |
23 |
#define TC_GRYSHORT 6 |
24 |
#define TC_RGBSHORT 7 |
25 |
26 |
/* figure out what kind of TIFF we have and if we can tone-map it */ |
27 |
static int |
28 |
getTIFFtype(TIFF *tif) |
29 |
30 |
uint16 comp, phot, pconf; |
31 |
uint16 samp_fmt, bits_samp; |
32 |
33 |
TIFFGetFieldDefaulted(tif, TIFFTAG_PLANARCONFIG, &pconf); |
34 |
if (pconf != PLANARCONFIG_CONTIG) |
35 |
return(0); |
36 |
TIFFGetFieldDefaulted(tif, TIFFTAG_PHOTOMETRIC, &phot); |
37 |
TIFFGetFieldDefaulted(tif, TIFFTAG_COMPRESSION, &comp); |
38 |
TIFFGetFieldDefaulted(tif, TIFFTAG_SAMPLEFORMAT, &samp_fmt); |
39 |
TIFFGetFieldDefaulted(tif, TIFFTAG_BITSPERSAMPLE, &bits_samp); |
40 |
switch (phot) { |
41 |
case PHOTOMETRIC_LOGLUV: |
42 |
if (comp == COMPRESSION_SGILOG) |
43 |
return(TC_LOGLUV32); |
44 |
if (comp == COMPRESSION_SGILOG24) |
45 |
return(TC_LOGLUV24); |
46 |
return(0); |
47 |
case PHOTOMETRIC_LOGL: |
48 |
49 |
return(TC_LOGL16); |
50 |
return(0); |
51 |
case PHOTOMETRIC_MINISBLACK: |
52 |
if (samp_fmt == SAMPLEFORMAT_UINT) { |
53 |
if (bits_samp == 16) |
54 |
return(TC_GRYSHORT); |
55 |
return(0); |
56 |
57 |
if (samp_fmt == SAMPLEFORMAT_IEEEFP) { |
58 |
if (bits_samp == 8*sizeof(float)) |
59 |
return(TC_GRYFLOAT); |
60 |
return(0); |
61 |
62 |
return(0); |
63 |
case PHOTOMETRIC_RGB: |
64 |
65 |
66 |
return(TC_RGBSHORT); |
67 |
return(0); |
68 |
69 |
70 |
71 |
return(TC_RGBFLOAT); |
72 |
return(0); |
73 |
74 |
return(0); |
75 |
76 |
return(0); |
77 |
78 |
79 |
/* load and convert TIFF */ |
80 |
int |
81 |
tmLoadTIFF(TMbright **lpp, BYTE **cpp, int *xp, int *yp, char *fname, TIFF *tp) |
82 |
83 |
char *funcName = fname==NULL ? "tmLoadTIFF" : fname; |
84 |
RGBPRIMP inppri = tmTop->monpri; |
85 |
RGBPRIMS myprims; |
86 |
float *fa; |
87 |
TIFF *tif; |
88 |
int err; |
89 |
union {uint16 *w; uint32 *l; float *f; MEM_PTR p;} sl; |
90 |
uint32 width, height; |
91 |
int tcase; |
92 |
double stonits; |
93 |
int y; |
94 |
/* check arguments */ |
95 |
if (tmTop == NULL) |
96 |
returnErr(TM_E_TMINVAL); |
97 |
if (lpp == NULL | xp == NULL | yp == NULL | |
98 |
(fname == NULL & tp == NULL)) |
99 |
returnErr(TM_E_ILLEGAL); |
100 |
/* check/get TIFF tags */ |
101 |
sl.p = NULL; *lpp = NULL; |
102 |
if (cpp != TM_NOCHROMP) *cpp = TM_NOCHROM; |
103 |
err = TM_E_BADFILE; |
104 |
if ((tif = tp) == NULL && (tif = TIFFOpen(fname, "r")) == NULL) |
105 |
returnErr(TM_E_BADFILE); |
106 |
tcase = getTIFFtype(tif); |
107 |
if (!tcase) |
108 |
goto done; |
109 |
if (!TIFFGetField(tif, TIFFTAG_IMAGEWIDTH, &width) || |
110 |
!TIFFGetField(tif, TIFFTAG_IMAGELENGTH, &height)) |
111 |
goto done; |
112 |
*xp = width; *yp = height; |
113 |
if (TIFFGetField(tif, TIFFTAG_PRIMARYCHROMATICITIES, &fa)) { |
114 |
myprims[RED][CIEX] = fa[0]; |
