--- ray/src/common/tmaptiff.c 2003/07/27 22:12:01 3.4 +++ ray/src/common/tmaptiff.c 2005/01/07 20:33:02 3.5 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: tmaptiff.c,v 3.4 2003/07/27 22:12:01 schorsch Exp $"; +static const char RCSid[] = "$Id: tmaptiff.c,v 3.5 2005/01/07 20:33:02 greg Exp $"; #endif /* * Perform tone mapping on TIFF input. @@ -78,10 +78,11 @@ getTIFFtype(TIFF *tif) /* load and convert TIFF */ int -tmLoadTIFF(TMbright **lpp, BYTE **cpp, int *xp, int *yp, char *fname, TIFF *tp) +tmLoadTIFF(TMstruct *tms, TMbright **lpp, BYTE **cpp, + int *xp, int *yp, char *fname, TIFF *tp) { char *funcName = fname==NULL ? "tmLoadTIFF" : fname; - RGBPRIMP inppri = tmTop->monpri; + RGBPRIMP inppri = tms->monpri; RGBPRIMS myprims; float *fa; TIFF *tif; @@ -92,7 +93,7 @@ tmLoadTIFF(TMbright **lpp, BYTE **cpp, int *xp, int *y double stonits; int y; /* check arguments */ - if (tmTop == NULL) + if (tms == NULL) returnErr(TM_E_TMINVAL); if ((lpp == NULL) | (xp == NULL) | (yp == NULL) | ((fname == NULL) & (tp == NULL))) @@ -132,28 +133,28 @@ tmLoadTIFF(TMbright **lpp, BYTE **cpp, int *xp, int *y case TC_LOGLUV24: TIFFSetField(tif, TIFFTAG_SGILOGDATAFMT, SGILOGDATAFMT_RAW); sl.l = (uint32 *)malloc(width*sizeof(uint32)); - tmSetSpace(TM_XYZPRIM, stonits); + tmSetSpace(tms, TM_XYZPRIM, stonits); break; case TC_LOGL16: TIFFSetField(tif, TIFFTAG_SGILOGDATAFMT, SGILOGDATAFMT_16BIT); sl.w = (uint16 *)malloc(width*sizeof(uint16)); - tmSetSpace(tmTop->monpri, stonits); + tmSetSpace(tms, tms->monpri, stonits); break; case TC_RGBFLOAT: sl.f = (float *)malloc(width*3*sizeof(float)); - tmSetSpace(inppri, stonits); + tmSetSpace(tms, inppri, stonits); break; case TC_GRYFLOAT: sl.f = (float *)malloc(width*sizeof(float)); - tmSetSpace(tmTop->monpri, stonits); + tmSetSpace(tms, tms->monpri, stonits); break; case TC_RGBSHORT: sl.w = (uint16 *)malloc(width*3*sizeof(uint16)); - tmSetSpace(inppri, stonits); + tmSetSpace(tms, inppri, stonits); break; case TC_GRYSHORT: sl.w = (uint16 *)malloc(width*sizeof(uint16)); - tmSetSpace(tmTop->monpri, stonits); + tmSetSpace(tms, tms->monpri, stonits); break; default: err = TM_E_CODERR1; @@ -186,33 +187,34 @@ tmLoadTIFF(TMbright **lpp, BYTE **cpp, int *xp, int *y } switch (tcase) { case TC_LOGLUV32: - err = tmCvLuv32(*lpp + y*width, + err = tmCvLuv32(tms, *lpp + y*width, cpp==TM_NOCHROMP ? TM_NOCHROM : *cpp+y*3*width, sl.l, width); break; case TC_LOGLUV24: - err = tmCvLuv24(*lpp + y*width, + err = tmCvLuv24(tms, *lpp + y*width, cpp==TM_NOCHROMP ? TM_NOCHROM : *cpp+y*3*width, sl.l, width); break; case TC_LOGL16: - err = tmCvL16(*lpp + y*width, sl.w, width); + err = tmCvL16(tms, *lpp + y*width, sl.w, width); break; case TC_RGBFLOAT: - err = tmCvColors(*lpp + y*width, + err = tmCvColors(tms, *lpp + y*width, cpp==TM_NOCHROMP ? TM_NOCHROM : *cpp+y*3*width, (COLOR *)sl.f, width); break; case TC_GRYFLOAT: - err = tmCvGrays(*lpp + y*width, sl.f, width); + err = tmCvGrays(tms, *lpp + y*width, sl.f, width); break; case TC_RGBSHORT: - err = tmCvRGB48(*lpp + y*width, + err = tmCvRGB48(tms, *lpp + y*width, cpp==TM_NOCHROMP ? TM_NOCHROM : *cpp+y*3*width, (uint16 (*)[3])sl.w, width, DEFGAM); break; case TC_GRYSHORT: - err = tmCvGray16(*lpp + y*width, sl.w, width, DEFGAM); + err = tmCvGray16(tms, *lpp + y*width, + sl.w, width, DEFGAM); break; default: err = TM_E_CODERR1; @@ -253,6 +255,7 @@ tmMapTIFF(BYTE **psp, int *xp, int *yp, int flags, RGB double gamval, double Lddyn, double Ldmax, char *fname, TIFF *tp) { char *funcName = fname==NULL ? "tmMapTIFF" : fname; + TMstruct *tms; TMbright *lp; BYTE *cp; int err; @@ -265,38 +268,38 @@ tmMapTIFF(BYTE **psp, int *xp, int *yp, int flags, RGB if (Ldmax < MINLDMAX) Ldmax = DEFLDMAX; if (flags & TM_F_BW) monpri = stdprims; /* initialize tone mapping */ - if (tmInit(flags, monpri, gamval) == NULL) + if ((tms = tmInit(flags, monpri, gamval)) == NULL) returnErr(TM_E_NOMEM); /* load and convert TIFF */ cp = TM_NOCHROM; - err = tmLoadTIFF(&lp, flags&TM_F_BW ? TM_NOCHROMP : &cp, + err = tmLoadTIFF(tms, &lp, flags&TM_F_BW ? TM_NOCHROMP : &cp, xp, yp, fname, tp); if (err != TM_E_OK) { - tmDone(NULL); + tmDone(tms); return(err); } if (cp == TM_NOCHROM) { *psp = (BYTE *)malloc(*xp * *yp * sizeof(BYTE)); if (*psp == NULL) { free((MEM_PTR)lp); - tmDone(NULL); + tmDone(tms); returnErr(TM_E_NOMEM); } } else *psp = cp; /* compute color mapping */ - err = tmAddHisto(lp, *xp * *yp, 1); + err = tmAddHisto(tms, lp, *xp * *yp, 1); if (err != TM_E_OK) goto done; - err = tmComputeMapping(gamval, Lddyn, Ldmax); + err = tmComputeMapping(tms, gamval, Lddyn, Ldmax); if (err != TM_E_OK) goto done; /* map pixels */ - err = tmMapPixels(*psp, lp, cp, *xp * *yp); + err = tmMapPixels(tms, *psp, lp, cp, *xp * *yp); done: /* clean up */ free((MEM_PTR)lp); - tmDone(NULL); + tmDone(tms); if (err != TM_E_OK) { /* free memory on error */ free((MEM_PTR)*psp); *psp = NULL;
