root/Development/ray/src/common/tmaptiff.c
Revision: 3.1
Committed: Sat Feb 22 02:07:22 2003 UTC (22 years, 8 months ago) by greg
5 * Perform tone mapping on TIFF input.
6 *
7 * Externals declared in tmaptiff.h
8 */
9
10 /* ====================================================================
11 * The Radiance Software License, Version 1.0
12 *
13 * Copyright (c) 1990 - 2002 The Regents of the University of California,
14 * through Lawrence Berkeley National Laboratory. All rights reserved.
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 *
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 *
23 * 2. Redistributions in binary form must reproduce the above copyright
24 * notice, this list of conditions and the following disclaimer in
25 * the documentation and/or other materials provided with the
26 * distribution.
27 *
28 * 3. The end-user documentation included with the redistribution,
29 * if any, must include the following acknowledgment:
30 * "This product includes Radiance software
31 * (http://radsite.lbl.gov/)
32 * developed by the Lawrence Berkeley National Laboratory
33 * (http://www.lbl.gov/)."
34 * Alternately, this acknowledgment may appear in the software itself,
35 * if and wherever such third-party acknowledgments normally appear.
36 *
37 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
38 * and "The Regents of the University of California" must
39 * not be used to endorse or promote products derived from this
40 * software without prior written permission. For written
41 * permission, please contact [email protected].
42 *
43 * 5. Products derived from this software may not be called "Radiance",
44 * nor may "Radiance" appear in their name, without prior written
45 * permission of Lawrence Berkeley National Laboratory.
46 *
47 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
48 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
49 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
50 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
51 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
52 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
53 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
54 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
55 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
56 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
57 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
58 * SUCH DAMAGE.
59 * ====================================================================
60 *
61 * This software consists of voluntary contributions made by many
62 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
63 * information on Lawrence Berkeley National Laboratory, please see
64 * <http://www.lbl.gov/>.
65 */
66
67 #include <stdio.h>
68 #include "tiffio.h"
69 #include "tmprivat.h"
70 #include "tmaptiff.h"
71
72
73 int
74 tmLoadTIFF(lpp, cpp, xp, yp, fname, tp) /* load and convert TIFF */
75 TMbright **lpp;
76 BYTE **cpp;
77 int *xp, *yp;
78 char *fname;
79 TIFF *tp;
80 {
81 char *funcName = fname==NULL ? "tmLoadTIFF" : fname;
82 TIFF *tif;
83 int err;
84 union {uint16 *w; uint32 *l; MEM_PTR p;} sl;
85 uint16 comp, phot, pconf;
86 uint32 width, height;
87 double stonits;
88 int y;
89 /* check arguments */
90 if (tmTop == NULL)
91 returnErr(TM_E_TMINVAL);
92 if (lpp == NULL | xp == NULL | yp == NULL |
93 (fname == NULL & tp == NULL))
94 returnErr(TM_E_ILLEGAL);
95 /* check/get TIFF tags */
96 sl.p = NULL; *lpp = NULL;
97 if (cpp != TM_NOCHROMP) *cpp = TM_NOCHROM;
98 err = TM_E_BADFILE;
99 if ((tif = tp) == NULL && (tif = TIFFOpen(fname, "r")) == NULL)
100 returnErr(TM_E_BADFILE);
101 TIFFGetFieldDefaulted(tif, TIFFTAG_PHOTOMETRIC, &phot);
102 TIFFGetFieldDefaulted(tif, TIFFTAG_COMPRESSION, &comp);
103 if (!TIFFGetField(tif, TIFFTAG_IMAGEWIDTH, &width) ||
104 !TIFFGetField(tif, TIFFTAG_IMAGELENGTH, &height))
105 goto done;
106 *xp = width; *yp = height;