115 |
myprims[RED][CIEY] = fa[1]; |
116 |
myprims[GRN][CIEX] = fa[2]; |
117 |
myprims[GRN][CIEY] = fa[3]; |
118 |
myprims[BLU][CIEX] = fa[4]; |
119 |
myprims[BLU][CIEY] = fa[5]; |
120 |
myprims[WHT][CIEX] = 1./3.; |
121 |
myprims[WHT][CIEY] = 1./3.; |
122 |
if (TIFFGetField(tif, TIFFTAG_WHITEPOINT, &fa)) { |
123 |
myprims[WHT][CIEX] = fa[0]; |
124 |
myprims[WHT][CIEY] = fa[1]; |
125 |
126 |
inppri = myprims; |
127 |
128 |
if (!TIFFGetField(tif, TIFFTAG_STONITS, &stonits)) |
129 |
stonits = 1.; |
130 |
switch (tcase) { /* set up conversion */ |
131 |
case TC_LOGLUV32: |
132 |
case TC_LOGLUV24: |
133 |
TIFFSetField(tif, TIFFTAG_SGILOGDATAFMT, SGILOGDATAFMT_RAW); |
134 |
sl.l = (uint32 *)malloc(width*sizeof(uint32)); |
135 |
tmSetSpace(TM_XYZPRIM, stonits); |
136 |
break; |
137 |
case TC_LOGL16: |
138 |
TIFFSetField(tif, TIFFTAG_SGILOGDATAFMT, SGILOGDATAFMT_16BIT); |
139 |
sl.w = (uint16 *)malloc(width*sizeof(uint16)); |
140 |
tmSetSpace(tmTop->monpri, stonits); |
141 |
break; |
142 |
case TC_RGBFLOAT: |
143 |
sl.f = (float *)malloc(width*3*sizeof(float)); |
144 |
tmSetSpace(inppri, stonits); |
145 |
break; |
146 |
case TC_GRYFLOAT: |
147 |
sl.f = (float *)malloc(width*sizeof(float)); |
148 |
149 |
break; |
150 |
case TC_RGBSHORT: |
151 |
sl.w = (uint16 *)malloc(width*3*sizeof(uint16)); |
152 |
153 |
break; |
154 |
case TC_GRYSHORT: |
155 |
156 |
157 |
break; |
158 |
default: |
159 |
err = TM_E_CODERR1; |
160 |
goto done; |
161 |
162 |
*lpp = (TMbright *)malloc(width*height*sizeof(TMbright)); |
163 |
if (sl.p == NULL | *lpp == NULL) { |
164 |
err = TM_E_NOMEM; |
165 |
goto done; |
166 |
167 |
switch (tcase) { /* allocate color if needed */ |
168 |
case TC_LOGLUV32: |
169 |
case TC_LOGLUV24: |
170 |
case TC_RGBFLOAT: |
171 |
case TC_RGBSHORT: |
172 |
if (cpp == TM_NOCHROMP) |
173 |
break; |
174 |
*cpp = (BYTE *)malloc(width*height*3*sizeof(BYTE)); |
175 |
if (*cpp == NULL) { |
176 |
err = TM_E_NOMEM; |
177 |
goto done; |
178 |
179 |
break; |
180 |
181 |
/* read and convert each scanline */ |
182 |
for (y = 0; y < height; y++) { |
183 |
if (TIFFReadScanline(tif, sl.p, y, 0) < 0) { |
184 |
185 |
break; |
186 |
187 |
switch (tcase) { |
188 |
case TC_LOGLUV32: |
189 |
err = tmCvLuv32(*lpp + y*width, |
190 |
cpp==TM_NOCHROMP ? TM_NOCHROM : *cpp+y*3*width, |
191 |
sl.l, width); |
192 |
break; |
193 |
case TC_LOGLUV24: |
194 |
err = tmCvLuv24(*lpp + y*width, |
195 |
196 |
sl.l, width); |
197 |
break; |
198 |
case TC_LOGL16: |
199 |
err = tmCvL16(*lpp + y*width, sl.w, width); |
200 |
break; |
201 |
case TC_RGBFLOAT: |
202 |
err = tmCvColors(*lpp + y*width, |
203 |
204 |
(COLOR *)sl.f, width); |
205 |
break; |
206 |
case TC_GRYFLOAT: |
207 |
err = tmCvGrays(*lpp + y*width, sl.f, width); |
