root/radiance/ray/src/common/tmapluv.c
Revision: 3.5
Committed: Tue Feb 25 02:47:22 2003 UTC (22 years, 5 months ago) by greg
Changes since 3.4: +1 -56 lines
5 * Routines for tone-mapping LogLuv encoded pixels.
6 *
7 * Externals declared in tmaptiff.h
8 */
9
10 #include "copyright.h"
11
12 #define LOGLUV_PUBLIC 1
13
14 #include <stdio.h>
15 #include <string.h>
16 #include <math.h>
17 #include "tiffio.h"
18 #include "tmprivat.h"
19 #include "tmaptiff.h"
20
21 #ifndef BSD
22 #define bzero(d,n) (void)memset(d,0,n)
23 #endif
24 #define uvflgop(p,uv,op) ((p)->rgbflg[(uv)>>5] op (1L<<((uv)&0x1f)))
25 #define isuvset(p,uv) uvflgop(p,uv,&)
26 #define setuv(p,uv) uvflgop(p,uv,|=)
27 #define clruv(p,uv) uvflgop(p,uv,&=~)
28 #define clruvall(p) bzero((MEM_PTR)(p)->rgbflg,sizeof((p)->rgbflg))
29
30 #ifdef NOPROTO
31 static MEM_PTR luv32Init();
32 static void luv32NewSpace();
33 static MEM_PTR luv24Init();
34 static void luv24NewSpace();
35 #else
36 static MEM_PTR luv32Init(struct tmStruct *);
37 static void luv32NewSpace(struct tmStruct *);
38 static MEM_PTR luv24Init(struct tmStruct *);
39 static void luv24NewSpace(struct tmStruct *);
40 #endif
41
42 typedef struct {
43 int offset; /* computed luminance offset */
44 BYTE rgbval[1<<16][3]; /* computed RGB value for given uv */
45 uint32 rgbflg[1<<(16-5)]; /* flags for computed values */
46 } LUV32DATA; /* LogLuv 32-bit conversion data */
47
48 #define UVNEU ((int)(UVSCALE*U_NEU)<<8 \
49 | (int)(UVSCALE*V_NEU))
50
51 static struct tmPackage luv32Pkg = { /* 32-bit package functions */
52 luv32Init, luv32NewSpace, free
53 };
54 static int luv32Reg = -1; /* 32-bit package reg. number */
55
56 typedef struct {
57 int offset; /* computed luminance offset */
58 BYTE rgbval[1<<14][3]; /* computed rgb value for uv index */
59 uint32 rgbflg[1<<(14-5)]; /* flags for computed values */
60 } LUV24DATA; /* LogLuv 24-bit conversion data */
61
62 static struct tmPackage luv24Pkg = { /* 24-bit package functions */
63 luv24Init, luv24NewSpace, free
64 };
65 static int luv24Reg = -1; /* 24-bit package reg. number */
66
67 static int uv14neu = -1; /* neutral index for 14-bit (u',v') */
68
69
70 static void
71 uv2rgb(rgb, tm, uvp) /* compute RGB from uv coordinate */
72 BYTE rgb[3];
73 register struct tmStruct *tm;
74 double uvp[2];
75 { /* Should check that tm->inppri==TM_XYZPRIM beforehand... */
76 double d, x, y;
77 COLOR XYZ, RGB;
78 /* convert to XYZ */
79 d = 1./(6.*uvp[0] - 16.*uvp[1] + 12.);
80 x = 9.*uvp[0] * d;
81 y = 4.*uvp[1] * d;
82 XYZ[CIEY] = 1./tm->inpsf;
83 XYZ[CIEX] = x/y * XYZ[CIEY];
84 XYZ[CIEZ] = (1.-x-y)/y * XYZ[CIEY];
85 /* convert to RGB and clip */
86 colortrans(RGB, tm->cmat, XYZ);
87 clipgamut(RGB, 1., CGAMUT_LOWER, cblack, cwhite);
88 /* perform final scaling & gamma */
89 d = tm->clf[RED] * RGB[RED];
90 rgb[RED] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam));
91 d = tm->clf[GRN] * RGB[GRN];
92 rgb[GRN] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam));
93 d = tm->clf[BLU] * RGB[BLU];
94 rgb[BLU] = d>=.999 ? 255 : (int)(256.*pow(d, 1./tm->mongam));
95 }
96
97
98 static TMbright
99 compmeshift(li, uvp) /* compute mesopic color shift */
100 TMbright li; /* encoded world luminance */
101 double uvp[2]; /* world (u',v') -> returned desaturated */
102 {
103 double scotrat;
104 register double d;
105
106 if (li >= BMESUPPER)
107 return(li);
108 scotrat = (.767676768 - 1.02356902*uvp[1])/uvp[0] - .343434343;
