1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* Routines for tone-mapping LogLuv encoded pixels. |
6 |
7 |
* Externals declared in tmaptiff.h |
8 |
9 |
10 |
11 |
* The Radiance Software License, Version 1.0 |
12 |
13 |
* Copyright (c) 1990 - 2002 The Regents of the University of California, |
14 |
* through Lawrence Berkeley National Laboratory. All rights reserved. |
15 |
16 |
* Redistribution and use in source and binary forms, with or without |
17 |
* modification, are permitted provided that the following conditions |
18 |
* are met: |
19 |
20 |
* 1. Redistributions of source code must retain the above copyright |
21 |
* notice, this list of conditions and the following disclaimer. |
22 |
23 |
* 2. Redistributions in binary form must reproduce the above copyright |
24 |
* notice, this list of conditions and the following disclaimer in |
25 |
* the documentation and/or other materials provided with the |
26 |
* distribution. |
27 |
28 |
* 3. The end-user documentation included with the redistribution, |
29 |
* if any, must include the following acknowledgment: |
30 |
* "This product includes Radiance software |
31 |
* (http://radsite.lbl.gov/) |
32 |
* developed by the Lawrence Berkeley National Laboratory |
33 |
* (http://www.lbl.gov/)." |
34 |
* Alternately, this acknowledgment may appear in the software itself, |
35 |
* if and wherever such third-party acknowledgments normally appear. |
36 |
37 |
* 4. The names "Radiance," "Lawrence Berkeley National Laboratory" |
38 |
* and "The Regents of the University of California" must |
39 |
* not be used to endorse or promote products derived from this |
40 |
* software without prior written permission. For written |
41 |
* permission, please contact [email protected]. |
42 |
43 |
* 5. Products derived from this software may not be called "Radiance", |
44 |
* nor may "Radiance" appear in their name, without prior written |
45 |
* permission of Lawrence Berkeley National Laboratory. |
46 |
47 |
* THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED |
48 |
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES |
49 |
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE |
50 |
* DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR |
51 |
* ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, |
52 |
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT |
53 |
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF |
54 |
* USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND |
55 |
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, |
56 |
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT |
57 |
* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF |
58 |
* SUCH DAMAGE. |
59 |
60 |
61 |
* This software consists of voluntary contributions made by many |
62 |
* individuals on behalf of Lawrence Berkeley National Laboratory. For more |
63 |
* information on Lawrence Berkeley National Laboratory, please see |
64 |
* <http://www.lbl.gov/>. |
65 |
66 |
67 |
#define LOGLUV_PUBLIC 1 |
68 |
69 |
#include <stdio.h> |
70 |
#include <string.h> |
71 |
#include <math.h> |
72 |
#include "tiffio.h" |
73 |
#include "tmprivat.h" |
74 |
#include "tmaptiff.h" |
75 |
76 |
