| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: tmapluv.c,v 3.8 2003/07/15 07:28:09 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Routines for tone-mapping LogLuv encoded pixels.
| 6 |
| 7 |
* Externals declared in tmaptiff.h
| 8 |
| 9 |
| 10 |
#include "copyright.h"
| 11 |
| 12 |
#define LOGLUV_PUBLIC 1
| 13 |
| 14 |
#include <stdio.h>
| 15 |
#include <string.h>
| 16 |
#include <math.h>
| 17 |
#include "tiffio.h"
| 18 |
#include "tmprivat.h"
| 19 |
#include "tmaptiff.h"
| 20 |
| 21 |
#define uvflgop(p,uv,op) ((p)->rgbflg[(uv)>>5] op (1L<<((uv)&0x1f)))
| 22 |
#define isuvset(p,uv) uvflgop(p,uv,&)
| 23 |
#define setuv(p,uv) uvflgop(p,uv,|=)
| 24 |
#define clruv(p,uv) uvflgop(p,uv,&=~)
| 25 |
#define clruvall(p) memset((MEM_PTR)(p)->rgbflg,'\0',sizeof((p)->rgbflg))
| 26 |
| 27 |
#ifdef NOPROTO
| 28 |
static MEM_PTR luv32Init();
| 29 |
static void luv32NewSpace();
| 30 |
static MEM_PTR luv24Init();
| 31 |
static void luv24NewSpace();
| 32 |
#else
| 33 |
static MEM_PTR luv32Init(struct tmStruct *);
| 34 |
static void luv32NewSpace(struct tmStruct *);
| 35 |
static MEM_PTR luv24Init(struct tmStruct *);
| 36 |
static void luv24NewSpace(struct tmStruct *);
| 37 |
#endif
| 38 |
| 39 |
typedef struct {
| 40 |
int offset; /* computed luminance offset */
| 41 |
BYTE rgbval[1<<16][3]; /* computed RGB value for given uv */
| 42 |
uint32 rgbflg[1<<(16-5)]; /* flags for computed values */
| 43 |
} LUV32DATA; /* LogLuv 32-bit conversion data */
| 44 |
| 45 |
#define UVNEU ((int)(UVSCALE*U_NEU)<<8 \
| 46 |
| (int)(UVSCALE*V_NEU))
| 47 |
| 48 |
static struct tmPackage luv32Pkg = { /* 32-bit package functions */
| 49 |
luv32Init, luv32NewSpace, free
| 50 |
| 51 |
static int luv32Reg = -1; /* 32-bit package reg. number */
| 52 |
| 53 |
typedef struct {
| 54 |
| 55 |
BYTE rgbval[1<<14][3]; /* computed rgb value for uv index */
| 56 |
uint32 rgbflg[1<<(14-5)]; /* flags for computed values */
| 57 |
} LUV24DATA; /* LogLuv 24-bit conversion data */
| 58 |
| 59 |
static struct tmPackage luv24Pkg = { /* 24-bit package functions */
| 60 |
luv24Init, luv24NewSpace, free
| 61 |
| 62 |
static int luv24Reg = -1; /* 24-bit package reg. number */
| 63 |
| 64 |
static int uv14neu = -1; /* neutral index for 14-bit (u',v') */
| 65 |
| 66 |
| 67 |
static void
| 68 |
uv2rgb(rgb, tm, uvp) /* compute RGB from uv coordinate */
| 69 |
BYTE rgb[3];
| 70 |
register struct tmStruct *tm;
| 71 |
double uvp[2];
| 72 |
{ /* Should check that tm->inppri==TM_XYZPRIM beforehand... */
| 73 |
double d, x, y;
| 74 |
COLOR XYZ, RGB;
| 75 |
/* convert to XYZ */
