root/radiance/ray/src/common/tmapluv.c
Revision: 3.6
Committed: Mon Jun 30 14:59:11 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 3.5: +2 -5 lines
2 static const char RCSid[] = "$Id: tmapluv.c,v 3.5 2003/02/25 02:47:22 greg Exp $";
5 * Routines for tone-mapping LogLuv encoded pixels.
6 *
7 * Externals declared in tmaptiff.h
8 */
9
10 #include "copyright.h"
11
12 #define LOGLUV_PUBLIC 1
13
14 #include <stdio.h>
15 #include <string.h>
16 #include <math.h>
17 #include "tiffio.h"
18 #include "tmprivat.h"
19 #include "tmaptiff.h"
20
21 #define uvflgop(p,uv,op) ((p)->rgbflg[(uv)>>5] op (1L<<((uv)&0x1f)))
22 #define isuvset(p,uv) uvflgop(p,uv,&)
23 #define setuv(p,uv) uvflgop(p,uv,|=)
24 #define clruv(p,uv) uvflgop(p,uv,&=~)
25 #define clruvall(p) memset((MEM_PTR)(p)->rgbflg,'\0',sizeof((p)->rgbflg))
26
27 #ifdef NOPROTO
28 static MEM_PTR luv32Init();
29 static void luv32NewSpace();
30 static MEM_PTR luv24Init();
31 static void luv24NewSpace();
32 #else
33 static MEM_PTR luv32Init(struct tmStruct *);
34 static void luv32NewSpace(struct tmStruct *);
35 static MEM_PTR luv24Init(struct tmStruct *);
36 static void luv24NewSpace(struct tmStruct *);
37 #endif
38
39 typedef struct {
40 int offset; /* computed luminance offset */
41 BYTE rgbval[1<<16][3]; /* computed RGB value for given uv */
42 uint32 rgbflg[1<<(16-5)]; /* flags for computed values */
43 } LUV32DATA; /* LogLuv 32-bit conversion data */
44
45 #define UVNEU ((int)(UVSCALE*U_NEU)<<8 \
46 | (int)(UVSCALE*V_NEU))
47
48 static struct tmPackage luv32Pkg = { /* 32-bit package functions */
49 luv32Init, luv32NewSpace, free
50 };
51 static int luv32Reg = -1; /* 32-bit package reg. number */
52
53 typedef struct {
54 int offset; /* computed luminance offset */
55 BYTE rgbval[1<<14][3]; /* computed rgb value for uv index */
56 uint32 rgbflg[1<<(14-5)]; /* flags for computed values */
57 } LUV24DATA; /* LogLuv 24-bit conversion data */
58
59 static struct tmPackage luv24Pkg = { /* 24-bit package functions */
60 luv24Init, luv24NewSpace, free
61 };
62 static int luv24Reg = -1; /* 24-bit package reg. number */
63
64 static int uv14neu = -1; /* neutral index for 14-bit (u',v') */
65
66
67 static void
68 uv2rgb(rgb, tm, uvp) /* compute RGB from uv coordinate */
69 BYTE rgb[3];
70 register struct tmStruct *tm;
71 double uvp[2];
72 { /* Should check that tm->inppri==TM_XYZPRIM beforehand... */
73 double d, x, y;
74 COLOR XYZ, RGB;
75 /* convert to XYZ */
76 d = 1./(6.*uvp[0] - 16.*uvp[1] + 12.);
77 x = 9.*uvp[0] * d;
78 y = 4.*uvp[1] * d;
79 XYZ[CIEY] = 1./tm->inpsf;
80 XYZ[CIEX] = x/y * XYZ[CIEY];
81 XYZ[CIEZ] = (1.-x-y)/y * XYZ[CIEY];
82 /* convert to RGB and clip */
83 colortrans(RGB, tm->cmat, XYZ);
84 clipgamut(RGB, 1., CGAMUT_LOWER, cblack, cwhite);
85 /* perform final scaling & gamma */
86 d = tm->clf[RED] * RGB[RED];
87 rgb[RED] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam));
88 d = tm->clf[GRN] * RGB[GRN];
89 rgb[GRN] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam));
90 d = tm->clf[BLU] * RGB[BLU];
91 rgb[BLU] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam));
92 }
93
94
95 static TMbright
96 compmeshift(li, uvp) /* compute mesopic color shift */
97 TMbright li; /* encoded world luminance */
98 double uvp[2]; /* world (u',v') -> returned desaturated */
99 {
100 double scotrat;
101 register double d;
102
103 if (li >= BMESUPPER)
104 return(li);
105 scotrat = (.767676768 - 1.02356902*uvp[1])/uvp[0] - .343434343;