109 if (li <= BMESLOWER) {
110 d = 0.;
111 uvp[0] = U_NEU; uvp[1] = V_NEU;
112 } else {
113 d = (tmMesofact[li-BMESLOWER] + .5) * (1./256.);
114 uvp[0] = d*uvp[0] + (1.-d)*U_NEU;
115 uvp[1] = d*uvp[1] + (1.-d)*V_NEU;
116 }
117 /*
118 d = li + (double)TM_BRTSCALE*log(d + (1.-d)*scotrat);
119 */
120 d = d + (1.-d)*scotrat;
121 d -= 1.; /* Taylor expansion of log(x) about 1 */
122 d = d*(1. + d*(-.5 + d*(1./3. + d*-.125)));
123 d = li + (double)TM_BRTSCALE*d;
124 return((TMbright)(d>0. ? d+.5 : d-.5));
125 }
126
127
128 int
129 tmCvLuv32(ls, cs, luvs, len) /* convert raw 32-bit LogLuv values */
130 TMbright *ls;
131 BYTE *cs;
132 uint32 *luvs;
133 int len;
134 {
135 static char funcName[] = "tmCvLuv32";
136 double uvp[2];
137 register LUV32DATA *ld;
138 register int i, j;
139 /* check arguments */
140 if (tmTop == NULL)
141 returnErr(TM_E_TMINVAL);
142 if (ls == NULL | luvs == NULL | len < 0)
143 returnErr(TM_E_ILLEGAL);
144 /* check package registration */
145 if (luv32Reg < 0) {
146 if ((luv32Reg = tmRegPkg(&luv32Pkg)) < 0)
147 returnErr(TM_E_CODERR1);
148 tmMkMesofact();
149 }
150 /* get package data */
151 if ((ld = (LUV32DATA *)tmPkgData(tmTop,luv32Reg)) == NULL)
152 returnErr(TM_E_NOMEM);
153 /* convert each pixel */
154 for (i = len; i--; ) {
155 j = luvs[i] >> 16; /* get luminance */
156 if (j & 0x8000) /* negative luminance */
157 ls[i] = TM_NOBRT; /* assign bogus value */
158 else /* else convert to lnL */
159 ls[i] = (BRT2SCALE(j) >> 8) - ld->offset;
160 if (cs == TM_NOCHROM) /* no color? */
161 continue;
162 /* get chrominance */
163 if (tmTop->flags & TM_F_MESOPIC && ls[i] < BMESUPPER) {
164 uvp[0] = 1./UVSCALE*((luvs[i]>>8 & 0xff) + .5);
165 uvp[1] = 1./UVSCALE*((luvs[i] & 0xff) + .5);
166 ls[i] = compmeshift(ls[i], uvp);
167 j = tmTop->flags&TM_F_BW || ls[i]<BMESLOWER
168 ? UVNEU
169 : (int)(uvp[0]*UVSCALE)<<8
170 | (int)(uvp[1]*UVSCALE);
171 } else {
172 j = tmTop->flags&TM_F_BW ? UVNEU : luvs[i]&0xffff;
173 }
174 if (!isuvset(ld, j)) {
175 uvp[0] = 1./UVSCALE*((j>>8) + .5);
176 uvp[1] = 1./UVSCALE*((j & 0xff) + .5);
177 uv2rgb(ld->rgbval[j], tmTop, uvp);
178 setuv(ld, j);
179 }
180 cs[3*i ] = ld->rgbval[j][RED];
181 cs[3*i+1] = ld->rgbval[j][GRN];
182 cs[3*i+2] = ld->rgbval[j][BLU];
183 }
184 returnOK;
185 }
186
187
188 int
189 tmCvLuv24(ls, cs, luvs, len) /* convert raw 24-bit LogLuv values */
190 TMbright *ls;
191 BYTE *cs;
192 uint32 *luvs;
193 int len;
194 {
195 char funcName[] = "tmCvLuv24";
196 double uvp[2];
197 register LUV24DATA *ld;
198 register int i, j;
199 /* check arguments */
200 if (tmTop == NULL)
201 returnErr(TM_E_TMINVAL);
202 if (ls == NULL | luvs == NULL | len < 0)
203 returnErr(TM_E_ILLEGAL);
204 /* check package registration */
205 if (luv24Reg < 0) {
206 if ((luv24Reg = tmRegPkg(&luv24Pkg)) < 0)
207 returnErr(TM_E_CODERR1);
208 tmMkMesofact();
209 }
210 /* get package data */
211 if ((ld = (LUV24DATA *)tmPkgData(tmTop,luv24Reg)) == NULL)
212 returnErr(TM_E_NOMEM);
213 /* convert each pixel */
214 for (i = len; i--; ) {
215 j = luvs[i] >> 14; /* get luminance */
216 ls[i] = (BRT2SCALE(j) >> 6) - ld->offset;
217 if (cs == TM_NOCHROM) /* no color? */
218 continue;
219 /* get chrominance */
220 if (tmTop->flags & TM_F_MESOPIC && ls[i] < BMESUPPER) {
221 if (uv_decode(uvp, uvp+1, luvs[i]&0x3fff) < 0) {
222 uvp[0] = U_NEU; /* should barf? */
223 uvp[1] = V_NEU;
224 }
225 ls[i] = compmeshift(ls[i], uvp);
