--- ray/src/common/tmapluv.c 1998/10/22 13:53:06 3.1 +++ ray/src/common/tmapluv.c 2009/02/09 20:48:08 3.14 @@ -1,36 +1,41 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: tmapluv.c,v 3.14 2009/02/09 20:48:08 greg Exp $"; #endif - /* * Routines for tone-mapping LogLuv encoded pixels. + * + * Externals declared in tmaptiff.h */ +#include "copyright.h" + +#define LOGLUV_PUBLIC 1 + #include +#include +#include #include -#include "tiffio.h" #include "tmprivat.h" -#include "uvcode.h" +#include "tiffio.h" +#include "tmaptiff.h" -#ifndef BSD -#define bzero(d,n) (void)memset(d,0,n) -#endif #define uvflgop(p,uv,op) ((p)->rgbflg[(uv)>>5] op (1L<<((uv)&0x1f))) #define isuvset(p,uv) uvflgop(p,uv,&) #define setuv(p,uv) uvflgop(p,uv,|=) #define clruv(p,uv) uvflgop(p,uv,&=~) -#define clruvall(p) bzero((MEM_PTR)(p)->rgbflg,sizeof((p)->rgbflg)) +#define clruvall(p) memset((MEM_PTR)(p)->rgbflg,'\0',sizeof((p)->rgbflg)) -#define U_NEU 0.210526316 -#define V_NEU 0.473684211 - +#ifdef NOPROTO static MEM_PTR luv32Init(); static void luv32NewSpace(); static MEM_PTR luv24Init(); static void luv24NewSpace(); -extern void free(); +#else +static MEM_PTR luv32Init(TMstruct *); +static void luv32NewSpace(TMstruct *); +static MEM_PTR luv24Init(TMstruct *); +static void luv24NewSpace(TMstruct *); +#endif typedef struct { int offset; /* computed luminance offset */ @@ -38,7 +43,6 @@ typedef struct { uint32 rgbflg[1<<(16-5)]; /* flags for computed values */ } LUV32DATA; /* LogLuv 32-bit conversion data */ -#define UVSCALE 410. #define UVNEU ((int)(UVSCALE*U_NEU)<<8 \ | (int)(UVSCALE*V_NEU)) @@ -61,31 +65,31 @@ static int luv24Reg = -1; /* 24-bit package reg. numb static int uv14neu = -1; /* neutral index for 14-bit (u',v') */ -static -uv2rgb(rgb, tm, uvp) /* compute RGB from uv coordinate */ +static void +uv2rgb(rgb, tms, uvp) /* compute RGB from uv coordinate */ BYTE rgb[3]; -register struct tmStruct *tm; +register TMstruct *tms; double uvp[2]; -{ /* Should check that tm->inppri==TM_XYZPRIM beforehand... */ +{ /* Should check that tms->inppri==TM_XYZPRIM beforehand... */ double d, x, y; - COLR XYZ, RGB; + COLOR XYZ, RGB; /* convert to XYZ */ d = 1./(6.*uvp[0] - 16.*uvp[1] + 12.); x = 9.*uvp[0] * d; y = 4.*uvp[1] * d; - XYZ[CIEY] = 1./tm->inpsf; + XYZ[CIEY] = 1./tms->inpsf; XYZ[CIEX] = x/y * XYZ[CIEY]; XYZ[CIEZ] = (1.-x-y)/y * XYZ[CIEY]; /* convert to RGB and clip */ - colortrans(RGB, tm->cmat, XYZ); - clipgamut(RGB, XYZ[CIEY], CGAMUT_LOWER, cblack, cwhite); + colortrans(RGB, tms->cmat, XYZ); + clipgamut(RGB, 1., CGAMUT_LOWER, cblack, cwhite); /* perform final scaling & gamma */ - d = tm->clf[RED] * RGB[RED]; - rgb[RED] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam)); - d = tm->clf[GRN] * RGB[GRN]; - rgb[GRN] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam)); - d = tm->clf[BLU] * RGB[BLU]; - rgb[BLU] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam)); + d = tms->clf[RED] * RGB[RED]; + rgb[RED] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tms->mongam)); + d = tms->clf[GRN] * RGB[GRN]; + rgb[GRN] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tms->mongam)); + d = tms->clf[BLU] * RGB[BLU]; + rgb[BLU] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tms->mongam)); } @@ -94,108 +98,83 @@ compmeshift(li, uvp) /* compute mesopic color shift TMbright li; /* encoded world luminance */ double uvp[2]; /* world (u',v') -> returned desaturated */ { - /* UNIMPLEMENTED */ - return(li); -} + double scotrat; + register double d; - -static int -uvpencode(uvp) /* encode (u',v') coordinates */ -double uvp[2]; -{ - register int vi, ui; - - if (uvp[1] < UV_VSTART) - return(-1); - vi = (uvp[1] - UV_VSTART)*(1./UV_SQSIZ); - if (vi >= UV_NVS) - return(-1); - if (uvp[0] < uv_row[vi].ustart) - return(-1); - ui = (uvp[0] - uv_row[vi].ustart)*(1./UV_SQSIZ); - if (ui >= uv_row[vi].nus) - return(-1); - return(uv_row[vi].ncum + ui); + if (li >= BMESUPPER) + return(li); + scotrat = (.767676768 - 1.02356902*uvp[1])/uvp[0] - .343434343; + if (li <= BMESLOWER) { + d = 0.; + uvp[0] = U_NEU; uvp[1] = V_NEU; + } else { + d = (tmMesofact[li-BMESLOWER] + .5) * (1./256.); + uvp[0] = d*uvp[0] + (1.-d)*U_NEU; + uvp[1] = d*uvp[1] + (1.-d)*V_NEU; + } + /* + d = li + (double)TM_BRTSCALE*log(d + (1.-d)*scotrat); + */ + d = d + (1.-d)*scotrat; + d -= 1.; /* Taylor expansion of log(x) about 1 */ + d = d*(1. + d*(-.5 + d*(1./3. + d*-.125))); + d = li + (double)TM_BRTSCALE*d; + return((TMbright)(d>0. ? d+.5 : d-.5)); } -static int -uvpdecode(uvp, c) /* decode (u',v') index */ -double uvp[2]; -int c; -{ - int upper, lower; - register int ui, vi; - - if (c < 0 || c >= UV_NDIVS) - return(-1); - lower = 0; /* binary search */ - upper = UV_NVS; - do { - vi = (lower + upper) >> 1; - ui = c - uv_row[vi].ncum; - if (ui > 0) - lower = vi; - else if (ui < 0) - upper = vi; - else - break; - } while (upper - lower > 1); - vi = lower; - ui = c - uv_row[vi].ncum; - uvp[0] = uv_row[vi].ustart + (ui+.5)*UV_SQSIZ; - uvp[1] = UV_VSTART + (vi+.5)*UV_SQSIZ; - return(0); -} - - int -tmCvLuv32(ls, cs, luvs, len) /* convert raw 32-bit LogLuv values */ -TMbright *ls; -BYTE *cs; -uint32 *luvs; -int len; +tmCvLuv32( /* convert raw 32-bit LogLuv values */ +TMstruct *tms, +TMbright *ls, +BYTE *cs, +uint32 *luvs, +int len +) { - static char funcName[] = "tmCvLuv32"; + static const char funcName[] = "tmCvLuv32"; double uvp[2]; register LUV32DATA *ld; register int i, j; /* check arguments */ - if (tmTop == NULL) + if (tms == NULL) returnErr(TM_E_TMINVAL); - if (ls == NULL | luvs == NULL | len < 0) + if ((ls == NULL) | (luvs == NULL) | (len < 0)) returnErr(TM_E_ILLEGAL); /* check package registration */ - if (luv32Reg < 0 && (luv32Reg = tmRegPkg(&luv32Pkg)) < 0) - returnErr(TM_E_CODERR1); + if (luv32Reg < 0) { + if ((luv32Reg = tmRegPkg(&luv32Pkg)) < 0) + returnErr(TM_E_CODERR1); + tmMkMesofact(); + } /* get package data */ - if ((ld = (LUV32DATA *)tmPkgData(tmTop,luv32Reg)) == NULL) + if ((ld = (LUV32DATA *)tmPkgData(tms,luv32Reg)) == NULL) returnErr(TM_E_NOMEM); /* convert each pixel */ for (i = len; i--; ) { j = luvs[i] >> 16; /* get luminance */ if (j & 0x8000) /* negative luminance */ - ls[i] = MINBRT-1; /* assign bogus value */ + ls[i] = TM_NOBRT; /* assign bogus value */ else /* else convert to lnL */ - ls[i] = (BRT2SCALE*j >> 8) - ld->offset; + ls[i] = (BRT2SCALE(j) >> 8) - ld->offset; if (cs == TM_NOCHROM) /* no color? */ continue; /* get chrominance */ - if (tmTop->flags & TM_F_MESOPIC && ls[i] < BMESUPPER) { + if (tms->flags & TM_F_MESOPIC && ls[i] < BMESUPPER) { uvp[0] = 