106 if (li <= BMESLOWER) {
107 d = 0.;
108 uvp[0] = U_NEU; uvp[1] = V_NEU;
109 } else {
110 d = (tmMesofact[li-BMESLOWER] + .5) * (1./256.);
111 uvp[0] = d*uvp[0] + (1.-d)*U_NEU;
112 uvp[1] = d*uvp[1] + (1.-d)*V_NEU;
113 }
114 /*
115 d = li + (double)TM_BRTSCALE*log(d + (1.-d)*scotrat);
116 */
117 d = d + (1.-d)*scotrat;
118 d -= 1.; /* Taylor expansion of log(x) about 1 */
119 d = d*(1. + d*(-.5 + d*(1./3. + d*-.125)));
120 d = li + (double)TM_BRTSCALE*d;
121 return((TMbright)(d>0. ? d+.5 : d-.5));
122 }
123
124
125 int
126 tmCvLuv32(ls, cs, luvs, len) /* convert raw 32-bit LogLuv values */
127 TMbright *ls;
128 BYTE *cs;
129 uint32 *luvs;
130 int len;
131 {
132 static char funcName[] = "tmCvLuv32";
133 double uvp[2];
134 register LUV32DATA *ld;
135 register int i, j;
136 /* check arguments */
137 if (tmTop == NULL)
138 returnErr(TM_E_TMINVAL);
139 if (ls == NULL | luvs == NULL | len < 0)
140 returnErr(TM_E_ILLEGAL);
141 /* check package registration */
142 if (luv32Reg < 0) {
143 if ((luv32Reg = tmRegPkg(&luv32Pkg)) < 0)
144 returnErr(TM_E_CODERR1);
145 tmMkMesofact();
146 }
147 /* get package data */
148 if ((ld = (LUV32DATA *)tmPkgData(tmTop,luv32Reg)) == NULL)
149 returnErr(TM_E_NOMEM);
150 /* convert each pixel */
151 for (i = len; i--; ) {
152 j = luvs[i] >> 16; /* get luminance */
153 if (j & 0x8000) /* negative luminance */
154 ls[i] = TM_NOBRT; /* assign bogus value */
155 else /* else convert to lnL */
156 ls[i] = (BRT2SCALE(j) >> 8) - ld->offset;
157 if (cs == TM_NOCHROM) /* no color? */
158 continue;
159 /* get chrominance */
160 if (tmTop->flags & TM_F_MESOPIC && ls[i] < BMESUPPER) {
161 uvp[0] = 1./UVSCALE*((luvs[i]>>8 & 0xff) + .5);
162 uvp[1] = 1./UVSCALE*((luvs[i] & 0xff) + .5);
163 ls[i] = compmeshift(ls[i], uvp);
164 j = tmTop->flags&TM_F_BW || ls[i]<BMESLOWER
165 ? UVNEU
166 : (int)(uvp[0]*UVSCALE)<<8
167 | (int)(uvp[1]*UVSCALE);
168 } else {
169 j = tmTop->flags&TM_F_BW ? UVNEU : luvs[i]&0xffff;
170 }
171 if (!isuvset(ld, j)) {
172 uvp[0] = 1./UVSCALE*((j>>8) + .5);
173 uvp[1] = 1./UVSCALE*((j & 0xff) + .5);
174 uv2rgb(ld->rgbval[j], tmTop, uvp);
175 setuv(ld, j);
176 }
177 cs[3*i ] = ld->rgbval[j][RED];
178 cs[3*i+1] = ld->rgbval[j][GRN];
179 cs[3*i+2] = ld->rgbval[j][BLU];
180 }
181 returnOK;
182 }
183
184
185 int
186 tmCvLuv24(ls, cs, luvs, len) /* convert raw 24-bit LogLuv values */
187 TMbright *ls;
188 BYTE *cs;
189 uint32 *luvs;
190 int len;
191 {
192 char funcName[] = "tmCvLuv24";
193 double uvp[2];
194 register LUV24DATA *ld;
195 register int i, j;
196 /* check arguments */
197 if (tmTop == NULL)
198 returnErr(TM_E_TMINVAL);
199 if (ls == NULL | luvs == NULL | len < 0)
200 returnErr(TM_E_ILLEGAL);
201 /* check package registration */
202 if (luv24Reg < 0) {
203 if ((luv24Reg = tmRegPkg(&luv24Pkg)) < 0)
204 returnErr(TM_E_CODERR1);
205 tmMkMesofact();
206 }
207 /* get package data */
208 if ((ld = (LUV24DATA *)tmPkgData(tmTop,luv24Reg)) == NULL)
209 returnErr(TM_E_NOMEM);
210 /* convert each pixel */
211 for (i = len; i--; ) {
212 j = luvs[i] >> 14; /* get luminance */
213 ls[i] = (BRT2SCALE(j) >> 6) - ld->offset;
214 if (cs == TM_NOCHROM) /* no color? */
215 continue;
216 /* get chrominance */
217 if (tmTop->flags & TM_F_MESOPIC && ls[i] < BMESUPPER) {
218 if (uv_decode(uvp, uvp+1, luvs[i]&0x3fff) < 0) {
219 uvp[0] = U_NEU; /* should barf? */
220 uvp[1] = V_NEU;
221 }
222 ls[i] = compmeshift(ls[i], uvp);
