--- ray/src/common/tmapluv.c 1998/10/26 17:07:05 3.2
+++ ray/src/common/tmapluv.c 2003/02/22 02:07:22 3.4
@@ -1,18 +1,77 @@
-/* Copyright (c) 1998 Silicon Graphics, Inc. */
#ifndef lint
-static char SCCSid[] = "$SunId$ SGI";
+static const char RCSid[] = "$Id: tmapluv.c,v 3.4 2003/02/22 02:07:22 greg Exp $";
#endif
* Routines for tone-mapping LogLuv encoded pixels.
+ * Externals declared in tmaptiff.h
+ * The Radiance Software License, Version 1.0
+ * Copyright (c) 1990 - 2002 The Regents of the University of California,
+ * through Lawrence Berkeley National Laboratory. All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions
+ * are met:
+ * 1. Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided with the
+ * distribution.
+ * 3. The end-user documentation included with the redistribution,
+ * if any, must include the following acknowledgment:
+ * "This product includes Radiance software
+ * (http://radsite.lbl.gov/)
+ * developed by the Lawrence Berkeley National Laboratory
+ * (http://www.lbl.gov/)."
+ * Alternately, this acknowledgment may appear in the software itself,
+ * if and wherever such third-party acknowledgments normally appear.
+ * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
+ * and "The Regents of the University of California" must
+ * not be used to endorse or promote products derived from this
+ * software without prior written permission. For written
+ * permission, please contact radiance@radsite.lbl.gov.
+ * 5. Products derived from this software may not be called "Radiance",
+ * nor may "Radiance" appear in their name, without prior written
+ * permission of Lawrence Berkeley National Laboratory.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
+ * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * This software consists of voluntary contributions made by many
+ * individuals on behalf of Lawrence Berkeley National Laboratory. For more
+ * information on Lawrence Berkeley National Laboratory, please see
+#define LOGLUV_PUBLIC 1
#include
+#include
#include
#include "tiffio.h"
#include "tmprivat.h"
-#include "uvcode.h"
+#include "tmaptiff.h"
#ifndef BSD
#define bzero(d,n) (void)memset(d,0,n)
@@ -23,14 +82,17 @@ static char SCCSid[] = "$SunId$ SGI";
#define clruv(p,uv) uvflgop(p,uv,&=~)
#define clruvall(p) bzero((MEM_PTR)(p)->rgbflg,sizeof((p)->rgbflg))
-#define U_NEU 0.210526316
-#define V_NEU 0.473684211
+#ifdef NOPROTO
static MEM_PTR luv32Init();
static void luv32NewSpace();
static MEM_PTR luv24Init();
static void luv24NewSpace();
-extern void free();
+#else
+static MEM_PTR luv32Init(struct tmStruct *);
+static void luv32NewSpace(struct tmStruct *);
+static MEM_PTR luv24Init(struct tmStruct *);
+static void luv24NewSpace(struct tmStruct *);
+#endif
typedef struct {
int offset; /* computed luminance offset */
@@ -38,7 +100,6 @@ typedef struct {
uint32 rgbflg[1<<(16-5)]; /* flags for computed values */
} LUV32DATA; /* LogLuv 32-bit conversion data */
-#define UVSCALE 410.
