root/radiance/ray/src/common/tmapluv.c
Sat Jan 15 16:57:46 2022 UTC (2 years, 4 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 3.16: +23 -23 lines
Diff to previous 3.16 , to selected 3.11
refactor: eliminated use of MEM_PTR and (char *) for untyped memory
Fri May 20 02:06:38 2011 UTC (13 years ago) by greg
CVS Tags: rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Changes since 3.15: +6 -6 lines
Diff to previous 3.15 , to selected 3.11
Thu Dec 2 18:10:40 2010 UTC (13 years, 6 months ago) by greg
Diff to previous 3.14 , to selected 3.11
Changed ordering of header inclusion to avoid compile issue
Mon Feb 9 20:48:08 2009 UTC (15 years, 4 months ago) by greg
Changes since 3.13: +2 -1 lines
Diff to previous 3.13 , to selected 3.11
Eliminated redefinition of malloc(3)
Sat May 31 18:28:34 2008 UTC (16 years ago) by greg
Diff to previous 3.12 , to selected 3.11
Changed ordering of include files to avoid redefinition error with libtiff
Tue Nov 15 06:53:00 2005 UTC (18 years, 6 months ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 3.11: +4 -16 lines
Diff to previous 3.11
Added tmCvLuminance() call
Revision 3.11 - (view) (download) (annotate) - [selected]
Fri Jan 7 21:41:06 2005 UTC (19 years, 5 months ago) by greg
Changes since 3.10: +3 -3 lines
Diff to previous 3.10
Moved error codes inside passed TMstruct
Fri Jan 7 20:33:02 2005 UTC (19 years, 5 months ago) by greg
Changes since 3.9: +79 -73 lines
Diff to previous 3.9 , to selected 3.11
Changes since 3.8: +4 -4 lines
Diff to previous 3.8 , to selected 3.11
Tue Jul 15 07:28:09 2003 UTC (20 years, 10 months ago) by greg
Changes since 3.7: +2 -2 lines
Diff to previous 3.7 , to selected 3.11
Improved speed of 48-bit RGB pixel conversion in tmCvRGB48()
Tue Jul 1 16:20:04 2003 UTC (20 years, 11 months ago) by greg
Changes since 3.6: +3 -2 lines
Diff to previous 3.6 , to selected 3.11
Compile fixes related to Photosphere
Changes since 3.5: +2 -5 lines
Diff to previous 3.5 , to selected 3.11
Changes since 3.4: +1 -56 lines
Diff to previous 3.4 , to selected 3.11
Changes since 3.3: +109 -88 lines
Diff to previous 3.3 , to selected 3.11
Sun Dec 20 16:38:29 1998 UTC (25 years, 5 months ago) by gwlarson
Diff to previous 3.2 , to selected 3.11
added TM_NOBRT macro for undefined brightnesses
Mon Oct 26 17:07:05 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 3.1: +19 -7 lines
Diff to previous 3.1 , to selected 3.11
implemented mesopic color shift
Thu Oct 22 13:53:06 1998 UTC (25 years, 7 months ago) by gwlarson
Diff to selected 3.11