223 if (tmTop->flags&TM_F_BW || ls[i]<BMESLOWER
224 || (j = uv_encode(uvp[0], uvp[1],
225 SGILOGENCODE_NODITHER)) < 0)
226 j = uv14neu;
227 } else {
228 j = tmTop->flags&TM_F_BW ? uv14neu : luvs[i]&0x3fff;
229 }
230 if (!isuvset(ld, j)) {
231 if (uv_decode(&uvp[0], &uvp[1], j) < 0) {
232 uvp[0] = U_NEU; uvp[1] = V_NEU;
233 }
234 uv2rgb(ld->rgbval[j], tmTop, uvp);
235 setuv(ld, j);
236 }
237 cs[3*i ] = ld->rgbval[j][RED];
238 cs[3*i+1] = ld->rgbval[j][GRN];
239 cs[3*i+2] = ld->rgbval[j][BLU];
240 }
241 returnOK;
242 }
243
244
245 int
246 tmCvL16(ls, l16s, len) /* convert 16-bit LogL values */
247 TMbright *ls;
248 uint16 *l16s;
249 int len;
250 {
251 static char funcName[] = "tmCvL16";
252 static double lastsf;
253 static int offset;
254 register int i;
255 /* check arguments */
256 if (tmTop == NULL)
257 returnErr(TM_E_TMINVAL);
258 if (ls == NULL | l16s == NULL | len < 0)
259 returnErr(TM_E_ILLEGAL);
260 /* check scaling offset */
261 if (!FEQ(tmTop->inpsf, lastsf)) {
262 offset = BRT2SCALE(64);
263 if (tmTop->inpsf > 1.0001)
264 offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5);
265 else if (tmTop->inpsf < 0.9999)
266 offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)-.5);
267 lastsf = tmTop->inpsf;
268 }
269 /* convert each pixel */
270 for (i = len; i--; ) {
271 if (l16s[i] & 0x8000) /* negative luminance */
272 ls[i] = TM_NOBRT; /* assign bogus value */
273 else /* else convert to lnL */
274 ls[i] = (BRT2SCALE(l16s[i]) >> 8) - offset;
275 }
276 returnOK;
277 }
278
279
280 static void
281 luv32NewSpace(tm) /* initialize 32-bit LogLuv color space */
282 struct tmStruct *tm;
283 {
284 register LUV32DATA *ld;
285
286 if (tm->inppri != TM_XYZPRIM) { /* panic time! */
287 fputs("Improper input color space in luv32NewSpace!\n", stderr);
288 exit(1);
289 }
290 ld = (LUV32DATA *)tm->pd[luv32Reg];
291 ld->offset = BRT2SCALE(64);
292 if (tm->inpsf > 1.0001)
293 ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5);
294 else if (tm->inpsf < 0.9999)
295 ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)-.5);
296 clruvall(ld);
297 }
298
299
300 static MEM_PTR
301 luv32Init(tm) /* allocate data for 32-bit LogLuv decoder */
302 struct tmStruct *tm;
303 {
304 register LUV32DATA *ld;
305
306 ld = (LUV32DATA *)malloc(sizeof(LUV32DATA));
307 if (ld == NULL)
308 return(NULL);
309 tm->pd[luv32Reg] = (MEM_PTR)ld;
310 luv32NewSpace(tm);
311 return((MEM_PTR)ld);
312 }
313
314
315 static void
316 luv24NewSpace(tm) /* initialize 24-bit LogLuv color space */
317 struct tmStruct *tm;
318 {
319 register LUV24DATA *ld;
320
321 if (tm->inppri != TM_XYZPRIM) { /* panic time! */
322 fputs("Improper input color space in luv24NewSpace!\n", stderr);
323 exit(1);
324 }
325 ld = (LUV24DATA *)tm->pd[luv24Reg];
326 ld->offset = BRT2SCALE(12);
327 if (tm->inpsf > 1.0001)
328 ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5);
329 else if (tm->inpsf < 0.9999)
330 ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)-.5);
331 clruvall(ld);
332 }
333
334
335 static MEM_PTR
336 luv24Init(tm) /* allocate data for 24-bit LogLuv decoder */
337 struct tmStruct *tm;
338 {
339 register LUV24DATA *ld;
340
341 ld = (LUV24DATA *)malloc(sizeof(LUV24DATA));
342 if (ld == NULL)
343 return(NULL);
344 tm->pd[luv24Reg] = (MEM_PTR)ld;
345 if (uv14neu < 0) /* initialize neutral color index */
346 uv14neu = uv_encode(U_NEU, V_NEU, SGILOGENCODE_NODITHER);
347 luv24NewSpace(tm);
348 return((MEM_PTR)ld);
349 }