226 if (tmTop->flags&TM_F_BW || ls[i]<BMESLOWER
227 || (j = uv_encode(uvp[0], uvp[1],
228 SGILOGENCODE_NODITHER)) < 0)
229 j = uv14neu;
230 } else {
231 j = tmTop->flags&TM_F_BW ? uv14neu : luvs[i]&0x3fff;
232 }
233 if (!isuvset(ld, j)) {
234 if (uv_decode(&uvp[0], &uvp[1], j) < 0) {
235 uvp[0] = U_NEU; uvp[1] = V_NEU;
236 }
237 uv2rgb(ld->rgbval[j], tmTop, uvp);
238 setuv(ld, j);
239 }
240 cs[3*i ] = ld->rgbval[j][RED];
241 cs[3*i+1] = ld->rgbval[j][GRN];
242 cs[3*i+2] = ld->rgbval[j][BLU];
243 }
244 returnOK;
245 }
246
247
248 int
249 tmCvL16(ls, l16s, len) /* convert 16-bit LogL values */
250 TMbright *ls;
251 uint16 *l16s;
252 int len;
253 {
254 static char funcName[] = "tmCvL16";
255 static double lastsf;
256 static int offset;
257 register int i;
258 /* check arguments */
259 if (tmTop == NULL)
260 returnErr(TM_E_TMINVAL);
261 if (ls == NULL | l16s == NULL | len < 0)
262 returnErr(TM_E_ILLEGAL);
263 /* check scaling offset */
264 if (!FEQ(tmTop->inpsf, lastsf)) {
265 offset = BRT2SCALE(64);
266 if (tmTop->inpsf > 1.0001)
267 offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5);
268 else if (tmTop->inpsf < 0.9999)
269 offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)-.5);
270 lastsf = tmTop->inpsf;
271 }
272 /* convert each pixel */
273 for (i = len; i--; ) {
274 if (l16s[i] & 0x8000) /* negative luminance */
275 ls[i] = TM_NOBRT; /* assign bogus value */
276 else /* else convert to lnL */
277 ls[i] = (BRT2SCALE(l16s[i]) >> 8) - offset;
278 }
279 returnOK;
280 }
281
282
283 static void
284 luv32NewSpace(tm) /* initialize 32-bit LogLuv color space */
285 struct tmStruct *tm;
286 {
287 register LUV32DATA *ld;
288
289 if (tm->inppri != TM_XYZPRIM) { /* panic time! */
290 fputs("Improper input color space in luv32NewSpace!\n", stderr);
291 exit(1);
292 }
293 ld = (LUV32DATA *)tm->pd[luv32Reg];
294 ld->offset = BRT2SCALE(64);
295 if (tm->inpsf > 1.0001)
296 ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5);
297 else if (tm->inpsf < 0.9999)
298 ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)-.5);
299 clruvall(ld);
300 }
301
302
303 static MEM_PTR
304 luv32Init(tm) /* allocate data for 32-bit LogLuv decoder */
305 struct tmStruct *tm;
306 {
307 register LUV32DATA *ld;
308
309 ld = (LUV32DATA *)malloc(sizeof(LUV32DATA));
310 if (ld == NULL)
311 return(NULL);
312 tm->pd[luv32Reg] = (MEM_PTR)ld;
313 luv32NewSpace(tm);
314 return((MEM_PTR)ld);
315 }
316
317
318 static void
319 luv24NewSpace(tm) /* initialize 24-bit LogLuv color space */
320 struct tmStruct *tm;
321 {
322 register LUV24DATA *ld;
323
324 if (tm->inppri != TM_XYZPRIM) { /* panic time! */
325 fputs("Improper input color space in luv24NewSpace!\n", stderr);
326 exit(1);
327 }
328 ld = (LUV24DATA *)tm->pd[luv24Reg];
329 ld->offset = BRT2SCALE(12);
330 if (tm->inpsf > 1.0001)
331 ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)+.5);
332 else if (tm->inpsf < 0.9999)
333 ld->offset -= (int)(TM_BRTSCALE*log(tmTop->inpsf)-.5);
334 clruvall(ld);
335 }
336
337
338 static MEM_PTR
339 luv24Init(tm) /* allocate data for 24-bit LogLuv decoder */
340 struct tmStruct *tm;
341 {
342 register LUV24DATA *ld;
343
344 ld = (LUV24DATA *)malloc(sizeof(LUV24DATA));
345 if (ld == NULL)
346 return(NULL);
347 tm->pd[luv24Reg] = (MEM_PTR)ld;
348 if (uv14neu < 0) /* initialize neutral color index */
349 uv14neu = uv_encode(U_NEU, V_NEU, SGILOGENCODE_NODITHER);
350 luv24NewSpace(tm);
351 return((MEM_PTR)ld);
352 }