| 76 |
d = 1./(6.*uvp[0] - 16.*uvp[1] + 12.);
| 77 |
x = 9.*uvp[0] * d;
| 78 |
y = 4.*uvp[1] * d;
| 79 |
XYZ[CIEY] = 1./tm->inpsf;
| 80 |
XYZ[CIEX] = x/y * XYZ[CIEY];
| 81 |
XYZ[CIEZ] = (1.-x-y)/y * XYZ[CIEY];
| 82 |
/* convert to RGB and clip */
| 83 |
colortrans(RGB, tm->cmat, XYZ);
| 84 |
clipgamut(RGB, 1., CGAMUT_LOWER, cblack, cwhite);
| 85 |
/* perform final scaling & gamma */
| 86 |
d = tm->clf[RED] * RGB[RED];
| 87 |
rgb[RED] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam));
| 88 |
d = tm->clf[GRN] * RGB[GRN];
| 89 |
rgb[GRN] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam));
| 90 |
d = tm->clf[BLU] * RGB[BLU];
| 91 |
rgb[BLU] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam));
| 92 |
| 93 |
| 94 |
| 95 |
static TMbright
| 96 |
compmeshift(li, uvp) /* compute mesopic color shift */
| 97 |
TMbright li; /* encoded world luminance */
| 98 |
double uvp[2]; /* world (u',v') -> returned desaturated */
| 99 |
| 100 |
double scotrat;
| 101 |
register double d;
| 102 |
| 103 |
if (li >= BMESUPPER)
| 104 |
return(li);
| 105 |
scotrat = (.767676768 - 1.02356902*uvp[1])/uvp[0] - .343434343;
| 106 |
if (li <= BMESLOWER) {
| 107 |
d = 0.;
| 108 |
uvp[0] = U_NEU; uvp[1] = V_NEU;
| 109 |
} else {
| 110 |
d = (tmMesofact[li-BMESLOWER] + .5) * (1./256.);
| 111 |
uvp[0] = d*uvp[0] + (1.-d)*U_NEU;
| 112 |
uvp[1] = d*uvp[1] + (1.-d)*V_NEU;
| 113 |
| 114 |
| 115 |
d = li + (double)TM_BRTSCALE*log(d + (1.-d)*scotrat);
| 116 |
| 117 |
d = d + (1.-d)*scotrat;
| 118 |
d -= 1.; /* Taylor expansion of log(x) about 1 */
| 119 |
d = d*(1. + d*(-.5 + d*(1./3. + d*-.125)));
| 120 |
d = li + (double)TM_BRTSCALE*d;
| 121 |
return((TMbright)(d>0. ? d+.5 : d-.5));
| 122 |
| 123 |
| 124 |
| 125 |
int
| 126 |
tmCvLuv32(ls, cs, luvs, len) /* convert raw 32-bit LogLuv values */
| 127 |
TMbright *ls;
| 128 |
BYTE *cs;
| 129 |
uint32 *luvs;
| 130 |
int len;
| 131 |
| 132 |
static char funcName[] = "tmCvLuv32";
| 133 |
double uvp[2];
| 134 |
register LUV32DATA *ld;
| 135 |
register int i, j;
| 136 |
/* check arguments */
| 137 |
if (tmTop == NULL)
| 138 |
returnErr(TM_E_TMINVAL);
| 139 |
if ((ls == NULL) | (luvs == NULL) | (len < 0))
| 140 |
returnErr(TM_E_ILLEGAL);
| 141 |
/* check package registration */
| 142 |
if (luv32Reg < 0) {
| 143 |
if ((luv32Reg = tmRegPkg(&luv32Pkg)) < 0)
| 144 |
returnErr(TM_E_CODERR1);
| 145 |
tmMkMesofact();
| 146 |
| 147 |
/* get package data */
| 148 |
if ((ld = (LUV32DATA *)tmPkgData(tmTop,luv32Reg)) == NULL)
| 149 |
returnErr(TM_E_NOMEM);
| 150 |
/* convert each pixel */
| 151 |
for (i = len; i--; ) {