1./UVSCALE*((luvs[i]>>8 & 0xff) + .5); uvp[1] = 1./UVSCALE*((luvs[i] & 0xff) + .5); ls[i] = compmeshift(ls[i], uvp); - j = tmTop->flags & TM_F_BW || ls[i] < BMESLOWER + j = tms->flags&TM_F_BW || ls[i]flags&TM_F_BW ? UVNEU : luvs[i]&0xffff; + j = tms->flags&TM_F_BW ? UVNEU : luvs[i]&0xffff; } if (!isuvset(ld, j)) { - uvp[0] = 1./UVSCALE*((luvs[i]>>8 & 0xff) + .5); - uvp[1] = 1./UVSCALE*((luvs[i] & 0xff) + .5); - uv2rgb(ld->rgbval[j], tmTop, uvp); + uvp[0] = 1./UVSCALE*((j>>8) + .5); + uvp[1] = 1./UVSCALE*((j & 0xff) + .5); + uv2rgb(ld->rgbval[j], tms, uvp); setuv(ld, j); } cs[3*i ] = ld->rgbval[j][RED]; @@ -207,52 +186,58 @@ int len; int -tmCvLuv24(ls, cs, luvs, len) /* convert raw 24-bit LogLuv values */ -TMbright *ls; -BYTE *cs; -uint32 *luvs; -int len; +tmCvLuv24( /* convert raw 24-bit LogLuv values */ +TMstruct *tms, +TMbright *ls, +BYTE *cs, +uint32 *luvs, +int len +) { char funcName[] = "tmCvLuv24"; double uvp[2]; register LUV24DATA *ld; register int i, j; /* check arguments */ - if (tmTop == NULL) + if (tms == NULL) returnErr(TM_E_TMINVAL); - if (ls == NULL | luvs == NULL | len < 0) + if ((ls == NULL) | (luvs == NULL) | (len < 0)) returnErr(TM_E_ILLEGAL); /* check package registration */ - if (luv24Reg < 0 && (luv24Reg = tmRegPkg(&luv24Pkg)) < 0) - returnErr(TM_E_CODERR1); + if (luv24Reg < 0) { + if ((luv24Reg = tmRegPkg(&luv24Pkg)) < 0) + returnErr(TM_E_CODERR1); + tmMkMesofact(); + } /* get package data */ - if ((ld = (LUV24DATA *)tmPkgData(tmTop,luv24Reg)) == NULL) + if ((ld = (LUV24DATA *)tmPkgData(tms,luv24Reg)) == NULL) returnErr(TM_E_NOMEM); /* convert each pixel */ for (i = len; i--; ) { j = luvs[i] >> 14; /* get luminance */ - ls[i] = (BRT2SCALE*j >> 6) - ld->offset; + ls[i] = (BRT2SCALE(j) >> 6) - ld->offset; if (cs == TM_NOCHROM) /* no color? */ continue; /* get chrominance */ - if (tmTop->flags & TM_F_MESOPIC && ls[i] < BMESUPPER) { - if (uvpdecode(uvp, luvs[i]&0x3fff) < 0) { + if (tms->flags & TM_F_MESOPIC && ls[i] < BMESUPPER) { + if (uv_decode(&uvp[0], &uvp[1], luvs[i]&0x3fff) < 0) { uvp[0] = U_NEU; /* should barf? */ uvp[1] = V_NEU; } ls[i] = compmeshift(ls[i], uvp); - if (tmTop->flags & TM_F_BW || ls[i] < BMESLOWER - || (j = uvpencode(uvp)) < 0) + if (tms->flags&TM_F_BW || ls[i]flags&TM_F_BW ? uv14neu : luvs[i]&0x3fff; + j = tms->flags&TM_F_BW ? uv14neu : + (int)(luvs[i]&0x3fff); } if (!isuvset(ld, j)) { - if (uvpdecode(uvp, j) < 0) { - uvp[0] = U_NEU; - uvp[1] = V_NEU; + if (uv_decode(&uvp[0], &uvp[1], j) < 0) { + uvp[0] = U_NEU; uvp[1] = V_NEU; } - uv2rgb(ld->rgbval[j], tmTop, uvp); + uv2rgb(ld->rgbval[j], tms, uvp); setuv(ld, j); } cs[3*i ] = ld->rgbval[j][RED]; @@ -264,111 +249,97 @@ int len; int -tmCvL16(ls, l16s, len) /* convert 16-bit LogL values */ -TMbright *ls; -uint16 *l16s; -int len; +tmCvL16( /* convert 16-bit LogL values */ +TMstruct *tms, +TMbright *ls, +uint16 *l16s, +int len +) { - static char funcName[] = "tmCvL16"; + static const char funcName[] = "tmCvL16"; static double lastsf; static int offset; register int i; /* check arguments */ - if (tmTop == NULL) + if (tms == NULL) returnErr(TM_E_TMINVAL); - if (ls == NULL | l16s == NULL | len < 0) + if ((ls == NULL) | (l16s == NULL) | (len < 0)) returnErr(TM_E_ILLEGAL); /* check scaling offset */ - if (!FEQ(tmTop->inpsf, lastsf)) { - offset = BRT2SCALE*64; - if (tmTop->inpsf > 1.0001) - offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5); - else if (tmTop->inpsf < 0.9999) - offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)-.5); - lastsf = tmTop->inpsf; + if (!FEQ(tms->inpsf, lastsf)) { + offset = BRT2SCALE(64) - tmCvLuminance(tms->inpsf); + lastsf = tms->inpsf; } /* convert each pixel */ for (i = len; i--; ) { if (l16s[i] & 0x8000) /* negative luminance */ - ls[i] = MINBRT-1; /* assign bogus value */ + ls[i] = TM_NOBRT; /* assign bogus value */ else /* else convert to lnL */ - ls[i] = (BRT2SCALE*l16s[i] >> 8) - offset; + ls[i] = (BRT2SCALE(l16s[i]) >> 8) - offset; } returnOK; } static void -luv32NewSpace(tm) /* initialize 32-bit LogLuv color space */ -struct tmStruct *tm; +luv32NewSpace(tms) /* initialize 32-bit LogLuv color space */ +TMstruct *tms; { register LUV32DATA *ld; - if (tm->inppri != TM_XYZPRIM) { /* panic time! */ + if (tms->inppri != TM_XYZPRIM) { /* panic time! */ fputs("Improper input color space in luv32NewSpace!\n", stderr); exit(1); } - ld = (LUV32DATA *)tm->pd[luv32Reg]; - ld->offset = BRT2SCALE*64; - if (tm->inpsf > 1.0001) - ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5); - else if (tm->inpsf < 0.9999) - ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)-.5); + ld = (LUV32DATA *)tms->pd[luv32Reg]; + ld->offset = BRT2SCALE(64) - tmCvLuminance(tms->inpsf); clruvall(ld); } static MEM_PTR -luv32Init(tm) /* allocate data for 32-bit LogLuv decoder */ -struct tmStruct *tm; +luv32Init(tms) /* allocate data for 32-bit LogLuv decoder */ +TMstruct *tms; { register LUV32DATA *ld; ld = (LUV32DATA *)malloc(sizeof(LUV32DATA)); if (ld == NULL) return(NULL); - tm->pd[luv32Reg] = (MEM_PTR)ld; - luv32NewSpace(tm); + tms->pd[luv32Reg] = (MEM_PTR)ld; + luv32NewSpace(tms); return((MEM_PTR)ld); } static void -luv24NewSpace(tm) /* initialize 24-bit LogLuv color space */ -struct tmStruct *tm; +luv24NewSpace(tms) /* initialize 24-bit LogLuv color space */ +TMstruct *tms; { register LUV24DATA *ld; - double uvp[2]; - if (tm->inppri != TM_XYZPRIM) { /* panic time! */ + if (tms->inppri != TM_XYZPRIM) { /* panic time! */ fputs("Improper input color space in luv24NewSpace!\n", stderr); exit(1); } - ld = (LUV24DATA *)tm->pd[luv24Reg]; - ld->offset = BRT2SCALE*12; - if (tm->inpsf > 1.0001) - ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5); - else if (tm->inpsf < 0.9999) - ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)-.5); + ld = (LUV24DATA *)tms->pd[luv24Reg]; + ld->offset = BRT2SCALE(12) - tmCvLuminance(tms->inpsf); clruvall(ld); } static MEM_PTR -luv24Init(tm) /* allocate data for 24-bit LogLuv decoder */ -struct tmStruct *tm; +luv24Init(tms) /* allocate data for 24-bit LogLuv decoder */ +TMstruct *tms; { register LUV24DATA *ld; ld = (LUV24DATA *)malloc(sizeof(LUV24DATA)); if (ld == NULL) return(NULL); - tm->pd[luv24Reg] = (MEM_PTR)ld; - if (uv14neu < 0) { /* initialize neutral color index */ - double uvp[2]; - uvp[0] = U_NEU; uvp[1] = V_NEU; - uv14neu = uvpencode(uvp); - } - luv24NewSpace(tm); + tms->pd[luv24Reg] = (MEM_PTR)ld; + if (uv14neu < 0) /* initialize neutral color index */ + uv14neu = uv_encode(U_NEU, V_NEU, SGILOGENCODE_NODITHER); + luv24NewSpace(tms); return((MEM_PTR)ld); }