107 TIFFGetFieldDefaulted(tif, TIFFTAG_PLANARCONFIG, &pconf);
108 if (pconf != PLANARCONFIG_CONTIG)
109 goto done;
110 if (!TIFFGetField(tif, TIFFTAG_STONITS, &stonits))
111 stonits = 1.;
112 if (phot == PHOTOMETRIC_LOGLUV) {
113 if (comp != COMPRESSION_SGILOG && comp != COMPRESSION_SGILOG24)
114 goto done;
115 TIFFSetField(tif, TIFFTAG_SGILOGDATAFMT, SGILOGDATAFMT_RAW);
116 sl.l = (uint32 *)malloc(width*sizeof(uint32));
117 if (cpp != TM_NOCHROMP) {
118 *cpp = (BYTE *)malloc(width*height*3*sizeof(BYTE));
119 if (*cpp == NULL) {
120 err = TM_E_NOMEM;
121 goto done;
122 }
123 }
124 } else if (phot == PHOTOMETRIC_LOGL) {
125 if (comp != COMPRESSION_SGILOG)
126 goto done;
127 TIFFSetField(tif, TIFFTAG_SGILOGDATAFMT, SGILOGDATAFMT_16BIT);
128 sl.w = (uint16 *)malloc(width*sizeof(uint16));
129 } else
130 goto done;
131 *lpp = (TMbright *)malloc(width*height*sizeof(TMbright));
132 if (sl.p == NULL | *lpp == NULL) {
133 err = TM_E_NOMEM;
134 goto done;
135 }
136 /* set input color space */
137 tmSetSpace(TM_XYZPRIM, stonits);
138 /* read and convert each scanline */
139 for (y = 0; y < height; y++) {
140 if (TIFFReadScanline(tif, sl.p, y, 0) < 0) {
141 err = TM_E_BADFILE;
142 break;
143 }
144 if (phot == PHOTOMETRIC_LOGL)
145 err = tmCvL16(*lpp + y*width, sl.w, width);
146 else if (comp == COMPRESSION_SGILOG24)
147 err = tmCvLuv24(*lpp + y*width,
148 cpp==TM_NOCHROMP ? TM_NOCHROM : *cpp+y*3*width,
149 sl.l, width);
150 else
151 err = tmCvLuv32(*lpp + y*width,
152 cpp==TM_NOCHROMP ? TM_NOCHROM : *cpp+y*3*width,
153 sl.l, width);
154 if (err != TM_E_OK)
155 break;
156 }
157 done: /* clean up */
158 if (tp == NULL)
159 TIFFClose(tif);
160 if (sl.p != NULL)
161 free(sl.p);
162 if (err != TM_E_OK) { /* free buffers on error */
163 if (*lpp != NULL)
164 free((MEM_PTR)*lpp);
165 *lpp = NULL;
166 if (cpp != TM_NOCHROMP) {
167 if (*cpp != TM_NOCHROM)
168 free((MEM_PTR)*cpp);
169 *cpp = NULL;
170 }
171 *xp = *yp = 0;
172 returnErr(err);
173 }
174 returnOK;
175 }
176
177
178 /*
179 * Load and tone-map a SGILOG TIFF.
180 * Beware of greyscale input -- you must check the PHOTOMETRIC tag to
181 * determine that the returned array contains only grey values, not RGB.
182 * As in tmMapPicture(), grey values are also returned if flags&TM_F_BW.
183 */
184 int
185 tmMapTIFF(psp, xp, yp, flags, monpri, gamval, Lddyn, Ldmax, fname, tp)
186 BYTE **psp;
187 int *xp, *yp;
188 int flags;
189 RGBPRIMP monpri;
190 double gamval, Lddyn, Ldmax;
191 char *fname;
192 TIFF *tp;
193 {
194 char *funcName = fname==NULL ? "tmMapTIFF" : fname;
195 TMbright *lp;
196 BYTE *cp;
197 int err;
198 /* check arguments */
199 if (psp == NULL | xp == NULL | yp == NULL | monpri == NULL |
200 (fname == NULL & tp == NULL))
201 returnErr(TM_E_ILLEGAL);
202 if (gamval < MINGAM) gamval = DEFGAM;
203 if (Lddyn < MINLDDYN) Lddyn = DEFLDDYN;
204 if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX;
205 if (flags & TM_F_BW) monpri = stdprims;
206 /* initialize tone mapping */
207 if (tmInit(flags, monpri, gamval) == NULL)
208 returnErr(TM_E_NOMEM);
209 /* load and convert TIFF */
210 cp = TM_NOCHROM;
211 err = tmLoadTIFF(&lp, flags&TM_F_BW ? TM_NOCHROMP : &cp,
212 xp, yp, fname, tp);
213 if (err != TM_E_OK) {
214 tmDone(NULL);
215 return(err);
216 }
217 if (cp == TM_NOCHROM) {
218 *psp = (BYTE *)malloc(*xp * *yp * sizeof(BYTE));
219 if (*psp == NULL) {
220 free((MEM_PTR)lp);
221 tmDone(NULL);
222 returnErr(TM_E_NOMEM);
223 }
224 } else
225 *psp = cp;
226 /* compute color mapping */
227 err = tmAddHisto(lp, *xp * *yp, 1);
228 if (err != TM_E_OK)
229 goto done;
230 err = tmComputeMapping(gamval, Lddyn, Ldmax);
231 if (err != TM_E_OK)
232 goto done;
233 /* map pixels */
234 err = tmMapPixels(*psp, lp, cp, *xp * *yp);
235
236 done: /* clean up */
237 free((MEM_PTR)lp);
238 tmDone(NULL);
239 if (err != TM_E_OK) { /* free memory on error */
240 free((MEM_PTR)*psp);
241 *psp = NULL;
242 *xp = *yp = 0;
243 returnErr(err);
244 }
245 returnOK;
246 }
