--- ray/src/common/tmapluv.c 2003/06/30 14:59:11 3.6 +++ ray/src/common/tmapluv.c 2010/12/02 18:10:40 3.15 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: tmapluv.c,v 3.6 2003/06/30 14:59:11 schorsch Exp $"; +static const char RCSid[] = "$Id: tmapluv.c,v 3.15 2010/12/02 18:10:40 greg Exp $"; #endif /* * Routines for tone-mapping LogLuv encoded pixels. @@ -12,6 +12,7 @@ static const char RCSid[] = "$Id: tmapluv.c,v 3.6 2003 #define LOGLUV_PUBLIC 1 #include +#include #include #include #include "tiffio.h" @@ -30,10 +31,10 @@ static void luv32NewSpace(); static MEM_PTR luv24Init(); static void luv24NewSpace(); #else -static MEM_PTR luv32Init(struct tmStruct *); -static void luv32NewSpace(struct tmStruct *); -static MEM_PTR luv24Init(struct tmStruct *); -static void luv24NewSpace(struct tmStruct *); +static MEM_PTR luv32Init(TMstruct *); +static void luv32NewSpace(TMstruct *); +static MEM_PTR luv24Init(TMstruct *); +static void luv24NewSpace(TMstruct *); #endif typedef struct { @@ -65,30 +66,30 @@ static int uv14neu = -1; /* neutral index for 14-bit static void -uv2rgb(rgb, tm, uvp) /* compute RGB from uv coordinate */ +uv2rgb(rgb, tms, uvp) /* compute RGB from uv coordinate */ BYTE rgb[3]; -register struct tmStruct *tm; +register TMstruct *tms; double uvp[2]; -{ /* Should check that tm->inppri==TM_XYZPRIM beforehand... */ +{ /* Should check that tms->inppri==TM_XYZPRIM beforehand... */ double d, x, y; COLOR XYZ, RGB; /* convert to XYZ */ d = 1./(6.*uvp[0] - 16.*uvp[1] + 12.); x = 9.*uvp[0] * d; y = 4.*uvp[1] * d; - XYZ[CIEY] = 1./tm->inpsf; + XYZ[CIEY] = 1./tms->inpsf; XYZ[CIEX] = x/y * XYZ[CIEY]; XYZ[CIEZ] = (1.-x-y)/y * XYZ[CIEY]; /* convert to RGB and clip */ - colortrans(RGB, tm->cmat, XYZ); + colortrans(RGB, tms->cmat, XYZ); clipgamut(RGB, 1., CGAMUT_LOWER, cblack, cwhite); /* perform final scaling & gamma */ - d = tm->clf[RED] * RGB[RED]; - rgb[RED] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam)); - d = tm->clf[GRN] * RGB[GRN]; - rgb[GRN] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam)); - d = tm->clf[BLU] * RGB[BLU]; - rgb[BLU] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam)); + d = tms->clf[RED] * RGB[RED]; + rgb[RED] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tms->mongam)); + d = tms->clf[GRN] * RGB[GRN]; + rgb[GRN] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tms->mongam)); + d = tms->clf[BLU] * RGB[BLU]; + rgb[BLU] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tms->mongam)); } @@ -123,20 +124,22 @@ double uvp[2]; /* world (u',v') -> returned desatura int -tmCvLuv32(ls, cs, luvs, len) /* convert raw 32-bit LogLuv values */ -TMbright *ls; -BYTE *cs; -uint32 *luvs; -int len; +tmCvLuv32( /* convert raw 32-bit LogLuv values */ +TMstruct *tms, +TMbright *ls, +BYTE *cs, +uint32 *luvs, +int len +) { - static char funcName[] = "tmCvLuv32"; + static const char funcName[] = "tmCvLuv32"; double uvp[2]; register LUV32DATA *ld; register int i, j; /* check arguments */ - if (tmTop == NULL) + if (tms == NULL) returnErr(TM_E_TMINVAL); - if (ls == NULL | luvs == NULL | len < 0) + if ((ls == NULL) | (luvs == NULL) | (len < 0)) returnErr(TM_E_ILLEGAL); /* check package registration */ if (luv32Reg < 0) { @@ -145,7 +148,7 @@ int len; tmMkMesofact(); } /* get package data */ - if ((ld = (LUV32DATA *)tmPkgData(tmTop,luv32Reg)) == NULL) + if ((ld = (LUV32DATA *)tmPkgData(tms,luv32Reg)) == NULL) returnErr(TM_E_NOMEM); /* convert each pixel */ for (i = len; i--; ) { @@ -157,21 +160,21 @@ int len; if (cs == TM_NOCHROM) /* no color? */ continue; /* get chrominance */ - if (tmTop->flags & TM_F_MESOPIC && ls[i] < BMESUPPER) { + if (tms->flags & TM_F_MESOPIC && ls[i] < BMESUPPER) { uvp[0] = 1./UVSCALE*((luvs[i]>>8 & 0xff) + .5); uvp[1] = 1./UVSCALE*((luvs[i] & 0xff) + .5); ls[i] = compmeshift(ls[i], uvp); - j = tmTop->flags&TM_F_BW || ls[i]flags&TM_F_BW || ls[i]flags&TM_F_BW ? UVNEU : luvs[i]&0xffff; + j = tms->flags&TM_F_BW ? UVNEU : luvs[i]&0xffff; } if (!isuvset(ld, j)) { uvp[0] = 1./UVSCALE*((j>>8) + .5); uvp[1] = 1./UVSCALE*((j & 0xff) + .5); - uv2rgb(ld->rgbval[j], tmTop, uvp); + uv2rgb(ld->rgbval[j], tms, uvp); setuv(ld, j); } cs[3*i ] = ld->rgbval[j][RED]; @@ -183,20 +186,22 @@ int len; int -tmCvLuv24(ls, cs, luvs, len) /* convert raw 24-bit LogLuv values */ -TMbright *ls; -BYTE *cs; -uint32 *luvs; -int len; +tmCvLuv24( /* convert raw 24-bit LogLuv values */ +TMstruct *tms, +TMbright *ls, +BYTE *cs, +uint32 *luvs, +int len +) { char funcName[] = "tmCvLuv24"; double uvp[2]; register LUV24DATA *ld; register int i, j; /* check arguments */ - if (tmTop == NULL) + if (tms == NULL) returnErr(TM_E_TMINVAL); - if (ls == NULL | luvs == NULL | len < 0) + if ((ls == NULL) | (luvs == NULL) | (len < 0)) returnErr(TM_E_ILLEGAL); /* check package registration */ if (luv24Reg < 0) { @@ -205,7 +210,7 @@ int len; tmMkMesofact(); } /* get package data */ - if ((ld = (LUV24DATA *)tmPkgData(tmTop,luv24Reg)) == NULL) + if ((ld = (LUV24DATA *)tmPkgData(tms,luv24Reg)) == NULL) returnErr(TM_E_NOMEM); /* convert each pixel */ for (i = len; i--; ) { @@ -214,24 +219,25 @@ int len; if (cs == TM_NOCHROM) /* no color? */ continue; /* get chrominance */ - if (tmTop->flags & TM_F_MESOPIC && ls[i] < BMESUPPER) { - if (uv_decode(uvp, uvp+1, luvs[i]&0x3fff) < 0) { + if (tms->flags & TM_F_MESOPIC && ls[i] < BMESUPPER) { + if (uv_decode(&uvp[0], &uvp[1], luvs[i]&0x3fff) < 0) { uvp[0] = U_NEU; /* should barf? */ uvp[1] = V_NEU; } ls[i] = compmeshift(ls[i], uvp); - if (tmTop->flags&TM_F_BW || ls[i]flags&TM_F_BW || ls[i]flags&TM_F_BW ? uv14neu : luvs[i]&0x3fff; + j = tms->flags&TM_F_BW ? uv14neu : + (int)(luvs[i]&0x3fff); } if (!isuvset(ld, j)) { if (uv_decode(&uvp[0], &uvp[1], j) < 0) { uvp[0] = U_NEU; uvp[1] = V_NEU; } - uv2rgb(ld->rgbval[j], tmTop, uvp); + uv2rgb(ld->rgbval[j], tms, uvp); setuv(ld, j); } cs[3*i ] = ld->rgbval[j][RED]; @@ -243,28 +249,26 @@ int len; int -tmCvL16(ls, l16s, len) /* convert 16-bit LogL values */ -TMbright *ls; -uint16 *l16s; -int len; +tmCvL16( /* convert 16-bit LogL values */ +TMstruct *tms, +TMbright *ls, +uint16 *l16s, +int len +) { - static char funcName[] = "tmCvL16"; + static const char funcName[] = "tmCvL16"; static double lastsf; static int offset; register int i; /* check