#define UVNEU ((int)(UVSCALE*U_NEU)<<8 \
| (int)(UVSCALE*V_NEU))
@@ -61,7 +122,7 @@ static int luv24Reg = -1; /* 24-bit package reg. numb
static int uv14neu = -1; /* neutral index for 14-bit (u',v') */
-static
+static void
uv2rgb(rgb, tm, uvp) /* compute RGB from uv coordinate */
BYTE rgb[3];
register struct tmStruct *tm;
@@ -78,7 +139,7 @@ double uvp[2];
XYZ[CIEZ] = (1.-x-y)/y * XYZ[CIEY];
/* convert to RGB and clip */
colortrans(RGB, tm->cmat, XYZ);
- clipgamut(RGB, XYZ[CIEY], CGAMUT_LOWER, cblack, cwhite);
+ clipgamut(RGB, 1., CGAMUT_LOWER, cblack, cwhite);
/* perform final scaling & gamma */
d = tm->clf[RED] * RGB[RED];
rgb[RED] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam));
@@ -94,74 +155,31 @@ compmeshift(li, uvp) /* compute mesopic color shift
TMbright li; /* encoded world luminance */
double uvp[2]; /* world (u',v') -> returned desaturated */
- double scotrat, d;
+ double scotrat;
+ register double d;
if (li >= BMESUPPER)
return(li);
- scotrat = 1.33/9.*(6.*uvp[0]-16.*uvp[1]+12.)/uvp[0] - 1.68;
+ scotrat = (.767676768 - 1.02356902*uvp[1])/uvp[0] - .343434343;
if (li <= BMESLOWER) {
d = 0.;
uvp[0] = U_NEU; uvp[1] = V_NEU;
} else {
- d = (tmLuminance(li) - LMESLOWER)/(LMESUPPER - LMESLOWER);
+ d = (tmMesofact[li-BMESLOWER] + .5) * (1./256.);
uvp[0] = d*uvp[0] + (1.-d)*U_NEU;
uvp[1] = d*uvp[1] + (1.-d)*V_NEU;
- d = li + (double)TM_BRTSCALE*log(d + (1.-d)*scotrat/2.26);
- return((TMbright)(d+.5));
+ d = li + (double)TM_BRTSCALE*log(d + (1.-d)*scotrat);
+ d = d + (1.-d)*scotrat;
+ d -= 1.; /* Taylor expansion of log(x) about 1 */
+ d = d*(1. + d*(-.5 + d*(1./3. + d*-.125)));
+ d = li + (double)TM_BRTSCALE*d;
+ return((TMbright)(d>0. ? d+.5 : d-.5));
-static int
-uvpencode(uvp) /* encode (u',v') coordinates */
-double uvp[2];
- register int vi, ui;
- if (uvp[1] < UV_VSTART)
- return(-1);
- vi = (uvp[1] - UV_VSTART)*(1./UV_SQSIZ);
- if (vi >= UV_NVS)
- return(-1);
- if (uvp[0] < uv_row[vi].ustart)
- return(-1);
- ui = (uvp[0] - uv_row[vi].ustart)*(1./UV_SQSIZ);
- if (ui >= uv_row[vi].nus)
- return(-1);
- return(uv_row[vi].ncum + ui);
-static int
-uvpdecode(uvp, c) /* decode (u',v') index */
-double uvp[2];
-int c;
- int upper, lower;
- register int ui, vi;
- if (c < 0 || c >= UV_NDIVS)
- return(-1);
- lower = 0; /* binary search */
- upper = UV_NVS;
- do {
- vi = (lower + upper) >> 1;
- ui = c - uv_row[vi].ncum;
- if (ui > 0)
- lower = vi;
- else if (ui < 0)
- upper = vi;
- else
- break;
- } while (upper - lower > 1);
- vi = lower;
- uvp[0] = uv_row[vi].ustart + (ui+.5)*UV_SQSIZ;
- uvp[1] = UV_VSTART + (vi+.5)*UV_SQSIZ;
- return(0);
int
tmCvLuv32(ls, cs, luvs, len) /* convert raw 32-bit LogLuv values */
TMbright *ls;
@@ -179,8 +197,11 @@ int len;
if (ls == NULL | luvs == NULL | len < 0)
returnErr(TM_E_ILLEGAL);
/* check package registration */
- if (luv32Reg < 0 && (luv32Reg = tmRegPkg(&luv32Pkg)) < 0)
- returnErr(TM_E_CODERR1);
+ if (luv32Reg < 0) {
+ if ((luv32Reg = tmRegPkg(&luv32Pkg)) < 0)
+ returnErr(TM_E_CODERR1);
+ tmMkMesofact();
/* get package data */