| 152 |
j = luvs[i] >> 16; /* get luminance */
| 153 |
if (j & 0x8000) /* negative luminance */
| 154 |
ls[i] = TM_NOBRT; /* assign bogus value */
| 155 |
else /* else convert to lnL */
| 156 |
ls[i] = (BRT2SCALE(j) >> 8) - ld->offset;
| 157 |
if (cs == TM_NOCHROM) /* no color? */
| 158 |
continue;
| 159 |
/* get chrominance */
| 160 |
if (tmTop->flags & TM_F_MESOPIC && ls[i] < BMESUPPER) {
| 161 |
uvp[0] = 1./UVSCALE*((luvs[i]>>8 & 0xff) + .5);
| 162 |
uvp[1] = 1./UVSCALE*((luvs[i] & 0xff) + .5);
| 163 |
ls[i] = compmeshift(ls[i], uvp);
| 164 |
j = tmTop->flags&TM_F_BW || ls[i]<BMESLOWER
| 165 |
? UVNEU
| 166 |
: (int)(uvp[0]*UVSCALE)<<8
| 167 |
| (int)(uvp[1]*UVSCALE);
| 168 |
} else {
| 169 |
j = tmTop->flags&TM_F_BW ? UVNEU : luvs[i]&0xffff;
| 170 |
| 171 |
if (!isuvset(ld, j)) {
| 172 |
uvp[0] = 1./UVSCALE*((j>>8) + .5);
| 173 |
uvp[1] = 1./UVSCALE*((j & 0xff) + .5);
| 174 |
uv2rgb(ld->rgbval[j], tmTop, uvp);
| 175 |
setuv(ld, j);
| 176 |
| 177 |
cs[3*i ] = ld->rgbval[j][RED];
| 178 |
cs[3*i+1] = ld->rgbval[j][GRN];
| 179 |
cs[3*i+2] = ld->rgbval[j][BLU];
| 180 |
| 181 |
returnOK;
| 182 |
| 183 |
| 184 |
| 185 |
int
| 186 |
tmCvLuv24(ls, cs, luvs, len) /* convert raw 24-bit LogLuv values */
| 187 |
TMbright *ls;
| 188 |
BYTE *cs;
| 189 |
uint32 *luvs;
| 190 |
int len;
| 191 |
| 192 |
char funcName[] = "tmCvLuv24";
| 193 |
double uvp[2];
| 194 |
register LUV24DATA *ld;
| 195 |
register int i, j;
| 196 |
| 197 |
if (tmTop == NULL)
| 198 |
| 199 |
| 200 |
| 201 |
| 202 |
if (luv24Reg < 0) {
| 203 |
if ((luv24Reg = tmRegPkg(&luv24Pkg)) < 0)
| 204 |
| 205 |
tmMkMesofact();
| 206 |
| 207 |
| 208 |
if ((ld = (LUV24DATA *)tmPkgData(tmTop,luv24Reg)) == NULL)
| 209 |
| 210 |
| 211 |
| 212 |
j = luvs[i] >> 14; /* get luminance */
| 213 |
ls[i] = (BRT2SCALE(j) >> 6) - ld->offset;
| 214 |
| 215 |
continue;
| 216 |
| 217 |
| 218 |
if (uv_decode(&uvp[0], &uvp[1], luvs[i]&0x3fff) < 0) {
| 219 |
uvp[0] = U_NEU; /* should barf? */
| 220 |
uvp[1] = V_NEU;
| 221 |
| 222 |
| 223 |
if (tmTop->flags&TM_F_BW || ls[i]<BMESLOWER
| 224 |
|| (j = uv_encode(uvp[0], uvp[1],
| 225 |
SGILOGENCODE_NODITHER)) < 0)
| 226 |
j = uv14neu;
| 227 |
} else {
| 228 |
j = tmTop->flags&TM_F_BW ? uv14neu :
| 229 |
(int)(luvs[i]&0x3fff);
| 230 |
| 231 |
| 232 |
if (uv_decode(&uvp[0], &uvp[1], j) < 0) {
| 233 |
| 234 |
| 235 |
| 236 |
setuv(ld, j);
| 237 |
| 238 |
| 239 |
| 240 |
| 241 |
| 242 |
returnOK;
| 243 |
| 244 |
| 245 |
| 246 |
int
| 247 |
tmCvL16(ls, l16s, len) /* convert 16-bit LogL values */
| 248 |
TMbright *ls;
| 249 |
uint16 *l16s;
| 250 |