arguments */ - if (tmTop == NULL) + if (tms == NULL) returnErr(TM_E_TMINVAL); - if (ls == NULL | l16s == NULL | len < 0) + if ((ls == NULL) | (l16s == NULL) | (len < 0)) returnErr(TM_E_ILLEGAL); /* check scaling offset */ - if (!FEQ(tmTop->inpsf, lastsf)) { - offset = BRT2SCALE(64); - if (tmTop->inpsf > 1.0001) - offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5); - else if (tmTop->inpsf < 0.9999) - offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)-.5); - lastsf = tmTop->inpsf; + if (!FEQ(tms->inpsf, lastsf)) { + offset = BRT2SCALE(64) - tmCvLuminance(tms->inpsf); + lastsf = tms->inpsf; } /* convert each pixel */ for (i = len; i--; ) { @@ -278,72 +282,64 @@ int len; static void -luv32NewSpace(tm) /* initialize 32-bit LogLuv color space */ -struct tmStruct *tm; +luv32NewSpace(tms) /* initialize 32-bit LogLuv color space */ +TMstruct *tms; { register LUV32DATA *ld; - if (tm->inppri != TM_XYZPRIM) { /* panic time! */ + if (tms->inppri != TM_XYZPRIM) { /* panic time! */ fputs("Improper input color space in luv32NewSpace!\n", stderr); exit(1); } - ld = (LUV32DATA *)tm->pd[luv32Reg]; - ld->offset = BRT2SCALE(64); - if (tm->inpsf > 1.0001) - ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5); - else if (tm->inpsf < 0.9999) - ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)-.5); + ld = (LUV32DATA *)tms->pd[luv32Reg]; + ld->offset = BRT2SCALE(64) - tmCvLuminance(tms->inpsf); clruvall(ld); } static MEM_PTR -luv32Init(tm) /* allocate data for 32-bit LogLuv decoder */ -struct tmStruct *tm; +luv32Init(tms) /* allocate data for 32-bit LogLuv decoder */ +TMstruct *tms; { register LUV32DATA *ld; ld = (LUV32DATA *)malloc(sizeof(LUV32DATA)); if (ld == NULL) return(NULL); - tm->pd[luv32Reg] = (MEM_PTR)ld; - luv32NewSpace(tm); + tms->pd[luv32Reg] = (MEM_PTR)ld; + luv32NewSpace(tms); return((MEM_PTR)ld); } static void -luv24NewSpace(tm) /* initialize 24-bit LogLuv color space */ -struct tmStruct *tm; +luv24NewSpace(tms) /* initialize 24-bit LogLuv color space */ +TMstruct *tms; { register LUV24DATA *ld; - if (tm->inppri != TM_XYZPRIM) { /* panic time! */ + if (tms->inppri != TM_XYZPRIM) { /* panic time! */ fputs("Improper input color space in luv24NewSpace!\n", stderr); exit(1); } - ld = (LUV24DATA *)tm->pd[luv24Reg]; - ld->offset = BRT2SCALE(12); - if (tm->inpsf > 1.0001) - ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5); - else if (tm->inpsf < 0.9999) - ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)-.5); + ld = (LUV24DATA *)tms->pd[luv24Reg]; + ld->offset = BRT2SCALE(12) - tmCvLuminance(tms->inpsf); clruvall(ld); } static MEM_PTR -luv24Init(tm) /* allocate data for 24-bit LogLuv decoder */ -struct tmStruct *tm; +luv24Init(tms) /* allocate data for 24-bit LogLuv decoder */ +TMstruct *tms; { register LUV24DATA *ld; ld = (LUV24DATA *)malloc(sizeof(LUV24DATA)); if (ld == NULL) return(NULL); - tm->pd[luv24Reg] = (MEM_PTR)ld; + tms->pd[luv24Reg] = (MEM_PTR)ld; if (uv14neu < 0) /* initialize neutral color index */ uv14neu = uv_encode(U_NEU, V_NEU, SGILOGENCODE_NODITHER); - luv24NewSpace(tm); + luv24NewSpace(tms); return((MEM_PTR)ld); }