if ((ld = (LUV32DATA *)tmPkgData(tmTop,luv32Reg)) == NULL)
returnErr(TM_E_NOMEM);
@@ -188,9 +209,9 @@ int len;
for (i = len; i--; ) {
j = luvs[i] >> 16; /* get luminance */
if (j & 0x8000) /* negative luminance */
- ls[i] = MINBRT-1; /* assign bogus value */
+ ls[i] = TM_NOBRT; /* assign bogus value */
else /* else convert to lnL */
- ls[i] = (BRT2SCALE*j >> 8) - ld->offset;
+ ls[i] = (BRT2SCALE(j) >> 8) - ld->offset;
if (cs == TM_NOCHROM) /* no color? */
continue;
/* get chrominance */
@@ -206,8 +227,8 @@ int len;
j = tmTop->flags&TM_F_BW ? UVNEU : luvs[i]&0xffff;
if (!isuvset(ld, j)) {
- uvp[0] = 1./UVSCALE*((luvs[i]>>8 & 0xff) + .5);
- uvp[1] = 1./UVSCALE*((luvs[i] & 0xff) + .5);
+ uvp[0] = 1./UVSCALE*((j>>8) + .5);
+ uvp[1] = 1./UVSCALE*((j & 0xff) + .5);
uv2rgb(ld->rgbval[j], tmTop, uvp);
setuv(ld, j);
@@ -236,32 +257,36 @@ int len;
- if (luv24Reg < 0 && (luv24Reg = tmRegPkg(&luv24Pkg)) < 0)
+ if (luv24Reg < 0) {
+ if ((luv24Reg = tmRegPkg(&luv24Pkg)) < 0)
+ tmMkMesofact();
if ((ld = (LUV24DATA *)tmPkgData(tmTop,luv24Reg)) == NULL)
/* convert each pixel */
j = luvs[i] >> 14; /* get luminance */
- ls[i] = (BRT2SCALE*j >> 6) - ld->offset;
+ ls[i] = (BRT2SCALE(j) >> 6) - ld->offset;
continue;
if (tmTop->flags & TM_F_MESOPIC && ls[i] < BMESUPPER) {
- if (uvpdecode(uvp, luvs[i]&0x3fff) < 0) {
+ if (uv_decode(uvp, uvp+1, luvs[i]&0x3fff) < 0) {
uvp[0] = U_NEU; /* should barf? */
uvp[1] = V_NEU;
ls[i] = compmeshift(ls[i], uvp);
if (tmTop->flags&TM_F_BW || ls[i]flags&TM_F_BW ? uv14neu : luvs[i]&0x3fff;
- if (uvpdecode(uvp, j) < 0) {
+ if (uv_decode(&uvp[0], &uvp[1], j) < 0) {
@@ -292,7 +317,7 @@ int len;
/* check scaling offset */
if (!FEQ(tmTop->inpsf, lastsf)) {
- offset = BRT2SCALE*64;
+ offset = BRT2SCALE(64);
if (tmTop->inpsf > 1.0001)
offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5);
else if (tmTop->inpsf < 0.9999)
@@ -302,9 +327,9 @@ int len;
if (l16s[i] & 0x8000) /* negative luminance */
- ls[i] = (BRT2SCALE*l16s[i] >> 8) - offset;
+ ls[i] = (BRT2SCALE(l16s[i]) >> 8) - offset;
returnOK;
@@ -321,7 +346,7 @@ struct tmStruct *tm;
exit(1);
ld = (LUV32DATA *)tm->pd[luv32Reg];
- ld->offset = BRT2SCALE*64;
+ ld->offset = BRT2SCALE(64);
if (tm->inpsf > 1.0001)
ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5);
else if (tm->inpsf < 0.9999)
@@ -350,14 +375,13 @@ luv24NewSpace(tm) /* initialize 24-bit LogLuv color s
register LUV24DATA *ld;
- double uvp[2];
if (tm->inppri != TM_XYZPRIM) { /* panic time! */
fputs("Improper input color space in luv24NewSpace!\n", stderr);
exit(1);
ld = (LUV24DATA *)tm->pd[luv24Reg];
- ld->offset = BRT2SCALE*12;
+ ld->offset = BRT2SCALE(12);
@@ -376,11 +400,8 @@ struct tmStruct *tm;
if (ld == NULL)
return(NULL);
tm->pd[luv24Reg] = (MEM_PTR)ld;
- if (uv14neu < 0) { /* initialize neutral color index */
- double uvp[2];
- uvp[0] = U_NEU; uvp[1] = V_NEU;
- uv14neu = uvpencode(uvp);
+ if (uv14neu < 0) /* initialize neutral color index */
+ uv14neu = uv_encode(U_NEU, V_NEU, SGILOGENCODE_NODITHER);
luv24NewSpace(tm);
return((MEM_PTR)ld);