int len;
| 251 |
| 252 |
static char funcName[] = "tmCvL16";
| 253 |
static double lastsf;
| 254 |
static int offset;
| 255 |
register int i;
| 256 |
| 257 |
if (tmTop == NULL)
| 258 |
| 259 |
if ((ls == NULL) | (l16s == NULL) | (len < 0))
| 260 |
| 261 |
/* check scaling offset */
| 262 |
if (!FEQ(tmTop->inpsf, lastsf)) {
| 263 |
offset = BRT2SCALE(64);
| 264 |
if (tmTop->inpsf > 1.0001)
| 265 |
offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5);
| 266 |
else if (tmTop->inpsf < 0.9999)
| 267 |
offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)-.5);
| 268 |
lastsf = tmTop->inpsf;
| 269 |
| 270 |
| 271 |
| 272 |
if (l16s[i] & 0x8000) /* negative luminance */
| 273 |
| 274 |
| 275 |
ls[i] = (BRT2SCALE(l16s[i]) >> 8) - offset;
| 276 |
| 277 |
returnOK;
| 278 |
| 279 |
| 280 |
| 281 |
static void
| 282 |
luv32NewSpace(tm) /* initialize 32-bit LogLuv color space */
| 283 |
| 284 |
| 285 |
| 286 |
| 287 |
if (tm->inppri != TM_XYZPRIM) { /* panic time! */
| 288 |
fputs("Improper input color space in luv32NewSpace!\n", stderr);
| 289 |
exit(1);
| 290 |
| 291 |
ld = (LUV32DATA *)tm->pd[luv32Reg];
| 292 |
ld->offset = BRT2SCALE(64);
| 293 |
if (tm->inpsf > 1.0001)
| 294 |
ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5);
| 295 |
else if (tm->inpsf < 0.9999)
| 296 |
ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)-.5);
| 297 |
clruvall(ld);
| 298 |
| 299 |
| 300 |
| 301 |
static MEM_PTR
| 302 |
luv32Init(tm) /* allocate data for 32-bit LogLuv decoder */
| 303 |
| 304 |
| 305 |
| 306 |
| 307 |
ld = (LUV32DATA *)malloc(sizeof(LUV32DATA));
| 308 |
if (ld == NULL)
| 309 |
return(NULL);
| 310 |
tm->pd[luv32Reg] = (MEM_PTR)ld;
| 311 |
luv32NewSpace(tm);
| 312 |
return((MEM_PTR)ld);
| 313 |
| 314 |
| 315 |
| 316 |
static void
| 317 |
luv24NewSpace(tm) /* initialize 24-bit LogLuv color space */
| 318 |
| 319 |
| 320 |
| 321 |
| 322 |
| 323 |
fputs("Improper input color space in luv24NewSpace!\n", stderr);
| 324 |
exit(1);
| 325 |
| 326 |
ld = (LUV24DATA *)tm->pd[luv24Reg];
| 327 |
ld->offset = BRT2SCALE(12);
| 328 |
| 329 |
| 330 |
| 331 |
| 332 |
clruvall(ld);
| 333 |
| 334 |
| 335 |
| 336 |
static MEM_PTR
| 337 |
luv24Init(tm) /* allocate data for 24-bit LogLuv decoder */
| 338 |
| 339 |
| 340 |
| 341 |
| 342 |
ld = (LUV24DATA *)malloc(sizeof(LUV24DATA));
| 343 |
if (ld == NULL)
| 344 |
return(NULL);
| 345 |
tm->pd[luv24Reg] = (MEM_PTR)ld;
| 346 |
if (uv14neu < 0) /* initialize neutral color index */
| 347 |
uv14neu = uv_encode(U_NEU, V_NEU, SGILOGENCODE_NODITHER);
| 348 |
luv24NewSpace(tm);
| 349 |
| 350 |