#ifndef BSD |
77 |
#define bzero(d,n) (void)memset(d,0,n) |
78 |
#endif |
79 |
#define uvflgop(p,uv,op) ((p)->rgbflg[(uv)>>5] op (1L<<((uv)&0x1f))) |
80 |
#define isuvset(p,uv) uvflgop(p,uv,&) |
81 |
#define setuv(p,uv) uvflgop(p,uv,|=) |
82 |
#define clruv(p,uv) uvflgop(p,uv,&=~) |
83 |
#define clruvall(p) bzero((MEM_PTR)(p)->rgbflg,sizeof((p)->rgbflg)) |
84 |
85 |
#ifdef NOPROTO |
86 |
static MEM_PTR luv32Init(); |
87 |
static void luv32NewSpace(); |
88 |
static MEM_PTR luv24Init(); |
89 |
static void luv24NewSpace(); |
90 |
#else |
91 |
static MEM_PTR luv32Init(struct tmStruct *); |
92 |
static void luv32NewSpace(struct tmStruct *); |
93 |
static MEM_PTR luv24Init(struct tmStruct *); |
94 |
static void luv24NewSpace(struct tmStruct *); |
95 |
#endif |
96 |
97 |
typedef struct { |
98 |
int offset; /* computed luminance offset */ |
99 |
BYTE rgbval[1<<16][3]; /* computed RGB value for given uv */ |
100 |
uint32 rgbflg[1<<(16-5)]; /* flags for computed values */ |
101 |
} LUV32DATA; /* LogLuv 32-bit conversion data */ |
102 |
103 |
#define UVNEU ((int)(UVSCALE*U_NEU)<<8 \ |
104 |
| (int)(UVSCALE*V_NEU)) |
105 |
106 |
static struct tmPackage luv32Pkg = { /* 32-bit package functions */ |
107 |
luv32Init, luv32NewSpace, free |
108 |
109 |
static int luv32Reg = -1; /* 32-bit package reg. number */ |
110 |
111 |
typedef struct { |
112 |
113 |
BYTE rgbval[1<<14][3]; /* computed rgb value for uv index */ |
114 |
uint32 rgbflg[1<<(14-5)]; /* flags for computed values */ |
115 |
} LUV24DATA; /* LogLuv 24-bit conversion data */ |
116 |
117 |
static struct tmPackage luv24Pkg = { /* 24-bit package functions */ |
118 |
luv24Init, luv24NewSpace, free |
119 |
120 |
static int luv24Reg = -1; /* 24-bit package reg. number */ |
121 |
122 |
static int uv14neu = -1; /* neutral index for 14-bit (u',v') */ |
123 |
124 |
125 |
static void |
126 |
uv2rgb(rgb, tm, uvp) /* compute RGB from uv coordinate */ |
127 |
BYTE rgb[3]; |
128 |
register struct tmStruct *tm; |
129 |
double uvp[2]; |
130 |
{ /* Should check that tm->inppri==TM_XYZPRIM beforehand... */ |
131 |
double d, x, y; |
132 |
COLOR XYZ, RGB; |
133 |
/* convert to XYZ */ |
134 |
d = 1./(6.*uvp[0] - 16.*uvp[1] + 12.); |
135 |
x = 9.*uvp[0] * d; |
136 |
y = 4.*uvp[1] * d; |
137 |
XYZ[CIEY] = 1./tm->inpsf; |
138 |
XYZ[CIEX] = x/y * XYZ[CIEY]; |
139 |
XYZ[CIEZ] = (1.-x-y)/y * XYZ[CIEY]; |
140 |
/* convert to RGB and clip */ |
141 |
colortrans(RGB, tm->cmat, XYZ); |
142 |
clipgamut(RGB, 1., CGAMUT_LOWER, cblack, cwhite); |
143 |
/* perform final scaling & gamma */ |
144 |
d = tm->clf[RED] * RGB[RED]; |
145 |
rgb[RED] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam)); |
146 |
d = tm->clf[GRN] * RGB[GRN]; |
147 |
rgb[GRN] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam)); |
148 |
d = tm->clf[BLU] * RGB[BLU]; |
149 |
rgb[BLU] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam)); |
150 |
151 |
152 |
153 |
static TMbright |
154 |
compmeshift(li, uvp) /* compute mesopic color shift */ |
155 |
TMbright li; /* encoded world luminance */ |
156 |
double uvp[2]; /* world (u',v') -> returned desaturated */ |
157 |
158 |
double scotrat; |
159 |
register double d; |
160 |
161 |
if (li >= BMESUPPER) |