208 |
break; |
209 |
case TC_RGBSHORT: |
210 |
err = tmCvRGB48(*lpp + y*width, |
211 |
212 |
(uint16 (*)[3])sl.w, width, DEFGAM); |
213 |
break; |
214 |
case TC_GRYSHORT: |
215 |
err = tmCvGray16(*lpp + y*width, sl.w, width, DEFGAM); |
216 |
break; |
217 |
default: |
218 |
219 |
break; |
220 |
221 |
if (err != TM_E_OK) |
222 |
break; |
223 |
224 |
done: /* clean up */ |
225 |
if (tp == NULL) |
226 |
TIFFClose(tif); |
227 |
if (sl.p != NULL) |
228 |
free(sl.p); |
229 |
if (err != TM_E_OK) { /* free buffers on error */ |
230 |
if (*lpp != NULL) |
231 |
free((MEM_PTR)*lpp); |
232 |
*lpp = NULL; |
233 |
if (cpp != TM_NOCHROMP) { |
234 |
if (*cpp != TM_NOCHROM) |
235 |
free((MEM_PTR)*cpp); |
236 |
*cpp = NULL; |
237 |
238 |
*xp = *yp = 0; |
239 |
returnErr(err); |
240 |
241 |
returnOK; |
242 |
243 |
244 |
245 |
246 |
* Load and tone-map a SGILOG TIFF. |
247 |
* Beware of greyscale input -- you must check the PHOTOMETRIC tag to |
248 |
* determine that the returned array contains only grey values, not RGB. |
249 |
* As in tmMapPicture(), grey values are also returned if flags&TM_F_BW. |
250 |
251 |
int |
252 |
tmMapTIFF(BYTE **psp, int *xp, int *yp, int flags, RGBPRIMP monpri, |
253 |
double gamval, double Lddyn, double Ldmax, char *fname, TIFF *tp) |
254 |
255 |
char *funcName = fname==NULL ? "tmMapTIFF" : fname; |
256 |
TMbright *lp; |
257 |
BYTE *cp; |
258 |
int err; |
259 |
260 |
if (psp == NULL | xp == NULL | yp == NULL | monpri == NULL | |
261 |
262 |
263 |
if (gamval < MINGAM) gamval = DEFGAM; |
264 |
if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN; |
265 |
if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX; |
266 |
if (flags & TM_F_BW) monpri = stdprims; |
267 |
/* initialize tone mapping */ |
268 |
if (tmInit(flags, monpri, gamval) == NULL) |
269 |
returnErr(TM_E_NOMEM); |
270 |
271 |
cp = TM_NOCHROM; |
272 |
err = tmLoadTIFF(&lp, flags&TM_F_BW ? TM_NOCHROMP : &cp, |
273 |
xp, yp, fname, tp); |
274 |
if (err != TM_E_OK) { |
275 |
tmDone(NULL); |
276 |
return(err); |
277 |
278 |
if (cp == TM_NOCHROM) { |
279 |
*psp = (BYTE *)malloc(*xp * *yp * sizeof(BYTE)); |
280 |
if (*psp == NULL) { |
281 |
free((MEM_PTR)lp); |
282 |
tmDone(NULL); |
283 |
284 |
285 |
} else |
286 |
*psp = cp; |
287 |
/* compute color mapping */ |
288 |
err = tmAddHisto(lp, *xp * *yp, 1); |
289 |
290 |
goto done; |
291 |
err = tmComputeMapping(gamval, Lddyn, Ldmax); |
292 |
293 |
goto done; |
294 |
/* map pixels */ |
295 |
err = tmMapPixels(*psp, lp, cp, *xp * *yp); |
296 |
297 |
298 |
299 |
tmDone(NULL); |
300 |
if (err != TM_E_OK) { /* free memory on error */ |
301 |
free((MEM_PTR)*psp); |
302 |
*psp = NULL; |
303 |
*xp = *yp = 0; |
304 |
returnErr(err); |
305 |
306 |
returnOK; |
307 |