162 |
return(li); |
163 |
scotrat = (.767676768 - 1.02356902*uvp[1])/uvp[0] - .343434343; |
164 |
if (li <= BMESLOWER) { |
165 |
d = 0.; |
166 |
uvp[0] = U_NEU; uvp[1] = V_NEU; |
167 |
} else { |
168 |
d = (tmMesofact[li-BMESLOWER] + .5) * (1./256.); |
169 |
uvp[0] = d*uvp[0] + (1.-d)*U_NEU; |
170 |
uvp[1] = d*uvp[1] + (1.-d)*V_NEU; |
171 |
172 |
173 |
d = li + (double)TM_BRTSCALE*log(d + (1.-d)*scotrat); |
174 |
175 |
d = d + (1.-d)*scotrat; |
176 |
d -= 1.; /* Taylor expansion of log(x) about 1 */ |
177 |
d = d*(1. + d*(-.5 + d*(1./3. + d*-.125))); |
178 |
d = li + (double)TM_BRTSCALE*d; |
179 |
return((TMbright)(d>0. ? d+.5 : d-.5)); |
180 |
181 |
182 |
183 |
int |
184 |
tmCvLuv32(ls, cs, luvs, len) /* convert raw 32-bit LogLuv values */ |
185 |
TMbright *ls; |
186 |
BYTE *cs; |
187 |
uint32 *luvs; |
188 |
int len; |
189 |
190 |
static char funcName[] = "tmCvLuv32"; |
191 |
double uvp[2]; |
192 |
register LUV32DATA *ld; |
193 |
register int i, j; |
194 |
/* check arguments */ |
195 |
if (tmTop == NULL) |
196 |
returnErr(TM_E_TMINVAL); |
197 |
if (ls == NULL | luvs == NULL | len < 0) |
198 |
returnErr(TM_E_ILLEGAL); |
199 |
/* check package registration */ |
200 |
if (luv32Reg < 0) { |
201 |
if ((luv32Reg = tmRegPkg(&luv32Pkg)) < 0) |
202 |
returnErr(TM_E_CODERR1); |
203 |
tmMkMesofact(); |
204 |
205 |
/* get package data */ |
206 |
if ((ld = (LUV32DATA *)tmPkgData(tmTop,luv32Reg)) == NULL) |
207 |
returnErr(TM_E_NOMEM); |
208 |
/* convert each pixel */ |
209 |
for (i = len; i--; ) { |
210 |
j = luvs[i] >> 16; /* get luminance */ |
211 |
if (j & 0x8000) /* negative luminance */ |
212 |
ls[i] = TM_NOBRT; /* assign bogus value */ |
213 |
else /* else convert to lnL */ |
214 |
ls[i] = (BRT2SCALE(j) >> 8) - ld->offset; |
215 |
if (cs == TM_NOCHROM) /* no color? */ |
216 |
continue; |
217 |
/* get chrominance */ |
218 |
if (tmTop->flags & TM_F_MESOPIC && ls[i] < BMESUPPER) { |
219 |
uvp[0] = 1./UVSCALE*((luvs[i]>>8 & 0xff) + .5); |
220 |
uvp[1] = 1./UVSCALE*((luvs[i] & 0xff) + .5); |
221 |
ls[i] = compmeshift(ls[i], uvp); |
222 |
j = tmTop->flags&TM_F_BW || ls[i]<BMESLOWER |
223 |
? UVNEU |
224 |
: (int)(uvp[0]*UVSCALE)<<8 |
225 |
| (int)(uvp[1]*UVSCALE); |
226 |
} else { |
227 |
j = tmTop->flags&TM_F_BW ? UVNEU : luvs[i]&0xffff; |
228 |
229 |
if (!isuvset(ld, j)) { |
230 |
uvp[0] = 1./UVSCALE*((j>>8) + .5); |
231 |
uvp[1] = 1./UVSCALE*((j & 0xff) + .5); |
232 |
uv2rgb(ld->rgbval[j], tmTop, uvp); |
233 |
setuv(ld, j); |
234 |
235 |
cs[3*i ] = ld->rgbval[j][RED]; |
236 |
cs[3*i+1] = ld->rgbval[j][GRN]; |
237 |
cs[3*i+2] = ld->rgbval[j][BLU]; |
238 |
239 |
returnOK; |
240 |
241 |
242 |
243 |
int |
244 |
tmCvLuv24(ls, cs, luvs, len) /* convert raw 24-bit LogLuv values */ |
245 |
TMbright *ls; |
246 |
BYTE *cs; |
247 |
uint32 *luvs; |
248 |
int len; |
249 |
250 |
char funcName[] = "tmCvLuv24"; |
251 |
double uvp[2]; |
252 |
register LUV24DATA *ld; |
253 |
254 |
255 |
256 |
257 |
258 |
259 |
260 |
if (luv24Reg < 0) { |
261 |
if ((luv24Reg = tmRegPkg(&luv24Pkg)) < 0) |
262 |
263 |
tmMkMesofact(); |
264 |
265 |
266 |
if ((ld = (LUV24DATA *)tmPkgData(tmTop,luv24Reg)) == NULL) |
267 |
268 |
269 |
270 |
j = luvs[i] >> 14; /* get luminance */ |
271 |
ls[i] = (BRT2SCALE(j) >> 6) - ld->offset; |
272 |
273 |
continue; |
274 |
275 |
276 |
if (uv_decode(uvp, uvp+1, luvs[i]&0x3fff) < 0) { |
277 |
uvp[0] = U_NEU; /* should barf? */ |
278 |
uvp[1] = V_NEU; |
279 |
280 |
281 |
if (tmTop->flags&TM_F_BW || ls[i]<BMESLOWER |
282 |
|| (j = uv_encode(uvp[0], uvp[1], |
283 |
SGILOGENCODE_NODITHER)) < 0) |
284 |
j = uv14neu; |
285 |
} else { |
286 |
j = tmTop->flags&TM_F_BW ? uv14neu : luvs[i]&0x3fff; |
287 |
288 |
289 |
if (uv_decode(&uvp[0], &uvp[1], j) < 0) { |
290 |
291 |
292 |
293 |
setuv(ld, j); |
294 |
295 |
296 |
297 |
298 |
299 |
returnOK; |
300 |
301 |
302 |
303 |
int |
304 |
tmCvL16(ls, l16s, len) /* convert 16-bit LogL values */ |
305 |
TMbright *ls; |
306 |
uint16 *l16s; |
307 |
int len; |
308 |
309 |
static char funcName[] = "tmCvL16"; |
310 |
static double lastsf; |
311 |
static int offset; |
312 |
register int i; |
313 |
314 |
315 |
316 |
if (ls == NULL | l16s == NULL | len < 0) |
317 |
318 |
/* check scaling offset */ |
319 |
if (!FEQ(tmTop->inpsf, lastsf)) { |
320 |
offset = BRT2SCALE(64); |
321 |
if (tmTop->inpsf > 1.0001) |
322 |
offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5); |
323 |
else if (tmTop->inpsf < 0.9999) |
324 |
offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)-.5); |
325 |
lastsf = tmTop->inpsf; |
326 |
327 |
328 |
329 |
if (l16s[i] & 0x8000) /* negative luminance */ |
330 |
331 |
332 |
ls[i] = (BRT2SCALE(l16s[i]) >> 8) - offset; |
333 |
334 |
returnOK; |
335 |
336 |
337 |
338 |
static void |
339 |
luv32NewSpace(tm) /* initialize 32-bit LogLuv color space */ |
340 |
341 |
342 |
343 |
344 |
if (tm->inppri != TM_XYZPRIM) { /* panic time! */ |
345 |
fputs("Improper input color space in luv32NewSpace!\n", stderr); |
346 |
exit(1); |
347 |
348 |
ld = (LUV32DATA *)tm->pd[luv32Reg]; |
349 |
ld->offset = BRT2SCALE(64); |
350 |
if (tm->inpsf > 1.0001) |
351 |
ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5); |
352 |
else if (tm->inpsf < 0.9999) |
353 |
ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)-.5); |
354 |
clruvall(ld); |
355 |
356 |
357 |
358 |
static MEM_PTR |
359 |
luv32Init(tm) /* allocate data for 32-bit LogLuv decoder */ |
360 |
361 |
362 |
363 |
364 |
ld = (LUV32DATA *)malloc(sizeof(LUV32DATA)); |
365 |
if (ld == NULL) |
366 |
return(NULL); |
367 |
tm->pd[luv32Reg] = (MEM_PTR)ld; |
368 |
luv32NewSpace(tm); |
369 |
return((MEM_PTR)ld); |
370 |
371 |
372 |
373 |
static void |
374 |
luv24NewSpace(tm) /* initialize 24-bit LogLuv color space */ |
375 |
376 |
377 |
378 |
379 |
380 |
fputs("Improper input color space in luv24NewSpace!\n", stderr); |
381 |
exit(1); |
382 |
383 |
ld = (LUV24DATA *)tm->pd[luv24Reg]; |
384 |
ld->offset = BRT2SCALE(12); |
385 |
386 |
387 |
388 |
389 |
clruvall(ld); |
390 |
391 |
392 |
393 |
static MEM_PTR |
394 |
luv24Init(tm) /* allocate data for 24-bit LogLuv decoder */ |
395 |
396 |
397 |
398 |
399 |
ld = (LUV24DATA *)malloc(sizeof(LUV24DATA)); |
400 |
if (ld == NULL) |
401 |
return(NULL); |
402 |
tm->pd[luv24Reg] = (MEM_PTR)ld; |
403 |
if (uv14neu < 0) /* initialize neutral color index */ |
404 |
uv14neu = uv_encode(U_NEU, V_NEU, SGILOGENCODE_NODITHER); |
405 |
luv24NewSpace(tm); |
406 |
407 |
